NEWBIE stick questions
ACQUA
#1 erstellt: 16. Dez 2006, 19:41
Hello,
I'm Acqua,from Belgium and new to this forum.
I'm looking for some speakers for an upgrade of my home cinema system and that's where I can use some help.
I've searched for the Cyburgs Stick's and i wondered if they are any good for using in a 5.1 setup?
The reason I've chosen de Stick's is bicause there easy to make and verry cheap. It's my first time I on this so i will take it easy and cheap.
Can anyone help me with this question?
HerrBolsch
#2 erstellt: 16. Dez 2006, 19:53
Welcome!
I think the Stick will be better than most of the small bricks you get at the electronic discounter.
Although they can can produce rather low frequencies, they are limited to small presure levels because of their small diaphragm. Therefore a subwoofer is highly recommend for home cinema. When using one, I would say the sticks are very good for this applience.
Greets, Hauke
ACQUA
#3 erstellt: 16. Dez 2006, 19:55
thanks for the quick reply,i'm going to build a sub also.
I'll keep my topic up to date for any changes
wolfman2
#4 erstellt: 16. Dez 2006, 22:42
I did build 2 sticks for my brother in Hamburg and he was asking me right away for 3 more because he thought it must be fantastic to use them for sourround.
There even is a stick´s center to be found here on this forum
(i think)
Ok they dont go terribly low but then try it and you will see if that is enough for you. (It sure is for my brother )
let us know what you will do
good luck
wolf
P.S. here you can find the entire Sticky collection
http://mitglied.lycos.de/bauplaene/Bauplaene/Hi-Fi%20Forum.htm
Once there you have to click on
"HIER LANG"
"BASSREFLEX"
"STICK"
If you have any other question just ask - we will translate
[Beitrag von wolfman2 am 16. Dez 2006, 22:52 bearbeitet]
Perrier
#5 erstellt: 17. Dez 2006, 13:10
welcome aqua,
this one:
http://www.hifi-foru...m_id=104&thread=8862
is a 6L BR with the stick-Driver+ Tweeter. Maybe a good variation to the stick. I think it is the better choice for Home Cinema - cause of the better high frequency response. It is not so "sweet spotty".
If you use a Subwoofer, you can close the BR-vent.In this case the stick is a little oversized, and you dont need to force the little driver down 50Hz. That saves a little more dynamic, when the W4 is exempted from low frequencies.
"Uibel" is going to update the stick with the same Tweeter at the moment. So its going to be very easy to update the stick too.
look here (very fresh, and not ready yet)
http://www.hifi-foru...m_id=104&thread=8940
have fun!
W3-871S with tweeter
ACQUA am 20.02.2007  –  Letzte Antwort am 21.02.2007  –  11 Beiträge
Dynamic Pearl speakers
temery am 20.03.2008  –  Letzte Antwort am 22.03.2008  –  4 Beiträge
plus-elektronik.de, any good?
FjendboDK am 31.01.2017  –  Letzte Antwort am 17.04.2019  –  7 Beiträge
DIY Planar magnetic fullrange loudspeaker
WrineX am 12.01.2019  –  Letzte Antwort am 13.01.2019  –  3 Beiträge
Viech mit Bändchen Hochtöner?
Simonix am 06.02.2006  –  Letzte Antwort am 08.02.2006  –  3 Beiträge
Jabo KH50 Horn, experience?
Jacobus am 30.05.2007  –  Letzte Antwort am 31.05.2007  –  3 Beiträge
instead of buying building is better?
josmuck am 23.02.2010  –  Letzte Antwort am 24.02.2010  –  7 Beiträge
filter questions
ACQUA am 21.02.2007  –  Letzte Antwort am 21.02.2007  –  2 Beiträge
Unabhängig messungen von Lautsprecherchassis angesammelt
HiFiCompass am 26.01.2018  –  Letzte Antwort am 11.03.2018  –  7 Beiträge
Visaton horn tweeter.
Valde am 12.03.2011  –  Letzte Antwort am 12.03.2011  –  2 Beiträge
2006
  • Registrierte Mitglieder930.657 ( Heute: 8 )
  • Neuestes Mitgliedhansano715
  • Gesamtzahl an Themen1.563.440
  • Gesamtzahl an Beiträgen21.825.425
Top Hersteller in Lautsprecher Widget schließen
