SONY TA 636 v. 1979 defekte Z-Diode
muellermoxx
#1 erstellt: 03. Mrz 2010, 11:15
Hallo, eine Z-Diode in diesem Verstärker hat sich verabschiedet. Sie trägt den Aufdruck 22 93 R. Wer kennt sich mit japanischen Bauteilen aus ? Habe leider keine Serviceunterlagen zum Gerät
Gruss Frank
tri-comp
#2 erstellt: 03. Mrz 2010, 13:04
Frank, please start your telepatie-generator. Ordinary mind-reading doesn't work over long distances
What I'm saying is, that I have the service-manual but I need to know the position-no. of the Zener to tell you the correct value. Most likely it's a 22V Zener but to be sure please provide the information.
mfg,
/tri-comp
muellermoxx
#3 erstellt: 03. Mrz 2010, 13:38
Hi, the z-diode is located in the REGULATOR CIRCUIT. It is D 505 . This item is rather fat - bigger than the usual z-diodes.
Regards
Frank
tri-comp
#4 erstellt: 03. Mrz 2010, 22:26
The Zener is indeed a 22V-Zenerdiode.
When it's a 'fat' one I would suggest using at least a 1W type. The original is 'only' 0,5Watt but they tend to become hot. Better use a 1-Watt type in my opinion.
This could be something like 1N4748A:
http://www.microsemi.com/datasheets/SA5-33.PDF
or the European types BZX85C22:
http://www.eworld.ru/store/smc/ds/bzx85.pdf
It is NOT uncommon for a Zener to become defective BUT there MAY be a reason for this.
The Transistor Q501/2SD809 should be examined for shorts or leak. If it's dead a new Zener will become defective immediately.
When you are at it, check or even better REPLACE the electrolytic cap's in the positive and negative supply-circuits.
These are: C504 to C511 inclusive.
You may even want to do the same around the Output IC to prevent it from blowing-up because of self-oscillation caused by failing electrolytic cap's.
Here the cap's are: C301, C304~C307, C351, C354~C357
Good luck,
mfg,
/tri-comp
Opps, forgot to say that according to the manual the typeno. of the original Zener is: EQA01-22R
[Beitrag von tri-comp am 03. Mrz 2010, 22:32 bearbeitet]
muellermoxx
#5 erstellt: 04. Mrz 2010, 10:57
@ TRI-COMP,
thanks for your very, very precise information ! I will do my very best...
Frank
Sony TA-636 - Ersatz für Endstufe
buhauf am 14.11.2010  –  Letzte Antwort am 14.11.2010  –  4 Beiträge
Sony Esprit TA-N88B
7rm7 am 15.03.2007  –  Letzte Antwort am 16.03.2007  –  4 Beiträge
Endstufe Sony TA-N55ES
Mäuserich am 10.04.2007  –  Letzte Antwort am 10.04.2007  –  4 Beiträge
Denon PMA-300V z-diode
bUmbAm22 am 06.03.2011  –  Letzte Antwort am 08.03.2011  –  10 Beiträge
Sony TA-N80ES "Protect"
Wilhelm-ES am 11.03.2010  –  Letzte Antwort am 14.03.2010  –  9 Beiträge
EUROLITE Z-50 defekte Kabelzugentlastung
apap am 09.10.2010  –  Letzte Antwort am 10.10.2010  –  2 Beiträge
Sony TA 5650
hein_troedel am 17.06.2016  –  Letzte Antwort am 18.06.2016  –  2 Beiträge
Sony TA-5650
msoem am 22.10.2014  –  Letzte Antwort am 27.12.2014  –  3 Beiträge
Sony TA-V710 -Beleuchtung ausgefallen-
Zulu110 am 01.10.2014  –  Letzte Antwort am 03.10.2014  –  12 Beiträge
Defekter Sony TA N55 ES
Joe_495 am 04.08.2019  –  Letzte Antwort am 05.10.2019  –  53 Beiträge
  • Registrierte Mitglieder930.458 ( Heute: 7 )
  • Neuestes MitgliedStevencon
  • Gesamtzahl an Themen1.562.905
  • Gesamtzahl an Beiträgen21.811.995
