| HIFI-FORUM » English » Stereo (Engl.) » Active Vs Passive Preamp | |
Active Vs Passive Preamp+A -A |
abhi.pani
erstellt: 19. Feb 2009, 11:32
Hello all Buddies, Preamp as I have mostly gathered has been one of the least discussed equipment (almost on all forums)....Even cables are discussed more .I recently moved from Integrated to Pre-Power combination and as usual started off paying least priority to preamplification. However I was lucky to meet some knowledgeable people, one of them being our very own Siva ji, who gave me some guidance towards the contribution of preamp in a audio chain. In the process I also got to try out a couple of them and compare them with each other. Yes, they made significant contribution in deciding how music sounds and to decide what and how much finally comes out of your speaker. So now I have a nice pre-power combo which matches almost all the criteria I had set initially when I upgraded from Integrated to pre-power. The preamp is an "Active" tube Preamp which is very transparent yet warm. This thing is as good as it gets for anything in under $3000 range. I knew this is a gem. Now, the other day another audiophile visited my place to listen to the setup and he brought along a very good passive preamp. This passive preamp has a TVC inside and is made from premium components. This passive device costs close to $3000 .I didnt know what to expect from a passive preamp. Moreover since my Source and Power amp are all solid state gears I always thought a tube preamp is required to keep the warmth around the sound and a passive is eliminating that .But as once we connected it, it was magic from the first moment onwards. The details were unimaginable. The transparency was almost walk through. The warmth was gone but it was replaced with reality. The instruments now had so much more attack and decay that it suddenly made no sense to add any warmth to it. When we connected back the active preamp, it was again nice and warm but a bit cloudy. Needless to say the micro details were hidden within the cloud and you could only get a faint sound of it (that too if you concentrate). All this thing with an active preamp which is superb and was almost flawless previously. For whatever great things the passive did there was one thing that was disturbing. The "Bass". Bass was not as tight in the passive as the active preamp. This was clear. Not that the passive was very bad...but relatively the bass was tad rounded and a bit loose. In some tracks the looseness was very evident and in some it manged to pull off without attracting any anomalies in bass. Just to emphasize once more, the bass in the passive was a little loose "relative" to the active. It was still pretty listenable and nice. But as I understand, since the passive brought out so much more resolution in the mids and highs, why is it that the same level of resolution is not available at low frequencies ? My source and power amp both give out very taut bass lines, I know that well. My power amp has an input impedance of 10 kohm and an input sensitivity of 1 Volt. The source has a RCA output impedance of 146 ohm and output voltage of 2.45 Volts. I did speak to the designers of the passive preamp and we calculated that the preamp output impedance in the worst case would be 166 ohms that is when I drive it to the full volume. For most of the real world listening volumes it would be well under 100 ohms (taking my source into consideration). This data definitely shows that theoretically there is no impedance mismatch problem between the pre and power. But practically our listening test does show that there is a problem in pre-power matching which resulted in loose bass. It would be nice to hear what other members of the forum think about this scenario and also it would be great if you guys can share your experience/views about active vs passive preamps. One thing that I learnt from this exercise is that there is a lot of information on the CD which the CDP retrieves, the speaker can resolve and in most cases a good power amp can deliver which are choked at the preamp level. Which also justifies why preamps can get very expensive. A good active preamp which can "preserve" the info coming in from the source (like a good passive does) and still drive the power amp well is not an easy thing to make or buy. It can definitely be the most expensive component in the chain...justifiably so!!
