| HIFI-FORUM » English » DIY (Engl.) » Sachiko speakers done | |
Sachiko speakers done+A -A |
quadtech
erstellt: 11. Jun 2009, 11:33
Folks, Just completed building my pair of Sachikos with Fostex FE206E drivers. They are the first speakers I have built, and in fact, my first significant carpentry work too. The drivers have just a couple of hours on them, but they sound pretty good. An excellent design by Scott Lindgren (scottmoose). I built them with marine ply, and finished with a walnut stained polish and a couple of coats of Touchwood (clear polyurethane). Used Fevicol glue. As I didn't have any clamps, used screws to hold the joints close, or some heavy stones. The source is an old Koss DVD player and the amp is the LM3886 Mauro Penasa design I posted earlier. Speaker cables made from Cat 5 cable. I am waiting for the drivers to get broken in (min of 150 hours suggested for the Fostex FE206E), so I can tweak the amount of stuffing in the driver chamber. Here is the photo build log. http://picasaweb.google.com/prasadb/Sachiko#Prasad |
Soundsgreat
erstellt: 11. Jun 2009, 12:57
Hi, Looking very good ! Congrats on a fine build !! did you manage to all or hired a carpenter for help ? in any case job well done !!By now how many hours the Amp themselves have ?? coz that will contribute to the overall sound ! The design is a solid one ! and should give a exemplary results !! Btw I would strongly recommend against using the CAT5 speaker cable that you are using now ! Regards. |
quadtech
erstellt: 11. Jun 2009, 14:42
Thanks!
The polishing was done by a painter. Everything else, I managed to do. Lots of learning along the way, including even how to use the power circular saw. Had some help from a relative of mine, which was really a god send. It is hard to do this size/complexity of speaker alone. If I ever build another speaker, I will get the ply sheets cut on a good table saw. This gives very precise cuts. I should say my diy rip fence was not very accurate - partly my fault, as my first cuts were my very first time using a power saw. Made mistakes.
I hardly used the amp after making it. So it might have max about 5 to 10 hours on it. I am curious about your comment on Cat5 cables. Lots of people on the net seem to recommend it. Anyway, will try to get hold of some good (not Monster!) cable and try. Prasad [Beitrag von quadtech am 11. Jun 2009, 14:44 bearbeitet] |
Soundsgreat
erstellt: 11. Jun 2009, 15:56
Hi, Good to hear the details ! yeah doing all alone is not an easy task,especially if you are in India, where for the smallest thing you have to die to procure it !! it surely is a learning process !!Yeah Buddy on contrary to what they say,I have made the speaker cables with the said CAT5 cable and was not very impressed with the sound ! The lowend was a major disappointment and was less as much as 30% compared to a standard cable !! The highs were the only thing that was acceptable to me with these cables ! Not only me I have seen some of my friends try and have the same result ! its partly coz of the default braiding pattern and the shielding,I even pulled all the wires from the CAT5 and individually braided them and checked the results,although it was better then the stock but still nowhere close to ideal ! another major issue with these type of cables are the capacitance,they are very high in them and hence some of the Amp may oscillate due to this !! So with all the above experiment I suggested you !! I have done many such speaker cable projects and have been able to Beat CHORD Silverscreen and other on a one to one comparison test !! So I do have some experience when say this !! Regards. [Beitrag von Soundsgreat am 12. Jun 2009, 05:33 bearbeitet] |
Gelscht
Gelöscht |
erstellt: 18. Jun 2009, 03:33
Hi, During a recent trip to Hyderabad,I had the pleasure of listening to Prasad's(Quadtech) speakers and his KT77 based amp. First off the quality of his workmanship is top notch. The sound quality of his set up despite the limitations of the front end(a portable CD/DVD player) is very good. Though the speakers are over six feet tall they do not take up a lot of floor space and the foot print is not too big. The double horn loaded cabs give the added weight and solidity to the bass which is often lacking in smaller cabinets using similar drivers. The bass is fast and tight without any overhang or blurring. Vocals are to die for and the midrange simply gorgeous.The highs are smooth and to my ears the extention seemed OK,but others might find it a little rolled off. This system is very musical and involving.I stopped trying to listen for flaws and just enjoyed myself listening to the music. It was a pleasure meeting with Prasad and listening to his lovley system. Regards Rajiv |
quadtech
erstellt: 18. Jun 2009, 04:00
Rajiv, Thanks for posting your impressions and the kind words on my work. It was a pleasure to have you here and get your feedback. My next task is to work on the limitations of my setup - frontend, speaker cables etc. Prasad |
Amp_Nut
erstellt: 18. Jun 2009, 09:47
CONGRATS ! Quadtech. For Whatever Its Worth, my personal experience ( contrary to gut feel) is that Interconnects influence the sound much more than Speaker Cable. I would suggest addressing the Interconnects, before the Speaker Cables.... |
ragadaz
erstellt: 11. Feb 2017, 23:48
Hi Quadtech, I'm looking for the plans for the Sachiko speakers. How did you get them! Could you send me some links? By the way congrats, great speakers! |
quadtech
erstellt: 21. Mai 2017, 07:45
sorry for the late reply. The plans are available from diyaudio.com site They are designed by scottmoose |
Inside instead of Outside! Neutral am 09.10.2006 – Letzte Antwort am 11.10.2006 – 11 Beiträge |
My new DIY headphones Savyasaachi am 25.01.2009 – Letzte Antwort am 15.05.2011 – 6 Beiträge |
75 ohm terminator on digital out of cdp/dvd player Manek am 01.03.2009 – Letzte Antwort am 11.03.2009 – 6 Beiträge |
First tube amp.help a rookie? Savyasaachi am 27.02.2009 – Letzte Antwort am 23.03.2009 – 36 Beiträge |
My DIY Interconnects ! Soundsgreat am 29.04.2009 – Letzte Antwort am 17.01.2010 – 10 Beiträge |
Coupling and bypass Capacitors? Savyasaachi am 04.06.2010 – Letzte Antwort am 08.03.2011 – 10 Beiträge |
DIY. Simple Back Loaded Horn project with vintage BOLTON drivers aks07 am 12.10.2008 – Letzte Antwort am 24.12.2008 – 27 Beiträge |
DIY Dome Tweeter ? Soundsgreat am 30.03.2009 – Letzte Antwort am 22.04.2009 – 17 Beiträge |
Bought my first tubes.now need an amp to put them in Savyasaachi am 09.02.2009 – Letzte Antwort am 11.02.2009 – 5 Beiträge |
Volunteers needed for listening test sivat am 30.08.2007 – Letzte Antwort am 17.10.2007 – 33 Beiträge |
- Registrierte Mitglieder930.657 ( Heute: 3 )
- Neuestes MitgliedCornwald
- Gesamtzahl an Themen1.563.431
- Gesamtzahl an Beiträgen21.825.139
