| HIFI-FORUM » English » DIY (Engl.) » Experiments with Finolex | |
Experiments with Finolex+A -A |
Manek
erstellt: 30. Apr 2007, 06:45
Hi all, Been playing around with finolex and other brands of wires to make DIY power cords..... One very nice revelation.....for cdp's and preamps....surprisingly the finolex 1.5sq mm 3 wire braided config works exceedingly well...and dirt cheap ! its only when one uses power amps or integrateds does 4 sq mm really make a bit of a difference. Polycab is a no no on all counts ! Have tried other local shielded(lam road) 3 core wires as well but are of no use. Even the thicker variety 4-6 sq mm sounds the same as a stock PC. Wish finolex made solid core wires.... Anyone know of solid core mains wires made by local companies with good copper quality ? Manek. |
Amp_Nut
erstellt: 30. Apr 2007, 07:36
Hi Manek, VERY interesting. Can you provide details of how you made the mains cable with finolex 1.5sq mm 3 wire braided wire > Is this a braided mains cable ? Where did you buy it ... Lohar Chawl or Lamington Road ? Did you strip the external sheath and plait the 3 braided wires ? Thanks for sharing. |
Manek
erstellt: 30. Apr 2007, 09:30
hi ampnut... finolex cable of 1.5 sqmm was bought from a finolex cable dealer, kemps corner, single wire(multi stranded). IEC plugs(elcom) and brass 3 pin plugs. I took 3 lengths of 2 mts each and braided them, each braided twist is approx 1 cm in length. very balanced presentation is what I found. dont expect it to change things drastically ! The 4 sq mm works a shade better with p-amps/integrateds. enjoy. manek. |
Amp_Nut
erstellt: 30. Apr 2007, 10:14
Hi Manek, 1. When you say 'Braided them" are you referring to plaiting them as what women do their hair ? 2. Or are you referring to getting a thin wire mesh / shield put around each wire... as done in shielded wires ? Thanks P.S: If you are referring to 1. above, and since you are anyway using Multi strand wire, maybe you can try with OFC speaker cable available at Lamington Road ? I guess the OFC will be pretty high purity copper. |
Manek
erstellt: 30. Apr 2007, 14:43
Tried number 1. good results for the price tried number two as well but with a single tin braided shield over all three wires with shield connected at the wall plug end to earth. both gave near similar results. Now I want to try good quality solid core. i tried the local variety solid core(used as earthing wire in homes) and it was as good as 1. BTW, I did think of using OFC spkr wire but most of the insulation is good for just around 250 volts...very dicey i would think. BTW I really wonder if most of the spkr wire available at lam road is "OFC"???. BTW I did check a few high end spkr cables to see thier insulation properties and the highest was 280-300V. I thought I was playing with fire. Manek. |
Manek
erstellt: 30. Apr 2007, 16:48
Ah yes.... I also tried a twisted pair config for line and neutral with a separate earth wire....that seemed to work better but havent tried that with the finolex wires. Thats next. Manek. |
75 ohm terminator on digital out of cdp/dvd player Manek am 01.03.2009 – Letzte Antwort am 11.03.2009 – 6 Beiträge |
More tube projects on the starting block Savyasaachi am 24.03.2009 – Letzte Antwort am 11.03.2010 – 31 Beiträge |
Inside instead of Outside! Neutral am 09.10.2006 – Letzte Antwort am 11.10.2006 – 11 Beiträge |
My new DIY headphones Savyasaachi am 25.01.2009 – Letzte Antwort am 15.05.2011 – 6 Beiträge |
Upgrading Clock , I/V stage and regulators on a DAC Savyasaachi am 19.01.2009 – Letzte Antwort am 25.01.2009 – 21 Beiträge |
Coupling and bypass Capacitors? Savyasaachi am 04.06.2010 – Letzte Antwort am 08.03.2011 – 10 Beiträge |
DIY Dome Tweeter ? Soundsgreat am 30.03.2009 – Letzte Antwort am 22.04.2009 – 17 Beiträge |
My DIY Speaker Cable ! Soundsgreat am 29.03.2009 – Letzte Antwort am 30.03.2009 – 4 Beiträge |
DIY : Design of a Rack sivat am 27.09.2007 – Letzte Antwort am 04.10.2007 – 7 Beiträge |
My DIY Interconnects ! Soundsgreat am 29.04.2009 – Letzte Antwort am 17.01.2010 – 10 Beiträge |
2007
Top Produkte in DIY (Engl.)
- Registrierte Mitglieder930.976 ( Heute: 1 )
- Neuestes Mitgliedkingeradon
- Gesamtzahl an Themen1.564.327
- Gesamtzahl an Beiträgen21.850.518
