| HIFI-FORUM » English » Stereo (Engl.) » Speaker Break In | |
Speaker Break In+A -A |
Behram
erstellt: 06. Okt 2005, 08:16
Hi Folks, Referring to Break In or Burn In of new speakers, typically how many operational hours does it usually take for new speakers ? What is the difference one should expect to hear. Is the change drastic or is it suttle ? Over a period of a time the user may not notice a difference since he may get used to the sound on account of regular listening. As regards "Toe in" of speakers, what is the norm most audiophiles follow. I prefer them parallel although my sound stage is quite wide compared to the depth. Is there a rule of thumb. Would appreciate inputs from speaker users. Thanks. Behram. |
cheraz
erstellt: 06. Okt 2005, 08:27
Behram, Burn in or Break in is something Audiophiles will argue and have been argueing for years. It will vary from system to system. Its not only your speakers but the cables, amp and even interconnects. There are some speakers that require up to 400hrs of listening for them to really come alive. You will suddenly feel the whole sound somehow opening up. I don`t know how to explain, let some hot shot soundy do that. As a relatively new person in this I can tell you that it is not so subtle but you can definately see and hear the difference. Toe in is also something I feel is different for everyone. Some like to toe in as much as when you are sitting on your couch between the speaker, you should be able to see only the front of the speakers. I don`t much appreciate that much. I like it toed it just a little. Lets hear some more opinions on this...... |
Shahrukh
erstellt: 06. Okt 2005, 08:34
Though it's the movable parts in a speaker that benefit most from the break in (the rubber surrounds etc...) different speakers take different burn in periods. For instance speakers that use Kevlar drivers take a good 100 hours. As for toe-in though the universal norm is 20 - 30 degrees, I suggest you decide for yourself. (Or let your ears decide for you). Most of us like just enough toe-in to have the main vocals dead centre, but some prefer a wider sounstage even though there's a very big, audible "hole" in the centre... it's all up to you dude. |
Shahrukh
erstellt: 06. Okt 2005, 08:40
A lil something on break-in from a fellow poster on another forum: -------------------------------------------------------------- What you are trying to break in is the driver's suspensions... namely the surrounds and the spiders. just like a pair of shoes... the parts in a speaker that are designed to move are stiff at first... the more you excercise these moving parts, the more relaxed they will become. if a speaker cone itself were to "break in" you'd have a crappy speaker. the whole point behind exotic cone materials is to STOP cone distortions without added weight. some cones are made out of aluminum because the material is light and rigid. once you break a speaker in, the softer surrounds and spiders will allow your cone to move easier and faster. would you run a marathon in a new pair of leather shoes? no. would you ever give up that well worn pair of shoes that are super comfortable? probably not. really ANY mechanical device can be improved by breaking it in. that's why many professional contractors run their drills etc. for an hour or so with no load to break the bearings in and get them seated. -------------------------------------------------------------- Hope it helped Shahrukh |
Krish
erstellt: 06. Okt 2005, 11:10
It's more belief than science I think. There are equally vociferous arguements for and against. The POV that I now tend to go with is that it's more about the time it takes for your ear and mind to adjust to the tonality. While the analogies drawn with a car or a shoe make a point but are not strictly accurate. Thats my HO K |
Shahrukh
erstellt: 06. Okt 2005, 11:33
As far as burn-in for cables and electronics is concerned, I don't think it makes sense. Speakers, I do. My reaons for believing are stated above. |
