| HIFI-FORUM » English » Stereo (Engl.) » GOing balanced.is it worth it? | |
GOing balanced.is it worth it?+A -A |
Savyasaachi
erstellt: 03. Jan 2009, 10:50
AS the title suggests...is it worth it? Please give me your opinions... Cheers, Saachi |
Arj
erstellt: 03. Jan 2009, 11:00
Sachi, from what i have figured out, it is very beneficial in the following cases 1. when you have very long runs of cables (Digital or ICs) 2. where RFI is high, balanced cables provide better performance over single ended 3. where the components are themselved designed as per balanced. e Electrocompaniet and Ayre are two brands than come to mind not sure of any other [Beitrag von Arj am 03. Jan 2009, 11:02 bearbeitet] |
Savyasaachi
erstellt: 03. Jan 2009, 11:02
Arj, Do you have any personal experience where you have compared the same gear in both unbalanced and in balanced configurations and seen a difference worth shelling out the money on? As i am very interested in that.. I know about the technical advantages..but what matters is the subjective gains.. [Beitrag von Savyasaachi am 03. Jan 2009, 11:02 bearbeitet] |
Arj
erstellt: 03. Jan 2009, 11:24
hmm I have 2 experiences ..in my case the thory was not proven right I had a Electrompaniet Pre for some time. I have used both Balanced and RCa cables between my DAC (Wadia 12 then) and it and found no major observable difference. On the other hand currently my Transport to DAC sounds better with my balanced DH labs digital cable than with an RCA DHlabs cable I used to test. the sound was much more smooth and had a better flow to it..although i doubt if i would have recognized the difference Blind I did discuss it with many folks and they all mentioned the points i mentioned in the above posts. So personally I would not shell out any extra money for balanced Apparently most equipment today do have a balanced connector (which is a market need rather than a technical one) but internally they do not really used balanced design which really defeats the purpose ! what compoennt are you looking at ? |
Savyasaachi
erstellt: 03. Jan 2009, 11:30
I just started out on a project to build a B22 amplifier and wondering whether to build a balanced amp with the possibility to drive two unbalanced headphones as well..or just go for a basic single ended amplifier.I am looking to build something similar to this.. http://www.amb.org/audio/beta22/gallery/cotdt/cotdt2.jpginternals http://www.amb.org/audio/beta22/gallery/cotdt/cotdt5.jpgI am also undertaking another headphone amp build..a Stacker (single ended) tube amp..so going single ended with the B22 means less time and money spent on it and more to spend on the Stacker [Beitrag von Savyasaachi am 03. Jan 2009, 12:35 bearbeitet] |
Manek
erstellt: 03. Jan 2009, 13:04
Funny you should ask that sachi. I just did this comparision an hour ago with a very expensive and highly resolving system... The difference was not noticable at all ! No sir ! Manek |
Savyasaachi
erstellt: 03. Jan 2009, 13:07
thanks for the reply Manek..reinforces my decision to go single ended.. |
Amp_Nut
erstellt: 03. Jan 2009, 16:26
My 2cents... a sort of an anti view to the establ;ished thinking. I had used only Unbalanced equipment all my life, so when I set out to buy myself a "Good" system, I decided that the Preamp MUST have balanced i/p and o/p... based on all the good things I had read in reviews... Balanced would (help) springborad me to the next level. The only other precondition I set for my Pre Amp was that it MUST have a Remote controlled Volume control. My current system : CD Player: Electrocompaniet EMC-1 UP (Balanced and Single Ended but Balanced is Recommended Strongly) Pre: Audio Research LS-26 (Balanced and Single Ended on Every Input and Output) Power Amps: Gamut M-200 Monoblocks (Balanced and Single Ended but Balanced is Recommended Strongly) Speakers Revel Ultima Studio with Transparent Audio Speaker cables. Interconnects ... currently experimenting on this front with various cables... Balanced and unbalanced. My conclusion ? I can hear a diff between Balanced and Single ended on Most Cables. I did hear ( or Thought I heard ? ) a Slightly easier music flow using Balanced SINE's Top-Of-The-Line interconnects ( $ 700 I think ). Yes, I got to try these in both, Balanced and single ended Avaatar. ( I Liked the SINE Interconnects ) My conclusion, Balanced... OK for one-up-manship, but for sound ... Nah ! The fewer electronic components of Unbalanced, will make a simpler circuit, and probably sound better.... That is My 'un-balanced' opinion |
