HIFI-FORUM » Surround & Heimkino » DVD-/DVD-A/SACD-Player » Oppo Digital - OPDV971H | |
Oppo Digital - OPDV971H+A -A |
Friedensreich
21:15
#201
erstellt: 27. Dez 2005, |||
Habe die FB auch gerade bestellt. Seriennummer habe ich mir auch geschenkt, da ich keine Lust hatte die Kiste wieder rauszuziehen. Bestaetigungs-mail ist schon da - bezahlt ist - nun warte ich mal ab. |
m2004
11:24
#202
erstellt: 28. Dez 2005, |||
Im Livingcinemaforum gibt es ja diese Liste bzgl. Oppofirmware und BBK971h-(e). Short list: Oppo 1022 + BBK971H = working with the remote trick. Oppo 1111 + BBK971H = not working, black oppo usa remote needed. Oppo 1022 + OPDV971H-E = not working remote trick does not help Oppo 1111 + OPDV971H-E = not working Bbk/oppo 0927 + OPDV971H-E = working, keep this combination! Dort steht das die Oppo 1111 FW nicht mit dem OPPO OPDV-971H -E von Livingcinema funzt. Auch nicht mit der USA FB. Hier haben aber doch einige diese Kombi am laufen, oder? |
vanbit
12:28
#203
Hello everyone. this question is destined to those who like have a pioneer plasma display and a dvd player oppo hooked up to it? I don't speak german at all but I think I saw 'reduce' had a test with this configuration. Unfortunately I didn't understand a thing. Is oppo dvd player worth buying to work with my PDP505HDE ? Please tell me ASAP cause I plan to place my order . Thanks in advance for you answer . Bye |
Bigkraut
13:25
#204
@vanbit in conclusion one could say that the Oppo is on hell of a player, clearly beating high prized players with the same features. recluce stated that the combination of a Pioneer 435-FDE display together with an Oppo provides a near perfect DVD-experience, so I believe it should be the same with your PDP505HDE hence via DVI you can enjoy up to 1080i. Via component there is no progressiv signal possible, so you need to have a HDMI/DVI input on your display to get the hole thing. I, myself have the Oppo working together with a Myrica V40 HD-LCD from Fujitsu Siemens via DVI. What can I say - 225 Euros well spent ! The picture is just perfect! Cinema like feeling all the way. You should get the same with your PLasma I'm sure! Bye Bigkraut |
recluce
16:09
#205
While I don't feel like translating the whole test, here is the bottom line of it: I made numerous tests with a test suite (Peter Finzel DVD) that is designed to evaluate any aspect of player and display. Most results (resolution, colour resolution, de-interlacer, scaler) were as close to perfect as possible. Note that the tests are exclusively PAL tests, so I cannot truely make any statements about NTSC mode, but visual impressions with both NTSC and PAL DVDs were equally stunning. However, you should use version 1027 or later firmware and "Video 2" mode to achieve these results. Earlier firmware or "Video 1" mode gave pretty bad results with the Peter Finzel test suite. My test equipment: PDP 435-FDE with BBK/Oppo 971H (firmware 1027), DVI to HDMI connection The only Oppo drawbacks I found: tray is a bit rickety, the old silver remote is not laid out very well, the player is only usable via DVI/HDMI as YUV does not use the DCDi chip. One temporary trouble: currently, not all remote controls will work with all firmware version. More information is available at ![]() Conclusion: the Oppo player is highly recomended with the 435-FDE - and thus, by extension, with the 505-XDE(FDE). You cannot buy a better player anywhere near the price of the Oppo, even high end players have a hard time to beat the Oppo on picture quality. |