Amp_Nut
erstellt: 19. Feb 2009, 12:19
Sir.... You are TEASING ! Names of the 2 Pre amps ( Yours and the 'Guest' in your system ? ) Worst case, do pm me the names. ENJOY ! |
Amp_Nut
erstellt: 19. Feb 2009, 12:23
I am not so sure about that conclusion. The loose bass could well be an artifact of the Transformer in that Passive Pre.... |
abhi.pani
erstellt: 19. Feb 2009, 12:37
Hi Amp_Nut, The Active preamp is Acoustic Portrait PM-1, a tube based design. Here is the link: http://www.corrson.com/elec_diy.htmlThe passive was a MFA (Music first audio) Classic: http://www.mfaudio.co.uk/index2.htm http://6moons.com/audioreviews/musicfirst/passive.htmlThe passive preamp has gathered tremendous reviews and probably uses very high quality transformers. The guys who make it (Stevens and Billington) supply their transformers to some of the high end passive preamp manufacturers. |
Amp_Nut
erstellt: 19. Feb 2009, 14:47
Slightly off topic.... After using a Non Remote controlled amplifier, I SWORE that a Remote Control would be an ESSENTIAL feature in any Pre / intergrated amp, I ever buy in future. |
square_wave
erstellt: 19. Feb 2009, 15:46
Hi Abhi, Is the gain issue resolved between the PM1 and the RG1 amplifier? Was this test done with the AP amp or the RG1 ? Now I know who came home…… ![]() If it is the same person, I never heard any looseness in the bass in his system. [Beitrag von square_wave am 19. Feb 2009, 15:49 bearbeitet] |
abhi.pani
erstellt: 19. Feb 2009, 20:00
Amp_Nut, As far as I remember even Gamut runs pretty well with Passives. Have you heard them ?
Hi Square_Wave, The test was done with RG1. Siva had recommended to try out a passive preamp. The gain issue is not all that severe. Just that when the recording is loud then the differential volume between two notches becomes a bit too much and finding an intermediate volume becomes difficult. But thats just an one off case. Regarding the looseness, yes I know that passive can match pretty well with many amps but mine doesnt seem to be all that preamp friendly. Needs more careful matching may be. |
bombaywalla
erstellt: 20. Feb 2009, 00:54
good sleuthing, Dr. Watson! |
milpai
erstellt: 20. Feb 2009, 00:55
Hi Abhi, Good to hear that you have moved from integrated completely. I have read on audio circle forums about your friends pre-amp. They are very good. But there are some newer firms that are not as big as Music First, but produce first rate TVCs. I have placed my order for a Promitheus TVC and am expecting them in 2-3 weeks. Here is the link: http://www.promitheusaudio.com/reference%20c-core/index.htmMine will have the Elma switches. Will let you know about my experience. I will be using my integrated as a power amp. I hope that the 2 components go well with each other. Later when I have enough budgets I will add a Red Wine Audio Sig 30.2 power amp or any other Class D amp. In the meanwhile you can also research on audiocircle.com for other pre-amps. Regards |
redwine
erstellt: 20. Feb 2009, 07:21
Perhaps a different line of thought here - One area where the TVC shines is to give great reproduction across the board at lower volumes compared to many others types of pres. You will typically hear more of everything at lower volumes than with other types of pres. Since the human ear is more sensitive to mids than lows it can give the appearance of higher overall volume (you can even try this with some older cheaper amps that have a bass treble control). If you have tried to level match between both setups by ear its almost a futile exercise and probably this is the cause than anything else. cheers |
square_wave
erstellt: 20. Feb 2009, 07:22
Yup, I have the same issue with my odyssey and PM1 with some recordings. With reference level recordings, the gain is just right. Like milpai said, the reference preamp from Prometheus is a good budget alternative. milpai, why are you considering only class D ? |
redwine
erstellt: 20. Feb 2009, 07:24
Hi Have heard the Promth TVC with the RWA in a couple of different setups and it can sound wonderful. Which speakers do you have? cheers |
square_wave
erstellt: 20. Feb 2009, 07:26
I agree. This is something I heard discussed among passive lovers. One major reason why Abhi's guest went for the passive preamp is detail level at very low volume levels.From my conversation with him, he was very particular about this. |
abhi.pani
erstellt: 20. Feb 2009, 10:08
Nice to read about more alternatives in TVC domain. Yes, even I have heard that they are superb in low level listening (that is where the output impedance is the lowest...if at all it has got anything to do with the sound). BTW, I did forget to mention one more aspect of this comparison: "Soundstage". The passive had much better separation of instruments and clear defined boundaries for each of them but overall the soundstage presented by them was pretty constricted between the speakers. The tube preamp conversely presented a larger soundstage with more vigour in it. Though the instruments were not separated as cleanly. Someone told me that tube equipments help in lighting up the soundstage better than solid states. I definitely saw that happening, the soundstage did light up with the tube preamp, at least in this case the theory worked . |
Arj
erstellt: 20. Feb 2009, 10:45
Abhi, How about another setup with the passive preamp in your Dining room. ![]() I would think that the source (in your case the DAC) would have a lot more role to play with a passive pre amp than an active one. IS that true ? [Beitrag von Arj am 20. Feb 2009, 10:53 bearbeitet] |
abhi.pani
erstellt: 20. Feb 2009, 12:00
I am planning one in the balcony also...because that is where I have to stay after I do all this .