Savyasaachi
erstellt: 04. Jan 2009, 03:14
Very interesting...amp_nut am not all that surprised to be honest..but impressive ssytem tough..should definitely make time to drop by and listen to it when i make it over. thanks for the insights gentlemen.. I am still debating though whether to go ahead and build a balanced amp with the option of driving two unbalanced headphones at the same time as well. I am thinking of designing it in this fashion [Beitrag von Savyasaachi am 04. Jan 2009, 04:07 bearbeitet] |
sivat
erstellt: 04. Jan 2009, 04:10
I have not read all posts above carefully. But here is my feedback. Balacned connection is essential when you have long runs of cables. For short runs like 1 m, you should be okay with RCA. Having said, it also depends on the circuitry of the two devices that you are connecting and also the circuit you use for balanced connection (I've tried transformers and OPAMPS...and prefer the transformer solution). Expermient and find out what suits you .. its not to say balanced will bad comared to single-ended ... but merely for the sake of science. |
bhagwan69
erstellt: 04. Jan 2009, 04:33
Interesting....... What did you use ? If I may ask ... |
bhagwan69
erstellt: 04. Jan 2009, 04:38
Part in Bold - I did not understand. Please do shed some light... Thanks. BTW - Nice set up - Congrats. Sounds Good. Room Plays well too !! |
Arj
erstellt: 04. Jan 2009, 05:13
If you do have a choice and if its not at a substantial cost, I would suggest you go balanced. There is not doubt that technically it is better in rejecting RFI... |
bhagwan69
erstellt: 04. Jan 2009, 05:33
Balanced Cables are far cheaper to product viz a viz Unbalanced Cables. The 'defacto' industry for XLR's are Neutrik & they are much much [400 %] cheaper than the Neutrik Pro Fi RCA Connectors. Hence having RCA Terminated Cables sure are more expensive to produce as compared to XLR Terminated Cables !!! Some products I have heard / used sound same on RCA & on XLR. Some sound better on XLR Some sound better on RCA I guess, it just depends on the 'way the circuit is layed out' !!! Design Plilosophy of the designer - I guess. Most [mind this] European designers 'prefer' RCA & Most American designers prefer XLR !! Very Very General Statement. I know. There are exceptions. Spectral - USA Gryphon & GamuT - Europe But, this is what I have generally observed..... |
Amp_Nut
erstellt: 04. Jan 2009, 05:48
Hi bhagwan69, Thanks for your kind words on my room and system sound. While it is far from ideal, It definately thrills me more than many systems I have heard... and (as you have often said ) thats what systems should be about ... delivering what the Owner likes, given constraints of budget, room, etc rather than a pursuit of a 'correct' sound.
The Balanced Connector is WAY more complex than the sigle ended RCA. The ONLY reason the balanced connector is cheaper, is the fact that it is manufactured in ZILLIONS rather than 1000s that the high end RCA ( single ended connector) is manufactured. Further, the Balanced Wire has 1 more conductor and is also far more complex and expensive to manufacture. Getting Balanced and Unbalanced interconnects at almost the same price is a Great deal (IMHO) for Balanced users. [Beitrag von Amp_Nut am 04. Jan 2009, 06:17 bearbeitet] |
Amp_Nut
erstellt: 04. Jan 2009, 05:53
Savyasaachi said:
IMHO The block diagram that you show, has the headpone driven in Bridge Mode... rather than balanced mode. The balanced or single ended will depend on the Cirkit topology of B22 Boards 1, 2 , 3 & 4 ( all identical, I presume ) Many amps recommend use in Bridge mode ( MBL ) while I think Crown ... more than 2 decades ago had a 1000W bridge amp that was Very Rave reviewed. Many feel that Bridged sound is Very dynamic and effortless, not so much for the 4X power it can deliver, but the fact that the return path from the load ( speakers / headphones ) does not go thru Ground. [Beitrag von Amp_Nut am 04. Jan 2009, 06:12 bearbeitet] |
