HIFI-FORUM » English » Stereo (Engl.) » Subwoofer Problems | |
Subwoofer Problems+A -A |
benkenobi
21:28
erstellt: 22. Feb 2005, |
hey guys, when i turn on/off the sub(with or without the receiver turned on)the subwoofer makes a loud thump. why is this happening and how do i solve it. also please help me how to determine the gain and crossover settings. i'm using it only fo rhome theater and with the yamaha rx-v450 only. the NAD is doing stereo duty. keep you posted on how it performs. please help guys. thanks in advance. benks |
big-ears
08:25
erstellt: 23. Feb 2005, |
Benks, This is apparently a widely prevalent phenomenon, attributed to grounding problems, and does not seem to have any precise solution. I am not an electrical guy and hence cannot give you a qualified answer. However, I was able to get around a similar problem in my active speakers by switching them off only after the auto turn off located in the speaker amp had done its job. You could try the same. I prefer keeping the low pass setting at around 50hz. You could try 50 to 60hz. Having done this, play a bass heavy track starting with the volume setting on minimum and increase slowly till you come to a point where it begins to get boomy. At this point turn it down a notch so that you don’t get any boominess. Also, try out various locations, till you find the best one. Corners will re-inforce the bass, as you have discovered with your speakers, so if it gets too boomy, move it out a little. Remember, quality bass is bass that is felt, ever so slightly, and not heard. Cheers |
benkenobi
09:01
but if i'm not able to solve the problem will it affect my sub by damagind it in any way in the long run. |
benkenobi
12:10
i'm still having the problem. how do i solve it. if i can't will it damage my sub in the long run |
Manek
12:15
ben, since you have expenisive equipment in your home now....i suggest you call your local electrician and have all power points checked for Earthing. Make sure he tightens all wires inside the socket for proper electrical connection and make sure switches are in decent condition. If you have old wiring, maybe its time to chnage that one segment which you will use for audio. If you are in a city besides bombay invest in a servo stabilizer. I'm not saying it will solve your sub problem, just mentioning the precautions you can take to avoid damage to other stuff you have. Manek. |
benkenobi
16:01
ok. i think i got the crossover setting right. 60Hz phase reversed. this is on the receiver. the onboard crossover on the sub has been taken out of the loop by setting it to 150Hz. i'll be getting the grounding wires checked tomorrow as the problem still exists. but, u guys please clarify to me if its going to damage my sub if the problem persists. thanks |
Manek
16:44
the best thing to do is write to the manufacturer and ask him if the sub is supposed to do this and if not what could the issue be. to be honest in the old days all amps power up would make the speakers go thump, I was also quiet disturbed about it and I would switch off the speaker selector switch. I would turn on the amp, wai 5 seconds and then switch on the speaker switch, that way I circumnavigated the problem. Manek. |
big-ears
06:54
erstellt: 24. Feb 2005, |
Benks, Have you checked connecting to other wall outlets? Does it go Thump with all of them? Also, does the sub have an auto power on/off switch? |
benkenobi
12:35
right, i took Manek's advise and wrote to definitive tech. this is what they had to say. " Thanks for your recent email to Definitive Technology. The "thumping" sound heard when a ProSub100TL first receives electricity and stops receiving electricity (or when it is turned on and off) is normal. It's not "dangerous" and won't cause any harm to your subwoofer (I'm sure it's annoying though.) I'd recommend plugging your ProSub100TL into an "unswitched" outlet that receives AC power all the time (and leaving it turned on). This way you won't hear any popping or thumping when you turn your system on or off. (Its auto on/off circuit will quietly turn the amplifier on and off.) (The amplifier used in the ProSub100TL has a unique power supply that draws its power from the AC outlet as needed. It doesn't have a traditional transformer and it doesn't' store its power on board. A draw back of this unique design is that it produces a transient when it first receives electricity and when it stops receiving electricity.) If you need any other information, please email me at cpelkowski@definitivetech.com. Thanks, Chet Pelkowski Definitive Technology " BTW, that's a roger to both ur questions big ears. [Beitrag von benkenobi am 24. Feb 2005, 12:45 bearbeitet] |
big-ears
13:00
Good, now you can sleep easy! |
Monsoon blues: Help please Neutral am 19.09.2005 – Letzte Antwort am 14.11.2005 – 21 Beiträge |
how to post pics on the forum? benkenobi am 04.03.2005 – Letzte Antwort am 04.03.2005 – 2 Beiträge |
Help with speakers connections pranab31 am 27.02.2006 – Letzte Antwort am 28.02.2006 – 5 Beiträge |
Taking the plunge : sonodyne speakers - please advise! trivisingh am 26.02.2005 – Letzte Antwort am 01.03.2005 – 13 Beiträge |
Building a subwoofer: Help needed! Neutral am 30.08.2005 – Letzte Antwort am 03.09.2005 – 30 Beiträge |
Fungi on speaker! - Help needed Ronnie22 am 13.11.2005 – Letzte Antwort am 14.11.2005 – 3 Beiträge |
Need help with speaker problem! trenzterra am 27.12.2003 – Letzte Antwort am 29.12.2003 – 2 Beiträge |
Help!! NAD C320BEE or C352CT NADist am 12.01.2005 – Letzte Antwort am 13.01.2005 – 7 Beiträge |
Denon AVR1505/485s Receiver Help apurba999 am 07.12.2005 – Letzte Antwort am 10.12.2005 – 2 Beiträge |
Help!!!!!!!!!!!!!!!! neckie am 16.09.2005 – Letzte Antwort am 21.09.2005 – 20 Beiträge |
2005
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder929.102 ( Heute: 6 )
- Neuestes MitgliedDerOctavian
- Gesamtzahl an Themen1.559.697
- Gesamtzahl an Beiträgen21.732.719
