power supply solutions
dressel
#1 erstellt: 30. Mrz 2005, 07:33
Friends,
hi every body !
I just went thro the various threads of this great forum & was really amazed! this has really been a boon for audio lovers like me; who have trying to metamorphose from just a music lover to a serious listener.
I basically own a decent HT set up,I thought why not give my family a little pleasure too; when I am spending over Rs1,00,000/-!!. But the thing is it gave me a compromised audio( sterio) rig. All the more it has given me a constant itch&urge to improvise.and I started looking for various DIY's. After lots of speaker position trials, furnshing the listening room I was able to get a resonably good sterio sound which was not comming only from the two speakers any more!Icould get a good,-what they call as - sound stage imaging.
One day I connected the whole of my system thro'the UPS OF MY computer and to my utter surprise there was remarkable improvement in the sound quality.The sound(the vocals and mid range) became absoltely clean,dry& transperant. it was also noticed by one of my friend who is also my sterio GURU. this was something really exciting.
&it pushed me to find out some serious power supply gears like filters or conditioners. I was trying hard to find such thing in market. but most of them were not marketed in India & were very costly.
and then samefriend of mine informed me about this forum & guarrented help from the senior members here.
so I want to know about some affordable power conditioners& any DIY tactes regarding power supply.
I am told Mr prthiviraj would be of great help to me.& my frind GURU Dr Aniruddha Dixit has referred me to him
All suggestions are eagerly awaited.
-dressel.
benkenobi
#2 erstellt: 30. Mrz 2005, 07:45
yeah that's right.power suppy makes a lot of difference.
myself and arjun(Arj) witnessed it first hand at Prthvi's place. he has MUrthy's power conditioners and vertex servo stabilisers. for both u can contact him.
Ben
dressel
#3 erstellt: 30. Mrz 2005, 12:44
Thanks for a prompt reply there Benk, can you give me contact for Mr Murthi?
I possess denon AVR1603,B&W303s, JBL PB12 sub and pioneer dvdplayer.Ofcorse Iam planning my sterio setup in days to come;so what sort of stabilizer or conditioner is recomonded for this setup,can I get the recomonded specs locally here?
[Beitrag von dressel am 30. Mrz 2005, 12:46 bearbeitet]
benkenobi
#4 erstellt: 30. Mrz 2005, 12:57
hey man,
like i said, Prithvi is the man to meet. regarding the servo stabilisers ,they are a local manufacturing outfit but come highly recommended. u may have to go in for atleast a 2kva(if ur tv is also big) and regarding the power conditioner u better talk to Prithvi.
Ben
roshan
#5 erstellt: 30. Mrz 2005, 13:55
Guy's,
I have a different story. Once I needed to test a UPS and played my set up through the UPS fo a couple of hrs and noticed a hum in the Amp at 0 volume.
Any reason why Dressel here had the opposite experience?
Roshan.
Prithvi
#6 erstellt: 30. Mrz 2005, 14:43
Hi! Dressel,
Great to see more people join the group. Off late havent been able to post as have been very busy with my hiend installs.
Anyhow. Mr. Murthy' makes the best available pwr conditioners from 500va to 3kva. These all are on a order basis only.
First of all pls let me know in detail ur system config. R u planning on adding a TV to it? You can also upgrade to his FINESSE pwr cords and interconnects, but all in time one step at a time.
I market MR. Murthy's products under the brand name of FINESSE. He also makes Bass traps, isolation platforms, spikes, pwr conditioners, pwr cables, inter-connects, racks, spk stands etc.
Do note that you will also need a VERTEX servo stabilizer which has been beefeed up to my specs, hence I call it an audiophile stabilizer. By the end of April we will have the best audiophile servo available ever in india, both in specs and looks. As of now major testing is going on and only once I am satisfied I will bring it into the market.
Pls send me a PM and I will respond. Dr. Dixit is a good client of mine. Give him my regards
Rgds
PRithvi
viren
#7 erstellt: 30. Mrz 2005, 15:47
Hello all,
Using a computer UPS for a stereo system is actually not a good idea. Even though this UPS generates a sine wave supply, it is not a smooth sine wave, that is, has a high distortion level. Also, the supply has a high noise level; good for a computer SMPS supply, but not for audio.
