| HIFI-FORUM » Fernseher & Beamer » Plasma-Fernseher » Muss ein Plasma "eingefahren" werden??? | |
Muss ein Plasma "eingefahren" werden???+A -A |
JohnZander
erstellt: 28. Feb 2005, 12:10
Hallo erst mal! Wie ich in diversen Beiträgen gelesen habe, sind einige der Meinung, dass Displays in den ersten 100-200 Betriebsstunden nicht über die Maßen aufgebrezelt werden sollten (Kontrast/Helligkeit). Ich als newbie kann mir das allerdings nicht erklären. Ist es nun so oder ist dies ein Irrglauben? Falls dies schon mal gefragt worden ist, habe ich es leider überlesen (Thread-Link wäre nett). Sei das Plasma mit Euch! |
smultron
erstellt: 28. Feb 2005, 13:00
Pansonic schreibt dazu: Plasma Break-In Like a fine new automobile, the performance of a plasma TV can be optimized by allowing a break-in period. By properly following these simple break-in instructions, you should be rewarded with long-term enjoyment of your plasma TV. Plasma phosphors are most susceptible to image retention in the first hundred hours of use. The panel becomes considerably less sensitive to burn-in after this period. Very often, televisions, including plasma, are shipped from the factory with the contrast control at a high setting to provide a bright picture under typical dealer showroom lighting conditions. In your home, the room light levels are usually one half or less than that in retail showrooms. The contrast control may need to be lowered in your home for comfortable contrast levels that do not induce eye strain. When the plasma is initially installed, videophiles say it is best to do the following: Make sure the display is in a viewing mode (aspect ratio) that completely fills the screen (there are often three or more settings from which to choose). The panel is shipped in this condition, in what is called the “Just” mode. Turn down the picture control (contrast) to 50% or less. Briefly engage the 4:3 mode to confirm the side bars are set to mid-gray(there is usually an adjustment in the Set Up menu that takes the sidebars from black to gray) to minimize the chance of burn-in. Return the set to a “full screen” (Just, Zoom, Full) position during the first hundred hours of use. During the first hundred hours of use it is best not to view the same channel for extended periods. This should prevent channel logos and other fixed images found on some channels from being retained. Avoid any static images (video games, computer images, DVD title screens, etc.) during the hundred-hour break-in. After the hundred-hour break-in period, during the next nine-hundred hours: Continue to retain the picture setting at 50% or less. Limit the use of 4:3 aspect ratio mode (traditional picture size that does not fill the entire screen) to 15% of viewing time. Limit the use of static images (computer, video games, etc.) to less than 10% of viewing time. After one-thousand viewing hours, panels are much less likely to experience image burn-in. Ich hoffe das hilft Dir weiter. |
JohnZander
erstellt: 28. Feb 2005, 13:11
Jadoch, sehr! Da hätte ich ja fast ein Fehler gemacht. DANKE! Sei das Plasma mit Euch! |
sirmatzel
erstellt: 28. Feb 2005, 13:24
Hey echt super , Danke für das posting ABER WAS IST MIT DEN LEUTEN DIE KEIN ODER NUR SEHR SCHWER ENGLISH LESEN KÖNNEN , wie z.B. auch ich wäre super wenn hier einer mal es kurz und kanpp ein deutschen könnte DANKE , DANKE , DANKE [Beitrag von sirmatzel am 28. Feb 2005, 13:26 bearbeitet] |
JohnZander
erstellt: 28. Feb 2005, 13:39
