Unterschied zwischen overhung und underhung?
Nimminger
#1 erstellt: 14. Jan 2010, 12:41
was ist eigentlich der Unterschied zwischen overhung und underhung?
Spielt das eine linearer als das andere?
Oder wie wo was
G
Nimminger
[Beitrag von Nimminger am 14. Jan 2010, 12:42 bearbeitet]
stereodreieck
#2 erstellt: 14. Jan 2010, 12:46
Overhung: Simple past tense and past participle of overhang.
Jetzt mal im ernst... was meinst Du damit und worauf beziehst Du das?
stereodreieck
#3 erstellt: 14. Jan 2010, 12:53
...folgendes habe ich dazu im Web gefunden:
Overhung & underhung coils
The image above shows two ways in which the voice coil is immersed in the magnetic field. The most common method is the overhung design where the height of the voice coil is greater than the magnetic gap's height. The underhung design which is used mostly in high-end speakers has the coil's height smaller than the gap's. The differences, advantages and disadvantages of both methods are given in the table below.
Overhung coil Underhung coil
• Coil height is greater than the gap's height. • Gap's height is greater than the coil's height.
• This method keeps the number of windings within the magnetic field (or flux) constant over the coil's normal excursion range. • This method keeps the magnetic flux that the coil experiences, constant over the coil's normal excursion range.
• Higher coil mass, sensitivity medium to high.‡ • Low coil mass, sensitivity low to medium.‡
• Soft non-linearity as the coil exceeds limits. • Hard non-linearity as the coil exceeds limits.
Both topologies attempt the same goal: linear force acting on the coil, for a driver that reproduces the applied signal faithfully.
stschroeder
#4 erstellt: 14. Jan 2010, 14:54
Nimminger
#5 erstellt: 14. Jan 2010, 16:31
Danke Männers
Unterschied zwischen Bose Acoustimass / Lifestyle
subsonic123 am 03.05.2010  –  Letzte Antwort am 05.05.2010  –  5 Beiträge
Unterschied zwischen Mono & Stereo Anschluss ?
stanko3 am 16.02.2010  –  Letzte Antwort am 16.02.2010  –  3 Beiträge
subwoofer unterschied
vr400 am 29.04.2004  –  Letzte Antwort am 29.04.2004  –  3 Beiträge
Unterschied Downfire und Frontfire!
trice am 02.10.2007  –  Letzte Antwort am 07.10.2007  –  17 Beiträge
Was ist der unterschied zwischen Bandpass Subwoofer und normal?
Stefanvolkersgau am 01.02.2004  –  Letzte Antwort am 10.02.2004  –  15 Beiträge
Unterschied zwischen Canton SUB 300 und Canton SUB 12.3
KingofKleinniendorf am 15.03.2018  –  Letzte Antwort am 21.07.2019  –  13 Beiträge
Klipsch SW-110 Unterschied zur Mark2
Lynch47 am 10.12.2013  –  Letzte Antwort am 12.12.2013  –  2 Beiträge
Doppelschwingspule: Unterschied 1x200w zu 2x200w
kampfkaese am 14.02.2017  –  Letzte Antwort am 17.02.2017  –  4 Beiträge
unterschied einschleifen?
-M!sterElement- am 19.03.2007  –  Letzte Antwort am 22.03.2007  –  6 Beiträge
Unterschied Amplifier Mode Auto-High/Low
T1001 am 01.01.2007  –  Letzte Antwort am 27.02.2014  –  11 Beiträge
  • Registrierte Mitglieder930.661 ( Heute: 2 )
  • Neuestes MitgliedNeroNepolus333
  • Gesamtzahl an Themen1.563.449
  • Gesamtzahl an Beiträgen21.825.674
