HIFI-FORUM » English » Other hifi (Engl.) » Using blue ray player as a high rez transport | |
Using blue ray player as a high rez transport+A -A |
Manek
#1 erstellt: 11. Feb 2012, 17:38 | |
Guys ! I happen to plug in a usb drive into my humble sony bdp S370 blue ray player usb socket and it started to play high rez wave files all they way upto 24/96 ! I thought it only played mp3, mpeg and stuff like that. Now I have found myself a transport for high rez without using any computer or any fancy usb cables....kinda works like a media player. Awesome ! Just plug a hard drive or a usb stick into it and play high rez music from it as long as I want to.... Manek |
Arj
#2 erstellt: 13. Feb 2012, 08:32 | |
manek..great info ! have you checked the Digital out ? is that also High Rez ? |
Manek
#3 erstellt: 13. Feb 2012, 18:29 | |
Yes arj, I am playing 24/96 files on usb pen drive built into the player, taking the digital out from the blue ray player into a dac at 24/96. Its seems to behave like a media player. I have tested 16/44, 16/48, 24/48, 24/88 and 24/96. They all show up with their respective bitrates. Ofcourse I did 3 official firmware upgrades till date. It doesn't support flac. But wave is good enough for now. The newer ones from sony may have flac software support too. Wonder if the pioneers have flac support via usb ? I am told oppo's have it. The shortcomings are: 1) No flac support, 2) Doesn't play dvd-a 3) pcm output from sacd via digital out is 16/48. Sacd out via hdmi in pcm format is 24/176. The last firmware update was june 11 so I doubt any more will come out for this model since newer models are out already. Now if entry level blue ray players start to come close to media devices in file format support, what's more does one want for 9k ? Happy days ! Manek |
Amp_Nut
#4 erstellt: 14. Feb 2012, 08:35 | |
Very interesting. OTOH, I recently had a Oppo player - BDP83 that came to me for installing the Region Crack Hardware & Lens cleaning (it was not working ) . I was rather disappointed with the BDP83 Sound Quality. I had expected Much better, considering its past Audiophile Status. On comparison with my Electrocompaniet UMC 1 UP, the shoot out was over in less than a minute. |
Manek
#5 erstellt: 14. Feb 2012, 19:09 | |
Would agree with you ampnut whole heartedly. Though my blue ray has 24/192 wolfson dacs, its own analogue outputs are not much to write home about. Use it a just a transport for discs or usb and then the fun begins....remember its just a 9,990/- rupee player.... Would expect a lot more from the oppo but I guess you do have a darn good cdp.....period ! Manek |
Amp_Nut
#6 erstellt: 16. Feb 2012, 05:42 | |
Hi Manek, Thank you for the compliment. However, my real disappointment with the Oppo player really stems from the fact that I did not hear any Audiophile pedigree traits in the Oppo sound. Most audiophiles have a preferred sound and may not necessarily like different sounding equipment. However, genuine Audiophile equipment will bring something special to the table..... whether its up yr street or not is a different matter. The Oppo BDP83 did not ... |
Manek
#7 erstellt: 16. Feb 2012, 20:21 | |
That last statement of yours just makes me feel better ! I was contemplating on getting a oppo and then didn't :-) Manek |
Manek
#8 erstellt: 19. Feb 2012, 20:55 | |
On a hunch, I burned some 16/44, 16/48, 24/96 wave files onto a dvd and played it back as a data dvd disk on the sony bdp player rather than from the usb pendrive/hard drive. Same software interface, just different media. Observations : 1) Data dvd cleaner in the highs and crecendo's, cleaner bass lines 2) Usb sounds more dynamic 3) Usb has more midrange bloom Manek |
Amp_Nut
#9 erstellt: 19. Feb 2012, 22:06 | |
Intersting.... Thanks for the info |
Manek
#10 erstellt: 24. Feb 2012, 17:56 | |
Managed to get a 500gb HDD portable drive (usb2.0) going with blue ray player instead of the pen drive from the players usb drive, also powered by the players usb port. Had to tweak the drives partition to get it working. Hit upon a bug or you may call it limitation, the browsing software doesn't go down more than 3 levels of directories from the root. I didn't encounter that with a pen drive. HDD is formated with fat32 and pendrives by default come with extFAT. Maybe one more firmware update would fix it ? Wonder when that's coming. Having a good time with this little thingie. And to think I had this player for over a year and didn't even bother with the usb for so long. Manek |
Amp_Nut
#11 erstellt: 26. Feb 2012, 11:09 | |
What was the tweak ? FAT 32 ? |
Manek
#12 erstellt: 27. Feb 2012, 14:03 | |
Yes fat32 but partitioned with swiss knife since vvindoz would partition only upto 32gb. Manek |
Manek
#13 erstellt: 17. Mrz 2012, 07:49 | |
Hi Along with the blue ray player, I hit upon two more jackpots, the ipad(64gb) and ipod(16gb). Both seem to play upto 16/48 wav files. So full cd/dvd res music on the go ! I wish it would play 24 bit but I guess that's asking for too much right now. .....this is fun. I have been ripping my cd's to wav with itunes and error correction enabled. The same libraries get exported to the ipad and ipod with very decent sound. Ipod is a bit edgy on the highs but not much to be bothered about. Am looking for a good set of phones for the ipod/ipad, sensitive and easy to drive. There is a camera dongle that apple has with the ipad which when fitted to the port near the home button helps in taking spdif output via usb into dac so that's next. A battery powered portable digital source ! Perhaps the samsung galaxy can do this too ? Regards Manek |