Yes thats true, I didnt try the balance out, maybe that would have made a difference because of higher output voltage. If there are some special requirements from the source to work with a passive successfully then I am unaware of it. My source has an output impedance of 146ohms and output voltage (RCA) of 2.45 Volts. Do the specs look out of place for the passive ? |
Arj
erstellt: 20. Feb 2009, 12:09
Hmm.i actualy am not too technically qualified to speak very authoritative here but i would guiess that with a passive pre, it is the source which is seeing the impedance of the power amp hence its characteristics may be important. My guess is that the output impednace quoted is for 1Khz..not sure as to how much that would be for the sub 50Hz in which you are facing lumpy Bass. is a change in source also bringing about this problem ? |
abhi.pani
erstellt: 20. Feb 2009, 12:20
I didnt try other sources .But it would make sense. I also have this strong feeling that when the speaker is not easy to drive and the amp is stressed then these problems are far more visible. The same combo driving a benign load may just not show up these weaknesess..just an observation from my past experiences with low powered tube amps, I could be entirely wrong . |
milpai
erstellt: 21. Feb 2009, 04:22
Redwine, I got your point regarding low volumes. But I did not get your point of quoting yourself Anyways, to reply to your question, I own the Quad 21L speakers and my integrated in the NAD C352 which I have been using for the past 3 1/2 years. Here is the link to my system: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1130536720Square_Wave, I think Class D amps have reached a stage where they can compete with SS and Tubes. Most people would say tubes are better but I really do not have the patience nor time to mess with them. I have other hobbies like photography and mountain biking. Most important - I have a 3 year old that I need to be with. Only when he goes to bed or goes to play, can I be with my music. So no time for bias or maintenance. Rather enjoy my music in the few hours a month I have. I wish a day was 36 hours!! I am looking at the Red Wine Sig 30.2 Amp as my power amp in future. But this may change depending on how the amps evolve through the months I wait. BTW, I have been interacting with a guy nearby who acquired the Promitheus Signature TVC (site not updated). He compared this to his $27K darTZeel Preamp and the TVC did not feel out of place. But his suggestion was to go for C-Cores rather than the EI trannies, as they open up the music to an astonishing levels. Abhi, Did you visit audiocircle.com for more info on TVC? There are numerous discussions on other preamps too. |
Arj
erstellt: 21. Feb 2009, 11:16
Abhi, do read this article on impedance matching. you need to be sure that your Pre matches your Dac as well a the Pre matches your power as well ![]() http://diyparadise.c...view&id=26&Itemid=27I do have a Question for the techies (Bombaywalla, Siva, Viren...) here. with a passive pre, what will be the impedance as seen by the Source ? is it a function of both Z(Pre) & Z(power) ?? while I presume with an active Pre, it will be Z(Pre) [Beitrag von Arj am 21. Feb 2009, 11:18 bearbeitet] |
bombaywalla
erstellt: 21. Feb 2009, 20:26
"Geek Squad" at your service, saar! The impedance seen by the source would be dependent heavily on Z(power). For a TVC, the input impedance of the TVC will be heavily dependent on the load connected at the TVC output i.e. the power amp input impedance. This is because, with all transformers, the output load gets reflected back to the input & the input drive load (CD player output impedance) get reflected to the output. Let's take Abhi's case here (since he started all this & he also subjected his system to a TVC pre! ) - his power amp input impedance is 10KOhms. If the TVC was set to 0dB (i.e. no attenuation) then the CDP would have seen an impedance of 10K + the DC resistance of the primary & secondary windings. This would have been in parallel with the CDP's own output impedance (don't know what that is). It is clear that the lower the CDP's own output impedance the less loaded down it (CDP) would have