HIFI-FORUM » English » Stereo (Engl.) » Bass & Treble in Stereo | |
Bass & Treble in Stereo+A -A |
SUNILYO
11:47
erstellt: 14. Jul 2006, |
Hi all One of my friends was telling me that in stereo one spkr gives the bass part and the other spkr gives out the treble part. is it true ?? or does it depend upon the recording ? The only thing i know about stereo is the sound is recorded in two discrete channels and while playing the same thing happens, sound is output from two discrete channels - left and right? is it something more to this theory? may be amp_nut could help in this. |
Shahrukh
12:00
He probably was referring to the drivers, Sunil. You know... a two-way speaker - where the crossover sends hi freq signals (treble) to the tweeter and mid/low freqs (bass) to the woofer(s). In a 3 way you'd have a dedicated driver for mids too. I'm guessing that's what he meant. |
SUNILYO
12:09
Dear Shahrukh, I have the Sonus 2605 which is a 3-way speaker. What is actually happening is the bass output from the right channel is more than the left one and the treble output in the left channel is more than the right one. This might be becoz presently it is connected to a local amp. i am using by Onida DVD player to play my audio CDs. now tell me is it due to the amp or the dvd player. |
Shahrukh
12:21
My initial guess would be the amp. However, I suggest you try them out with another amp, if possible, and see what happens. If they sound ok, it's your amp. If the same problem occurs, your speakers have a glitch. Have them changed ASAP! |
abhi.pani
12:23
I know about this problem..........its totally the amp...thats the culprit...in local crappy amps the sound is like that (One channel bass and other one treble) but any decent amp will actually give you proper sound with proper balance of bass and treble from both speakers. Go for a good amp buddy ![]() |
Shahrukh
12:23
The above is assuming you have all your connections correct of course. Check the connections FIRST! |
SUNILYO
12:27
I have gone thru all the connections and as far as i know all of them are in the right places. So i think it IS the amp which is doing the job. So all i can do at this point is wait till next month till i buy my new amp. Because before buying them it was auditioned with a Yamaha stereo amp which did not give any problems and sound good. |
Shahrukh
12:30
I'd avoid using the speakers with the current amp, if I were you. BTW, which amp is this and how old is it? |
Manek
12:34
are the speakers wired in the correct manner ? + to + and - to - ? |
SUNILYO
12:40
Yes I know. but i really wanted to listen to them at my house and i couldnt wait till the new amp. But i listen to them at moderate volumes so that the amp does not create any problems. |
SUNILYO
12:41
everything is in proper place. |
Amp_Nut
12:55
SUNILYO 1. Flip your left & Right speaker connections at the amplifier. Has the effect also swapped channels ? If yes, your amp is a lemon. 2. If no, its probably your room acoustics.... if one speaker is deep in a corner, and the other is not, the corner speaker will have more bass. 3. Playing the devil's advocate ..... MAYBE.... JUST MAYBE your new speakers are faulty ? Just to be 100% sure, run them on a known good amp, borrowed from a friend or the show room... |
SUNILYO
13:14
I will try this one today and see what are the results. There is one more i would like to ask. The sonus have bipole connections what are they, how does it affect sound and how do i use them. |
Shahrukh
13:31
You mean 'biwire' connections. As far as i know, the 2605 isn't a bipole speaker. ![]() |
SUNILYO
13:41
Yes that right. It says 'biwiring' and 'biamping' ready. What does that mean? |
square_wave
13:47
Your speaker is bi-wirable. You have to have two runs of speaker wire in each direction and connect them separately to the highs and lows terminals. I suggest you don’t bother with that now. Bi-wiring makes a slight difference when you have a fully optimized system. Spend your money else where now. A decent integrated amp, good speaker wires, an entry level cd player and decent interconnect etcc… when you have done all this, do a bi-wire. |
Amp_Nut
14:05
SUNILYO If your speakers are Bi-wireable, EACH Speaker enclosure ( Left & Right) will have 2 red terminals and 2 Black terminals, at the back. Check that, 1. at the speaker itself, the two REDS are connected to each other, and the 2 Blacks are connected to each other. 2. From the amplifier, The Left Channel Red should go to the 2 RED Terminals at the Left speaker rear. ( These 2 terminals should be connected ) Ditto for the Black wire from the Left Channel amp to the same speaker box. I suspect, that the 2 Reds and the 2 Black are not connected, at the rear of the speaker. That could be the reason why one plays High Freq ( only) and the other Low Freq Only ! Do revert ![]() [Beitrag von Amp_Nut am 14. Jul 2006, 14:07 bearbeitet] |
SUNILYO
14:11
There are indeed to 2 red and black terminals on each spkr. Both of them are connected by a bridge which came supplied with the speakers. the bridge is in form of a gold plated metal strip. it might be possible the bridges are not set properly at either ends. should i try to connect them using a copper wire ??? |
Jeeves
14:29
Sunilyo, a question even if its silly...how many cds have you experienced this with. If its just one...!! it could be the recording! Jeeves |
SUNILYO
14:45
No I haven't. but will try that too today. |
Debu
20:48
Not a bad idea, pls try and let us know. - Debu |
Amp_Nut
11:19
erstellt: 15. Jul 2006, |
Just tightning the terminals so that the Gold plated bridge is held Firmly at Both end, would be fine. Awaiting yr feedback ! ![]() |
Amp_Nut
14:18
erstellt: 17. Jul 2006, |
Hi SUNILYO
Just a reminder... would love to have yr feedback.... ![]() |
SUNILYO
14:30
Hi guys I rechecked all the connections and found every thing to be tight and secure. The problem is with the input connection of my lousy amp its loose. I interchanged the L/R connections and it worked. later when i switched on the amp again the same problem persisted and i had to repeat the steps again. |
Amp_Nut
17:11
#25
Thanks for the feedback, SUNILYO ! A stereo amp is really 2 identical amps in a single box. This can often be used to advantage, by swapping channels around, to eliminate or confirm that 1 channel of the amp, or some other stereo component is at fault... ![]() |
Bass Tilt, Treble Tilt and how its useful Sonic_Master am 07.12.2005 – Letzte Antwort am 08.12.2005 – 11 Beiträge |
Treble quality from Proac Response D15 Sonic_Master am 11.05.2005 – Letzte Antwort am 12.05.2005 – 14 Beiträge |
10" Driver for Mid bass will it be ok? Sonic_Master am 12.12.2005 – Letzte Antwort am 12.12.2005 – 7 Beiträge |
Car Stereo deepug am 01.07.2005 – Letzte Antwort am 01.07.2005 – 8 Beiträge |
Stereo help! Ironpants am 23.05.2005 – Letzte Antwort am 23.05.2005 – 2 Beiträge |
DAC 14AWG srikarkav am 10.08.2009 – Letzte Antwort am 12.08.2009 – 4 Beiträge |
Conked Stereo Amp XandY am 22.12.2005 – Letzte Antwort am 22.12.2005 – 9 Beiträge |
STEREO NEWS ! Manek am 08.07.2005 – Letzte Antwort am 12.07.2005 – 2 Beiträge |
Advice needed for bass echoing panditr am 27.03.2005 – Letzte Antwort am 31.03.2005 – 22 Beiträge |
Indian stereo component system Neutral am 23.03.2005 – Letzte Antwort am 24.03.2005 – 13 Beiträge |
2006
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder926.682 ( Heute: )
- Neuestes Mitgliedstoepsel79
- Gesamtzahl an Themen1.553.701
- Gesamtzahl an Beiträgen21.596.763
