HIFI-FORUM » English » Stereo (Engl.) » Equalizer Software | |
Equalizer Software+A -A |
Albertinho
#1 erstellt: 25. Jan 2006, 12:39 | |
I had some problems with some of my music (as i've described here:http://www.hifi-foru...um_id=59&thread=1005), so to solve it I need to filter all frequencies in the subsonic range. But instead of editing every single song in Cool Edit, maybe you could point me to some good software equalizer which i could set to filter for example everything under 30Hz that comes out of my soundcard and put it to work in background all the time... The one I have in Winamp (v2.91) only has 60, 170, 310Hz etc. bands, that's not low enough... Also, I noticed there's a "Phono Subsonic" input on my amp... I have the soundcard connected to the "Aux" input, maybe if I connect it to Phono Subsonic, would the amp filter all the low freqs then? [Beitrag von Albertinho am 25. Jan 2006, 12:53 bearbeitet] |
Behram
#2 erstellt: 25. Jan 2006, 16:35 | |
The phono subsonic input is RIAA equalized and should be only used with manetic phono cartrigdes. Also the sensitivity is quite hih (2.5 mv) For 30 Hz filtering you could use Windows Media player equalizer and pull the 32 Hz slider all the way down which should be minus 12 db. |
Albertinho
#3 erstellt: 25. Jan 2006, 18:45 | |
I found a pretty good Winamp2 filter plugin here: http://shibatch.sourceforge.net/ I've set it to -30dB gain from 0 to 30Hz and it seems to have solved my problems! |
Albertinho
#4 erstellt: 27. Jan 2006, 18:15 | |
Ah but the problem has been solved only in winamp... When my pc plays sounds from some other program, the problem can re-appear. Maybe if you could point me to some equalizer which has effect on the entire sound card output? Or some subsonic filter software for windows? But, at least the music works well now... |
Good to have some basic tools lying around benkenobi am 15.08.2005 – Letzte Antwort am 18.08.2005 – 4 Beiträge |
Need Help to My NAD 3020 eelekim am 11.05.2004 – Letzte Antwort am 14.05.2004 – 4 Beiträge |
8 speakers knownothing am 03.04.2005 – Letzte Antwort am 05.04.2005 – 6 Beiträge |
Help! I need some components. benkenobi am 28.06.2005 – Letzte Antwort am 01.07.2005 – 11 Beiträge |
Searching for some B&W Webon am 13.10.2003 – Letzte Antwort am 17.11.2003 – 66 Beiträge |
Bright amp with which speaker. Alymangy am 02.02.2005 – Letzte Antwort am 02.02.2005 – 12 Beiträge |
Hi to all.. I am Sandeep Sonic_Master am 23.04.2005 – Letzte Antwort am 28.04.2005 – 55 Beiträge |
which amp to buy ??? johnny69 am 12.11.2003 – Letzte Antwort am 17.11.2003 – 8 Beiträge |
Vinyl record to mp3 convertor RRao am 08.09.2006 – Letzte Antwort am 08.09.2006 – 7 Beiträge |
Some random thoughts square_wave am 09.03.2005 – Letzte Antwort am 12.03.2005 – 3 Beiträge |
2006
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder927.961 ( Heute: 10 )
- Neuestes MitgliedPaat24
- Gesamtzahl an Themen1.557.028
- Gesamtzahl an Beiträgen21.670.983
