| HIFI-FORUM » PC, Netzwerk & Multimedia » Multimediaplayer » Der Dvico TVIX M-6500A/7000 Sammelthread | |
Gehe zu Seite: |vorherige| Erste . 10 . 20 . 30 . 40 . 45 46 47 48 49 50 51 52 53 54 . Letzte |nächste|
Der Dvico TVIX M-6500A/7000 Sammelthread+A -A |
dvico6500
#2410
erstellt: 16. Jun 2009, 16:30
Es gibt wieder neue Firmware 1.3.137 http://www.ewers-pc....76536f52e8c7571fc003Changes from 1.3.129 1. Fixed NTP server option is disabled when IP is get properly through DHCP server. 2. Now TV connection type is set to HDMI even if the EDID is not get from HDMI. 3. Imporved Enhanced AC3 stream on recorded streams through a tuner. 4. Network stream performance is optimized. 5. For DTV, fixed the recorded file name is not correctly set for the som Czech stations. Known issues and limitations for Video related - Some TP/TS information may not correct. - When HD Audio pass-through is on, S/PDIF does not output. - When HD Audio pass-through is off with HD audio stream, the playback is not smooth. ¡Û When DTS audio setting is digital, HDMI audio is ON and HD audio pass-through is set to ON, then audio is not heard on the SPDIF output. ¡Û For the same setting, if HDMI audio is set to OFF, then it sounds through the SPDIF output. - Some TP/TS files may cause the system rebooting. - Some WMV may not play correctly. - The digital output for AAC/WMA is disabled. - Does not support PCM audio track on MP4 now. - TVIX may not get IP from DHCP server after change between DTV and Player modes and this can be solved by retrying DHCP on the setup. Known issues for Audio and pictures playing - For MP3 files with low sampling frequency, the TVIX might crash while playing or trick play like FF or RW. - M4A files are not supported now and AAC may not play correctly. Known issues for PVR - After channel changed, you may not here audio in short time. . To work around it, you can press DTV key or Audio key on the remote. Known issues for general issues - If you play files without refreshing the file list after delete files through FTP or SAMBA server, the system will reboot. *** If you play files with HD audio tracks like Dolby TrueHD, , Dolby Digital Plus, DTS-HD MA or LPCM, you better turn on HD Audio pass through on the setup even though you don¡¯t have a receiver that supports decoding of these formats. Otherwise, you will hear strange noise with some repetitive popping noise. Currently, we don¡¯t support core decoding, if you don¡¯t have a HD audio decoder receiver, you need to select other then these HD audio tracks audio track for now. http://www.hd-mediap...4e46e1e054aa77955d84
Chase
#2411
erstellt: 16. Jun 2009, 16:53
Super, wieder ne neue Firmware. Finde gut, dass Dvico sich gut um sein Gerät kümmert und es ständig verbessert. Bisher hatte ich auch noch nie nennenswerte Probleme. Bin mehr als zufrieden. |
bostler1
#2412
erstellt: 17. Jun 2009, 08:36
Hallo zusammen, erst mal hallo, bin neu hier... habe hier im Forum das ein oder andere Mal gelesen, dass die meisten ihre Geräte wohl bei tvix-shop.de gekauft haben. Ich habe mir vor 3 Wochen den 6500er dort bestellt. Leider habe ich ihn noch nicht bekommen. Auf meine E-Mails, Nachrichten über die Webseite oder den "Callback-Service" hat sich keiner gemeldet. Hat jemand eine Ahnung, ob es den shop noch gibt oder ob das normale Lieferzeiten bei denen sind? Wo könnte man dieses Gerät denn sonst noch zu einem fairen Preis bestellen? Viele Grüße, bostler1 |