Amp_Nut
#14 erstellt: 17. Mrz 2012, 10:31 | |
Manek said:
Are you SURE about this ? The Ipod also provides a USB connection via its Apple to USB cable, biut it will NOT output Digital out, unless enabled by a separate device ( such as the Wadia dock... for which Apple charges a HUGE royalty PER DEVICE |
Arj
#15 erstellt: 17. Mrz 2012, 12:07 | |
Is this something you have tried ? i have the camera dongle but no good USD/Spdif converter to verify .. |
Manek
#16 erstellt: 17. Mrz 2012, 12:34 | |
Ampnut Yes about the ipad, not the ipod. Read about it on the net so will explore more about the camera connection kit. Now if the ipad can do it then netbooks would be also ideal sources along with other tablets. Small, light, massive storage via external hdd(netbook). I am wondering if the smps power supply of a netbook is so much of a deterrent for high quality music on the go ? Even netbook batteries nowadays last pretty long. http://www.stereo.ne...a3856ffa46a0dd53e78a Manek |
Manek
#17 erstellt: 17. Mrz 2012, 12:53 | |
And for "I" devices, do I go ALAC or stick to wav/aiff ? Alac would be so much more usefull in terms of storage. Manek |
Manek
#18 erstellt: 17. Mrz 2012, 17:55 | |
hi all Found another limitation to the sony bdp s370 blue ray player....hard disk is now over 100gb and the player finds it difficult to read the TOC on startup. It gives errors "cannot load file type". One power reset from the remote fixes it. It happens every time I use the HDD with the blue ray player. No such issues when I connect the same HDD to a computer. I guess this player was never made to support hard drives, only pen drives. Interesting....I wonder if I should split the existing files into two or more large pen drives for stability ? I believe the later model s380 reads ntfs/nfs partitions as well so I guess would be tweaked to read large storage devices. Interesting no ? Wonder if Sony would release a patch for the s370 ? Manek |
Amp_Nut
#19 erstellt: 18. Mrz 2012, 08:15 | |
Maybe it just does not 'like' the huge FAT32 partition created by Swiss Knife ? Such a large partition in FAT32 was just not meant to be .... |
Manek
#20 erstellt: 18. Mrz 2012, 15:16 | |
Fat32 file systems can take a lot except for a file size limitation of 3 to 4 gb per file( I forget the exact number). The pc doesn't show any such behavior, just the bd player. You can format linux and apple systems with fat32 and they would be fine. The s380 I believe recognizes ntfs too and that would mean proper hard disk support. Your are right, what I am doing is "desi jugaad" and I guess I have got to do more to make it work well :-) Manek |
Manek
#21 erstellt: 21. Mrz 2012, 07:44 | |
Any of you guys using a external usb powered hard drive to playback music ? If so try powering the hard drive from two usb ports with a splitter cable which comes with two usb port connectors. Its funny that you get to hear differences from unsuspecting quarters. I was trying to see if my hard drive was not getting enough power to explain the previously mentioned behavior of the blue ray player popping "device not supported" error. When I used the splitter I got a different presentation...more easy flowing and relaxed. Is it the power or the change of cable ? Don't know yet. Am using very stock lam road/oem single and splitter cable to connect hard drive. I haven't got a "device not supported" error now but the " cannot load data" error persists on power up from the cold. |
Arj
#22 erstellt: 21. Mrz 2012, 17:35 | |
actually you are supposed to feed these disks with the splitter cable only. the power given with one USB is too less for the motor and the cause of many a failed HDD due to a dead motor !! [Beitrag von Arj am 21. Mrz 2012, 17:36 bearbeitet] |
Manek
#23 erstellt: 21. Mrz 2012, 18:28 | |
I would agree with you in principle arj. But the original cable supplied with hard drive is also a single cable. It could be that there are far too many usb's not implemented right and far too many hard drives that don't stick to the power consumpstion rated by usb specs. Older computers with usb 1.0 had to be used with splitter cables to power external hard drives. But with the advent to 2.0 on usb the portable devices, I think got enough power to be powered by one port. So I will for the moment stick with the splitter cable. Manek |
Linn Records launches high-quality streaming music service Prithvi am 04.06.2010 – Letzte Antwort am 25.06.2010 – 9 Beiträge |
Help in Selection Of the Right System Menon am 10.09.2005 – Letzte Antwort am 03.10.2005 – 3 Beiträge |
Need Advice On A 2 Channel Sound Card Amp_Nut am 02.12.2006 – Letzte Antwort am 06.12.2006 – 23 Beiträge |
Audio quality difference between DVD player and CD player sandipb am 16.11.2007 – Letzte Antwort am 17.11.2007 – 2 Beiträge |
Dali Blue 6006 or Canton LE 190 ASR am 28.09.2005 – Letzte Antwort am 03.10.2005 – 2 Beiträge |
Comparison of modern graphics card to hardware DVD players for DVD decoding reignofchaos am 03.09.2006 – Letzte Antwort am 04.09.2006 – 6 Beiträge |
DVD player power supplies Manek am 31.07.2006 – Letzte Antwort am 04.08.2006 – 14 Beiträge |
iPod & MP-3 Player Users Amp_Nut am 31.07.2006 – Letzte Antwort am 17.08.2006 – 12 Beiträge |
The LINN LP12SE wins another EISA award Prithvi am 07.09.2007 – Letzte Antwort am 07.09.2007 – 2 Beiträge |
Rethms Saadhana wins 6 moons 2008 Blue Moon Award Prithvi am 02.01.2009 – Letzte Antwort am 02.01.2009 – 3 Beiträge |
- Registrierte Mitglieder926.516 ( Heute: 4 )
- Neuestes MitgliedThomasNOF
- Gesamtzahl an Themen1.553.133
- Gesamtzahl an Beiträgen21.584.881