diskspinner
erstellt: 06. Okt 2005, 11:48
If we do a A/B comparison test (preferably blind folded) with two pairs of speakers of same model, one completely new, another with 100-200 hrs run-in...we should be able to tell. So we got a simple method to find out. But again opinion may differ. |
Shahrukh
erstellt: 06. Okt 2005, 12:00
To be frank, I did. The older speakers had a warmer, smoother, more natural sound. |
cheraz
erstellt: 06. Okt 2005, 12:42
But the point here is to do this testing blind folded Shahrukh. |
Shahrukh
erstellt: 06. Okt 2005, 12:56
No, didn't do a blind test.8) Did it with my pair of Diamond 8.1s (black) and a brand new, fresh-out-of-the-carton silver pair. [Beitrag von Shahrukh am 06. Okt 2005, 13:04 bearbeitet] |
diskspinner
erstellt: 07. Okt 2005, 03:15
So it can also mean black Wharfedale 8.1s' sound better than Silver Wharfedale 8.1s' irrespective of the old/new factor. |
Shahrukh
erstellt: 07. Okt 2005, 05:22
Could be. But, keeping Wharfedale's reputation in mind, I seriously doubt it. |
square_wave
erstellt: 07. Okt 2005, 09:16
New speakers definitely need to be broken in to perform its best. The changes are across the frequency spectrum but most noticeable is the reduction in harshness in the highs, cleaner mids and more defined and open bass. The speaker appears to sound effortless after breaking in. Most speakers will sound congested out of the box. The time needed to break in is speaker dependant. |
abhi.pani
erstellt: 07. Okt 2005, 09:22
Agreed. I have noticed that too. Initially even I was of the impression that break-in is a concept, may not work for speakers. But I have seen live difference between two speakers, one out of the box and the other after 50 odd hours of break-in. Now dont ask me if I was blind folded, I was not but to prove my point I will have to tell you that even my wife could immediately recognize the better sounding speaker (She does'nt know anything about break-in )What else buddies.... |
Manek
erstellt: 07. Okt 2005, 09:45
Abhi, Your wife like any other does know a lot about the phenomenon of break-in. We break-in speakers, they break-in husbands Unkown to you and all of us...one fine day(maybe after 100hrs or maybe after 1000)you start to sound a bit different(more refined in one or many aspects) than what you did earlier, much to her liking Think about it ! Manek. [Beitrag von Manek am 07. Okt 2005, 09:46 bearbeitet] |
cheraz
erstellt: 07. Okt 2005, 09:57
For me, it lasted only 1 hr. After that I sounded exactly like she wanted me to (no high pitches....only smooth low purrs) |
abhi.pani
erstellt: 07. Okt 2005, 09:59
Manek, That was the most practical humour I have heard/seen throughout my days at Hifi-forum... Kya yaar...you hit it so straight, I am floored.... Actually I am thinking what you have said....Man you woke me up but I am helpless.... |
Manek
erstellt: 07. Okt 2005, 12:22
We are all helpless my friend abhi, continuously tweaked to suit their changing(fickle)tastes and can do very little about it Cheraz, wise man you are for not resisting for too long but one must resist at the begining for an hour or two but no more, after all we are men and have to put up a brave front and show that we are no pushovers ! Compliance does not come easy Manek. |
kspv
erstellt: 09. Okt 2005, 07:28
Drivers changing attributes after breaking-in is scientifically proven. Vikash, a member from Bangalore in www.diyaudio.com (is he here?), posted the variation in Thiel-Small parameters of drivers at successive intervals of burning-in: http://www.vikash.info/audio/audax/break-in.asp http://www.vikash.info/audio/xls10/But whether this shift in Thiel-Small parameters results in an audible difference, is an altogether different question. The link below discusses the phenomenon of driver break-in. It concludes that variation / inconsistency at the production level results in an audible difference, more than any post-manufacturing breaking-in. http://www.audioholi...s/SpeakerBreakIn.phpIn case of amps, tube amps may be needing breaking-in to give optimum performance because of the nature of technology involved. But with other amps, there is no scientific proof which says that breaking-in results in measurable difference (not to speak of audible difference) in any parameter. Break-in of cables & interconnects? Neigh....!!! [Beitrag von kspv am 09. Okt 2005, 07:52 bearbeitet] |