hkrumb
#2413
erstellt: 17. Jun 2009, 17:05
http://www.tvix-shop.de/de/shop_content.php?coID=4ruf an ...oder bestell woanders ...damals war Herr Winkelmann Inhaber der Domain , ob es sich trotzdem um den gleichen Shop handelt ,wo ich meinen Divco 6500 gekauft hab, wag ich zu bezweifeln hier ein paar Shops ,nur kauf nicht gerade bei pixmania ![]() http://geizhals.at/deutschland/a313001.html [Beitrag von hkrumb am 17. Jun 2009, 17:06 bearbeitet] |
Devine72
#2414
erstellt: 21. Jun 2009, 07:12
ich habe kürzlich versucht mit Winamp eine Playlist zu erstellen, war auch soweit kein Problem. Die MP3 Daten liegen alle auf meiner Internen Tvix Hdd in verschiedenen Ordnern/Unterordnern. Die erstellte PLS/M3U Datei hab ich dann in einem seperaten Ordner ebenfalls auf der internen Tvix Hdd abgespeichert jedoch wird beim anklicken der PLS/M3U (habe beides getestet) kein Titel abgespielt, es passiert rein garnichts. Was habe ich nicht beachtet oder falsch gemacht ? Gruß Devine Direkt antworten |
thbeim
#2415
erstellt: 23. Jun 2009, 10:43
Hallo zusammen, ich brauche dringend Hilfe!!!!!!!! Ich kann neuerdings nicht mehr per Samba auf meinen Qnap109 zugreifen. Ich habe statische IP eingestellt und unter Samba: Qmultimedia 192.168.178.021 = IP Qnap tvixhd1 = Benutzer tvixhd1 = password eingestellt und auch einen Benutzer tvixhd1 mit gleichem Password auf dem Qnap eingerichtet. Der Ping geht auch - allerdings, wenn ich auf den Qnap zugreifen will, bekomme ich nur einen schwarzen Bildschirm. |
Urukai30
#2416
erstellt: 23. Jun 2009, 11:22
hi... dann hast du wohl etwas verstellt. hast du jumbo frames aktiviert? das hatte ich mal und bekam auch keine verbindung mehr. |
1486patrick
#2417
erstellt: 23. Jun 2009, 12:03
@bostler1: sonst bestell ih dir bei Alternate.de, die haben den auch und haben immer einen guten Service. Und schnell sind sie auch immer. Gruß Patrick |
thbeim
#2418
erstellt: 23. Jun 2009, 13:50
Nein, dass kannte ich noch von füher! Sonst jemand eine Idee??? |
Disco70er
#2419
erstellt: 24. Jun 2009, 10:19
Hallo, habe seit geraumer Zeid den 7000er mit 1,5 TB-festplatte. Probiere auch immer fleissig neue Firmwares aus, momentan 1.3.110 bzw. jetzt 1.3.137. Seitdem neues Problem. Die Grundeinstellung steht auf NTSC und läßt sich NICHT ändern. Bei MKVs und DivX kein Thema, da wird automatisch auf Pal umgestellt, aber nicht bei mpg2 (DVB-S - Aufnahmen, z.B. von Premiere, demuxt und neu geschnitten über ProjextX und Cuttermaran). Das heisst Mpgs werden in NTSC mit Ruckeln wiedergegeben. MPEGs machen bei mir ca. 80% aus. Dazu kommt, dass man die Audiospur nicht wechseln kann, kein Rückwärtzspulen, keine Restzeitanzeige. Bei welcheer Firmware funktioniert das bzw. an wenn muss ich dieses Problem senden???? Oder schaut Ihr alle nur HD über das Gerät Gruss und Danke Disco70er |
zGas
#2420
erstellt: 24. Jun 2009, 19:49
Hast Du ein der letzten Betas drauf? Ich betreibe meine Box ohne Platte und seit einer der letzten Betas muss ich expliziet z.B. im Video-Modus oben die Quelle "anklicken" damit er den Inhalt des Samba-Shares auflistet. Früher hatte er das automatisch gemacht. |
thbeim
#2421
erstellt: 25. Jun 2009, 16:31
Jau habe ich. Hab jetzt mal auf Werkseinstellung zurückgesetzt... und siehe da ich sehe den Inhalt wieder. Dann die neuste Beta und schon wieder das gleiche Problem. Hat den hier keiner die gleichen Sorgen oder weiss, ab welcher Firm das noch funktioniert? |