been by this 10K input impedance. This input impedance is the worst-case scenario. Now, I'm quite sure that these guys were NOT listening to music with the TVC set to 0dB attenuation! That would have been paint-peeling loud.So, if the TVC was set to any other attenuation level (besides 0dB), the impedance seen by the CDP would have been higher by the square of the attenuation factor. For example, if the TVC was set to -3dB, 3dB = 2 (linear), thus the 10K input impedance of the power amp would have looked like 10K * 2^2 = 40K at the TVC input. You can see that now the CDP output would have had 40K in parallel with its own output impedance. I.E. the CDP was loaded down much less. If you use even higher attenuation settings (-6dB, -9dB, etc, etc) the 10K power amp inp impedance would look larger & larger at the TVC input thereby loading the CDP less & less. This is a good thing - the less loaded down the CDP is, the less distortion in the audio spectrum. Hope that this clarifies. |
Arj
erstellt: 22. Feb 2009, 06:54
Sirji ! Dont Have words. Only |
Arj
erstellt: 22. Feb 2009, 08:04
i guess what would be interesting is to find out the Input impedance of the power amp at say 50Hz and then try to see the load again..just to see if it si the impedance mismatch with the source ? the problem defined by abhi appears to be the classic impedance mismatch case that i could find in my reading. but i guess the area which will bug the life out of ahny audiophile is the apparently fantastic sound at midrange and above in relation to his current Pre But the sudden deterioration at at the Bass level ! |
Manek
erstellt: 22. Feb 2009, 10:32
Arj in that case the output impedance chart across freq's for the cdp would be needed to see if the cdp was loaded at those low freq's or not. I have tried the axiom passive pre from luminous audio a few times and have noticed that they work best with power amps with high input impedance of 20kohms and above and input sensitivity around 700mv's and less. Good volume, good detail, balanced sound, cheap. Manek |
Manek
#25
erstellt: 22. Feb 2009, 12:30
Bombaywalla How much would high cable capacitance or inductance affect the sound of a transformer based passive ? They do seem to play a part with resistive pre's. Manek |
Amp_Nut
#26
erstellt: 22. Feb 2009, 19:37
Sirji... just my 2 cents... The Impedance is reflected / multiplied by the Squre of the Turns Ratio. Hence double/Half the turns = Double / Half the VOLTAGE ( not the power. ) Hence if the Power Amp has an input impedance of 10 K and the transformer was used to attenuate 6 dB ( ie -6 dB).... Not -3dB, then its input impedance would reflect as 10 K x 2square = 40 K Ohms... on the other side of the Transformer.. a happy situation for the Pre or DAC driving the Transformer. Also, () Unrelated to the Turns ratio ) ANY Transformer design is a balancing act between HF & LF performance. For audio applications, spanning 10 Octaves ( High Freq of 20K = 1000 Times the Low freq of 20 Hz ) there are some significant challanges This pre is probably speced for an even wider Bandwidth... But the specs will probably be when driven by a 600 Ohm output impedance ( or better ) device. The site does not provide specs, and the mag review does have some test graphs, but cant zoom into detail, since it pixelises... and its all Greek ! ( Literaly ) A larger Core will yield good Low Freq Response, but high Iron losses at High Freq.. and Visa Versa. That is why I have speculated in an earlier post that the less than ideal Low Freq performance Abhi has experienced could be due to the Transformer ... rather than an Impedance mis-match. [Beitrag von Amp_Nut am 22. Feb 2009, 19:47 bearbeitet] |
Amp_Nut
#27
erstellt: 22. Feb 2009, 19:44
In principle, the transformer will better handle reactive ( Capacitance and / or inductance ) loads, than a Resistive passive. The Transformer actually provides MORE current at its output, than what it receives at the Input, when it is used to attenuate a signal. THAT is a Very DISTINCT advantage over a resistive passive pre, particularly for reactive loads. 2. The reactive load ( Capacitance and / or inductance ) will be reflected on the other winding, again by the Square of the Turns Ratio in use, as indicated in my post above. 3. The Transformer is Likely to have a Higher SELF inductance & capacitance than a resistive passive. [Beitrag von Amp_Nut am 22. Feb 2009, 19:45 bearbeitet] |