Also kurz gesagt, das Panel ist in den ersten 100h sehr anfällig. Kontrast nicht über 50% regeln. Am besten die Zoom-Funktion nutzen (keinerlei schwarze Ränder) Oft den Kanal wechseln (So kann sich das Sender-Logo nicht einbrennen) Keine Darstellung von PC-Daten bzw. Internet (über VGA/DVI) Kein Videotext (oder nur selten) In den nächsten 900h: Kontrast nicht über 50% regeln Bilddarstellungen mit schwarzen Rändern (4:3) auf 15% der Gesamtzeit reduzieren Stille Bilder (Computer, Videotext, Videogames) auf 10% der Gesamtzeit reduzieren So, nun noch eine kleine Anmerkung von mir: - Leises "Danke für das schöne Bild" sagen wenn Ihr das Plasma ausschaltet - Wenn keiner kuckt kann man auch mal ein Handküsschen rüberschmeissen (aber nur wenn keiner Kuckt, sonst gilt man schnell als schwer bekloppt . Wichtig!)Sei das Plasma mit Euch! |
JohnZander
erstellt: 28. Feb 2005, 13:48
@sirmatzel Übrigens glaube ich hier noch einen sehr interessanten Link für Dich zu haben: http://babelfish.altavista.com/Da kannst Du die ganze Passage die Du nicht verstehst reinkopieren und Dir übersetzen lassen (mit kleinen Abstrichen / Eine Bank kann nun mal was zum hinsetzen oder ein Gelsinstitut sein). Oder Du läßt Dir gleich ganze Seiten übersetzen! Sei das Plasma mit Euch! |
EiGuscheMa
erstellt: 28. Feb 2005, 15:31
Nicht zu vergessen, dass dieser Panasonic-Artikel schon ein paar Jährchen auf dem Buckel hat und daher für die neuesten Geräte nicht mehr soooo viel Bedeutung hat. Ausserdem werden zumindest die "all in one" bereits eingefahren ausgeliefert ( ca. 150 Stunden ist wohl "normal"). Na trotzdem: "man" macht sicherlich nichts falsch, wenn man sich an diese Empfehlungen hält..... |
smultron
erstellt: 28. Feb 2005, 15:59
Naja, November 2004 ist doch nicht alt, oder? Im selben Artikel wird auch die neue Lebensdauer von 60.000h erwähnt. |
JohnZander
erstellt: 28. Feb 2005, 16:43
Was verstehst Du darunter? |
Anton2000
erstellt: 28. Feb 2005, 18:04
Ein plasma muß ebenso wie eine Röhre eingefahren werden. Sind auch im Prinzip verwandt. Bei einer Röhre sollte die Helligkeit deswegen nicht überzogen werden wegen ungleichmäßigem Elektronenkanonen Abbrand führt zu frühzeitigem Kurzschluß in ihr. Beide besitzen Phoshorleuchtschicht bei Röhre wir mit elektronen erregt und bei Plasma mit UV-Licht: Das heiß Leuchtkraft erst mit den Jahren erhöhen!!!! Wenn Phoshor gut eingefahren (gealtert) dann sind selbst längere Standbilder nicht einbrand gefährdet. Anton [Beitrag von Anton2000 am 28. Feb 2005, 18:20 bearbeitet] |
Plasma oder Rückpro??? akiman am 09.03.2005 – Letzte Antwort am 02.11.2005 – 31 Beiträge |
Plasma? heinzi34 am 27.11.2004 – Letzte Antwort am 26.01.2005 – 14 Beiträge |
Transport Plasma makei81 am 02.11.2005 – Letzte Antwort am 04.11.2005 – 16 Beiträge |
Plasma waagrecht = defekter Plasma ? Buffy am 27.01.2005 – Letzte Antwort am 31.01.2005 – 26 Beiträge |
Plasma 65" Plasma Transport liegend (MUSS!) - wie am besten ? m70537 am 21.02.2015 – Letzte Antwort am 28.07.2015 – 7 Beiträge |
Plasma und ISF kalibrierung coen99 am 27.01.2005 – Letzte Antwort am 05.12.2011 – 7 Beiträge |
Muss ein Plasma unbedingt HD Ready sein ? tk264 am 25.04.2005 – Letzte Antwort am 26.04.2005 – 27 Beiträge |
Plasma-Beleuchtung adios am 26.06.2005 – Letzte Antwort am 26.06.2005 – 4 Beiträge |
MAQMA Plasma allfux am 20.07.2006 – Letzte Antwort am 22.07.2006 – 5 Beiträge |
plasma ibiza am 31.10.2004 – Letzte Antwort am 01.11.2004 – 4 Beiträge |
2005
Top Produkte in Plasma-Fernseher
Top 10 Threads in Plasma-Fernseher der letzten 7 Tage
- Hilfe! TV bekommt vom VHS kein Signal
- Plasma (GW20) transportieren, für stehend Auto zu klein
- Flimmern beim Plasma normal?
- Standbild "Radio" Einbrenngefahr ?
- Plasma geeignet zum Videospielen
- Erledigt! Filme von alter LG TV Festplatte auf PC kopieren funktioniert
- Plasma hinlegen?
- Hilfe ganzes Bild eingebrannt !
- Auspacken/Aufstellen eines Plasma-TVs
Top 10 Threads in Plasma-Fernseher der letzten 50 Tage
- Plasma hinlegen?
- Gesamtzahl an Beiträgen21.838.810
. Wichtig!)
