USB dacs
square_wave
#1 erstellt: 06. Dez 2010, 13:50
A quick question.
In a HDD playback system, if one is using a USB dac (asynchronous mode), does it make any difference if one is using a Laptop or a dedicated PC. In this case the sound completely bypasses the soundcard.
A good example of a USB dac.
http://blog.stereophile.com/ces2009/ayres_qb-9_usb_dac_revealed/
Anyone out here has tried USB DACs in assync mode in their HHD based playback systems ?
These are said to have a tight spec when it comes to Jitter.
[Beitrag von square_wave am 06. Dez 2010, 13:51 bearbeitet]
Amp_Nut
#2 erstellt: 07. Dez 2010, 03:57
IMHO, the asynchronous mode makes a HUGE difference....
I have heard the reult of an outboard USB to SPDIF async converter, and I would go to the extent that you havent got to "Hi-Fi" without async...
square_wave
#3 erstellt: 07. Dez 2010, 04:45
@amp nut,
I think I need to make my question clearer.
Question no:1
Laptop VS dedicated PC while using a assync usb dac ?
Question no: 2
Pristine HD track sttting on a PC/Laptop and played via a assync dac.
VS
Same track sitting on cd and played via a cd player
Assumption: The DAC in both cases are of the same calibre.
Arj
#4 erstellt: 07. Dez 2010, 08:42
Q1: dedicated is your answer as you can get your computer to work only those services which are necessary.
While it can be argued either way, USB controllers work on a time share basis wrt processor time and if you do anything else on the PC which is processor intensive you impact the sound. frankly the cost of a dedicated PC/Laptop need not be very high...even a second hand Pentium desktop can be stripped down to do this work
Q2: pristine HD on PC will be far better due to its inherent high sampling and hence higher resolution. (as long as the PC is of a decent configuration)
[Beitrag von Arj am 07. Dez 2010, 08:44 bearbeitet]
bhagwan69
#5 erstellt: 09. Dez 2010, 12:07
square_wave schrieb:
Question no: 2
VS
I have done this several times.
I used Meridian 808i.2 as a CD Player & the same machine as a DAC via its digital input & I did not hear a 'diff'
Then I also compared an EMM 2 box machine with a CD in it against a Computer through a dCS Scarlatti & the dCS was 'better'
I also compared a Bow Tech ZZ Eight DAC against these 2 set ups & it was not even close.
The name of the game is not what is used, but how it is used...
Just my 2 bits...
square_wave
#6 erstellt: 10. Dez 2010, 09:19
Question no: 2
VS
Just my 2 bits...
Thank you for the inputs.
1-If one is going the PC way, what kind of a PC would you recommend?
2-What are the pertinent points you would take into account in the implementation if one is using an assync usb dac and a PC as a source.
bhagwan69
#7 erstellt: 10. Dez 2010, 09:31
I do not know much;
This machine was made by sbfx [forum member] for me.
He is a 1/2 techie.
You guys in Bangalore know much much more.
But, msb too could advise.
I just say, use a good case - original & an excellent 400 + Watts power supply cossair kind & a good top end mother board + 4GB of RAM at least.
No Fans - natural aspiration. No additional cooling. No Over clocking. No Antivirus. No Software, only windows & foobar.
msb1
#8 erstellt: 12. Dez 2010, 18:10
I've posted my PC specs on this thread:
http://www.hifi-foru...um_id=59&thread=1606
I sold my CD Player and am now 100% PC playback.
PC to M2Tech EVO USB/SPDIF Converter to PD MPD-5 DAC.
Better than CD IMO
Arj
#9 erstellt: 12. Dez 2010, 19:28
Hi MSB..how are your experiments with USB dacs coming up ? what are you partnering with your Evo ?
bhagwan69
#10 erstellt: 13. Dez 2010, 03:48
PD is his DAC.
You can look it up - it is a top end DAC - amongst the top 5 in the world right now......
bhagwan69
#11 erstellt: 13. Dez 2010, 03:51
Savyasaachi
#12 erstellt: 13. Dez 2010, 04:10
hmmm..they are based out of Portland...will call and see if they welcome drop ins for an audition.
Arj
#13 erstellt: 13. Dez 2010, 06:08
Can any expert explain what this means
So before any processing can happen we need to bring these 2 components into the same domain: The Playback Designs system quantizes the clock jitter into a digital signal, where it then can be subtracted from the original sample rate while the latter is converted to analog at the same time
is it the same as stripping the clock signal off and reclocking following some error cancellation ?
DACs - Are they a worthy upgrade ?
neono am 06.05.2010  –  Letzte Antwort am 20.08.2010  –  29 Beiträge
If you think a power cable makes a difference.
msb1 am 07.03.2008  –  Letzte Antwort am 07.03.2008  –  3 Beiträge
Would a Mini-compo be a good source?
Neutral am 15.06.2005  –  Letzte Antwort am 09.09.2005  –  26 Beiträge
Expensive Audio CD player - what difference does it make?
jayashree am 18.10.2008  –  Letzte Antwort am 06.11.2008  –  33 Beiträge
DAC on a Budget
purnendu am 03.06.2009  –  Letzte Antwort am 04.06.2009  –  6 Beiträge
DAC
neono am 02.09.2005  –  Letzte Antwort am 05.09.2005  –  2 Beiträge
USB to Digital converter
msb1 am 05.11.2008  –  Letzte Antwort am 08.11.2010  –  249 Beiträge
Wharfedale or a good Indian Brand - Please suggest
skoka123 am 27.01.2005  –  Letzte Antwort am 31.01.2005  –  16 Beiträge
Buying A DAC For HDD Playback
Amp_Nut am 01.06.2011  –  Letzte Antwort am 23.10.2011  –  107 Beiträge
Norge or Telome anyone?
Neutral am 30.06.2005  –  Letzte Antwort am 02.07.2005  –  12 Beiträge
  • Registrierte Mitglieder930.694 ( Heute: 1 )
  • Neuestes Mitgliedflordobie93614
  • Gesamtzahl an Themen1.563.560
  • Gesamtzahl an Beiträgen21.828.976
