HIFI-FORUM » English » Stereo (Engl.) » KEF iQ5 | |
KEF iQ5+A -A |
Shahrukh
06:10
erstellt: 06. Mrz 2006, ||
iQ5 has reached. Just unpacked them yesterday. Burning them in with some very ordinary cables right now. Initial reactions? 1. Extremely well packed (took half an hour to take them out). 2. Great build 3. Decent image/sounstage 4. Good detail Unfortunately, I'm noticing quite some bass suckout in my room. Also, the speakrs sound a bit harsh now. Will post a detailed review once they run in and I've tackled the bass issue. Otherwise, they're real decent. ...More later. |
nimz
10:04
waiting..... |
audiojet
10:49
hi, firstly, congratulations. Its exciting to open up new stuff : ) could you tell us your room size (apx)? you're using the iq5's with a marantz amp? what is your exact setup? rgds, vikram |
stevieboy
10:58
wow. are u from bangalore vickram? would really love to come over and listen to those cadences if u have them. |
stevieboy
10:59
ok sorry. checked. ur from bombay ![]() |
Shahrukh
11:43
Thanks Vikram, Yes, I'm using a Marantz AVR. SR 4400. My full setup can be viewed by clicking my ID. Room size is 21 X 8 ft. The listening position is breadth wise. I can't have it any other way. This setup almost eliminates the side wall factor. Though there's a wall + door on the left (from listening position) the right side is a window with curtains. Guess that's what's causing the suckout. (I had a pair of Wharfedale Diamond 8.1s earlier and thought the lack of bass was the speakers themselves. ) |
square_wave
12:36
The room plays a big role in the final reproduced sound. You probably have a lot of bumps and holes at some critical areas in the bass region. Play around with the placement and try and get some minimal room treatment done. Here’s a helpful link. ![]() |
Arj
13:32
try modelling your room here as well ![]() (click on the link for "Launch CARA Quick in new window" ) |
Shahrukh
14:38
Thanks! Even squarewave's link had the CARA Quick simulator. I had a go at it. According to CARA, my positioning is alright. Unfortunately it doesn't give me solutions. I can't customise it to where my doors/windows are placed. It is based on a closed room. |
Arj
15:32
for that you need to buy the software ![]() |
Shahrukh
12:24
erstellt: 13. Mrz 2006, ||
Damn! This bass thing is bugging me no end. Mostly it doesn't go below the upper midbass region. But then on some tracks (Nusrat Fateh Ali Khan/Peter Gabriel - Taboo) it goes way down low. Almost sub woofer levels but without the tummy thumping quality. It's like a very mature speaker "I'll give you bass only when you really need it - I'm no club monitor" ![]() |
square_wave
13:12
Did this speaker behave any differently at the showroom ? If so, you have a room problem. Try using the equalizer in the AVR or better still, get your room/placement sorted out. Anyway, a purist approach with an AVR is a very futile exercise, so why not use the equalizer and see if you can sort it out. |
Shahrukh
13:30
Yes yes it's the room. No side walls. Big door (uncloseable) to the next room. Dunno how to solve the problem. |
Arj
14:24
Could you describe the room and the music ? it would be a shot in the dark kind of suggestion otherwise ! ![]() typically bass deficiency could be due to the recording, the source, amplifier-speaker, mismatch, room-speaker mismatch, speaker positioning or the amount of damping in the room. finally.. and not the least, over expectation from the listener in the bass region ![]() if you have the hell freezes over by eagles, listen to the first couple of drum thumps. if you can feel that they are tight then you are doing ok. positioning is perhaps the most important for bass and some playing around in its nearness to the walls might get you somewhere There is a review of the iQ9 in stereophile ![]() one interesting comment is "The reproduction of bass instruments depended on the recording. Jerome Harris' bass on "The Mooche," from Editor's Choice (CD, Stereophile STPH016-2), was a touch warm but quite natural, although the kick drum seemed a bit thick on this recording through the KEFs. The double bass on George Crumb's Quest (CD, Bridge 9069) was naturally woody, but with a resonant quality that sounded overly round. The iQ9's midbass was most problematic with electric bass guitars that were mixed high in rock recordings. On Mighty Sam McClain's Give It Up to Love (CD, JVC JVCXR 0012-2), the emphasized, resonant, sluggish bass guitar sounded more like organ-pedal tones." and this speaker is rated down to 38Hz with 3 woofers compared to the 2 smaller woofers and 43db rating of the iQ5. i am not sure if an equaliser would improve that, as you will only compromise the midrange and get more distorted bass hence as long as your positioning is optimised for bass and your midrange as clean, the only other way to add bass would be via a sub. |
Shahrukh
15:26
How do I post a pic here? I'll give you guys a rough sketch of my room. |
Amp_Nut
07:23
erstellt: 14. Mrz 2006, ||
Hi Shahrukh, While the lack of bass COULD be your room... maybe you could also look at the following :
1. Different speakers Do sound different, and the difference is often most readily apparent in the bass, as a 'deficiency' I know, I felt that when I switched from my old B&W 802s to Sonus Fabor. 2. Often you may be better off with the less bass from the new speakers, than boom from the old ones ( my case ) though its AWEFULLY difficult to come to terms with that initially.