das6Mio$ohr
19:55
#206
erstellt: 29. Dez 2005, |||
Im AVS Forum der AMIs kann jeder OPPO besitzer voten welche Punktzahl man dem OPPO geben würde. ![]() 1 = schlecht 10= seh gut Eine kleine hilfe für die noch unsicheren die mit dem Gedanken spielen sich auch einen OPPO zuzulegen . * |
vanbit
20:52
#207
According to this survey, it would seem this dvd player works fine. Thanks for the information. I would like to show you the problem I got with my denon by taking a picture of the screen but unfortunately my wife just dropped the camera which is now broken. I will find some other way soon. By looking at it close enough, in the dark background, I got pinkish noise. You got two particular examples in 2 different movies : Batman begin: when the poisonous gas is released, the picture in gotham city is already dark but with the gas cloud flying around, the viewing is just intolerable. It's a festival of mosquito noise, with yellowish/pinkish/ reddish blotches all over the screen. Second example is the dukes of hazzard unrated version. When general lee is encircled by cops cars. Driving off, General Lee is slewing round and round flinging stones and dust at cops. Yet again the denon is incapable to reproduce correctly this debris cloud. Anyway my ordeal is soon over cause I placed my order at oppo digital upon the basis of the general good opinion about this marvellous oppo 971H. Thanks you one more time for your concern. Bye. ![]() |
FreshGodFather
01:37
#208
erstellt: 30. Dez 2005, |||
Guten Abend, ich spiele mit den Gedanken mir auch den OPPo zu holen, hätte aber noch ne frage an alle schon glücklichen Besitzern: Wird bei Dvds mit mehrsprachigen Menüs das Menü auf deutsch dargestellt, oder zeigt er das in English an bzw. ist das im Player einstellbar? |
Bigkraut
02:50
#209
Tach, das Menü wird auch in Deutsch angezeigt. Kann man im Setup als Menü-Option einstellen, genau wie Sprache und Untertitel. Wenn es hier im Forum heißt der Oppo kann kein Deutsch, dann bezieht sich das nur auf die Bildschirmanzeige was Audio-Track bzw. Sprache des Untertitel angeht.Also kommt dort nicht wie gewohnt "01/02 DD5.1 German" sonder einfach nur die Audio-Tracknummer ohne Sprachkennung. Ist ein bischen ungewohnt, wenn man das von einen früheren Player gewohnt ist, aber es läßt sich aushalten. Für mich ein klarer Punkt beim nächsten Firmware-Update. Tschöö Bigkraut |
Jungholtz
22:57
#210
So, Ihr lieben! Hab gerade mal bei Linvingcinema nachgeschaut und festgestellt, dass Rene eine neue Firmware 1226 für den Euro-Oppo mit schwarzer FB und Scartausgang hat. PAL 2:2 und Delay bis 120 ms soll z.B. klappen. ![]() Er wollte die Software noch heute auf seiner Seite verfügbar machen. Noch nichts da aber das klingt doch sehr erfreulich. Zum Scalen hab ich auch noch was beizutragen (noch mit alter Software 927): Bei mir am Plasma ging auf PAL nur 576i. Bei NTSC hingegen alle Modi bis 1080i. Bin mir aber sicher, dass dieser Effekt entgegen Vermutungen anderer (s.o.) nichts mit dem Display zu tun hat, sondern mit der alten FW vom Juni! Das "teure" Ohr und Recluce haben ältere Player mit der 1022 FW drauf. Diese hat gegenüber der 927 sehr viele Verbesserungen, insbesondere auch im PAL-Bereich. Daher bin ich nun sehr gespannt auf die neue 1226. Guten Rutsch und ein neues Jahr mit vielen guten Videoabenden. ![]() |