bernd159
#2422
erstellt: 26. Jun 2009, 19:22
Hallo Zusammen Ich habe heute die neue Firmware 1.3.137 eingespielt. seitdem bekomme ich keine verbindung auf dem Fernsehe. Die Verbindung zum Fernsehe ist eine HDMI Kabel. was kann ich hier machen. gruss Bernd |
hkrumb
#2423
erstellt: 26. Jun 2009, 21:51
TV OUT Taste der Fernbedienung drücken ...so oft ,bis was zu sehen ist |
Strider
#2424
erstellt: 26. Jun 2009, 23:02
Hi, das Netzwerk Problem hatte ich auch - sobald ich eine Firmware neuer als 1.3.110 eingespielt habe, war nach einer Weile weder mit SMB noch über den NFS Sharing Client ein Zugriff auf meinen NAS-Server möglich. Und das obwohl der Ping erfolgreich war... Also: mit Firmware 1.3.110 sollte es gehen. |
bernd159
#2425
erstellt: 27. Jun 2009, 08:34
Danke für deine Hilfe nun geht es es wider. Ist das normal das alles Einstellung weg sind nach Firmware neue einspielen ? Frage kann man die Einstellungen über eine webinterfaces machen oder hat der gar keins gruss Bernd
Strider
#2426
erstellt: 27. Jun 2009, 14:20
Webinterface is nich, der Dvico ist ein Standaloneplayer mit LAN-Anschluss, kein "Network Entertainer" wie z.B. Netgears EVA. Mit den Einstellungen ist das so eine Sache - bei manchen Updates bleiben sie erhalten, bei anderen wieder nicht - Dvico hat da irgendwie keine klare Linie... [Beitrag von Strider am 27. Jun 2009, 14:24 bearbeitet] |
Kaspa
#2427
erstellt: 05. Jul 2009, 19:28
Hallo, weiß jemand, ob es die Möglichkeit gibt die Festplatte zu verschlüsseln oder nur den Passwortschutz für die einzelnen Ordner? |
Chase
#2428
erstellt: 07. Jul 2009, 08:06
@ Kaspa, soweit ich weiß geht das nicht. Hab zumindest noch nichts darüber gelesen. Aber vielleicht mit einem Zustaztool für den Dvico. |
nyfedex
#2429
erstellt: 10. Jul 2009, 10:39
Hallo, ich bin neuerdings auch Besitzer eines TVIX M-7000 und bin eigentlich wirklich positiv von dem Gerät überrascht. Ein Problem lässt sich leider aber auch nach Upgrade auf die neueste Firmware nicht lösen. Ein Großteil der Audiodaten, die ich überspielt habe, dröhnen beim abspielen übder die Box. Im Prinzip klingt das so wie zur alten Kassettenzeit, wenn man die Aufnahme total übersteuert hat. Es handelt sich hierbei nicht um einzelne Dateien sondern um so ziemlich alle Lieder, die z.B. mit .wav und .mp3 sowie auch PCM files aufgenommen wurden, eigentlich alle in sehr hoher Qualität (mp3 immer 320 kb). Wenn ich die Songs vom Laptop in die Anlage einspeise oder direkt über Laptop höre sind sie einwandfrei. Auch spielt die Box jegliche Videos absolut fehlerfrei, auch im Ton, angeschlossen über Digitalkabel wie auch Analog. Nur bei Audio dateien kommt dieser Fehler über den analogen wie auch digitalen Ausgang. Hat vielleicht jemand eine Idee woran das liegen könnte? danke im Voraus. Viele Grüße |
MiLie
#2430
erstellt: 10. Jul 2009, 14:11
hallo, auch bei mir sind die mp3 wesentlich lauter als die videofiles, aber mit runternehmen der Lautstärke am tivx geht es gut. |
kleinschreiber
#2431
der Tvix hat eine eigene Lautstärkenregelung. Klingt so als wenn sie bei dir am Anschlag steht. Dreh sie mal in die Mitte. Audio klingt sehr sauber bei meinen 320 MP3s |
tim631105
#2432
erstellt: 10. Jul 2009, 18:48
Hi Was der unterschied zwischen der 147er und der Firmware 1.3.148 09/07/2009 (BD-Lite Edition) Für was steht das Lite ? |