You could place your speakers on the floor or move them ( or even 1 of them ) into a corner for more bass. This should be only a temporary measure, if you get bass quantity instead of quality. We always want a 'WOW' factor with our new stuff... sometimes it takes time for the speakers to burn in too. 3. Over time ( atleast 100 Hours of 'music' ) most speaker will open up.... more and tighter bass, better imaging etc. 4. Not all demo rooms are good.... I know of one which has asbestos sheets as walls carved out off a computer show room. The bass BOOMs ! So dont take the demo room as your reference.... [Beitrag von Amp_Nut am 14. Mrz 2006, 07:29 bearbeitet] |
Shahrukh
07:55
Thanks Amp/Arj, Actually, the way I see it, it's a combination of factors. 1. The speakers are just over a week old. Lots of break in required. 2. The room. 3. My source. It's a cheapo US supermarket brand DVDP. Was gifted by a dear friend, hence has a lot of sentimental value in the household. But, I think its time has come ![]() See, if I really concentrate, low end is there. But most of the time, it's like the woofer present specifically for bass has no function at all. Add to that the harshness of a new tweeter, it can get a bit unnerving esp after getting used to that warm Wharfedale sound. That said, here's what I must add. The soundstaging qualities of the iQ5 are excellent. It goes way, way beyond the speakers. Even the imaging is spot on. (As spot-on as I can get with my gear). Separation of instruments is good. The speakers do a marvellous job of immediately dissapearing in to the soundstage. That, guys is such a fascinating pleasure. I guess I'll wait for burn-in to really enjoy these babies. |
Arj
08:03
although manufacturerus claim long burn in times, 30-50 hours should be enough for reaching upto 90% of potential.. so just leave it on overnight at a low volume with some heavy bass music . |
Behram
09:23
Hi Shahrukh, I was in your same situation 9 months ago. Lack of Bass and tweeter harshness were my complaints too. Ofcourse I did not have KEF speakers but Jamo. I modified the crossover values and now they sound fine. |
Manek
14:42
Sharukh, are you using the analogue outputs of the dvdp or digital ? your av recvr dacs would be far better than the ones built into your dvdp.....so thats one thing you could try. Secondly ...are your speaker wires too long ? Manek. [Beitrag von Manek am 14. Mrz 2006, 14:43 bearbeitet] |
Shahrukh
14:46
My speaker wires are 2m a side. I'm using the analogue currently, I'll change to digital and see the difference. Anyone in Mumbai got a spare Dig Coax Cable I borrow?? ![]() |
Manek
14:54
us the same analogue cables initially...not an issue...i'm sure you will find a difference overall :-) |
Arj
15:45
its a good point by manek. regarding analogue Vs digital .. actually they are the same.but usually digital cables have a better spec wrt impedance, as too long a rise time in the digital signal can cause jitter which affects timing and clarity.. usually any decent IC cable makes a pretty good digital cable ![]() |
Shahrukh
15:47
Will try and let y'all know the difference. |
Shahrukh
07:23
#25
erstellt: 16. Mrz 2006, ||
Tried connecting to my AVRs DAC in PCM mode. Yes Manek, the bass improved, the harshness went. Unfortunately, so did the image. It got quite blurry. Well atleast I know that the culprit is my source now. So I guess I'll replace it ASAP. The Philips DVD players are supposed to be good in stereo ACD mode, right? |
Manek
10:29
#26
If I were you, I would put my money on something like a nad 521bee or a similar kind if cdp. A good/shielded digital cable with low jitter may just solve your problem of a fuzzy image. The pioneer universal players make for a very decent transport if you want to use the AVR's dacs. manek. |
ajacob
20:45
#27
erstellt: 24. Mrz 2006, ||
Hi Shahrukh Just wanted to know..where did you buy the KEF IQ5s from and at what price? Thanks Anil Jacob |
Horst_t
21:01
#28
@ all, I've bought the IQ5 a few weeks ago for a friend of mine from Hifi-Regler Germany. Special offer, because of damaged packaging. ![]() However, with small Audio-Planar AntiSpikes die Sound improved a lot. (bass and voices). It is difficult to describe value for money for a LS of about 500-600 € and the antispike for approx. 100€. Our oppinion: it is worth doing it. Sorry for the poor English. Have a nice weekend. [Beitrag von Horst_t am 24. Mrz 2006, 21:02 bearbeitet] |
myriad
07:31
#29
erstellt: 25. Mrz 2006, ||
Hello Shahrukh, There are some more things you can try. 1. Move the speakers closer to each other. Preferably 8 feet apart. 2. Move the speakers inside. At least they should have 4 feet gap from the rear wall. 3. Put your amp and cdp on a decent isolation. You can get them DIYed with bicycle tubes. (Bicycle tubes have given me better results than sand box and racquetballs). |
Shahrukh
11:12
#30
Pardon my ignorance, but what exactly are anti-spikes? Are they something like discs you put under the speaker spikes or is it like what we called a Spike Guard from the mains unit? Thanks for the suggestion anyway.