Computer UPS's like a constant load, that of a computer, since the current draw does not vary. Quite the opposite with music - with transients demanding upto ten times more instantaneous power.
Better to go with a high capacity servo stabilizer, or an isolation transformer, to get rid of electrical noise in the supply.
Viren.
Prithvi
#8 erstellt: 30. Mrz 2005, 16:16
Viren,
thts exactly what I have suggested a good servo and a good pwr con/isolation stabilizer will do the trick
rgds
prithvi
Check out www.rethm.com (made in india)
dressel
#9 erstellt: 31. Mrz 2005, 04:21
Hi guys
Roshan, I did get a great improvement with UPS. Actually I never used it as a power source when power is cut off .I used it may be as a filter . But ultimately fired it. got the battery completely exhausted,& Thats why I am now in search of an authentic power regulator!!
I do agree with you Viren this was not a great idea atall it was just a simple house hold trick but it worked for me for a few days.
I have PMed a detailed information about my system to you Prithvi. I wait for your pm or reply.
Gosh!! this thing is turning out to be interesting.
--dressel.
Manek
#10 erstellt: 31. Mrz 2005, 04:51
To give you a couple of options.....
Monster power conditioner is being marketed in India and is supposed to be rated well by the press. Some people though have not found it to make any difference.
Designer audio in bombay has an audiophile power conditioner which I have heard and it works extremely well. They are basically electrical filters. You may beed to buy a servo with it depending on which city you reside in.
BTW dressel, which part of the country do you reside ?
manek.
Arj
#11 erstellt: 31. Mrz 2005, 05:00
depends on the power rating of your amp Vis a vis the UPS.
components like the UPS would not be able to supply the large amount of dynamic power required by higher power amps hence the need for Audiophile grade filters/stabilisers.
if the UPS has at least a rating of 2 times the power rating of your amp it may perform better..
the reason your UPS sounded better might be as the waveform of the AC signal given might have been superrior to the power you receive at you place..hence a good conditionar migh give you some very good benefits
dressel
#12 erstellt: 31. Mrz 2005, 08:21
I reside at KOLHAPUR, Maharashtra. Have you been here Manek?
my place being near to an industrial area has lots of power fluctuations.
--Dressel.
Manek
#13 erstellt: 31. Mrz 2005, 10:08
dressel hi,life is good, could be better
The first thing you need is a good servo stabilizer with to control the fluctuations and protect your equipment. The line filter part you could add to your liking and budget.
Where can I get a replacement of this cartridge!
abhi.pani am 13.07.2007  –  Letzte Antwort am 03.09.2007  –  29 Beiträge
Help / Advice for building a new system
kaliste am 03.01.2005  –  Letzte Antwort am 07.01.2005  –  10 Beiträge
Help me upgrade my amp please!!!
RajB am 18.01.2005  –  Letzte Antwort am 19.01.2005  –  9 Beiträge
Would a Mini-compo be a good source?
Neutral am 15.06.2005  –  Letzte Antwort am 09.09.2005  –  26 Beiträge
My 2 Ch Music System
sat am 12.09.2005  –  Letzte Antwort am 12.09.2005  –  5 Beiträge
Whither This Search For Musical Ecstasy?
viren am 30.03.2006  –  Letzte Antwort am 12.04.2006  –  43 Beiträge
Think i found a find!
puchoo am 11.06.2007  –  Letzte Antwort am 11.06.2007  –  4 Beiträge
A great initiation to tube sound
Savyasaachi am 19.02.2008  –  Letzte Antwort am 22.02.2008  –  13 Beiträge
Really sad too day.
Prithvi am 03.03.2005  –  Letzte Antwort am 04.03.2005  –  3 Beiträge
Recommendations for audio setup
Nagaraj am 18.11.2004  –  Letzte Antwort am 22.11.2004  –  9 Beiträge
2005
  • Registrierte Mitglieder930.662 ( Heute: 5 )
  • Neuestes MitgliedSven480
  • Gesamtzahl an Themen1.563.460
  • Gesamtzahl an Beiträgen21.826.127