LOURO70
#2433
erstellt: 10. Jul 2009, 20:59
Es gibt wieder neue Firmware, sogar zwei Firmware 1.3.148 09/07/2009 (BD-Lite Edition) Firmware 1.3.147 09/07/2009 (Regular Edition) klickCHANGELOG: Changes from 1.3.129 TViX HD M-6500 1.3.147/1.3.148(UJuckbox) Release note audio playlist Manual 1) Added the Audio playlist function (* Please download the detailed guide for the audio playlist function) - Select multiple songs that you want to listen and save them as a playlist conveniently (to be saved in Audio/Playlist folder) - When pressing ¡®Audio¡¯ key on the remote, it will move to the Audio/Playlist folder automatically - Listen to music without TV or display ¡¤ When setting Autorun in setup, the first playlist in the Audio/Playlist folder will be played automatically unless there is autorun folder. 2) Contents native resolution output function has been Added (Please read below carefully before use the Native resolution feature. If a user do not set resolution correctly, the video may not be displayed or I might hurt display. Please use this function with caution) 2-1) Native Resolution menu on "SET UP" - If a user turns on Native Resolution on the Setup-Video/Audio, the Auto NTSC/PAL/24Hz option will be disabled and will not be used. The NTSC/PAL/24Hz option will be functional if and only if Native Resolution is turned off. - When a user turns on Native Resolution, a popup, will be shown. the user can select native content resolution output he want ¡¤ Users can turn on and off for the each resolution. ¡¤ If the user turns on, the check box will be checked and when a video file is played, the source will be output according to the resolution and scan type(progressive/interlace) regardless of the current TV out setting. ¡¤ If the user turns off, the source will be scaled to the resolution and refresh rate set by the TV out setting in SET UP menu. ¡¤ If the user¡¯s display device does not support specific input mode, users will not see any video. In this case, just press stop and the video output mode will go back to the initial mode on the SET UP menu.. ¡¤ For the 720p, we separated the mode to "720p24Hz" and "1080p24Hz", since most display devices do not support 720p24Hz mode. If users displays do not support neither 720p24Hz nor 1080p24Hz, users will not be able to see 24Hz video clips. 2-2) Resolution change popup - If TVIX does not detect resolution and frame rate correctly, the Native Resolution will not work properly. In this case, users can press TV Out button while video clips are played. They can change to a specific output mode by selecting correct resolution and frame rate. - TV out button will show the Resolution change popup if the video clip is playing. Otherwise, it will change the Video mode NTSC->480p(DVI)->PAL->576p(DVI) for the a emergency recovery.(If a user use HDMI, a user must reset set video output mode on the using SETUP menu, otherwise, audio will not be sent over HDMI) Available frame rate(refresh rate) table for each resolution 480i 59.94Hz, 60Hz 576i 50Hz 480p 59.94Hz, 60Hz 576p 50Hz 720p 23.976Hz, 24Hz, 29.97Hz, 30Hz, 50Hz, 59.94Hz, 60Hz 1080i 50Hz, 59.94Hz, 60Hz 1080p 23.976Hz, 24Hz, 29.97Hz, 30Hz, 50Hz, 59.94Hz, 60Hz 3) Audio play besides audio playlist function - Fixed the shuffle function for autorun in setup - Supports M4A extension 4) Video playing - Provides page up/down function with |<<,>>| keys on the remote for the audio/subtitle/chapter pop-up - Rebooting problem when playing mkv that includes the vob subtile has been fixed. 