Jungholtz
02:08
#211
erstellt: 31. Dez 2005, |||
Hier der Link zur neuen Software 1226, die weitestgehend der 1111b entspricht. ![]() Viel Spass beim Patchen! |
Friedensreich
04:18
#212
yoo!! Firmware-Upgrade funzt!!!! Zeigt jetzt auch bei geoeffnetem Tray und OSD die aktuelle Firmware an. Vor dem Upgrade hab ich natuerlich versucht mir bei einer DVD eine Stelle zu merken und ich glaube sogar, dass sie nach dem Upgrade ein wenig "laenger" schaerfer wirkt. Die "HIFI-Audiowelt" und das "restliche Leben" haben mir allerdings schon oft bewiesen, dass man gelegntlich doch nur sehr subjektiv urteilt, wenn man verliebt ist ![]() ... soll heissen.. einen Quantensprung hab ich nicht feststellen koennen... werde jetzt erstmal weiter gucken... ![]() |
housemeister1970
16:11
#213
Hi@all Nach all dem Weihnachtsstress bin ich nun auch dazugekommen, meinen Oppo (Europa-Version) nochmals mit der neuen FW 1226 zu testen. Was bitte bedeutet PAL 2:2 ? Ich hatte ja mit der 0917er FW das Problem, daß selbst im Video 2 Modus das Deinterlacing im Vergleich zum Panasonic DVD-S 97 nicht ganz optimal war. Leider hat sich nach dem Aufspielen der neuen Firmware daran nichts geändert ![]() Schade eigentlich! Ich kann zwar mit dem wirklich kleinen Defizit im Deinterlacing gut leben, aber ich versteh nicht, warum andere User hier davon noch nix bemerkt haben. Offenbar fehlt der direkte Vergleich zu einem Pansonic oder Denon Player mit DCDi. Der Filmmode des Panasonic scheint in meinen Augen besser zu greifen. Der Oppo hinkt da ein bissi hinterher. Ich sprech da wirklich nur von nem Bruchteil einer Sekunde. Ganz verstehen kann ich das zwar nicht, da der Oppo ja den FLI 2310 verbaut hat und der Panasonic lediglich den FLI 2301. Das lässt vermuten, daß nicht nur der Faroudja für gutes Bild und Deinterlacing zuständig ist. Nun, bin dennoch bildtechnisch vom Oppo nach wie vor sehr angetan und werde den Player auch behalten. Da der Support von Oppo wohl als sehr gut zu bezeichnen ist, geh ich mal davon aus, daß durch noch folgende Firmware-Updates mein Problem behoben wird. So long zu meiner Erfahrung zur neuen Firmware 1226 für den Europa-Oppo. Gruß Ralph |
semmi
16:47
#214
Habe auch die neue FM aufgespielt, die Gladiator Scene ( Überflug über das Kolosseum rechts unten ) wird nun klar dargestellt, vorher war das Flimmern sichtbar. Aber wie kann man den Video 2 und DIVX einstellen. Dieses Menü ist nicht unterlegt. Der Samsung 950 ist in dieser Scene leicht unterlegen und rein subjektiv sind die Farben besser. |
peternowo
16:57
#215
mal ne kurze frage - kann der oppo auch 720P signale über DVI Scalieren - um einen evtl. Overscan/Underscan zu regeln ? Danke für die Info Peter |
Friedensreich
18:21
#216
Die Schublade muss herausgefahren sein.. dann geht es. |
semmi
18:25
#217
Vielen Dank, das geht ja superfix mit den Antworten. ![]() ![]() ![]() |
semmi
20:02
#218
Ich bemerke keinen Unterschied zwischen Video 2 und 2 ! Wo soll der Unterschied sein???? |
semmi
20:03
#219
Sorry, soll natürlich 1 und 2 heissen! |
housemeister1970
20:34
#220
Da geb ich Semmi recht.................ich sehe ebenso keinen klitzekleinen Unterschied zwischen Video 1 und 2. Das widerum lässt den Verdacht aufkommen, daß eine hoffentlich noch kommende Firmware diesen Fehler behebt. Denn....... Wenn Video 2 optimal für Filmwiedergabe ist, dann müsste der Logik nach Video 1 ideal für Videoaufnahmen sein. Aber wie gesagt, es ist definitiv kein Unterschied sichtbar, egal ob ich Videomaterial über den Player laufen lasse oder Filmmaterial. Gruss und einen guten Rutsch euch allen wünscht euch Ralph |
