mortin logan vantage speakers - 85% discount
nietzsche
#1 erstellt: 21. Nov 2008, 06:02
My friend is planning to buy martin Logan vantage speakers by this week end. Which amp will match (pre and power combo or processor and power blocks) with these speakers? He said on MRP they are offering 85% discount
He is in Chicago. He is a novice. Please guide. Shall I advise him to go and buy or look out for other speakers?
Regards
bhagwan69
#2 erstellt: 21. Nov 2008, 11:38
Vantage SpecificationsFrequency Response: 34–23,000 Hz ± 3dB
Horizontal Dispersion: 30 degrees
Vertical Dispersion: 40" (102cm) line source
Sensitivity: 92 dB/2.83 volts/meter
Impedance: 4 ohms, 1 at 20kHz
Crossover Frequency: 400 Hz
Components: Custom-wound audio transformer, air core coils, polypropylene capacitors
Woofer Type: 8" (20.3cm) (per channel) cast basket, high excursion, aluminum cone with extended throw drive assembly, non-resonance asymmetrical chamber format, bass reflex
Woofer Amp Power: 200 watts/channel (4 ohms)
Bass Control: ±10dB at 35Hz
Power Handling: 250 watts per channel
Signal Inputs: Custom bi-wire binding posts
Mains Power Draw: Idle: 8W/channel
Max: 140W/channel
Weight: 52 lbs./channel (23.6 kg)
Dimensions (HxWxD): 57" × 10.7" × 16.25" (144.7 × 27.3 × 41.3 cm)
http://www.us.martinlogan.com/specs/vantage.html
The simplest option - vfm is from NuForce
@ 85 % off - buy with eyes shut !!!
Too good a deal to let go....
nietzsche
#3 erstellt: 21. Nov 2008, 12:39
Namaste,
Thanks Bhagwan Ji. I will ask him to proceed further. My friend told me that US market is in very bad shape, and they are willing to sell many branded products on weight basis.Any audiophiles from States can through light in this regard.
regards
bhagwan69
#4 erstellt: 21. Nov 2008, 17:05
nietzsche schrieb:
Namaste,
regards
If that is the case - then Bombaywalla should consider a CD Player upgrade - Esoteric P3 + D3 @ 85 % is a steal. If your friend can get one for me, the funds are ready. I too will consider.
Manek
#5 erstellt: 21. Nov 2008, 17:11
Hmmmm
Not sure if the us market is that bad across the country. Didn't get any news like that from the people I know.
Bombaywala, your comments appreciated ? Wonder when our dealers here would drop prices to 85 percent of their msrp ? :-)
Manek
bhagwan69
#6 erstellt: 21. Nov 2008, 17:15
Manek
Blue Foods going down = A2V giving discounts ?
Wishful thinking....
Sorry - joking;;;
bombaywalla
#7 erstellt: 21. Nov 2008, 19:29
bhagwan69 schrieb:
nietzsche schrieb:
Namaste,
regards
If that is the case - then Bombaywalla should consider a CD Player upgrade - Esoteric P3 + D3 @ 85 % is a steal. If your friend can get one for me, the funds are ready. I too will consider. :angel
Thanks for the suggestion, Bhagwan69!
If the Esoteric P3 + D3 is going for 85% I should seriously consider buying the pair w/ my eyes shut!
Nietzsche, can you please provide the dealer's name in Chicago? You can PM email w/ that info. I will then contact him for details. Thanks!
Amp_Nut
#8 erstellt: 22. Nov 2008, 05:28
Maybe we should consider a 'Group Buy' ... 20 pieces and maybe get a further discount ?
Incidentally, just yesterday I was reading Stereopile and it said that a survey showed that the UK HiFi industry last year was more resilient than other consumer goods !
Amp_Nut
#9 erstellt: 22. Nov 2008, 05:34
I studied yesterday's Times Of India clip, and from what I read, the Blue Foods sale was a REALLY good deal for SC.
He really sold only a PART (yes majority) of GOODWILL for Rs 150 Crores while retaining ALL is Real Estate and running hotels !
The deal was done apparently 2 months ago, and he probably would get no-where near that money for 'goodwill' today, with Dark Clouds of recession looming...
It does not look like a distress sale, but a well timed business decision.
nietzsche
#10 erstellt: 24. Nov 2008, 10:15
Dear Bombaywalla,
I have written to my friend. Once I get the info. I will pass it on to you.
I told him to buy the martin logan vantage speakers.
regards
bombaywalla
#11 erstellt: 25. Nov 2008, 18:59
Manek schrieb:
Hmmmm
Manek
Correct, Manek. I am not receiving any such pieces of news either. Prices of certain hi-fi gear + accessories have not dropped much. A dealer that I know used to give 20% off regularly & is not offering 25% off. Other internet dealers are offering closer to 30% off. Certain used gear, if hot, is holding up its re-sale value very well. People are not willing to let those items go for low-ball prices. I have tried to tempt them for a few items that I have interest in right now.
I also understand that most dealers have reduced or eliminated stock & are charging 15-20% re-stocking fees if you return a custom order item. Also understand that if one has to repair an item thru the dealer the time is fairly long esp. if the gear is imported as they dealer/distrib has to order the part from overseas. This happened to a friend's friend who needed new xformers for his Art Audio tube amp.
FWIW.
bombaywalla
#12 erstellt: 25. Nov 2008, 19:00
nietzsche schrieb:
Dear Bombaywalla,
regards
Thank you nietzsche. Awaiting feedback from you....
abhijitnath
#13 erstellt: 26. Nov 2008, 09:46
I'm hunting for the ML Dynamo sub (which normally comes with the Vantage home theeater set). Any idea if that is on sale as well? I'd really appreciate it if you could ask your friend...thanks!
kspv
#14 erstellt: 29. Nov 2008, 16:11
The offer looks too good to be true. Search Google with the string "white van speaker scam".
Jamo Speakers
Manek am 08.01.2004  –  Letzte Antwort am 07.02.2004  –  3 Beiträge
new speakers?
cholo333 am 28.07.2004  –  Letzte Antwort am 29.08.2004  –  3 Beiträge
Innovative speakers
benkenobi am 04.02.2005  –  Letzte Antwort am 04.02.2005  –  2 Beiträge
Canton Speakers
hifinovice1 am 11.03.2005  –  Letzte Antwort am 11.03.2005  –  3 Beiträge
EPOS Speakers
hifinovice1 am 15.03.2005  –  Letzte Antwort am 01.04.2005  –  5 Beiträge
8 speakers
knownothing am 03.04.2005  –  Letzte Antwort am 05.04.2005  –  6 Beiträge
Help Speakers...
Altamira am 24.06.2005  –  Letzte Antwort am 24.06.2005  –  3 Beiträge
used speakers
anirvan am 02.08.2005  –  Letzte Antwort am 19.08.2005  –  4 Beiträge
Magnat Speakers
Voodoo_CHild am 21.08.2007  –  Letzte Antwort am 21.08.2007  –  3 Beiträge
Active speakers
bobbybpl am 05.12.2010  –  Letzte Antwort am 10.12.2010  –  16 Beiträge
  • Registrierte Mitglieder928.586 ( Heute: 3 )
  • Neuestes Mitgliedbcgoodman
  • Gesamtzahl an Themen1.558.528
  • Gesamtzahl an Beiträgen21.704.477