5) Network - Support for deleting files on network folder has been added (*Netshare isn¡¯t supported) - Improved NFS speed (High bit rate movie will play better even with 10/100 connection ) ¡¤ In case you have problem with 1G LAN, we recommend to use 10/100M mode. (1G option may or may not work better than 10/100M mode depends on the network environment) 6) UJukebox - External subtitle when playing ISO file is supported but the name of subtitle should be same as the ISO file TViX can show two different subtitle in at the same time when selecting the external subtitle. - Position of internal subtitle can be adjusted. How to : After pressing the subtitle key on the remote, while the subtitle mode OSD is shown, press the up/down key on the remote (for internal/external text subtitle, after pressing the subtitle key on the remote, you can adjust the position and size of it as well) 7) Etc - Improved UI : appearance of some icons have been enhanced. - Keeps separate BCS value according to output Hz (23.976, 24, 25, 29.97, 30, 50, 59.94 and 60Hz) - Known issues for Video related - Some TP/TS information may not correct. - When HD Audio pass-through is on, S/PDIF does not output. - When HD Audio pass-through is off with HD audio stream, the playback is not smooth. * When DTS audio setting is digital, HDMI audio is ON and HD audio passthrough is set to ON, then audio is not heard on the SPDIF output. * For the same setting, if HDMI audio is set to OFF, then audio is HEARD on the SPDIF output. - Some TP/TS files may cause the system rebooting. - Some WMV may not play correctly. - The digital output for AAC/WMA is disabled. - Does not support PCM audio track on MP4 now. - Some low sampling frequency on AVI and MKV may not sound on HDMI. - Some MKV with AAC may not sound. - Known issues for Audio and pictures playing - For MP3 files with low sampling frequency, the TVIX might crash while playing or trick play like FF or RW. - Known issues for PVR - After channel changed, you may not here audio in short time. This is the bug from the chip manufacturer. To solve this, you can press DTV key or Audio key on the remote. - Known issues for general issues. - If you play files without refreshing the file list after delete files through FTP or SAMBA server, the system will reboot. |
Chase
#2434
erstellt: 11. Jul 2009, 05:23
Super, neue Firmware . Sind paar nützliche Änderungen drin! |
Kaspa
#2435
erstellt: 11. Jul 2009, 09:08
Ich hätte mal eine Frage zum täglichen Gebrauch des TVIX 6500 A. Habe vor meine komplette MP3-Sammlung auf das Gerät zu überspielen. Auf meinem Laptop nutzte ich bisher das Programm Helium Music Manager, welches ich auch zur Oragnisation der MP3´s weiterhin verwenden will. Ist es möglich, wenn der Dvivo 6500A am PC angeschlossen ist, das Abspielen der Musik vom PC aus zu starten? Ziel ist es den 6500A an eine Anlage anzuschließen und über den Laptop zu steuern. |
chlodwig_22
#2436
erstellt: 11. Jul 2009, 11:53
Habe gerade update auf Version 1.3.147 gemacht und nach einlesen boot und loading abwechselnd auf und das wars. Was kann man tun um eine intakte FW-Version aufzuspielen! Bitte um Hilfestellung! |
chlodwig_22
#2437
erstellt: 11. Jul 2009, 12:27
