| HIFI-FORUM » English » Stereo (Engl.) » bookshelf 2 way speakers with 90db+ sensitivity | |
bookshelf 2 way speakers with 90db+ sensitivity+A -A |
Manek
erstellt: 16. Sep 2008, 04:12
Hi A friend wanted me to recommend standmount 2 way speakers available in india which are 90db+ and 6-8 ohms impedance for around 50k. I could only come up with klipsch as a brand. Any ideas ? Maybe jbl would have some thing ? He wants to drive them with an old leak amp. Manek |
abhi.pani
erstellt: 16. Sep 2008, 04:40
If its for Rock then your recommendations are nice else... .Look at these speakers from Energy. http://www.energy-sp...c-10-specifications/They are supposed to be really good. Its available in India as well. |
stevieboy
erstellt: 16. Sep 2008, 06:38
mordaunt short had a pair of bookshelves ms 902i but they were budget round 20 or so. they played loud with viren's old el84 15 watt amp. monitor audio too has the bronze's which have high sensitivity. i'm sure the gold speakers too have high sensitivity. epos too might be a good match cos the crossover is simple from the reviews i've read. wont waste watts in the crossover circuit! |
stevieboy
erstellt: 16. Sep 2008, 06:41
i've also heard dynaudio play loud enough with a cayin 30 (or so) watt amp |
bhagwan69
erstellt: 16. Sep 2008, 07:03
Woofers (1) 6 " Audiotechnology C-Quenze Tweeter (1) Raven R1.1 Ribbon Tweeter Height : 42cm Width : 27.5cm Depth : 37.5cm Weight : 20kg Frequency Response :25Hz - 35Khz Nominal Impedance : 8ohms Sensitivity : 89db SPL/2.83v Power Handling : 150W http://www.sununionaudio.com.hk/en_Frameset-1.htmNot 90 but 89. Can that do ? I have for sale - Brand New - Not open. http://www.sununionaudio.com.hk/jpg/expectD-pal.jpgThis is the Back Plate. Noble Expect is the Model Name. One of the 'best' woofers in the world. Same as that on the Siltech Speaker & on Peak Consult & on the Varity Audio etc. etc. Even Rockport Technologies has this same woofer used. It may not fir your 'budget' I am selling this @ 175/- K But, just take a look. May a 'top line' contender for a great stand mount speaker !!! <a href="http://imageshack.us"><img src="http://img208.imageshack.us/img208/6747/expect01zl9.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/img208/expect01zl9.jpg/1/"><img src="http://img208.imageshack.us/img208/expect01zl9.jpg/1/w398.png" border="0"></a> [img=http://img208.imageshack.us/img208/9656/expect02ko0.jpg] [img=http://img208.imageshack.us/img208/expect02ko0.jpg/1/w392.png] [Beitrag von bhagwan69 am 16. Sep 2008, 07:11 bearbeitet] |
bhagwan69
erstellt: 16. Sep 2008, 07:10
[Beitrag von bhagwan69 am 16. Sep 2008, 07:13 bearbeitet] |
Arj
erstellt: 16. Sep 2008, 09:23
manek, i remember Leak amps as having power capability between 10-30 push pull..am i right? in that case the Klipsch and JBL would be a very good choice considering availability in india. i believe Spendors also go very well with tube amps..although pricing in india is not what i am familiar with. |
Manek
erstellt: 16. Sep 2008, 14:36
Hi all Thanks for the tips. Bhagwan, those are way out of his budget but will let him know.the freq response is quite flat. Nice. Abhi, energy could be an option. All round music preference, rock, pop, jazz, etc....that's what makes it a bit more difficult. Arj, the old leaks do have small power outputs. Stevieboy, its not just about volume but also about presenting as benign a load as possible to the amp at moderate to higher volumes. We did speak about dynaudio. Aren't missions usually on the higher side on sensitivity ? Need to check. Speakers with good old paper cone mid bass drivers would be ideal. We also spoke of full rangers like fostex etc but they are a no go for him. Manek |
sivat
erstellt: 16. Sep 2008, 16:55
It will be very difficult to find a conventional dynamic loudspeaker with 90db sensitivity. However, it is not to say that your tube amp cannot drive a loudspeaker with 86db sensitivity. I know this person in Singapore who used to demo the 2A3 SET with a 86 db bookshelf speaker, so that people can see for themself... Having said all this....DIY ... I'm sure the local peerless available in Mumbai will be very good start. Deaf had a wonderful speaker made with these drivers...check with him. |
reignofchaos
erstellt: 16. Sep 2008, 19:36
Usher X-718 http://usheraudiousa.com/products/loudspeakers/x-series/x-718This thing retails for 55k or thereabouts. Very very good speaker for the price. I have the higher end Be-718 (and extremely well reviewed ) with the beryllium tweeter which are harder to drive than this one. A 20 watt Musical Fidelity class A amp can drive the Be-718 easily. So I guess this one should be very easy load. [Beitrag von reignofchaos am 16. Sep 2008, 19:38 bearbeitet] |
Manek
erstellt: 17. Sep 2008, 04:19
