| HIFI-FORUM » English » Stereo (Engl.) » TIPS & TWEAKS | |
TIPS & TWEAKS+A -A |
Manek
erstellt: 30. Dez 2003, 06:04
I found a great tweak for my stereo. CORK..... I took a cork sheet 12mm thick, cut it to size of my cd player, amp, and speaker bases and put them below the equipment. The sound has become more clean and uniform, melow. The change is as dramatic. Damping really helps.... |
Manek
erstellt: 02. Jan 2004, 08:49
Just tried another trick on my cadence arita bookshelves. I got myself two 5 pound weights, the kind you would use on a dumbell. Wrapped it in soft chamois cloth and kept it on top of the speaker aligning it flush against the back horizontal line of the speaker, its amazing how the clear bass got clearer and the lower mids were more open. Heard about this from a friend and decided to try it and it worked like a charm. |
Manek
Anybody else has any tips and tweaks to share ? |
AnilL
erstellt: 03. Jan 2004, 09:04
Manek..... old pal, "Cork up" with all the postings!! Instead, make time to come home.Really need some "sound advice"..... speaker placement, sound proofing, isolators etc. And finally.... to buy or not to buy.... the Cadence Avitas!! Tips Tweaks & Traps - like the old software books huh? Shandy is on the house. Cheers. Anil |
Manek
erstellt: 03. Jan 2004, 09:18
Anil...heh heh....welcome to the forum. buy the Avitas....junk the B&W's...thats my sincere advice I found my isolators in the cork board I'll take you up on the shandy offer anytime |
kimber-frank
erstellt: 03. Jan 2004, 16:50
Hey! Cork! Good idea! I will try this! |
Manek
erstellt: 05. Jan 2004, 06:32
do that kimber and hear the difference. |
Manek
erstellt: 12. Feb 2004, 05:37
My NAD 320BEE integrated has metal gold plated jumpers between the pre-out and main-in. This jumper I feel is made of either nickel, brass with zinc content and plated gold. Nickel or brass are not the best choice for sound. I want to replace these metal jumpers with good short copper interconnect cables with connectors. The cables and connectors I am looking for should not only be neutral in sound but also should not give or take away nothing from and to the pre-out signal. So it should faithfully transport the signal from the pre-out to the main-in. I dont mind using readymade or hand fabricated stuff. Any ideas ? |
Arj
erstellt: 16. Feb 2004, 10:26
I used a pair of old Ecosse Composers instead...frankly It just beats me as to why NAD could not provide a better connector ! Home made stuff would not be easy as you would need that exact size to fit in..and for a good connection you Would need use a RCA termination. Hmm perhaps a Good thick copper wire with RCA termination might do the trick..since the size is so short Cable impedance would not be that big a factor as to affect tonality [Beitrag von Arj am 16. Feb 2004, 10:31 bearbeitet] |
cheraz
erstellt: 16. Feb 2004, 10:51
Have you`ll tried the "Beak" which is provided extra by Totem? It is to be put on top of the speakers by which they claim it controls resonances and allows for better driver integration and results in imaging and dynamic improvement. |
Arj
erstellt: 16. Feb 2004, 12:53
The Beak and Claw both are good but only if you get them with the totems...if you plan on buying them separately , they are obnoxiously priced |
Manek
erstellt: 16. Feb 2004, 13:06
Arj, I tried it with good cable...Vandenhul Hybrid MKIII D-102. I found no difference at all. Tried it not once but 4 times with extended listening sessions. So i'm now wondering if it really is worth the effort ? Do the NAD engineers know better ? |
Arj
erstellt: 16. Feb 2004, 14:23
I could notice some difference..unfortunately Good or Bad I could not say as the soundstage was just about the same ![]() But it did play Louder .. (My speakers have a 98dB sensistivity and small difference do show up ! |
Manek
erstellt: 17. Feb 2004, 06:34
maybe next time i'll try a one piece silver wire. I'm trying to souce a good small piece from the dealers. |
centipod
erstellt: 19. Feb 2004, 10:17
Instead of cork. I read in the last number of what hifi that you could use squashballs (black, rubber, size of a golfball) for dampening. You cut them in halves and place them under your cdplayer, amp etc. So you need 4 halvs per unit. Hmm.. I wonder how much they cost? |
Manek
erstellt: 19. Feb 2004, 10:52
squash balls are not cheap but they are not expensive either. I prefer cork as my CDP is on a flat surface and cannot be easily toppled over. My cork peice is as wide as the cdp. Why dont you try the squash balls and let me know. manek. |
Arj
erstellt: 19. Feb 2004, 13:21
Manek, is your CDP resting directly on the cork ? If so you could try keeping 3 Wooden (Hardwood) Cones or Pyramids under the CDP.(ie in case you have not done it already !) Since you are using a cork it could be with the point up. Usually youo should be able to see a difference in the soundstage. Ideally one of them should be directly under the CD Tray mechanism and others at the back I use DH cones/Squares which has a similiar action. |
Manek
erstellt: 20. Feb 2004, 06:25
Hi Arj, I've tried isolators in a few shapes and forms. To be honest cork sheet worked best for me. Isolators/cones did not do much. By the way my CDP sits on a hardwood plank. speakers on a granite plank. |
Think i found a find! puchoo am 11.06.2007 – Letzte Antwort am 11.06.2007 – 4 Beiträge |
My NAD/PSB System-Finally NAD_Fan am 30.09.2004 – Letzte Antwort am 30.09.2004 – 2 Beiträge |
how to wire my speakers into my amp? pumpanani am 14.12.2004 – Letzte Antwort am 15.12.2004 – 2 Beiträge |
Manek and Arj needed cheraz am 22.06.2004 – Letzte Antwort am 27.07.2004 – 47 Beiträge |
Free tweak (?)to improve midrange & Bass. Arj am 11.07.2007 – Letzte Antwort am 27.07.2007 – 9 Beiträge |
I burnt my fingers, but saved my subwoofer! Neutral am 14.09.2006 – Letzte Antwort am 20.09.2006 – 21 Beiträge |
My feelings about the Heathrow show leben_in_symphonie am 09.10.2004 – Letzte Antwort am 11.10.2004 – 3 Beiträge |
Suggestions Speaker stands and Subwoofer kvish am 09.09.2006 – Letzte Antwort am 20.09.2006 – 21 Beiträge |
Advise for speaker selection sanjay am 11.09.2004 – Letzte Antwort am 26.10.2004 – 41 Beiträge |
Stereo and Computer Speakers Alexb123 am 12.01.2004 – Letzte Antwort am 12.01.2004 – 6 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.668 ( Heute: )
- Neuestes Mitglied
- Gesamtzahl an Themen1.563.466
- Gesamtzahl an Beiträgen21.826.335