Habe über Notstart und Setup-Taste festhalten wieder eine intakte FW aufgespielt. Hoffe Aktualisierung auf 1.3.125 klappt. War bis jetzt damit zufrieden. An der neuen reizt micht die Playlist für Audio. Aber safety first! |
MiLie
#2438
erstellt: 11. Jul 2009, 13:49
hallo, war wohl nix mit der neuen Software fragt nach ob er Playlist speichern soll, meldet das er gespeichert hat - speichert aber nichts (oder irgendwohin, wo man es nicht wiederfindet )fast 50% der MP3 bricht er mitten im Tittel ab und fängt den nächsten an normal das Verzeichnis "runterspielen" geht garnicht mehr, will immer Playlist machen. videos dei er immer gespielt hat spielt er plötzlich nicht mehr, meldet unbekannte Fileformat andere Viedeos die 16:9 sind spielt er plötzlich 4:3 ![]() (OK zoomtaste tut es, ging aber vorher) automatische Umschaltung (Pal/NTSC) macht er nicht mehr richtig - schönes ruckeln oder manuell umschalten |
Devine72
#2439
erstellt: 11. Jul 2009, 17:06
kann ich bestätigen hab ähnliche Probs wird zu Teufel nirgends eine Playlist gespeichert Im Ansatz ne gute Idee, wo ich auch seid längerem drauf gewartet habe, nur die umsetzung ist wohl echt bescheiden gelaufen Ob die da bei Dvico überhaupt was testen bevor Sie die User damit befeuern ![]() ps. die Playlist Funktion kann man im Setup deaktivieren [Beitrag von Devine72 am 11. Jul 2009, 17:07 bearbeitet] |
MiLie
#2440
erstellt: 12. Jul 2009, 09:37
hallo, musste gestern feststellen, dass er Probleme mit MP3 macht, bei längeren mp3s ( stunde oder so) fängt er plötzlich nach ca 10 - 15 min an die Mp3 "kaotisch" abzuspielen. Das klingt dann als wäre es übesteuert und zuätzlich wie Echo, ist nix mehr zu verstehen. Man muss dann Pause drücken und wieder Play und dann klingt es für die nächsten 10-15 min wieder normal. werde wohl zurückspielen. |
dmstender
#2441
erstellt: 12. Jul 2009, 12:50
Auf diese Native-Resolution Funktion warte ich ja schon lange, aber so ganz zu funktionieren scheint sie nicht: Bei normalem DVD-Material (wohl 576i) kommt auf meinem TV kein Bild :-( Funktioniert das bei irgendjemandem? |
Chase
#2442
erstellt: 18. Jul 2009, 05:13
Hab gestern mal mit dem Tivx ein paar DTS-Audio Tracks angehört. Als der Wechsel zu nem anderen Lied war drückte ich in diesem Moment auf Stop. Könnte aber auch aus Versehen eine andere Taste gewesen sein. Da kam dann eine Einblendung ob ich eine "m3u" Playlist erstellen will. Wusste gar nicht dass so etwas integriert ist. Wie kann man diese Funktion denn auf normalem Wege aufrufen. Es ist die neueste Beta Firmware drauf. |
MiLie
#2443
erstellt: 18. Jul 2009, 08:56
ich habe sie wieder ausgeschaltet, mein Ferseher meldete bei einigen Filmen " nicht unterstützte Auflösung", habe es nicht weiter verfolgt. |
MiLie
#2444
erstellt: 18. Jul 2009, 16:57
hallo, also ich bin jetzt fast so weit, das Teil einzupacken und zurückzuschicken, jetzt kann man ja nichteinmal mehr Dateien drauf kopieren ( über Netzwerk). mit jeder neuen Sotware geht definitiv weniger, langsam grenzt das schon an Frechheit, was di da anbieten. |
Chase
#2445
erstellt: 19. Jul 2009, 07:19
Hallo Leute, es gibt wieder eine neue Firmware (1.3.150 - BD Lite Version). Es sollten mehrere Bugs beseitigt sein, die mit den vorherigen Versionen aufgetreten sind. Hier der Downloadlink: http://demod.dvico.com/TVIX/6500/tvix_M-6x00_1.3.150.fwp.zip |
Eifel-Elch
#2446
erstellt: 19. Jul 2009, 09:04