Amp_Nut
erstellt: 04. Jan 2009, 06:02
Oops... 1 more thought... getting a 4 gang pot that tracks well will be difficult and / or expensive ... (DACT) But then, I guess you are in persuit of high end, and have budgetted accordingly ... |
Arj
erstellt: 04. Jan 2009, 06:39
Hey thats a very nice and smooth CDP..especially the transport section which is about as good as high end does ! |
Amp_Nut
erstellt: 04. Jan 2009, 08:05
Thanks, Arj, It uses the Philips Pro mechanism, like the one you are using. Electrocompaniet also offers a "Spider" Clamp for the CD, which makes a HUGE difference to the sound... bass tightens up and the entire sound opens up... like Grunge cleared. IMHO the difference is So significant, that the CDP should Not be sold without it ! The reson I am mentioning this, is that I am sure that a similar clamp will make a similar difference to your Transport too.... Maybe someone is aware of such as accessory, from a 3rd party vendor, for all CD Pro mechanisms ? See the Pic at : http://www.pbase.com/2c3d/image/34846827 |
Savyasaachi
erstellt: 04. Jan 2009, 08:27
Very nice CDP amp nut..envious now... |
Arj
erstellt: 04. Jan 2009, 09:31
Mine is not a CDM Pro2..it a CDM 12.4.not as good as the Pro [Beitrag von Arj am 04. Jan 2009, 09:34 bearbeitet] |
bhagwan69
erstellt: 04. Jan 2009, 09:44
This clamp looks like a clamp that is used by Bow Technologies in their ZZ Eight CD Player - I heard that many many years back in Singapore - 2003 I think. If it makes 'such a diff' then why does Electrocompaniet not supply the CD Player with that clamp as 'standard' ??? I wonder... What is the Transport that ARJ has ? |
Amp_Nut
erstellt: 04. Jan 2009, 10:08
Arj, I think the clamp or anything similar will do its magic on any Top loading mech .... like the Bow, mentioned by Bhagwan69 bhagwan89 said :
Good question, Sir ! Specially when the player costs as much as it does... At the price of the spider, I guess its a Considerable extra Money in the bank.... so why give it away free [Beitrag von Amp_Nut am 04. Jan 2009, 10:11 bearbeitet] |
sivat
erstellt: 04. Jan 2009, 14:11
Arj, EC uses the CDM transport, not the more expensive CD-PRO2M/K. Do note that the - CDM can also be used as a top loading mechanism with some small mods. Which means, the transport you have can also be used as a top loading one with a puck. Regards Siva. |
Arj
#25
erstellt: 09. Jan 2009, 16:17
Hey Siva missed out on this post. This is really interesting. I am presuming the mods are more mechanical in nature than electronic. |
sivat
#26
erstellt: 10. Jan 2009, 16:03
Yes. This is completely mechanical....but the "Eject" will mean slightly different..."Reload". |
Is Jamo E-series worth it? Neutral am 21.04.2005 – Letzte Antwort am 26.04.2005 – 21 Beiträge |
NAD @ soundnvision - is it recomended? vpriyan am 22.11.2005 – Letzte Antwort am 29.11.2005 – 5 Beiträge |
Connector.Is it important? vpriyan am 16.01.2007 – Letzte Antwort am 17.01.2007 – 12 Beiträge |
Section for HDD/Computer Audio Krish am 02.11.2010 – Letzte Antwort am 02.11.2010 – 4 Beiträge |
Built to Last: 28 years and still going strong! Neutral am 18.11.2005 – Letzte Antwort am 22.11.2005 – 14 Beiträge |
Jeff Rowland Concentra 2 anybody auditioned it? Sonic_Master am 06.06.2005 – Letzte Antwort am 13.06.2005 – 4 Beiträge |
Best Enclosure Structure.... is it sphere? Sonic_Master am 28.11.2005 – Letzte Antwort am 29.11.2005 – 6 Beiträge |
Yamaha AX497 amp - how is it? Bibs am 03.02.2006 – Letzte Antwort am 08.02.2006 – 4 Beiträge |
192 KHz/24bit DAC - Is it true? vpriyan am 22.11.2008 – Letzte Antwort am 04.12.2008 – 12 Beiträge |
Vandersteen Audio dealer/Distributor ? Arj am 28.10.2007 – Letzte Antwort am 29.10.2007 – 8 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.555 ( Heute: 4 )
- Neuestes MitgliedMicromot
- Gesamtzahl an Themen1.563.199
- Gesamtzahl an Beiträgen21.818.826