bombaywalla
#28
erstellt: 23. Feb 2009, 00:29
Amp_Nut, you are very correct! After I finalized my post I read it & realized that I had made an error. I was going to edit my post & change that "2^2" to "sqrt(2)^2" but the 'boss' called me for something else & thereafter I clean forgot! But you are correct: there is a typo in the impedance calculation for the -3dB case - the input impedance seen by the CDP would be 10K * sqrt(2)^2 = 20K. |
bombaywalla
#29
erstellt: 23. Feb 2009, 00:44
Manek, I don't know if I have the correct answer for this or not but I did a network analysis on this little circuit using the source DC winding resistance of the TVC secondary, cable capacitance & power amp input impedance. The result that I got seems a little counter-intuitive - the cable capacitance interacts with the DC winding resistance & power amp input impedance to, basically, create a high-pass response. This is the part that jives with my earlier understanding of the matter. The counter-intuitive part is that the higher the cable capacitance the better the low frequency response will be! ![]() The circuit is less messy to analyze using just the cable capacitance. I get the same result as above (the higher the cable capacitance the better the low frequency response will be) when I include the cable inductance. I wrote counter-intuitive because we, usually, want to buy interconnects that have the lowest C/ft & L/ft. 99% of the time the use is with an active pre. The game could be entirely different when a TVC pre is being considered. In the end, I *think* that my result might not be as counter-intuitive as it seems because I have seen TVC manuf suggest using large coupling caps (2.2uF-10uF) preceeding the TVC if the power amp has low(er) input impedance. Hope that this helps (more than confuses). |
bombaywalla
#30
erstellt: 23. Feb 2009, 00:57
Arj, I have a feeling that it will not matter since the TVC was being used at a fairly high attenuation setting. For example: let us say that the power amp was a POS & it's input impedance dropped by 2X at 50Hz. So, 5K at 50Hz. Let's say Abhi & guest were listening to music at the 28dB attenuation setting. 28dB = 25 (linear). I left out the decimal places to keep it easy. [Math Police, did I do this correctly??!! }So, the 5K would like 5K * 25^2 = 3.125M Ohms. This is really very high & Abhi's CDP would not be loaded down by the power amp inp impedance. I think that his power amp is really very good & that its input impedance will not drop much at 50Hz so the load on the CDP will be higher than what I calculated above.
Well, do you guys have a good memory? If yes, do you all remember that many of us helped Abhi sometime in 2008 w.r.t acoutically treating his listening room with tube traps, acoustic absorbers & reflectors for the wall, etc?? I remember this because I contributed a fair bit to that thread. You all might remember that Abhi said that his room had some bass & other issues & was in need to some much needed (desperate?) acoustic treatment. So, it is quite possible that Abhi was hearing his room mess up the bass. This should also be considered in the overall pix. [Beitrag von bombaywalla am 23. Feb 2009, 00:59 bearbeitet] |
Arj
#31
erstellt: 23. Feb 2009, 05:06
Hi B'walla ,i am not too sure of that.. i have heard his regular setup and there is a light bass boom (I would rate it somewhere between 50-60Hz) as in most regular rooms and some reverberation/overhang but would not have called it Lumpy in any way. Maybe Abhi can clarify on this furthur.. [Beitrag von Arj am 23. Feb 2009, 05:09 bearbeitet] |
Manek
#32
erstellt: 23. Feb 2009, 07:58
Tks ampnut and bombaywalla for your responses. |
abhi.pani
#33
erstellt: 23. Feb 2009, 09:39