Hi Leute, ich sehe, dass hier doch einige sich intensiv mit dem Teil befassen. Mal sehen, was Ihr hierzu sagt: In unregelmäßigen Abständen, auch unabhängig von der Firmwareversion, habe ich manchmal einen - ich nenne es mal so - Ziehharmonika-Effekt an der rechten Bildseite. Das heißt, das Bild fängt an seitwärts zu zittern. Das beginnt erst mit einem schmalen Streifen und erweitert sich dann bis zur Bildmitte. Heute hab ich es mal weiterlaufen laufen lassen, und irgendwann war der Bildschirm dunkel. Zu beheben ist das nur durch einen Neustart des 7000er. Angeschlossen ist der Bildschirm per HDMI. Der Ton hat dadurch keine Beeinträchtigungen (optischer Anschluß). Habt Ihr dafür ne Erklärung? Aktuell hab ich die 137er Firmware drauf und bin recht zufrieden. Nur die Netzwerkgeschwindigkeit ist mir was zu langsam (hab nen Speedport 100 als WLAN dran). Streamen von HD-Material geht nicht ohne Probleme .Auch mit dem TVIXIE komme ich recht gut klar, ich hab das nur noch nicht mit den Unter-Unterordnern hingekriegt... Gruß |
MiLie
#2447
erstellt: 19. Jul 2009, 09:09
Hallo, kann ich nicht bestätigen, die Samba-Funktion ist nicht Fehlerfrei, der tivx ist zwar zu sehen, man kann aber nichts kopieren, bei größern Dateien bricht er weg, (Fehler Windows: Netzwerkverbindung steht nicht mehr zur Verfügung,bei Vista bleibt der Explorer hängen). ich habe aber festgestellt dass es jetzt ein Ikon für Mediaserver gibt, dieser scheint sogar zu funktionieren, zumindest hat er die Medienfreigabe vom WMP11 sofort erkannt und spielt dessen Playlisten. |
burnett000
#2448
erstellt: 19. Jul 2009, 11:11
Hab nun mal die neueste FW also die 150er drauf gespielt. Geht alles einwandfrei. Habe aber nun noch nen zusätzlichen Button Media Server dabei. Wie kann man den benutzen? über LAN? [Beitrag von burnett000 am 19. Jul 2009, 11:11 bearbeitet] |
MiLie
#2449
erstellt: 19. Jul 2009, 11:40
Mediaserver ist ein Dienst der Mediendateien anderen zur Verfügung stellt (über LAN) da gibt s verschiedenene Software in Netz. Windows Mediaplayer ab Version 11 bietet diesen Dienst auch an. unter Medienbibliothek gibt es den eintrag Medienfreigabe, gebe dort deine Medien für das Netzwerk frei. Kurz darauf sollte dein Divx unter Medienserver die Freigabe anzeigen, gehts du dort drauf kannst du z.B. die Playlisten, die du im Mediaplyer gespeichert hast abspielen |
Slayer_1983
#2450
erstellt: 19. Jul 2009, 16:42
Das Bildzittern und dann schwarzbild hab Ich damit wegbekommen, dass Ich HDMI Audio Ausgeschaltet habe. |
Achim***
#2451
erstellt: 20. Jul 2009, 20:31
Hallo, ich bin neu hier. Habe jetzt eine Kamera die AVCHD aufnimmt und will das nun auch entsprechend auf den Beamer bringen. So bin ich auf den TViX M-6500A gekommen. Gefällt mir ganz gut nur konnte ich noch keine Antwort auf diese Frage bekommen: Kann man das Gerät auch ohne angeschalteten Fernseher vernünftig bedienen? Reicht die Info auf dem eingebauten Display dazu aus? Ich habe kkeine Lust bzum Musik auswählen und abspielen immer den fernseher an zu schalten. Kann mir jemand dazu eine Auskunft geben? Vieleicht ein paar Bilder von Display in Aktion? Freue mich auf Antworten Gruß Achim |
lokmotive
#2452
erstellt: 21. Jul 2009, 10:26
Hallo Bei der Firmware 1.3.137 habe ich an beiden USb anschlüssen keine Ordnerstruktur mehr nur das Hintergundbild (ist mir bei anderen Versionen auch schon passiert) , wenn ich auf die Firmware 1.3.110 Boote funktioniert es wieder.Ich hätte aber gerne eine neuere drauf weiss wer einen Rat, oder kennt wer das Problem? Danke im Vorraus |
