| HIFI-FORUM » English » Stereo (Engl.) » DVD soundtracks too soft! | |
DVD soundtracks too soft!+A -A |
Neutral
erstellt: 07. Feb 2006, 15:55
I use a computer as a source. Whenever I play any DVD soundtrack, the volume level drops to a third or a fourth of normal CD or MP3 playback. An example: When I play the Enya 'May it be' song that accompanies the ending titles of the Lord of the Rings I DVD, I can barely hear it even at full vol. (I play using Power DVD 5). If I switched to Winamp without lowering the vol, my ears would have flown out the window. Why is the vol so low in Power DVD or on DVDs? Does anyone have a solution to this problem? Or are DVDs always mastered with low vol (with no normalization applied)? |
Savyasaachi
erstellt: 07. Feb 2006, 18:59
I have no such problems with Power DVD. Tried with many DVDS to check for the problem that u have mentioned, no luck. I think that you better check if the equalizer is turned on in Winamp. check the preamp level on Winamp. also, check the device level settings by going to start menu>accesories>entertainment>volume control. |
Neutral
erstellt: 08. Feb 2006, 15:11
Sachi, I will try tomorrow with Win DVD. But as far as I know the problem is with the vol level on DVDs. I am surprised that you have not encountered the same thing. The MP3 vol level is not boosted through equalization. It is the natural vol. |
kousik_s
erstellt: 01. Mrz 2006, 06:25
i have found that this problem happens in some pirated dvds. try original dvds. as for lord of the rings, go to the setup menu and change to 2 channel mode, if you have a 2 or 2.1 setup. [Beitrag von kousik_s am 02. Mrz 2006, 06:09 bearbeitet] |
Neutral
erstellt: 02. Mrz 2006, 14:23
I'll try the 2-ch mode as I have 2 speakers. I was DD 5.1 earlier as I thought it would sound better. |
Sonic_Master
erstellt: 03. Mrz 2006, 07:55
hey man the main reason for such drop is that there is a setting in the audio setup in Pow DVD where the setting by default will be in "quiet" mode... and you have to switch it to "noisy environment" then it will be enough loud to fetch to the amp... I had the same problem but i fixed it.. cheers, Sandeep |
Neutral
erstellt: 03. Mrz 2006, 16:00
Thanks Sandeep, Hope that will help. |
Really sad too day. Prithvi am 03.03.2005 – Letzte Antwort am 04.03.2005 – 3 Beiträge |
Too much Yakking on the forum benkenobi am 28.04.2005 – Letzte Antwort am 30.04.2005 – 15 Beiträge |
DVD Player cheraz am 12.09.2004 – Letzte Antwort am 21.09.2004 – 10 Beiträge |
DAC neono am 02.09.2005 – Letzte Antwort am 05.09.2005 – 2 Beiträge |
Jugaad: Record cleaning purnendu am 12.09.2006 – Letzte Antwort am 14.09.2006 – 13 Beiträge |
DVD skipping/stopping problems anirvan am 16.12.2005 – Letzte Antwort am 19.12.2005 – 7 Beiträge |
Customs duty on DVD tryst am 05.01.2006 – Letzte Antwort am 28.03.2007 – 13 Beiträge |
DVD or Audio CD sanathan am 19.01.2006 – Letzte Antwort am 13.02.2006 – 55 Beiträge |
Upgrading CD/DVD Player vfm am 01.02.2006 – Letzte Antwort am 01.02.2006 – 2 Beiträge |
DVD-A anyone Debu am 16.07.2006 – Letzte Antwort am 17.07.2006 – 3 Beiträge |
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.955 ( Heute: 4 )
- Neuestes MitgliedMark12345
- Gesamtzahl an Themen1.564.258
- Gesamtzahl an Beiträgen21.848.522