sze
15:36
#221
erstellt: 01. Jan 2006, |||
Frage an andere Oppo User. Ein frohes neues Jahr wünsche ich allen. Ich habe ein kleines Problem mit meinem Oppo. Vielleicht kann mir jemand helfen. Folgende Problematik. Wenn ich einen schwarzen Hintergrund habe, so sehe ich auf diesem noch Teilfragnmente von der Bildschirminformation davor. Einfaches Beispiel. Wenn der Oppo Bildschirmschoner anspringt und das Oppo Zeichen über den Bildschirm wandert, so sehe ich an der Stelle wo das Oppo Zeichen war noch das leichte Oval des Oppo Zeichens nachleuchten. Aber nur ganz schwach. So macht sich das auch bei Filmen bemerkbar. Angeschlossen ist der Oppo via DVI (1080i) an meinem LG LX2r. Wenn ich über meinen anderen DVD Player via Componenten oder via PC (DVI) DVD's schaue, so kann ich das Verhalten nicht feststellen. Scheint also am Oppo zu liegen. |
recluce
17:07
#222
Gesetzt den Fall, dass Du PAL Disks schaust und über HDMI ausgibst: der Video 1 Modus versagt in manchen Szenen völlig, das Bild kann flackern oder gar blinken. Ich zitiere mich mal selbst aus meinem Test:
Kann natürlich sein, dass der Video 1 Modus jetzt verbessert worden ist, aber laut Living Cinema soll die 1226 Euro sich nicht großartig von 1111/1027 unterscheiden. Trotzdem, wer eine Peter Finzel DVD und die neue Firmware hat, möge doch bitte mal die De-Interlacer Tests mit Video 1 und Video 2 Modus fahren. |
semmi
17:18
#223
ich habs mit der Finzel CD getestet und ich bemerke nicht den geringsten Unterschied zwischen Video 1 und 2. Vor dem FM update war die Stufe 3 beim Progressiv und Interlace Test bei der Finzel CD sehr schlecht, jetzt ist nur noch ein wenig Flackern im linken oberen Bereich zu bemerken. |
recluce
17:25
#224
Danke für die schnelle Antwort! Dann gibt es wohl doch ein paar (kaum/nicht dokumentierte) Verbesserungen, dass der Video 1 Modus jetzt OK ist, ist definitiv ein Fortschritt. Jetzt stellt sich natürlich auch bei mir die Frage: wofür sind die beiden Modi den nun gedacht? |
vanbit
17:41
#225
Thanks for the info. Is enabling 'video 2 'in the menu the only thing I gotta do to get a decent picture? what other settings have you adjusted in the menu ? Will you please tell me exactly what your settings are with your plasma pioneer? Thank you in advance.Happy new year. Bye. |
das6Mio$ohr
19:42
#226
Ein paar seiten vorher: ![]() Meinem bekannten gefiel das Bild des OPPO noch etwas besser wie das des 2910. Er hat sich den OPPO nun auch aus den USA bestellt und ist super happy damit. * |
Netto
15:15
#227
erstellt: 02. Jan 2006, |||
Hi, hab mir jetzt auch den OPPO OPDV-971H -E DVD Player DVI HDMI Scart (OPDV971H-E)bestellt,mit dem zusatz das ich neueste firmware und FB haben möchte. Es scheint aber jetzt ja so zu sein das sich durch die neue FW1027 das ganze hickhack mit FB und FW auflöst.Prima ![]() Livingcinema hat schon bei mir via Paypal abgebucht,jetzt bin ich mal gespannt wann die nächste Lieferung in Holland ankommt und ich meinen Player erhalte. Zu den Grundeinstellungen: Codefree: Player einschalten, ohne Disk - Setup drücken - "9210" eintippen (keine sichtbare Reaktion bis zur Eingabe der letzten Ziffer) - es erscheint eine