| HIFI-FORUM » English » Stereo (Engl.) » SPEAKER HELP | |
SPEAKER HELP+A -A |
MetalDave
erstellt: 26. Jun 2005, 08:57
Hi, I am fairly new to the HIFI forums as well as the technology side of things and I have a question to ask if you dont mind... I currently own a Sony GXS75 Mini Hifi system which has a total system output of 300W. The speakers that it came with handle 150 watts max at 6 ohms each, recently I added some old pioneer floor standing speakers to the setup which have a max output of 30watts at 8ohms each. In the near future I am planning on getting rid of the pioneer speakers as one has a blown speaker and purchasing some Sony SSMF550H Floor Standing Speakers which have a Max Power Handling of 150 watts and an Impendance of 8 ohms. My Question is will these speakers work if I add them to my Hifi System, as in will there be enough power to work? Will there be any notable difference in Sound Quality, will My HIFI system be louder. Your help would be much apprecited, thanks... My current Hifi System (Sony GXS75): http://www.sony.com....MHCGSX75,MENUITEM103The Speakers I would like to add to my HIFI system: http://www.sony.com....d=SSMF550H,MENUITEM4
[Beitrag von MetalDave am 26. Jun 2005, 09:05 bearbeitet] |
jsa_ind
erstellt: 26. Jun 2005, 09:28
Dear Dave, The term System Power can be very misleading on the links which you gave there was no mention of RMS rating....a more accurate way of discribing the power capabilities of your system Will your system sound louder....I cannot tell as information like SPL is not available. But I guess it will sound more fuller & richer....that should answer your question about Sound Quality Will they be enough power..yes....though if your are spending that kind of money & could dispose or buy another piece of audio equipment....an integrated amplifier is what would be recommended. Regards, Junia. |
MetalDave
erstellt: 26. Jun 2005, 11:14
I found the RMS info in my owners manual. Continuous RMS power output (reference): 150+150 Watts (6 ohms at 1kHz, 10 percent THD) Total Harmonic Distortion less then 0.09 percent (6ohms at 1kHz, 70Watts) |
jsa_ind
erstellt: 26. Jun 2005, 13:24
Dear Dave, Something does not feel right is it 150 + 150 Watts RMS for sure ? Normally to produce such a high RMS output a lot more has to go in a piece of equipment as what I can see in the Sony. Though I might be completly wrong on this. If you are sure aout the rating then there are no problems, go for the extra speakers !! Regards, Junia |
MetalDave
erstellt: 26. Jun 2005, 15:01
Main Unit Info as written in the manual... Specifications Main Unit (HCD - GSX75) Amplifier Section MHC - GSX75 For the U.S MODEL Audio Power Specifications Power Output and Total Harmonic Distortion: With 6 ohm loads, both channels driven,from 120 - 10,000 Hz; rated 150 watts (For GSX75)per channel minimum RMS power, with no more 10 percent total harmonic distortion from 250 milliwatts to rated ouput. Also what I wrote before "150+150watts" is what it says in the manual, so im guessing that the info is correct. [Beitrag von MetalDave am 26. Jun 2005, 15:04 bearbeitet] |
Dipak
erstellt: 26. Jun 2005, 17:02
hello dave why sony speakers? have you tested them or just because they are sony like your system? however for true hifi-qualities you won't get around changing the system i fear.. greets dipak |
Help with speakers connections pranab31 am 27.02.2006 – Letzte Antwort am 28.02.2006 – 5 Beiträge |
Bright amp with which speaker. Alymangy am 02.02.2005 – Letzte Antwort am 02.02.2005 – 12 Beiträge |
suggestion on Floor standing speakers rajeshmathew am 20.08.2004 – Letzte Antwort am 26.08.2004 – 6 Beiträge |
Suggestion for budget bookshelf/floor standing speakers vivekama am 06.08.2005 – Letzte Antwort am 08.08.2005 – 3 Beiträge |
which amp to buy ??? johnny69 am 12.11.2003 – Letzte Antwort am 17.11.2003 – 8 Beiträge |
One speaker "louder" than the other? particleman am 30.01.2008 – Letzte Antwort am 25.04.2008 – 24 Beiträge |
Finding the Fault The_Bullet am 20.09.2005 – Letzte Antwort am 20.09.2005 – 3 Beiträge |
Budget amp and speakers. Help!! Psycholic am 30.06.2005 – Letzte Antwort am 30.06.2005 – 8 Beiträge |
A Peculiar observation.more of a problem abhi.pani am 13.10.2006 – Letzte Antwort am 16.10.2006 – 28 Beiträge |
Amp and speakers in a limited budget vjc am 15.01.2006 – Letzte Antwort am 25.01.2006 – 28 Beiträge |
2005
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.546 ( Heute: 1 )
- Neuestes MitgliedLunako
- Gesamtzahl an Themen1.563.151
- Gesamtzahl an Beiträgen21.817.832
