Onkyo Speaker SKF101
Srini
#1 erstellt: 20. Jan 2005, 10:54
Hi to all
I am new member to this forum
I bought a pair of Onkyo peakers at a sale in onkyo showroom, Bangalore.
Speaker specifications
16 cm Cone Woofer x 2
2.5 cm Soft-Dome Tweeter
Magnetically shielded
Gold-plated,heavy-duty, multiway binding posts
MDF cabinet
Impedance: 6 ohm
Max. input power: 150W
Frequency response:32Hz-35kHz
WHD: 216 x 921 x 285 mm
Weight: 14.2 kg
I would like to know about the speaker performance as I have tested it in the showroom and I am getting a NAD320BEE amp this month end. So I would like to know about this combination.
Regards
S.Giridhar
12inchdriver
#2 erstellt: 20. Jan 2005, 11:12
CONGRATULATIONS BUT YOU HAVE GOT THE ONES WHICH ARE USED FOR HT SYSTEMS.....WELL YOU NEED TO SEE HOW IT PERFORMS WITH NAD.
Srini
#3 erstellt: 20. Jan 2005, 11:31
Thank you for the reply
I would like to know the difference between HT speakers and the stereo speakers
12inchdriver
#4 erstellt: 20. Jan 2005, 12:05
HT refers to the Home theatre and normally these speakers are used with subwoofers and you don't feel the bass deficiency.but when used for stereo you might notice the narrow range
Srini
#5 erstellt: 20. Jan 2005, 12:10
ok I got it
But this speaker has 2 woofers so will it overcome the problem.
How will be the vocals clarity because I love to hear slow romantic songs but I have observed at little high volumes the vocals starts to dominate so can u just explain me about it.
SUB_BOSS
Gesperrt
#6 erstellt: 20. Jan 2005, 13:05
hi srini,
vocals will definately be good as the 6 1/2 inch drivers are inherently more biased towards mids.it is not like you have a made a wrong buy.yes it is a good choice. But never be in the assumption that the double woofers will give you good bass, i've heard that Cadence can kick the ass out of JBL northridge with twin 10inch woofers.Since you listen to romantic music which are dominated by vocals I feel this will serve your purpose.My understanding is HT speakers are quite peaky with vocals and Stereo speakers are wider in range.but pure stereo is a very expensive affair.you could've tried ONKYO SKF 202( not available but some dealers stock it). It has 8 inch LF drivers and a very good speaker system for stereo.
[Beitrag von SUB_BOSS am 20. Jan 2005, 13:14 bearbeitet]
Srini
#7 erstellt: 20. Jan 2005, 13:14
thank u Sub Boss for ur reply.
If I need to connect a subwoofer to the Nad 320BEE amp is it possible. Usually the stereo amp have only two outputs so is there any possibility.
SUB_BOSS
Gesperrt
#8 erstellt: 20. Jan 2005, 13:21
there is really no necessity that you need a sub to boost bass, it has plenty of it. What i meant was you can never get too close to low frequencies and I'm reffering to below 40hz. You have chosen a very good amp.Congrats on your purchase and enjoy the beautiful combo NAD+ONKYO.
P.S . where did you buy the amp and how much did u pay.
SUB_BOSS
Gesperrt
#9 erstellt: 20. Jan 2005, 14:50
ops sorry you r buying from US.I wanted to know if there is any diffrence in specs.i mean between Asian and US models...coz i've seen some diffrences in other brands.
Hemanth
#10 erstellt: 20. Jan 2005, 16:29
Nad 320bee specs for US
SPECIFICATIONS - NAD C 320BEE
Pre-Amp Section
Line level inputs
Input impedance (R+C) 200k ohm / 320pF
Input sensitivity; rated power 220mV
Frequency response (-3dB 3Hz - 70kHz) ±0.3dB
Line level outputs
Output impedance 80 ohm
Tape Source Z + 1k ohm
Phones 220 ohm
Signal/noise ratio 106dB
Tone controls
Treble 5dB at 10kHz
Bass 8dB at 100Hz
Remote Control Yes
Power Amp Section
Continuous output power 50W (17dBW)
Rated distortion (THD 20Hz-20kHz) 0.03%
Clipping power 68W (18dBW)
IHF dynamic headroom at 8 ohm +3.4dB
IHF dynamic power at 8 ohm 110W (20.41dBW)
IHF dynamic power at 4 ohm 160W (22.04dBW)
IHF dynamic power at 2 ohm 210W (23.2dBW)
Damping factor (ref. 8 ohm, 50Hz) >60
Input impedance 20kohm/ 470pF
Input sensitivity (for rated power into 8 ohm) 630mA
Voltage gain 29dB
Frequency response; 20Hz-20kHz +/-0.3dB
-3dB at: 3Hz/70kHz
Signal/noise ratio; ref 1W 100dB
Signal/noise ratio; ref rated power 117dB
Physical Specifications
Dimensions (W x H x D) 171/8 x 315/16 x 117/16"
(435 x 100 x 290mm)
Net weight 14.33 lbs (6.5kg)
Shipping weight 16.98 lbs (7.7kg)
• 2 x 50W Minimum Continuous Power into 4 / 8 ohms • 110W, 160W, 210W, IHF Dynamic power
into 8, 4 and 2 ohms, respectively • PowerDriveTM amplifier technology • Headphones socket
• Relay Input Switching • High Current HolmgrenTM Toroidal Power Transformer • 7 Line inputs,
including two tape in/outs • All discrete circuitry • Short signal path from input to output
• All sockets Gold Plated • Bass and Treble controls with Tone Defeat switch • Main-amp Input &
Pre-amp Output • NAD Soft ClippingTM • IR Input & Output • 12V Trigger Output
• Full System Remote control including Stand-by/Off
SPEAKER HELP
MetalDave am 26.06.2005  –  Letzte Antwort am 26.06.2005  –  6 Beiträge
Speaker for Onkyo tx-nr900:Bangalore
manishk13 am 24.01.2005  –  Letzte Antwort am 25.01.2005  –  3 Beiträge
Bright amp with which speaker.
Alymangy am 02.02.2005  –  Letzte Antwort am 02.02.2005  –  12 Beiträge
Which speaker to pair Marantz PM17 + CD7300 - Decision made :)
bharathana am 23.08.2007  –  Letzte Antwort am 27.10.2007  –  34 Beiträge
Speaker opinion
vcs am 27.03.2006  –  Letzte Antwort am 27.03.2006  –  12 Beiträge
Newbie speaker audition
Ananth am 06.02.2007  –  Letzte Antwort am 11.02.2007  –  12 Beiträge
Speaker Help
txs_dude am 22.02.2004  –  Letzte Antwort am 23.02.2004  –  3 Beiträge
Suggestions Speaker stands and Subwoofer
kvish am 09.09.2006  –  Letzte Antwort am 20.09.2006  –  21 Beiträge
Speaker Design & Building What Is It All About ?
jsa_ind am 21.08.2005  –  Letzte Antwort am 02.11.2005  –  125 Beiträge
What Cables to use ??
abhi.pani am 19.01.2005  –  Letzte Antwort am 19.01.2005  –  6 Beiträge
2005
  • Registrierte Mitglieder928.441 ( Heute: 7 )
  • Neuestes Mitgliedkentonheinig8
  • Gesamtzahl an Themen1.558.233
  • Gesamtzahl an Beiträgen21.697.335
