Connecting two power amps to Preamp
ckn
#1 erstellt: 14. Apr 2006, 13:29
Question for the knowledgable.
Can i connect two power amps of different w.p.c. to the same pre amp? Are there any specific things that one should watch out for?
Will combining tube power amps to a SS pre amp pose any problem?
Thanks in advance.
ckn
Arj
#2 erstellt: 14. Apr 2006, 13:44
No problem at all ..
but if the gain of the power amps are different each will output a different wattage for the same signal.
hence if you are Bi amping horizondally, the input into the tweeter and the woofers will be different and if you are vertically bi amping then one speaker will have a different output than the other..
to do this well you need to have an attenuator in the P-amp with the higher gain and try to match the levels.. but its painful !
bombaywalla
#3 erstellt: 14. Apr 2006, 19:11
ckn schrieb:
yes! no problem if the output imp of the preamp is small enough (50 ohms, 600Ohms, 1KOhms) & the input imp of the power amp is large enough (50Kohms, 100Kohms or higher).
If this is not the case, what will happen is that the preamp will load the power amp & you'll get rolled off high freq + the bass will sound bloated.
see above re. inp & out impedances
Thanks in advance.
ckn
should not if you ensure that the inp & out impedances are low enough & high enough respectively.
Also, read "Arj" comment re. the amps having diff gain hence having diff output levels for the same preamp volume setting. Additionally, the tube & SS power amps will have diff sonic signatures that might or might not blend w/ each other - particularly important if you are bi-amping.
if you have 1 amp driving 1 pair of speakers in 1 room & the other amp driving a 2nd set of speakers in another room, tonal signature should not be an issue.
Connecting SMPS devices to Hi-Fi
hifinovice1 am 12.04.2005  –  Letzte Antwort am 18.04.2005  –  3 Beiträge
preamp
surrealistix am 28.07.2007  –  Letzte Antwort am 31.07.2007  –  9 Beiträge
Compare Amps,
powersupply am 06.09.2005  –  Letzte Antwort am 09.09.2005  –  14 Beiträge
Connecting a walkman to NAD 320
vinodt am 05.01.2005  –  Letzte Antwort am 06.01.2005  –  3 Beiträge
Connecting PC sound card to Denon receiver
shashankmittal am 12.09.2005  –  Letzte Antwort am 12.09.2005  –  2 Beiträge
Tube PreAmp and SS Power Amp
herculepirate am 23.04.2007  –  Letzte Antwort am 13.05.2007  –  48 Beiträge
Want spkrs to go with Cairn amps
ckn am 20.03.2006  –  Letzte Antwort am 02.04.2006  –  21 Beiträge
Active Vs Passive Preamp
abhi.pani am 19.02.2009  –  Letzte Antwort am 23.02.2009  –  34 Beiträge
Two Saturday afternoons well spend??.
square_wave am 13.06.2005  –  Letzte Antwort am 23.06.2005  –  63 Beiträge
Tupe Preamp options
panditr am 20.01.2006  –  Letzte Antwort am 26.01.2006  –  16 Beiträge
2006
  • Registrierte Mitglieder930.997 ( Heute: 1 )
  • Neuestes MitgliedHifi-Hobby
  • Gesamtzahl an Themen1.564.407
  • Gesamtzahl an Beiträgen21.853.015