Yes siva....I know it will be difficult but I think its worth the search if low powered amps are to be used and thanks for the lead. Btw I did find one model of mission m32i to be rated close. Don't know what mission is upto lately. Manek |
Jeeves
erstellt: 17. Sep 2008, 07:12
Manek many years ago I had JBL LX800 F/S speakers with 91 db if I remember right. Were relatively cheap at around 30k I think. They were good. Must be out of production now for sure. Jeeves [Beitrag von Jeeves am 17. Sep 2008, 07:13 bearbeitet] |
Krish
erstellt: 17. Sep 2008, 11:08
Polk RTi A1 loudspeaker Manek, check out the specs of this one: Frequency range: 50Hz–27kHz. Nominal impedance: 8 ohms. Sensitivity: 89dB/2.83V/m. Recommended amplification: 20–125Wpc. Here is a recent, positive review from Stereophile.It seems to fit your brief every which way; be it budget, sensitivity or working with a variety of musical genres. http://stereophile.com/standloudspeakers/908polk/index.htmlAvailable at ProFx, Atria, Worli for Rs 15000. Give it a listen. Krish |
Manek
erstellt: 17. Sep 2008, 11:59
Yes krish I looked up polk and also found jm focal chorus, same specs..... And guess what sold by the same guys ! So now that makes it 4 choices.not bad. Still looking.... Manek |
particleman
erstellt: 17. Sep 2008, 14:44
Hi, You also have: Monitor Audio RS1 40Hz - 30 kHz, 90 dB, 6-8 ohms, 80 watts handling selling at mid-30s PSB Image B25 45Hz - 23 kHz, 89 dB, 4-6 ohms, 100 watts handling selling at low-20s Focal Chorus 807V 50Hz - 28 kHz, 92 dB, 8 ohms, 175 watts handling selling at 51,000 So on paper the Focal Chorus 807v seems like a good fit |
bombaywalla
erstellt: 17. Sep 2008, 17:49
Hi Manek, How about 1 more choice - Wharfedale Diamond 9.1 or 9.2? Agreed that these are 86dB sensitivity but the review that I read in HiFi Plus said that these speakers were a benign 6 Ohm load to the amplifier. Also, this speaker was an all-rounder meaning that it sounded very good for all genres of music. I believe that the Diamond 9.X series has been a hit in Europe. There are several for sale on Ebay at good prices. You friend might be able to get them for USD500 or less - well within his budget. |
Manek
erstellt: 17. Sep 2008, 18:25
The 9.2's I have heard and are good for their price. Tannoy....hmmm just struck me may have stuff with their dual concentric speakers. Regards Manek |
abhi.pani
erstellt: 18. Sep 2008, 05:56
IMO the following speakers are crap... .Polk RTi A1 loudspeaker .Monitor Audio RS1 .Focal Chorus 807V Sorry for being a bit too blunt...but I have had first hand auditioning experiences with all of these and they just dont fit anywhere in my list of speakers to even consider. They might have the specs on paper but thats about it. |
abhi.pani
erstellt: 18. Sep 2008, 08:04
Sorry to disagree Siva, but I dont think its a good way to go in this case. DIY in my opinion shouldnt' be taken up if you want to get it right the first time. I have seen quite a few first attempts going absolutely bizzare. May be it works for some fortunate ones who are guided by expert DIYers without much experimentations....but not for people who start off with some basic idea (maybe from the internet or so) and still expect a great product at the end of their first attempt (something that beats a good commercial product). Mostly you end up in a awkward product which is half-cooked in some areas and over-cooked in others. |
bhagwan69
erstellt: 18. Sep 2008, 11:11
I actually like the MA - RS1. Sorry to disagree.... |
sivat
erstellt: 18. Sep 2008, 11:16
The problem with first time DIY ... is the same as the fist time "buying" a hifi solution You do not know what is right sound....whether u buy a product or DIY .... u will continue to learn and your opinion changes with time. |
bombaywalla
erstellt: 18. Sep 2008, 13:16
Manek, Indeed TAnnoy is another good brand to consider. However, not all Tannoy stand-mounts were created equal & in fact most of them were rather blah sounding. The new System 800, System 1000, System 1200, etc speakers are too tizzy sounding compared to their predecessors. Buy with caution! If your friend gets one of the dual concentrics of yester years (DMT series or Gold Monitor, etc) he will surely get a speaker for a life-time & very high efficiency ( such as 94dB) to boot! Other stand mounts like PBM6.5 & PBM8 I have no experience with. Another model is the "Reveal" series. Looks like any other speaker i.e. does not seem to be dual concentric. Yet another model was the "Mercury" which was sold more for HT (atleast here in the USA). Might still be good enough for 2-ch? Their "Revolution" & "revolution Signature" models look dual concentric. No idea how they sound. To me they look rather modern & might have the modern (tipped up) sound. I've been told that ever since they started manuf in China, cabinet quality has shrunk, which has had a detrimental effect on the sound. No wonder the older models fetch great prices even today. |
