HIFI-FORUM » English » Stereo (Engl.) » DIY Bolton speakers | |
DIY Bolton speakers+A -A |
Neutral
21:09
erstellt: 11. Aug 2006, |
My friend has with him DIY flrs. They use a 12" and a 3" Bolton drivers in each channel. How many continuous watts of power would these speakers need to drive them comfortably?
SDhawan
13:48
erstellt: 12. Aug 2006, |
Hi ! I think that its the voice coil, mounting, input impedence and sensitivity that determine the required amp power rating and no the diameter of the drivers. The DIY kit would specify the ratings. Anyway you could do a hit and trial to find what works the best - start with low power amp and then try higher power. Take care not to use very high volumes with high power amps. Regards Sanjay |
ani
17:13
It is easier to burn out a speaker/ speakers using a lower powered amp by trying to get more than what it can deliver. ie if the amp/speaker combo cannot produce sufficient sound pressure level you will try to get more output from the amp thus causing clipping of its output waveform, which is nothing but part of square wave which will burn out the HF driver faster than most hi powered amp can . so it is always better to start with a medium powered amp something like 50w rms in case of solid state or a classic pushpull tube of about 30W. |
Neutral
12:47
erstellt: 13. Aug 2006, |
This is quite an irritating situation for me. The speakers are around 25+ years old and my friend has long forgotten the specs of the drivers that he used in them ![]() I asked him about the X-max and the sensitivity, but he was quite clueless. The enclosure is huge: breadth 42cm x depth 43cm x height 80cm. Wow ![]() ![]() I was suggesting to him amps from Norge - 2060 80W at 4 ohms; Torvin TA300 - 80W at 4 ohms; Proton D540 dual mono - 40W; and a Luxman - 120W. Not sure of the ohms for the older amps. Besides, the truthfulness of manufacturers vary. Any other suggestions for Chennai? I do hope that these amps will drive the speakers well. Sanjay, I think that the larger the diameter of a driver the more the surface area and the air moved. So driving these might be tough. On the other hand, the larger enclosure might make the acoustic volume and thus the sensitivity higher. Yes ani, I would not try out amps specified lower than 40W as I know that this friend does get carried away sometimes. And a lower powered amp wouldn't hold up. BTW, how good would a Yamaha etc AV receiver be for such Bolton speakers - maybe the third model from the bottom. The entry-level stuff would be trash. I would personally have preferred a pre-power combo like my own Pulz 60W or from Sonodyne, but his budget's a constraint (around 6K). Might not make sense to go higher for older speakers. |
screamgigi
20:01
If those Boltons were made in 80's, than expect a power handling capacity of upto 70 watts RMS. As someone posted before, a lower power solid state amp has more potential for damage. |
square_wave
10:23
erstellt: 16. Aug 2006, |
I used to make speakers with Bolton drivers for my friends in the 90’s. Making some extra pocket money for the bikes and booze during college days ![]() |
Neutral
15:08
Sorry that you are far away from Chennai, Square! Otherwise, I would invite you over for some nostalgia. Yes, Peerless and Vifa make better entry-level drivers. But let's give the old dog its due. The fact that they have survived 20+ years is a tribute to good build quality and careful handling. |
sivat
04:10
erstellt: 17. Aug 2006, |
No two bolton drivers (of the same model) will measure the same. The T/S Parameters are very inconistent ...to make any dedicated design for them !! BUT...they still sound much better than some of the chinese models that have become very popular these days. I'm sure an amp like Norge combined with such speakers and a decent DVD player - will be better than most boom-boxes. Go ahead and enjoy your Bolton project. litte piece of advice ... try and avoid drivers more than 7" inch in size. There are practical reasons to consider. The transducers design has changed along with the change in amplification during the past couple of decades...just bcos speakers from 70s and early 80s used huge drivers (which was very much essential those days)....we don't have to, in our present day. Cheers Siva. |
square_wave
05:44
Yes. We essentially used to make them to replace the boom box speakers which came with the mini/midi combo systems. They used to sound much better and had a very high-loudness/party factor which we was what we needed those days. The finer points of audio were far away from our minds. But we used to have so much fun with those. |
Neutral
11:01
erstellt: 18. Aug 2006, |
Hi Siva, I too have noticed that modern fronts rarely cross 8". What was the advantage of those huge 12" drivers (in the Bolton speakers). Is their purpose: 1. To increase low bass 2. To increase efficiency 3. To compensate for low driver excursion capabilities Give me your explanation please. |
Help with speakers connections pranab31 am 27.02.2006 – Letzte Antwort am 28.02.2006 – 5 Beiträge |
Of Speakers and Roaches soulforged am 21.04.2006 – Letzte Antwort am 05.05.2006 – 41 Beiträge |
Need Assistanceon Speakers pitchucold am 09.02.2006 – Letzte Antwort am 03.03.2006 – 61 Beiträge |
My new DIY ghetto finish speakers. vjcritic am 05.09.2007 – Letzte Antwort am 06.09.2007 – 8 Beiträge |
Floor speakers and surrounds TROJAN_HORSE am 16.09.2005 – Letzte Antwort am 24.09.2005 – 16 Beiträge |
Planar speakers Savyasaachi am 11.01.2011 – Letzte Antwort am 27.10.2011 – 127 Beiträge |
Need help in choosing speakers trivisingh am 25.01.2005 – Letzte Antwort am 11.02.2005 – 25 Beiträge |
Pro crossovers for DIY Manek am 21.08.2006 – Letzte Antwort am 22.08.2006 – 2 Beiträge |
My new speakers. neono am 16.08.2006 – Letzte Antwort am 19.08.2006 – 14 Beiträge |
Suggestion for budget bookshelf/floor standing speakers vivekama am 06.08.2005 – Letzte Antwort am 08.08.2005 – 3 Beiträge |
2006
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.589 ( Heute: 1 )
- Neuestes Mitgliedshellygruner54
- Gesamtzahl an Themen1.558.562
- Gesamtzahl an Beiträgen21.705.244