Dfxtreme
#2453
erstellt: 21. Jul 2009, 11:42
hab das auch. Wenn ich die Festplatte anschalte wenn der Player schon hochgefahren ist geht es komischerweise. |
dabommel
#2454
erstellt: 22. Jul 2009, 20:52
Hatte das auch beim Umschalten der USB Ports. Mit der FW 1.3.150 tritt es aber nich mehr auf. |
zGas
#2455
erstellt: 23. Jul 2009, 11:27
Chase
#2456
erstellt: 23. Jul 2009, 18:52
@ zGas, aber das ist doch die gleiche wie schon vor mehreren Tagen raus kam, oder? Also zumindest gibt's schon ne 1.3.150 Version. |
dabommel
#2457
erstellt: 24. Jul 2009, 16:46
LANDOS
#2458
erstellt: 24. Jul 2009, 19:26
Hi, momentan macht mein Dvico 6500er ein wenig Effekte. Er ruckelt bei normalen Divx, wo er normal nie Probleme hatte. Desweiteren ist die Display Anzeige sehr dunkel geworden. Ausgelöst wurde dies durch auschalten mittels Steckerziehen? Ja ich weiß, behämmert was man manchmal tut. Welche Firmware ist momentan die empfehlenswerteste. Gruß ausm Ruhrpott |
zGas
#2459
erstellt: 24. Jul 2009, 22:38
Funktioniert bei Euch die Funktion "Native Resolution", die mit 1.3.147 und 1.3.150 mitkommt? Mein Menü lass ich in 1080p (Video Out Mode: Auto EDID) anzeigen, aber ein DVD.iso spielt er sichtlich an (Counter läuft) bringt aber nur ein schwarzes Bild. Nachtrag: die 1.3.158 verhält sich genauso... [Beitrag von zGas am 24. Jul 2009, 22:52 bearbeitet] |
zGas
#2460
erstellt: 25. Jul 2009, 13:36
Hab gerad gelesen, dass DViCo den Nachfolger TViX M-6600 um September herausbringen wird auf Basis eines Realtek-Chips.
Quelle: http://www.mpcclub.com/modules.php?name=News&file=article&sid=793 |
Der Dvico TVIX M-6500A/7000 Sammelthread lokmotive am 30.05.2008 – Letzte Antwort am 30.05.2008 – 2 Beiträge |
Der Dvico TVIX M-6500A/7000 Gestaltungs-Thread zGas am 03.09.2008 – Letzte Antwort am 27.04.2010 – 177 Beiträge |
DVICO 7000 (TVIX HD M-7000) kambanis am 17.01.2010 – Letzte Antwort am 01.08.2010 – 2 Beiträge |
Dvico TVIX M-6500A/7000 mit HD Ton? ice2man am 17.08.2008 – Letzte Antwort am 21.08.2008 – 14 Beiträge |
Dvico TVix 6500A DVD-Laufwerk anschliessen? sarotti67 am 24.09.2008 – Letzte Antwort am 17.03.2009 – 8 Beiträge |
Der Dvico TViX M-5100SH bzw. M-4100SH Sammelthread diba am 23.03.2007 – Letzte Antwort am 09.11.2010 – 1076 Beiträge |
Unterschied zwischen DViCO TVIX M-5100SH und M-6500A Dfxtreme am 19.09.2008 – Letzte Antwort am 21.09.2008 – 7 Beiträge |
Dvico Tvix 6500A an PC anschließen Dfxtreme am 07.10.2008 – Letzte Antwort am 08.10.2008 – 9 Beiträge |
BlueRay Files auf Dvico TVIX M-6500A abspielen. LOURO70 am 20.02.2008 – Letzte Antwort am 21.02.2008 – 3 Beiträge |
Coverbilder bei TViX M-6500A Tikey51 am 03.03.2008 – Letzte Antwort am 03.03.2008 – 2 Beiträge |
Top 10 Threads in Multimediaplayer der letzten 7 Tage
- Amazon Fire-Tv Stick und LG OLED55CX9LA
- HI RES Streaming über QOBUZ
- INNUOS ZENmini - ZEN - ZENith -Pulse Serie - Roon Erfahrungsaustausch
- Noxon iRadio 400 keine Internetsender mehr
- Lösung der DENON WLAN Probleme
- Pioneer N-70AE / N-50AE / N-30AE
- Bluesound VAULT 2i
- Kodi v20 KEINE MKV Dateien & erkennt Bibliothek nicht mehr auf Nvidia Shild
- Anleitung für DUMMIES: Audiophiler Raspberry Selbstbau Low Budget Musikplayer/-streamer
- Audio Netzwerkplayer was bringts?
Top 10 Threads in Multimediaplayer der letzten 50 Tage
- Gesamtzahl an Beiträgen21.838.914