Savyasaachi
erstellt: 18. Sep 2008, 15:44
well put siva... I would go one step further and recommend the Wharfedale Evo-10/20 speakers ..i have the Evo 10(bought it used for 80$.. ) Much better than the diamond series IMHO..and worth the upgrade..or course the quad 12L is a great option too. |
Krish
erstellt: 19. Sep 2008, 04:02
Hmmm. Interesting.Do elaborate. K |
particleman
#25
erstellt: 19. Sep 2008, 04:25
I would appreciate it if you would elaborate on this. Is it a specific quality that put you off? I ask because I plan to buy the RS6 shortly. |
bhagwan69
#26
erstellt: 19. Sep 2008, 06:32
Must Buy ! Nice speaker. |
Arj
#27
erstellt: 19. Sep 2008, 08:34
My experience with Monitor audio silver (I believe the older verson of th RS) series has been very good. with the wrong amp it can sound bright, but with amp o the warmr side of neutral is sounds good. although IMHO it is a Rock an Rol speaker in the sense that its Bass is excellent but midrange a bit recessed...but again for its price it is great speaker. |
Manek
#28
erstellt: 19. Sep 2008, 09:42
Arj I did think the mids were a bit thin in the older model but I think they have addressed that issue with rs series. Monitor audio, good for the money I'd say. Manek |
particleman
#29
erstellt: 19. Sep 2008, 15:00
@Bhagwan, Arj, Manek: Thank you all, good sirs. Much appreciated - I feel very reassured. Manek, sorry for the minor derailment of your thread. Back on topic: No one has mentioned Quad 12L? Also, if brought abroad then Totem Rainmaker should be under 50k ($950) but in India it is nearly double. I heard these Totems with a tube amp and it was a wonderful experience - Jazz was especially nice. Edit: I noticed Savyasaachi mentioned the Quads as well, my mistake. [Beitrag von particleman am 19. Sep 2008, 15:01 bearbeitet] |
Manek
#30
erstellt: 20. Sep 2008, 03:09
I doubt that would touch 88 db sensitivity. I say that cuase I have heard a 86 db speaker play louder at the exactly same volume in the same setup than the 12l which is rated higher. Its again how the speaker is measured and tested. But again nice for the price. |
abhi.pani
#31
erstellt: 22. Sep 2008, 05:10
Well something similar was my experience when I heard it a year or so back. Bright and slightly recessed midrange. IMO, MA starts getting good from its GS series. |
abhi.pani
#32
erstellt: 22. Sep 2008, 05:18
Hi Krish, Well, I have had multiple auditions of the Polk, starting from their Monitor series all the way to Lsi series. IMHO, Monitor and Rti series speakers seriously lack in the midrange dept. They are good for compressed rock and pop but nothing beyond it. Play some Jazz and Ghazal on them and you would know what I intending at. I have listened to them in proper listening rooms and not in some AV expo so I am pretty sure of their mediocre behaviour. But then they do have nice bass (very tight). Highs are typically American. Having said that, their LSi series is nice. They are far more matured sounding with an evenly balanced tonality. But I havent heard their BS extensively so didnt recommend. |
abhi.pani
#33
erstellt: 22. Sep 2008, 05:26
Well, for most people getting into hifi, they definitely have some background to good quality sound reproduction and thats why they intend to get to the next level. Also one has the option of comparing multiple speakers which are available off the shelf and then buying which ever he liked most. That I think is a far safer approach for a first timer. I would still maintain that DIY should be taken up if you want to continue DIYing till you reach a product with a desired performance....and not as a one time stint. |
Arj
#34
erstellt: 22. Sep 2008, 06:01
that might be quite true...their entry level are more for the HT market i believe ? |
new speakers? cholo333 am 28.07.2004 – Letzte Antwort am 29.08.2004 – 3 Beiträge |
Help with speakers connections pranab31 am 27.02.2006 – Letzte Antwort am 28.02.2006 – 5 Beiträge |
QUAD 11L speakers panditr am 01.08.2005 – Letzte Antwort am 24.08.2005 – 20 Beiträge |
Canton Speakers hifinovice1 am 11.03.2005 – Letzte Antwort am 11.03.2005 – 3 Beiträge |
Suggestion for budget bookshelf/floor standing speakers vivekama am 06.08.2005 – Letzte Antwort am 08.08.2005 – 3 Beiträge |
Speakers with NAD 740 samsam am 23.03.2005 – Letzte Antwort am 25.03.2005 – 5 Beiträge |
Crossover design for 2-way speakers Neutral am 24.09.2006 – Letzte Antwort am 26.09.2006 – 4 Beiträge |
Speakers for NAD C352 in_step am 29.03.2005 – Letzte Antwort am 29.03.2005 – 8 Beiträge |
speaker sensitivity TROJAN_HORSE am 04.03.2005 – Letzte Antwort am 04.03.2005 – 6 Beiträge |
bose speakers with denon amp. kewl am 21.10.2006 – Letzte Antwort am 23.10.2006 – 10 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.661 ( Heute: 2 )
- Neuestes MitgliedNeroNepolus333
- Gesamtzahl an Beiträgen21.825.692