Thanks for the advice myriad, but the distance between the two walls (behind the speakers and behind my seating position) is a little over 8 ft. [Beitrag von Shahrukh am 25. Mrz 2006, 11:13 bearbeitet] |
Arj
11:33
#31
I think he means this.. ![]() Audio plan is a De based company which makes footers which are not spikes hence called Anti spikes.. basically flat cylinders made of carbon fiber material. footers need to be chosen based on whether you want to couple/decouple/absorb speaker vibrations. there is no one single way as it depends on the speaker enclosure and the flooring. of course home made remedies work very well too.. [Beitrag von Arj am 25. Mrz 2006, 11:34 bearbeitet] |
Shahrukh
12:00
#32
Thanks Arj, Haven't figured them out yet but I'm not too sure I want to go in for a 100€ tweak right now. However, I'm sure there's a much cheaper homemade solution. |
Arj
12:13
#33
IMHO,you should not ![]() Manek , if i remember right, had a very practical isolation.. a thin cork sheet on the floor, granite slab on it and speakers on that slab.. you can either spike or use bushing on the speaker feet and you have a very good speaker base ![]() |
Shahrukh
06:39
#34
erstellt: 27. Mrz 2006, ||
In that case, wouldn't coins do the trick?? |
Arj
07:11
#35
not really.. the idea is to first isolate then couple.. but then experiment to see what works for you. some speakers/rooms like the isolation bit better and some do better with tightly coupled speakers. (If your flooring is concrete/ceramic then youd better use coins instead on only spikes.. preferably any Brass/copper coins) |
Shahrukh
12:50
#36
The good news is the iQ5s are sounding better now. This break in period IS VERY LONG. But then, it's getting better. Now, lemme just change my source and I'll post a complete review. |
Klipsch RF II's happy with them but... SUB_BOSS am 29.03.2005 – Letzte Antwort am 31.03.2005 – 37 Beiträge |
Siltech cables ? check these out ! square_wave am 26.08.2008 – Letzte Antwort am 01.09.2008 – 37 Beiträge |
My experience with Acoustic portrait. I am buying them. square_wave am 02.05.2005 – Letzte Antwort am 18.06.2005 – 37 Beiträge |
Pls help me get started with a stereo system. zhopudey am 13.05.2006 – Letzte Antwort am 22.05.2006 – 27 Beiträge |
Wyred4Sound Dac 2 ? An Owners Review Krish am 11.08.2011 – Letzte Antwort am 09.11.2011 – 7 Beiträge |
Think i found a find! puchoo am 11.06.2007 – Letzte Antwort am 11.06.2007 – 4 Beiträge |
The importance of a good cdp not to mention recordings. benkenobi am 20.04.2005 – Letzte Antwort am 22.04.2005 – 20 Beiträge |
My Drivers..i Finally got them! benkenobi am 06.07.2005 – Letzte Antwort am 06.02.2006 – 309 Beiträge |
Auditioned the Acoustic portratits yesterday..:)) square_wave am 04.03.2005 – Letzte Antwort am 14.03.2005 – 23 Beiträge |
New system kousik_s am 12.09.2006 – Letzte Antwort am 13.09.2006 – 20 Beiträge |
2006
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.735 ( Heute: 9 )
- Neuestes MitgliedFarcyyy
- Gesamtzahl an Themen1.558.874
- Gesamtzahl an Beiträgen21.712.773
