Accuphase P600 problema digital display
yena60
#1 erstellt: 13. Nov 2021, 21:10
I brought ACC. P600 from my trusted technician, with a problem with the digital display.
The display lights up but shows 666 or 000, reading updates arrive but do not come
Two logic boards are used for this reading, the first has on board
two microcontrollers (with proprietary firmware), A / D conversion and power supplies.
The second mounts CMOS logic that should drive the displays.
The only thing it has detected on this is the power supply voltage of about 4.4V against the 5V required.
It could be one of these bad chips. It is not possible to take a test due to difficult accessibility
of the board when mounted and the absence of any type of scheme.
All integrated on logic board replaced, same result, display all 666
Replaced another 4 on another display board, the same.
If someone has suggestions and can help me or has the manual available (even for a fee)
I would be grateful. Thanks
accuphase p600
CarlM.
#2 erstellt: 14. Nov 2021, 16:11
I'm not very familiar with Accuphase. Therefore I waited to answer you.
I searched the internet and found the model A60. The display looks very similar. A service manual is available for download:
https://elektrotanya...sm.pdf/download.html
Maybe it helps to understand and analyze the problem.
Good luck!
Carl
yena60
#3 erstellt: 14. Nov 2021, 18:03
Thanks for the reply, I pass this manual to my technician hoping it will be useful
monkeybonn
#4 erstellt: 19. Mrz 2024, 10:46
Hello,
did you got it repaired?
Ersatz Trafo Accuphase P600
yamahamx1000 am 30.09.2019  –  Letzte Antwort am 20.07.2023  –  136 Beiträge
Accuphase 500L auf 240 Volt umstellen
yamahamx1000 am 18.08.2024  –  Letzte Antwort am 19.08.2024  –  7 Beiträge
Accuphase P300
marc.aurel am 27.02.2011  –  Letzte Antwort am 27.02.2011  –  3 Beiträge
Accuphase P300
stefan2408 am 18.03.2012  –  Letzte Antwort am 27.04.2012  –  8 Beiträge
Accuphase P 300 Defekt
2Boxen-2Ohren am 18.12.2008  –  Letzte Antwort am 18.12.2008  –  2 Beiträge
Accuphase e 204 kaputt.Hilfe!
lavapost am 20.12.2008  –  Letzte Antwort am 28.12.2008  –  3 Beiträge
accuphase 202 defekt?
Niranjana am 25.01.2009  –  Letzte Antwort am 25.01.2009  –  4 Beiträge
Accuphase E-302
boomer_xl am 28.06.2009  –  Letzte Antwort am 29.06.2009  –  2 Beiträge
Accuphase E203 defekt - Hannover
BertiIrmo am 26.01.2010  –  Letzte Antwort am 27.01.2010  –  2 Beiträge
Accuphase DP-70
hpdeussen am 09.03.2010  –  Letzte Antwort am 19.03.2010  –  5 Beiträge
  • Registrierte Mitglieder930.516 ( Heute: 8 )
  • Neuestes Mitgliedreginaa238
  • Gesamtzahl an Themen1.563.053
  • Gesamtzahl an Beiträgen21.815.702