Hey Guys, I could not check the forum on the weekend but WOW I am pretty overwhelmed with the response (both quality and quantity). I can see various line of thoughts out here starting from Impedance mismatch to Transformer Winding Characteristics. Hello Amp_Nut, Your observation of the transformer characteristics is pretty interesting. If a transformer is really designed to give better HF (which I was getting) and compromise on LF then I am blocked. I am just banking upon the factor that these guys at MFA are one of the masters in the world transformers and are supposedly one of the best passive preamp makers. Yes they do have higher end preamps than the one I tried and they say that their better preamps have a "bigger core". Something you have pointed out. I did have a detailed discussion with them on phone and surprisingly they did not admit that there could be a transformer related issue which could have caused the problem. They definitely said that there higher end preamps do better bass but they also simultaneously said that this preamp should have worked with my power amp specs. Whatever be the case trying out a different passive TVC definitely seems to be the next logical step for me. That would clarify the issue better. Hi Bombaywalla and Arj, My room definitely is far from ideal. I do have some bass related problems. While I have treated my room upto an extent, I have not yet done anything significant for bass. All I am doing is finding the best feasible listening position where bass is cleaner. I have tried some bass traps at the corner recent which didnt work .Someone very knowledgeable had visited my place a year back and had immediately pointed out that my room has a good amount of standing waves. Now I am not talented enough to find out the sonic difference between a bass boom caused by standing waves versus bass boom caused by corner reinforcement. However, this knowledgeable gentleman also told me very clearly that corner traps wouldnt solve my problems and I would need a "Helmholtz Resonator" .Now I really see that corner trap is not working . While I do feel that there should be some treatment for the corners of my room but looks like that is not enough.I have to talk to Helmholtz Bhai for some respite .As for the preamp giving out lumpy bass.....yes it did add a little looseness and rounded structure to the bass which made the sound a little lumpy. May be in a very well treated room it would have sounded more acceptable. |
bombaywalla
#34
erstellt: 23. Feb 2009, 19:30
Abhi, From my impedance calculations, I seem to agree with the MFA folks that the bass issues do not appear to be related to the pre-power impedance mismatch. seeking an audience with Helmholtz-bhai is a good idea but I am also wondering if you can make use of the info in this weblink? http://www.ethanwiner.com/acoustics.htmlit might be more amenable to implementing given where you are physically located. I personally do not think that your tube traps are a loss - you need to fine tune them & also add more aesthetically pleasing treatments. I say this 'cuz you already have time & money & understanding invested in your current room treatments. (alternatively, you can junk what you have & start fresh with Helmholtz resonators). [Beitrag von bombaywalla am 23. Feb 2009, 19:45 bearbeitet] |
Active vs Passive speakers Sonic_Master am 16.08.2005 – Letzte Antwort am 24.08.2005 – 21 Beiträge |
preamp surrealistix am 28.07.2007 – Letzte Antwort am 31.07.2007 – 9 Beiträge |
Active Pre-amps V/s Passive Pre-amps Manek am 14.11.2003 – Letzte Antwort am 09.02.2006 – 16 Beiträge |
Why Active? Sonic_Master am 28.11.2005 – Letzte Antwort am 04.12.2005 – 42 Beiträge |
Active speakers bobbybpl am 05.12.2010 – Letzte Antwort am 10.12.2010 – 16 Beiträge |
Active Monitors and Pro speakers binoymehra am 19.08.2007 – Letzte Antwort am 20.08.2007 – 5 Beiträge |
Pulz amp-preamp Ratings!!? neckie am 23.02.2005 – Letzte Antwort am 26.02.2005 – 18 Beiträge |
Preamp as Headphone Amplifier? Neutral am 05.01.2006 – Letzte Antwort am 11.01.2006 – 10 Beiträge |
Tupe Preamp options panditr am 20.01.2006 – Letzte Antwort am 26.01.2006 – 16 Beiträge |
Promitheus TVC Preamp hifinovice1 am 30.10.2007 – Letzte Antwort am 21.03.2011 – 38 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder931.038 ( Heute: 4 )
- Neuestes Mitglied#Slowhand22#
- Gesamtzahl an Themen1.564.506
- Gesamtzahl an Beiträgen21.855.982
