STEG 4.01 AMP +PHD FB 6.1 KIT PRO - WIE SOLL ICH DIE STEG AM BESTEN EINSTELLEN? (schreibt Deutsch)
adeo
#1 erstellt: 16. Jul 2012, 23:43
Hi all!
STEG K 4.01 einstellungen mit diesen PHD babies:
http://www.phd.it/welcome_to/speakers/fb61pro_kit.asp
PRO FIRENZE
6,5" Triple Layer Fiberglass Cone/Bass Driver;
1" Fiberglass/Silk Dome Neodymium Tweeter;
12dB Two Way Passive Crossover;
Power Handling RMS/MAX:
150/300 Watts
Sensitivity (SPL@1W):
92dB
Frequency Response:
40Hz - 20Khz
I have a question, I have installed my new PHD FB 6.1 KIT PRO with the STEG 4.01 AMP as you see on the attached link. I would like to SET up the STEG as perfectly as it gets but still I am not sure about some things I have read in the manual!
Manual p.27-29...
http://www.audio-sys.../STEG_USRMAN_4CH.pdf
Questions - the filtereffect on the STEG - there are 2 possibilities - AQXM2, for the four way connection with the frequnce modules (since I do not have them and use crossovers from the PHD speaker Kit - I regard them as unnecessary) or SW4FQ - there are the 60,80,100,120, what should I turn on to get the best frequency divided sound?
Then there is the filter on/off button - turn off?
And the modes: mode LP - low pass/ HP - high pass?
THANK YOU IN ADVANCE FRIENDS!!
[Beitrag von adeo am 17. Jul 2012, 09:23 bearbeitet]
Bajs
#2 erstellt: 17. Jul 2012, 00:09
Ok, i'm confused, but here goes:
Wenn du das FQ-Modul nicht hast bleibt dir nur die Option SW4FQ.
Das fungiert dann quasi als High-Pass-Filter, der sollte bei 60-80Hz liegen, am besten mal ausprobieren.
Again, to make sure:
Unless you own the frequency-module, you will have to use the "SW4FQ"-setting.
This puts the amp in some sort of "manual"-mode, which enables you to either set high- or low-pass-filters, well...manually.
Since you want to use your front speakers, you need to set a high-pass somehwere between 60-80Hz, depending on which setting u like best.
Falls ich hier Blödsinn geredet habe - kenne die Stufe nicht wirklich, hab mich nur durch die BDA gekämpft - bitte korrigieren.
adeo
#3 erstellt: 17. Jul 2012, 08:37
Ja genau, die Module habe ich nicht also denke ich das die SW4FQ Option die Losung ist.
Ich habe das System in Quadro - also 2x PHD FB KIT vorne und 2x PHD FB KIT hinten. Also alle 4 Kanale sind angeschlossen. Der STEG ist super, die Power unglaublich.
Das heisst dann also, das der Filter AN sein soll oder AUS?
Mode: Hp oder Lp ?
Die Filter habe ich bei 60Hz liegen, kann es aber andern. Is ja logisch das ich den besten sound raushohlen will. Eigentlich will nur die Grundeinstellung hier richtig haben, denn es ist aus dem Manual auch nicht klar wenn was on / off ist
NOCH IDEEN?
M
[Beitrag von adeo am 18. Jul 2012, 10:14 bearbeitet]
Steg 4.01 schaltet ab?
Black-Devil am 02.07.2008  –  Letzte Antwort am 29.08.2008  –  2 Beiträge
Steg K 4.01 & Steg K 2.02 grün leuchtet, rot blinkt
marc226 am 01.10.2012  –  Letzte Antwort am 01.01.2013  –  10 Beiträge
Probleme beim Einpegeln (Steg K 4.01)
raffiSSL am 21.08.2010  –  Letzte Antwort am 25.08.2010  –  6 Beiträge
PHD 4075
The-BuTcHeR am 24.06.2010  –  Letzte Antwort am 24.06.2010  –  2 Beiträge
Brückenbetrieb Steg?
tonci am 26.05.2007  –  Letzte Antwort am 26.05.2007  –  3 Beiträge
FS-Amp Steg K4.01 gegen Steg K4.02 tauschen ?
Abgetz am 27.04.2013  –  Letzte Antwort am 27.04.2013  –  4 Beiträge
Brauche Rat, wie Steg K verkabeln
Darkkosmo am 09.08.2016  –  Letzte Antwort am 10.08.2016  –  15 Beiträge
Steg AQ reparieren!
Pizzaro am 09.06.2010  –  Letzte Antwort am 09.06.2010  –  3 Beiträge
Welche Frequenzmofule ? Steg K
Abgetz am 22.05.2013  –  Letzte Antwort am 22.05.2013  –  2 Beiträge
Steg K2.02 Massefehler
3510maniac am 27.02.2008  –  Letzte Antwort am 20.04.2012  –  52 Beiträge
2012
  • Registrierte Mitglieder930.640 ( Heute: 11 )
  • Neuestes MitgliedBrummkreisel17
  • Gesamtzahl an Themen1.563.391
  • Gesamtzahl an Beiträgen21.824.003
