| HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Dual C844 deck. assistance of the club required | |
Dual C844 deck. assistance of the club required+A -A |
Alex_MGM
erstellt: 02. Mai 2009, 17:50
Dear collegues, please advise anything/ The problem: DUAl C844 cassette deck (purchased at ebay.de) Here are pictures: http://photofile.ru/...03761/#mainImageLink http://photofile.ru/...03780/#mainImageLink http://photofile.ru/...03812/#mainImageLinkThe deck arrived with weared belts. I placed new beltas and deck can normally fast forward and rewind tape. But when in play mode - the left capstan moves the tape slightly better than the right one. So the tape begins to accumulate between the left capstan and rec/play heads. Looling at the capstans I do not see any sihgts of wear, also both capstans are rotating from the same motor so rotation speed is to be the same on both capstans. But reality does not confirm this. When braking the left cassette - the tape moves normally, with the same speed via both capstans. So please advice what to check? Should the left cassette to brake in play mode? Anuthing else? Alexander |
Monsterle
erstellt: 02. Mai 2009, 18:28
You may check if the capstans, the winders and the pressure rolls need cleaning. Use a Q-tip soaked with some isopropyl alcohol for this. Regards, Monsterle [Beitrag von Monsterle am 02. Mai 2009, 18:33 bearbeitet] |
armin777
Gesperrt |
erstellt: 05. Mai 2009, 07:38
Hello Aleksander, I had the same problem with a C-844, after building in of both capstan-belts it ran perfectly. The problem was, the right capstan: if ther is a only a little slip - it will make problems - especially in high-speed-mode. best regards Armin |
Dual C844 assistance of the club required Alex_MGM am 04.04.2009 – Letzte Antwort am 04.04.2009 – 2 Beiträge |
-- Dual C844 -- Capstanmotorregelung spinnt SirSinnlos am 06.05.2012 – Letzte Antwort am 06.05.2012 – 3 Beiträge |
Dual C844 macht zicken declaration am 07.09.2013 – Letzte Antwort am 07.09.2013 – 4 Beiträge |
Dual C844 Reparatur am 25.09.2005 – Letzte Antwort am 26.09.2005 – 3 Beiträge |
Dual C844 Riemen passt nicht ! Ultrakonkret am 24.02.2021 – Letzte Antwort am 24.02.2021 – 3 Beiträge |
Dual c844 nach Riemenwechsel bei play direkt in FF nick541 am 02.06.2023 – Letzte Antwort am 03.06.2023 – 2 Beiträge |
Reinigung von Fisher Dual Cassetten Deck CR-W77 JürgenAretz am 08.07.2022 – Letzte Antwort am 23.08.2022 – 6 Beiträge |
Dual C939 Tapedeck der_tommy am 18.02.2011 – Letzte Antwort am 26.02.2011 – 4 Beiträge |
Dual C816 Tapedeck Koelle2301 am 02.09.2023 – Letzte Antwort am 20.12.2023 – 5 Beiträge |
Dual C 824 Hilfe Pegeleinstellung araso am 29.03.2007 – Letzte Antwort am 03.04.2007 – 5 Beiträge |
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder930.643 ( Heute: 3 )
- Neuestes MitgliedKugel0815
- Gesamtzahl an Themen1.563.406
- Gesamtzahl an Beiträgen21.824.451
