NR-5000
Asterix007
#1 erstellt: 20. Jan 2006, 11:42
Hello,
sorry for my english, but my deutch is inexistant.
I have a NR5000 and I would like to ask owner of this wonderfull receiver to test something.
I use a MAIN A 7.1 config and a MAIN B Stéréo config Bi-Amp actually
In the manual it is mentionned than we can configure SPEAKER A as MAIN A and SPEAKER B as MAIN A too with the SurrBack in Bi-Amp mode. But on my receiver, as soon as select Main A in Sp B, I can't select Bi-Amp in SurrBack...
Thanks for checking.
I use firmware 1.06, I heard that 1.09 is available... has somebody this version ?
Thanks !
mr.pink
#2 erstellt: 20. Jan 2006, 16:55
it's a little hard to follow your setup description. The idea of bi-amping is that you connect your front speakers to Main A and Surround Back. There are 7 amplifiers inside the receiver, so you can't have 7.1 setup running with bi-amping for the fronts without external amplifiers (as you need 4 amplifiers for the front instead of 2). Does this help you? Or did I misunderstand your question.
Regarding the firmware, I have 1.08 installed and 1.09 downloaded but not installed. 1.08 was a major improvement, I personally saw no reason to upgrade to 1.09. If you want to have one of the firmwares, you can send me your e-mail address via PM. But please be careful what you do, as you know a firmware update is always a more or less high risk.
Best regards,
mr. pink
Asterix007
#3 erstellt: 20. Jan 2006, 20:21
Hi mr.Pink,
Thanks for your answer, I will try to make it clearer.
In the manual (English page 23) of the NR5000, you can make a configuration like this :
1-1.Speaker Config
Speaker A
a.Front L/R :Main A
b.Center :Main A
c.Surr L/R :Main A
d.Surr Back :Main A 2ch
e.Subwoofer :Main A
Speaker B
f.Front L/R :Main A
g.Center :Not Used
h.Surr L/R :Not Used
i.Surr Back :BiAmp for Front
j.Subwoofer :Not Used
The advantage of select MainA for speaker B is that you can select either Speaker A or Speaker B in the Listening mode setup. So for movie in DD5.1 you select Speaker A and for a good CD Audio in Stereo mode, you select Speaker B.
But the problem is that, when I select main A in the point f., I can't select Bi-Amp in i. point.
I hope it's better explained now
Could you check if you can please.
Thanks in advance.
Concerning firmware 1.08, have you the file for NR5000 ?
mr.pink
#4 erstellt: 20. Jan 2006, 20:33
yes, I have the firmwares 1.08 and 1.09 for the TX-NR5000E. I would recommend you to go for an update, as the 1.06 had some strange bugs. However, I don't know whether your particular problem will be solved as well, but I will check how my receiver reacts.
Best regards,
mr. pink
Asterix007
#5 erstellt: 20. Jan 2006, 21:52
OK, i'm waiting your test...
I send you a MP
denon avr 4308 jpeg jpg viewing bilddarstellung
dreamfox am 22.01.2008  –  Letzte Antwort am 24.01.2008  –  3 Beiträge
Kombi-Test on Stereoplay 11.2003
redskorpion am 29.02.2004  –  Letzte Antwort am 03.03.2004  –  5 Beiträge
Yamaha RX-V740 problem
redoced am 31.03.2004  –  Letzte Antwort am 04.04.2004  –  8 Beiträge
Centrum products? (English)
AlexS am 13.12.2003  –  Letzte Antwort am 17.12.2003  –  3 Beiträge
Yamaha Memory Guard
jdd2000 am 06.05.2004  –  Letzte Antwort am 06.05.2004  –  5 Beiträge
Bi-wiring mit A+B
wiseman am 21.06.2004  –  Letzte Antwort am 21.06.2004  –  7 Beiträge
Traveling to berlin next week, Where do I buy AV Receiver?
Shaked_Buktus am 14.03.2017  –  Letzte Antwort am 15.03.2017  –  7 Beiträge
Pioneer VSX 912: A+B=Bi-Amping?
achduliebergott am 20.01.2005  –  Letzte Antwort am 21.01.2005  –  11 Beiträge
Which Receiver & speakers: Pioneer,Yamaha,Denon or Marantz
mikehifi am 11.03.2008  –  Letzte Antwort am 14.03.2008  –  9 Beiträge
B-Speaker mit Rear kombinieren
Ako84 am 03.02.2008  –  Letzte Antwort am 06.02.2008  –  13 Beiträge
2006
  • Registrierte Mitglieder930.678 ( Heute: 4 )
  • Neuestes MitgliedSylvie29
  • Gesamtzahl an Themen1.563.490
  • Gesamtzahl an Beiträgen21.826.867