Anzeige mit diversen Informationen. Jetzt "0" eingeben, Region Code ist jetzt auf Null gesetzt. Fertig. Videoeinstellung: VIDEO 2 Schärfe - low Helligkeit - 0 Kontrast - 0 Farbe - 0 TrueLife - on CCR - on NR - off Wars das ,oder gibt es noch was zu beachten ? ![]() Angeschlossen über wird über DVI,ist das original Kabel zu gebrauchen oder sollte ich mir schonmal was neues suchen? Zum 720p modus: Gibt da noch eine Zoommöglichkeit,ähnlich wie Ezview bei samsung? [Beitrag von Netto am 02. Jan 2006, 15:19 bearbeitet] |
das6Mio$ohr
16:11
#228
Man kann in allen Auflösungen Zoomen. 1,2x / 1,3x / 1,5x / 2x / 2,5x / 3x / 3,5x / 4x / 0,5x / 0,3x / 0,25x. Wenn du den Player CODEfree machst kannst du auch gleich den VIDEO 2 Modus einstellen. Das geht auch nur ohne Disc im Laufwerk. Das wechseln der Auflösungen geht nicht im Widergabe-modus wie beim Samsung.Du mußt den Film anhalten und mit dem DVI-Butten auf der FB umschalten. [Beitrag von das6Mio$ohr am 02. Jan 2006, 16:18 bearbeitet] |
Bigkraut
17:00
#229
zum Zoom habe ich gleich mal ne Frage: Wie bekomme ich das Zoom-Symbol ausgeblendet?? Geht das überhaupt? Gruß Bigkraut |
Ranya
19:07
#230
Wer wäre den so lieb und könnte mal ein paar Bilder vom BBK posten? (Insbesondere die Rückansicht/Anschlussseite) PS: Kann sein das der Player gerade bei livingCinema.nl ausverkauft ist? |
pit55
19:23
#231
Hi,du musst auf den Kursiv-Link zum neuen Oppo klicken,das US-Modell gibt es nicht mehr ![]() |
Jungholtz
20:29
#232
Hallo Netto, von Dir und den anderen Aldi-Plasma-Besitzern hab ich schon viele Anregungen erhalten. Bei den neuen Geräten ist Regioncode schon auf 0 gesetzt. Aber für Video 2 musst du sowieso ins Setup. Da kannst du ja gleich nachsehen. Auch das Menü zur Grundeinstellung (ganz rechts) dort gleich mit bearbeiten (Sprachen etc.). Hier solltest du bei der Display-Einstellung NTSC einloggen. Ich hatte mich weiter oben sehr zuversichtlich gezeigt, dass die mangelnde PAL-Darstellung an meinem Plasma durch die FW 1226 behoben sein würde - das kann ich mir aber abschminken. Nach wie vor funktionieren alle NTSC-Modi. Bei PAL aber nur 576p. Liegt möglicherweise doch an unserem Display. Macht aber gar nichts, denn das NTSC-Bild ist bei entsprechendem Eingangssignal echt super. Selbst aufbereitete MPEG-Digitalstreams vom Satelliten kommen ansprechend rüber (vor einer Woche gab es Deep Blue mit einmaligen BBC-Unterwasseraufnahmen). Hier kann man bereits feststellen, dass die progressive Zuspielung von einer erstellten DVD besser als die Qualität des elementaren Streams sein kann. Na - würd mich interessieren, was du so für Erfahrungen machst. Bezüglich der möglichen Unterschiede zwischen Video Mode 1 und 2 habe ich festgestellt, dass die Wiedergabe im Modus 2 schärfer und pregnanter ist als im Alternativmode. Wie sieht es bei den anderen nach FW-Update aus? Das von sze bemerkte Nachglühen kann ich nachvollziehen. Kann ich aber nicht mehr mit dem alten Player vergleichen, da er schon sein Altenteil fristet. Hat schon jemand eine Idee zum Ausblenden des Zoomfaktors? Grüße aus den Vogesen |
Ranya
20:36
#233
Kursiv-Link? War ich jetzt gemeint? ![]() Den hier,... ---> ![]() ...,oder? Weil im Einkaufskorb steht mit 3 Sternen in Rot ***niet voorradig. |
das6Mio$ohr
23:24
#234
Hier die Rückansicht des BBK 971H ![]() Die komplette seite auf schwedisch ![]() * [Beitrag von das6Mio$ohr am 02. Jan 2006, 23:25 bearbeitet] |
