Crossover Related Question
abhi.pani
#1 erstellt: 05. Jul 2006, 09:02
Guys,
Please let me know about this:
1. If there are two speakers (both are two way, and have the same drivers, cabinets etc...except the crossover), Speaker A has its tweeter crossed over at 12db/octave and speaker B has its tweeter crossed over at 6db/octave.
The MidBass driver is crossed over at 6db/octave for both of them.
1. What could be the audible difference in sound ?
2. Which speaker should sound better?
3. Anything else thats worth noting between the two speakers ?
Kindly let me know about this asap.
Manek
#2 erstellt: 05. Jul 2006, 09:51
you mean one speaker has a 1st order roll off and the other has a 2nd order rolloff.....
One cant really pinpoint which will sound better as it depends on many variables like driver characteristics crossover frequency chosen, serial or parallel topology, baffle step compensation, active or passive design, etc etc etc....and all the things that designers do with crossovers.
Some swear by first order and some designers believe and use higher orders.
So to my mind its not a parameter to judge sonic quality.
Your dyns have first order crossovers dont they ?
Manek.
abhi.pani
#3 erstellt: 05. Jul 2006, 10:06
Ya Manek my Dyns do have first order.
Ok, I will try to give you few more details that I know...
Speaker A: Crossover frequency 3100hz, Design Passive
Speaker B: Crossover frequence 2700hz, Design Passive
Topology I am not sure off but both have the same topology
Is it still not enough to conclude anything ??
Manek
#4 erstellt: 05. Jul 2006, 10:09
no conclusion ......
deaf
#5 erstellt: 05. Jul 2006, 10:36
Dear Abhi Pani
Firstly with different x-overs the speakers cannot have the same enclosure.That is because the tweeter will have to be placed differently for both the speakers in relation to the woofer.The moment you make that one change, then it no longer is identical in any sense.
Deaf.
Behram
#6 erstellt: 05. Jul 2006, 11:00
Dear Abhi,
I can tell you one thing from experience. The human ear is most sensitive in that freq. range 2Khz - 3 khz. If at all this region is chosen as the crossover point the slopes should be chosen so that there is no hump in the overall frequency response or else the speaker will sound harsh ot squaky.
Given the parameters you described 12db/octave should sound better sonically considering that the hump is levelled or at the most it enters the trough region.
Regards.
Behram.
abhi.pani
#7 erstellt: 05. Jul 2006, 11:07
Can anyone explain me what is the meaning of 12db/octave slope ? What could be its implication on music reproduction ?
deaf
#8 erstellt: 05. Jul 2006, 11:08
More than what type of slope is choosen electrically,the acoustic slopes of the two drivers should be identical.Only a correct acoustic handover between drivers will result in a good sound.I am of course assuming that the dips and peaks at x-over are at a minimum.However do keep in mind,just a respectable frequency response does not ensure a great sound.
Deaf.
Behram
#9 erstellt: 05. Jul 2006, 11:18
An Octave is typically double the frequency. Let me put it this way. Reference at 2 khz the lower octave is 1 khz and the upper one at 4 khz. Since reactive components are used in a crossover network (L & C)their reactance varies with frequency. A figure of 12 db/octave would mean that if the reactance at 2 khz is 0 db (ideally) it would be -12db at 4 khz. So eventually one would be hearing musical content 12 db down at 4 khz than what one would hear at 2 khz.
Still confused ?
Behram.
Sonic_Master
#10 erstellt: 07. Jul 2006, 12:40
hi abhi,
the crossover frequencies...and the driver rolloff is a very much related... IN general a driver can be crossed before the rolloff
i mean if a mid bass driver with a freq resp of 40 to 3khz with flat freq response and we have to check how fast it rolls of and then to see which order or crossover that you have to choose for it... if you choose a xover point which is chosen in the safe region then no problem but we need to consider even the phase response also....
Its a very long prcess in choosing the right points and the right drivers....
so if your crossover is done right with good drivers then your speakers sound well...
but prefered to go with the first order which are sonically very good... but higher the order you go more the problems you face...
cheers,
Sandeep
Crossover design for 2-way speakers
Neutral am 24.09.2006  –  Letzte Antwort am 26.09.2006  –  4 Beiträge
Good speakers for old system
kousik_s am 06.05.2006  –  Letzte Antwort am 17.05.2006  –  21 Beiträge
10" Driver for Mid bass will it be ok?
Sonic_Master am 12.12.2005  –  Letzte Antwort am 12.12.2005  –  7 Beiträge
Quad 22L Speaker Connection
TjMV3 am 16.07.2004  –  Letzte Antwort am 01.07.2005  –  5 Beiträge
what makes a speaker timing go awry?
stevieboy am 22.11.2005  –  Letzte Antwort am 28.11.2005  –  36 Beiträge
Difference between songs in CDs and DVDs
sandipb am 26.11.2007  –  Letzte Antwort am 27.11.2007  –  5 Beiträge
What is the difference between Pre Amp & Amplifier?
philipmorris am 19.07.2006  –  Letzte Antwort am 19.07.2006  –  6 Beiträge
Got a quotation for Athena & Mirage
abhi.pani am 28.07.2005  –  Letzte Antwort am 28.07.2005  –  5 Beiträge
Stereo and Computer Speakers
Alexb123 am 12.01.2004  –  Letzte Antwort am 12.01.2004  –  6 Beiträge
Two technical questions
Neutral am 01.09.2005  –  Letzte Antwort am 03.09.2005  –  9 Beiträge
2006
  • Registrierte Mitglieder930.980 ( Heute: 7 )
  • Neuestes MitgliedNoworob
  • Gesamtzahl an Themen1.564.342
  • Gesamtzahl an Beiträgen21.850.794
