| HIFI-FORUM » English » Stereo (Engl.) » Turntable hum | |
Turntable hum+A -A |
abhijitnath
erstellt: 11. Aug 2008, 11:05
I hooked up my ancient Philips TT to a Sansui integrated over the weekend, and was greeted by a loud hum, and no musical output. The phono input is working (I tested it with a line level input at low volumes) as is the TT (tested it with my guitar amp). Is it a grounding issue? Both the amp and TT have 2 pin plugs; however, the amp has a plug at the back with reads GND. Do I take a cable and plug it into the ground of the socket the amp is plugged into? Am I on the right track, or am I missing something? People on the board who have a working knowledge of electrical engineering, please do help. I don't want to plug all this in, only to find that the amp is blown forever! Thanks. |
goolimangala
erstellt: 12. Aug 2008, 02:07
Your tone arm cable should have grounding wire which has to be connected to the ground of your amp. If this grounding wire is missing check if it's possibly cut off and fix a new one. |
sivat
You are correct. You will have connect the Ground of the turntable to the ground of the phono-stage...or the GND pin of the amp (if the phono-stage is built into the amp) It's okay if your amp and TT has only 2 pin...its not ideal, but okay. |
abhijitnath
erstellt: 13. Aug 2008, 06:48
Thanks a ton Will try this over the weekend. Will ask you guys again if I can't locate the ground wire on the TT! Just a question...why isn't the hum there on the other amp I used (a Laney guitar amp)? Is it because of the 3 pin plug or is there any other reason? |
Hum from Turntable myriad am 12.10.2007 – Letzte Antwort am 13.10.2007 – 7 Beiträge |
how to wire my speakers into my amp? pumpanani am 14.12.2004 – Letzte Antwort am 15.12.2004 – 2 Beiträge |
low volumes filmguy am 27.10.2004 – Letzte Antwort am 01.11.2004 – 7 Beiträge |
Is "the vinyl revival" a scam? Shahrukh am 10.08.2010 – Letzte Antwort am 11.08.2010 – 18 Beiträge |
What is the difference between Pre Amp & Amplifier? philipmorris am 19.07.2006 – Letzte Antwort am 19.07.2006 – 6 Beiträge |
My SH-GE90 is broken!! :-( nfung am 01.04.2005 – Letzte Antwort am 01.04.2005 – 2 Beiträge |
Bright amp with which speaker. Alymangy am 02.02.2005 – Letzte Antwort am 02.02.2005 – 12 Beiträge |
Buying on the Net purnendu am 29.04.2005 – Letzte Antwort am 25.08.2005 – 11 Beiträge |
Valve amp huming Rick_F am 18.11.2003 – Letzte Antwort am 08.06.2007 – 20 Beiträge |
The importance of a good cdp not to mention recordings. benkenobi am 20.04.2005 – Letzte Antwort am 22.04.2005 – 20 Beiträge |
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.676 ( Heute: 2 )
- Neuestes MitgliedRain_Ed
- Gesamtzahl an Beiträgen21.827.061
