Solid Wood Baffles with MDF/Ply boxes?
DaveFred
#1 erstellt: 26. Jun 2020, 04:01
Hello,
What have been peoples experiences/thoughts on combining solid wood baffles with sheet good (MDF or Ply) boxes?
My 30+ years of woodworking experience tells me that such a large cross grain joint is a bad idea that can only end with the baffle splitting. Yet, I have seen countless examples of such construction posted on the Interwebs.
I know one thing that would help for sure, and that is "ripping and flipping" the wood, so you end up with a quartersawn baffle (of all the lumber cuts quartersawn has the least amount of movement).
Are people getting lucky?
Is it that we live in climate controlled houses where the humidity is fairly constant?
Is it that the modern PVA glues that we use have some "give" to them?
Are there any guidelines people have used for how wide a solid wood baffle they would on an MDF/ply box?
Does the thickness of the baffle matter?
Any failure examples where the baffle did crack?
What about where the baffles were a glue up of layers of plywood? With this type of baffle, you would think there would still be movement as the layers are not constrained in their "thickness", just in their width and length.
What are your thoughts?
Thank you,
David.
Verleimen von MDF Platten
Dr.Oktor am 23.01.2018  –  Letzte Antwort am 26.01.2018  –  9 Beiträge
Alcone + Alpair + Eiche
stopbit am 19.12.2010  –  Letzte Antwort am 21.12.2010  –  3 Beiträge
2Wege Aktiv SB Ac. + Vifa XT Waveguide
boarder am 07.09.2011  –  Letzte Antwort am 25.01.2012  –  23 Beiträge
Holzkegel drexeln
paco_de_colonia am 10.12.2018  –  Letzte Antwort am 13.12.2018  –  8 Beiträge
Hinweis: Gehäuse zu verschenken (Hamburg)
JohnD am 03.02.2024  –  Letzte Antwort am 02.10.2024  –  6 Beiträge
Compound Sub 330
Acoustimass10 am 24.12.2009  –  Letzte Antwort am 04.01.2010  –  57 Beiträge
3-Wege-Standlautsinger mit Mivoc-Systemen
Audiograf am 12.05.2017  –  Letzte Antwort am 28.05.2017  –  16 Beiträge
LT
MBU am 27.01.2022  –  Letzte Antwort am 24.11.2022  –  60 Beiträge
Tangband W 69-1042 Subwoofer
da_basti am 27.10.2008  –  Letzte Antwort am 25.10.2009  –  8 Beiträge
Baubericht Calypso, 2,5-Wegebox mit HDA-Membran
Boxenbastler am 11.04.2009  –  Letzte Antwort am 23.02.2010  –  18 Beiträge
2020
  • Registrierte Mitglieder930.983 ( Heute: 5 )
  • Neuestes Mitgliedpetermayerhofer
  • Gesamtzahl an Themen1.564.351
  • Gesamtzahl an Beiträgen21.851.151