benkenobi
erstellt: 09. Okt 2005, 08:25
Nope..Vikash is from Great Britain. He actually came up with the search facility for projects on diyaudio.com. the website is hosted by 'Planet10' dave from canada. Vikash also designed the website for BrianGT..chipamp.com. Cheers, Benkenobi |
True_sound
erstellt: 13. Okt 2005, 09:25
There are burn-in Cd's available in Singapore which makes things easy ! |
Arj
erstellt: 13. Okt 2005, 09:40
there are many break in CDs from Chesky records to XLO..even the Sterephile discs are good.. But the most cost effective way is to use music you play regularly. most of the above are just Sine wave or White/Pink noise signals ! After all that is the Music you are going to play on it ! (During Speaker breakin sessions I used, when I am not in the house, I prefer Stravinsky's Rites of Spring which can have some mean transients between high and Low Frequencies). you can downlod many of these from the Net in MP3 form if you want. also throw in some Chemical Bros Bass stuff if you want ! (I have the XLO disk and honestly do not know if it really makes a difference !) |
bhagwan69
erstellt: 13. Okt 2005, 11:30
Using a CD to burn in speakers is a very very expensive option; Simply because it leads to a lot of ware & tare of your CD Player - tracks played on repeat for hours at end. The transport mechanism goes for a toss !! I have lost a TEAC CD Player this way. Therefore I suggest that you connect a Radio to your pre / power amp or to your intergrated amp. That way the radio keeps on playing & your speakers get 'burnt in' Try to do this for 3 to 5 yours a day. In 2 to 3 different sessions. That way your amplifier too gets some rest. If you have an I-Pod, then that too could be used. But I strongly suggest against the use of a CD Player. Regards, BHAGWAN69 |
Arj
erstellt: 13. Okt 2005, 11:56
we are talking 50-60 ,hours at max .am a bit surprised (And worreid) that the CDP should not be able to do that. I mean as a first take if a CDP fails to run that much then it is not really a good choice (I had run my NAD for close to 36 hours continously..thankfully it did not give in) |
Manek
#25
erstellt: 14. Okt 2005, 05:41
I like to break in anycomponent by just listening to it daily at my normal listening volumes for a couple of hours...that way break-in is not too hard on the components and if at all there are differences one gets to hear them progressively. Manek. |
what is Speaker Break-In juggy_25 am 17.07.2006 – Letzte Antwort am 24.07.2006 – 6 Beiträge |
Correct method of comparing speakers? Neutral am 18.10.2005 – Letzte Antwort am 24.10.2005 – 7 Beiträge |
What Cables to use ?? abhi.pani am 19.01.2005 – Letzte Antwort am 19.01.2005 – 6 Beiträge |
how to wire my speakers into my amp? pumpanani am 14.12.2004 – Letzte Antwort am 15.12.2004 – 2 Beiträge |
Of Speakers and Roaches soulforged am 21.04.2006 – Letzte Antwort am 05.05.2006 – 41 Beiträge |
Expensive Audio CD player - what difference does it make? jayashree am 18.10.2008 – Letzte Antwort am 06.11.2008 – 33 Beiträge |
Studio Monitors Vs. Bookshelf Speakers: What's the difference? SDhawan am 12.09.2006 – Letzte Antwort am 20.09.2006 – 64 Beiträge |
new speakers? cholo333 am 28.07.2004 – Letzte Antwort am 29.08.2004 – 3 Beiträge |
Help with speakers connections pranab31 am 27.02.2006 – Letzte Antwort am 28.02.2006 – 5 Beiträge |
bad sound most of time!!! mister-malcontent am 13.07.2004 – Letzte Antwort am 14.07.2004 – 4 Beiträge |
2005
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.935 ( Heute: 8 )
- Neuestes Mitgliedchrisjeff
- Gesamtzahl an Themen1.564.208
- Gesamtzahl an Beiträgen21.846.835