Friedensreich
00:16
#235
erstellt: 03. Jan 2006, |||
Hallo, meine Fernbedienung aus Amerika is da! Das 'nenn ich Service! Dienstag bestellt und heute(Montag) schon da! Is wohl was dran, das die amerikanische Wirtschaft dynamischer ist ![]() Hab leider momentan keine Gelegenheit sie zu testen, melde mich die Tage dann nochmal. |
semmi
11:30
#236
Wie kann ich Noise Reduction aktivieren? Danke! |
ACamp
15:28
#237
erstellt: 04. Jan 2006, |||
Hallo Dieser Player scheint ja eine echte Alternative zu den etablierten Marken/Herstellern zu sein. Ist das Problem mit der nicht direkt anwählbaren deutschen tonspur und dem Untertietel mit der FW 1226 beim Euro-Oppo (der mit dem -E Zusatz) behoben ? Hab´zwar den gesamten Threat durchgelesen, aber die Antwort darauf nicht gefunden. Oder hab´ich da was übersehen ? Bestand das Problem beim Euro-Oppo überhaubt oder betraf es nur den aus den USA ? Vielen Dank. Gruß ACamp |
Ranya
18:45
#238
Wüste jemand mehr zu dem verbauten Chipsatz? MediaTek MT1389FE Verbaut worden ist der z.B. im: Yamaha DVD-S557 Starmedia DivX 5050 SilverCrest KH 6507 Siltex DV967 Das ganze hab ich aus ![]() Die Herstellerangaben sind bei Kompatibilität zu avi recht unterschiedlich. Die einen sagen DivX 6 Ja, die anderen Nein. Den MediaTek MT1389DE ist mir bekannt, der ist recht gut. |
Nova-Neo
19:17
#239
@ ACamp
Auf welchen Player sich das bezogen hat kann ich Dir zwar nicht sagen aber mit dem 972H-E, neuer FB und der FW 1226 kein Problem. Hab ich so bei mir am laufen... Gruss Sven... [Beitrag von Nova-Neo am 04. Jan 2006, 19:18 bearbeitet] |
ACamp
20:07
#240
Hallo Nova-Neo, meinst Du mit "neuer FB" die, die beim 972H-E gleich mit dabei war oder hast du Dir eine neue aus den USA bestellt ? Danke. Gruß ACamp |
Nova-Neo
20:27
#241
Bei den vielen Fb´s kann man schon leicht den Überblick verlieren. Ich meine die FB die neuerdings "serienmäßig" bei dem 972H-E dabei ist. Gruss Sven... |
ACamp
21:31
#242
Hi Nova-Neo, Ich muß leider nochmal nachfragen. ![]() DVD-Player einfach die DVD reinlege, sie starte und Untertitel und Sprache sind automatisch in deutsch ? Oder muß das vor dem Start (jedem ?) der DVD in Menu eingestellt werden bzw. wärend sie schon läuft ? Nochmals danke. Gruß ACamp [Beitrag von ACamp am 04. Jan 2006, 21:34 bearbeitet] |
recluce
22:31
#243
Vorher "True Life" auf "On" schalten, dann ist auch die Noise Reduction anwählbar. Kann sein, dass der Player dabei auf "Stop" stehen muß, da kann ich mich im Moment nicht genau erinnern. |
Bigkraut
22:48
#244
@ACamp:
Das erstere ist richtig, nach der Eingabe der Grundeinstellung beim Oppo auf deutsches Menü,Ton und Untertitel wird jede DVD dann wie gewünscht wiedergegeben. Es ist nicht notwendig dann bei Diskwechsel etwas neu einzustellen. Auch das Anzeigen von Audio bzw. Untertitel Sprache ist mit der neuen FW jetzt kein Problem - der Oppo kann da auch deutsch ![]() Meine Angaben beziehen sich auf die E-Version mit neuster FW. Gruß Bigkraut |
Netto
12:20
#245
erstellt: 05. Jan 2006, |||
Na toll . Die livingcinema.nl site ist down : "We are working on our servers to reestablish the livingcinema service. Please have some patience as we are working on it. Pending orders are handled, waiting for arrival of the products and dispatching is continuing. mail:livingcinema@revodesign.nl" Hoffe doch inständig das es keine Ausrede ist und ich noch meinen Player bekomme.Wenn der Laden pleite geht bin ich mal eben 250 euro ärmer,das tut mir weh. Da es bisher aber nur positives über livingcinema.nl zu lesen gab ,denke ich mal das es einfach nur ein technisches Problem ist und alle Vorbesteller wie versprochen auch ihre Ware ausgeliefert bekommen.Habe per Paypal Vorkasse geleistet und bekomme bei sowas schnell die Krise... ![]() |
