| HIFI-FORUM » English » Stereo (Engl.) » Sub Woofer | |
Sub Woofer+A -A |
Alexb123
erstellt: 23. Dez 2003, 13:32
Hi All I have a Technics Stereo System (House) I already have a sub attached would it be possible to attach another one? How would I do this is there a lead that I can buy? Any help would be great. Many Thanks Alex |
Manek
erstellt: 23. Dez 2003, 14:24
two subs in a system ? you will end up getting horrible bass... |
aleiex
erstellt: 26. Dez 2003, 17:17
just get one hideously big woofer...... |
Alexb123
erstellt: 26. Dez 2003, 17:20
Thats weird are you saying get a Sub that looks like my Mum. I would like to get the same sub as I already have so that they match, does anyone know here I can get a lead to do this? Cheers |
aleiex
erstellt: 26. Dez 2003, 17:40
you must have caught the wrong end of the stick somewhere.. nothing said bout your mum... well i guess you should try out what works better two subs or one big sub |
Alexb123
erstellt: 26. Dez 2003, 18:43
Relax was just messing around :o) |
aleiex
erstellt: 26. Dez 2003, 18:49
yeah rite.... |
daviblub
erstellt: 26. Dez 2003, 19:02
Where is your problem. I know that many subs ae connecteed via a cinch cable i guess you got an active wofer? So you can use an Y-adapter to connect two diferent wofers! Hope this does help. |
Manek
erstellt: 29. Dez 2003, 05:57
a Y adaptor will definately put load on your amp...better check with your friendly neighbourhood dealer on how to connect two subs and not fry your amp. |
Bass-Oldie
erstellt: 29. Dez 2003, 06:55
Hi Manek, I cannot support your last mail with the Y Cable. It (a Y-Cable) is the normal / standard way to connect two amps (whether normal Amps or active Subwoofers, doesn't matter) to one source. That's why the cable is existing ![]() Also in every Subwoofer Manual, this connection is mentioned as the way to connect the second one up. Some Subwoofer feature even a "Cinch Out" Connection for this purpose. One has to be sure then, it is just a drivetrough connection if a second sub shall be connected via those. Some Subwoofer have an internal LowCut Filter in this connection as they expect to drive satellite speakers from there! Regars, Axel |
Manek
erstellt: 29. Dez 2003, 09:02
bass-oldie, Hi....you've taught me something new today..thanks...never thought someone would want 2 subs...one sub is bad enough I'm not a great proponet of subs as i dont like them too much and dont use them. I believe in towers for bass. I find subs too slow and fatin their voicing....gimme a good floorstander anytime.....even for DVD and home theatre. |
Bass-Oldie
erstellt: 29. Dez 2003, 11:27
Hi Manek, I do believe in large floorstanders too (have a look into my profile :-). However, the LowFrequencyEffect Channel does still carry information, which will not sent anywhere else if I do not connect a Sub to it. That's why I bought them despite the Kappa's ability for good strong bass. Also, some DVD-Audio records will not play in 5-channel mode if there is no Sub detected (this of course is a fault, but the records exist, though). Regards, Ax |
Manek
erstellt: 29. Dez 2003, 14:01
seriously ? wont play ? thats getting a bit to finiky about the hardware....!!!! this is news to me too... Even if you configure the speakers in the receiver as large the LF channel is supposed to pass all low frequencies to the large configured speakers....atleast thats what a few manuals say.... |
stadtbusjack
erstellt: 29. Dez 2003, 14:06
@Manek: There is a user (Elric) in the german part of the forum, who uses I think SEVEN subwoofers or active bass-modules in his surround-system! Multiple subwoofers can also be used to solve acoustic room-problems. |
Manek
erstellt: 29. Dez 2003, 14:19
yeah but seven ? seven ? I really find it hard to imagine seven subs in my room. all seven pumping out bas at seven different times....I can believe multiple woofers in the cinema hall...but at home ? Home sweet home ? dont seven subs play hell with the family crystal ? |
stadtbusjack
erstellt: 29. Dez 2003, 14:25
Well, I've never heard so many subwoofers in one room, but he seems to like it |
Bass-Oldie
erstellt: 29. Dez 2003, 15:11
@ Manek
Now, they do play, but only in Stereo mode. Which is not what you want if you by a 5.1 channel recording... I know of some records, only from Warner Music, which have this problem. Its more a DVD authoring problem during the creation of the DVD than the Hardware which plays the record, I was told. Cheers, Axel |
Manek
erstellt: 30. Dez 2003, 05:38
Hmmm...understood.... |
Alexb123
erstellt: 12. Jan 2004, 14:20
Thanks for all your replys Im a bit lost by most of them but Im more informed than before will have to have a think about what to do. Cheers Alex |
Brap
erstellt: 14. Jan 2004, 21:54
Stick with an older Velodyne. Just love my 15" Good luck |
Would you use a sub(s) in a Stereo setup? benkenobi am 23.09.2005 – Letzte Antwort am 24.10.2005 – 39 Beiträge |
How do I repair my tube amp? hydrovac am 17.07.2013 – Letzte Antwort am 19.07.2013 – 2 Beiträge |
Another newbie seeks help sabhash_nakshatra am 09.11.2004 – Letzte Antwort am 11.11.2004 – 6 Beiträge |
Help / Advice for building a new system kaliste am 03.01.2005 – Letzte Antwort am 07.01.2005 – 10 Beiträge |
Stereo and Computer Speakers Alexb123 am 12.01.2004 – Letzte Antwort am 12.01.2004 – 6 Beiträge |
Can there ever be a single perfect music system? zhopudey am 07.02.2007 – Letzte Antwort am 21.08.2007 – 25 Beiträge |
which amp to buy ??? johnny69 am 12.11.2003 – Letzte Antwort am 17.11.2003 – 8 Beiträge |
how do i? inititis2 am 05.06.2005 – Letzte Antwort am 14.06.2005 – 8 Beiträge |
Would a Mini-compo be a good source? Neutral am 15.06.2005 – Letzte Antwort am 09.09.2005 – 26 Beiträge |
how do i ludlow859 am 16.05.2004 – Letzte Antwort am 17.05.2004 – 2 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.661 ( Heute: 8 )
- Neuestes Mitgliedhansano715
- Gesamtzahl an Themen1.563.444
- Gesamtzahl an Beiträgen21.825.513
