Akai AM A1 - right speaker problem
stelioslaw
#1 erstellt: 16. Apr 2020, 09:06
After about 20 years, I decided to re install my old 80's stereo .It is an AKAI AM A1. I installed the speakers in order to check if it is still alive, but I noticed that the right side sounds lower and a bit strange (as it sound from deep). I decided to open the amp even if I am not an expert. I saw that there is no noticeable wear or any kind of damage on the boards or the wiring. But one of the fuses that, although it had to be 1.6a, it is obviously changed by one with 2.0L.
Could this be the problem or I have to check for something else?
Dadof3
Moderator
#2 erstellt: 16. Apr 2020, 17:47
The fuse cannot be the culprit - either it is still intact or not, and if it does not work, you will not hear anything.
Can you rule out that the speakers are causing the issue?
What happens if you switch the speakers from left to right?
stelioslaw
#3 erstellt: 21. Apr 2020, 08:40
The fuse was indeed the culprit. The amplifier was still in function (even though the sound was horrible from one side) with a burned fuse. I changed it and now the 40year stereo is working perfectly.
Dadof3
Moderator
#4 erstellt: 21. Apr 2020, 08:49
Very strange, I wonder what kind of fuse that was.
Anyway, thanks for the feedback, and hopefully you'll enjoy it for another 40 years ...
Need help with speaker problem!
trenzterra am 27.12.2003  –  Letzte Antwort am 29.12.2003  –  2 Beiträge
Fungi on speaker! - Help needed
Ronnie22 am 13.11.2005  –  Letzte Antwort am 14.11.2005  –  3 Beiträge
Need ur help: Right amp channel not working
Neutral am 20.08.2007  –  Letzte Antwort am 20.08.2007  –  4 Beiträge
Small speaker suggestions?
tomhifi am 04.10.2003  –  Letzte Antwort am 07.10.2003  –  8 Beiträge
Woofer Problem!! :o(
damo am 26.10.2003  –  Letzte Antwort am 26.10.2003  –  4 Beiträge
SPEAKER HELP
MetalDave am 26.06.2005  –  Letzte Antwort am 26.06.2005  –  6 Beiträge
Does this price seem right to you?
Virgil am 19.07.2005  –  Letzte Antwort am 20.07.2005  –  7 Beiträge
Speaker Cables
deepug am 24.02.2005  –  Letzte Antwort am 28.02.2005  –  21 Beiträge
Speaker positioning
Arj am 08.11.2009  –  Letzte Antwort am 11.11.2009  –  13 Beiträge
Speaker Help
txs_dude am 22.02.2004  –  Letzte Antwort am 23.02.2004  –  3 Beiträge
2020
  • Registrierte Mitglieder929.581 ( Heute: 5 )
  • Neuestes MitgliedGalaxi01
  • Gesamtzahl an Themen1.560.764
  • Gesamtzahl an Beiträgen21.759.249