Jungholtz
12:36
#246
Don't worry, Netto. Bei meiner Bestellung Mitte Dezember war der Server auch kurzfristig down. Das lag an einer Umstellung der Homepage wegen der Oppo/BKK Markenverwirrung. Gerät kam trotzdem relativ rasch, obwohl ich mir schon Sorgen machte, ob das Teil wohl noch vor Weihnachten ankommt. Grüße, Joachim |
Ranya
12:48
#247
Soweit ich gesehen habe, sind die Geräte z.Z. eh vergriffen. |
Netto
14:49
#248
Ich denke genauso,trotzdem habe ich Herzklopfen bis oben hin. @ranya Das ist richtig ich bin ein vorbesteller und vorrauszahler. |
LivingCinema
18:13
#249
Tja uns passiert das auch mal, adsl liegt raus, ihr habt zuviel "heruntergeladen" ![]() Aber jede keinen sorgen und "pleite" geschichten sind vollig unnotig. Mfg Livingcinema |
Ranya
19:57
#250
@Netto Pleite, hehe. Ne, dafür war die Resonanz hier im Forum viel zu positiv. Zumindest so positiv das ich mir auch einen oppo/bbk bestellt habe. Bin mir nicht sicher, aber wenn die vergriffen sind könnte es sein das wir ein Gerät mit frischer Firmware und ohne FB Hickhack bekommen. *Think pink [Beitrag von Ranya am 05. Jan 2006, 19:58 bearbeitet] |
Netto
08:12
#251
erstellt: 06. Jan 2006, |||
Alles wird gut ![]() ![]() Schade das es den Oppo nicht in schwarz gibt,ich kenne 2 Leute die ihn sich den sonst auch kaufen würden. |
Oppo Digital - OPDV971H DivX HD Problem VvoODy am 10.05.2006 – Letzte Antwort am 10.05.2006 – 4 Beiträge |
Oppo OPDV971H-E oder welche Alternative? sptotal am 20.06.2006 – Letzte Antwort am 21.06.2006 – 11 Beiträge |
Oppo Digital DV-981HD herbi14 am 04.12.2006 – Letzte Antwort am 29.03.2009 – 226 Beiträge |
Läuft Plus Piano HE 3100 mit Oppo OPDV971H über DVI ? Markus-71 am 04.01.2006 – Letzte Antwort am 04.01.2006 – 2 Beiträge |
OPPO DV-970HD inomics am 31.05.2006 – Letzte Antwort am 04.06.2006 – 9 Beiträge |
Vergleich zwischen DVD-S52 und OPDV971H DamienX am 20.06.2006 – Letzte Antwort am 21.06.2006 – 5 Beiträge |
Oppo DV981 Konfiguration HDMI-Ausgang AKHAAS am 19.11.2008 – Letzte Antwort am 05.12.2010 – 6 Beiträge |
Oppo vs Denon 1910 michael_hoch am 05.01.2006 – Letzte Antwort am 06.01.2006 – 5 Beiträge |
Kombination Oppo - Sanyo z4 michael_hoch am 27.01.2006 – Letzte Antwort am 06.02.2006 – 2 Beiträge |
Oppo DV-981HD bully2 am 16.03.2007 – Letzte Antwort am 16.03.2007 – 2 Beiträge |
Top 10 Threads in DVD-/DVD-A/SACD-Player der letzten 7 Tage
- mit externem Dvd-Laufwerk am Tv Dvd schauen möglich?
- DVD-Videoformat auf Stick - wie anschauen am TV?
- Sony SCD-XB 940 hat Leseprobleme
- Probleme mit Pioneer XV-DV303, bäuchte Hilfe!
- DVD Player ließt keine SD-Karte und USB mehr !
- Avi mal abspielen und ein ander mal nicht
- Stereo oder Lt/Rt?
- Untertitel nur für englische Parts in der ansonsten auf deutsch eingestellten DVD
- Probleme mit Panasonic SC-PT70
- Alten Pioneer-Laser Disc-Player optimal an AV-Receiver und LCD-TV anschließen
Top 10 Threads in DVD-/DVD-A/SACD-Player der letzten 50 Tage
- Registrierte Mitglieder929.108 ( Heute: 4 )
- Neuestes MitgliedPoslChelock
- Gesamtzahl an Themen1.559.704
- Gesamtzahl an Beiträgen21.732.907
