| HIFI-FORUM » Surround & Heimkino » A/V-Receiver/-Verstärker » Onkyo » TX-NR676E HDR Passthrough not working | |
TX-NR676E HDR Passthrough not working+A -A |
Chompas
erstellt: 08. Dez 2019, 11:19
Hallo! My apologies for writing in english. I moved to Germany recently and I'm currently learning the language I've adquired an Xbox One X which supports 4k and HDR. My TV is a LG Oled B8 which fully supports this modes. The problem I'm having is that when I connect the Xbox through the Receiver for passthrough, 4K is working as expected but HDR is not. As soon as I connect the Xbox directly to the TV the problem is solved so my guess is that there's something wrong with the HDR passthrough. I'm using all certified high speed HDMI cables and I'm using the same ones when I connect directly to the TV or through the receiver so I can confirm the cables are not the issue. The receiver is updated to the latest version 1121-5020-3070-0011. I've also found online about switching Standard vs. Enhanced modes by holding BD/DVD button and pressing the Power button but nothing appears on my receiver screen allowing to switch those modes when I press that combination of keys (https://forums.redflagdeals.com/anyone-having-issues-getting-4k-hdr-work-onkyo-receiver-ps4-pro-xbox-one-x-2280785/) I've read all the technical specifications and the main reason I bought this receiver was to be able to passthrough 4K and HDR. Without this feature it's useless for me. I sincerely ask for your help on this topic. Thanks. |
Tundor
erstellt: 08. Dez 2019, 16:10
Hey there, never had any issues with my PS4 Pro on HDR passthrough on the same model as you have. However, you can check the following (found this on google a while ago, this is apparently not explained in the users manual). Hold the physical button at your receiver of input source (for instance BD/DVD). While holding it, push the On / Standby button to cycle between HDR standard and HDR extendend. (Make sure to use the physical button on the receiver, not at your remote!) I would bet your input source is on standard right now and after you switch it to extended it's gonna work. Good luck. [Beitrag von Tundor am 08. Dez 2019, 16:11 bearbeitet] |
Chompas
erstellt: 08. Dez 2019, 21:19
Hi! You are a genius. I found something similar on the internet but I was doing it with the remote control and not the physical buttons so nothing was happening. I still can’t believe this is not specified in the manual. Thanks and thanks and thanks it works as expected now. You saved the day. |
Tundor
erstellt: 08. Dez 2019, 21:22
Thanks for the feedback. Glad I could help out =) |
xeno83
erstellt: 28. Nov 2020, 00:06
OMG...you saved my day, too. Thanks :-) |
xeno83
erstellt: 28. Nov 2020, 00:07
OMG...you saved my day, too. Thanks :-) Gerade einmal drei Beiträge und schon zwei Leuten den Tag gerettet. Grossartig. |
Onkyo TX-NR676E HDMI Passthrough Problem Penny2912 am 02.11.2017 – Letzte Antwort am 24.06.2022 – 10 Beiträge |
Onkyo TX-NR676E schleift kein HDR durch Master100AH am 27.10.2017 – Letzte Antwort am 28.11.2020 – 23 Beiträge |
TX-NR676E Tuner Level Visu_O am 13.10.2017 – Letzte Antwort am 20.10.2017 – 5 Beiträge |
Onkyo TX-NR676E mikeaudio am 04.01.2018 – Letzte Antwort am 05.01.2018 – 12 Beiträge |
Onkyo TX-NR676E vs PS4pro vs Hisense VS HDR evert am 29.10.2017 – Letzte Antwort am 16.05.2018 – 24 Beiträge |
HDMI Passthrough TX -509 Skahead69 am 03.05.2012 – Letzte Antwort am 03.05.2012 – 4 Beiträge |
TX-NR626 4k Passthrough Teerbaby am 05.12.2016 – Letzte Antwort am 06.12.2016 – 5 Beiträge |
Onkyo TX-NR676E Netzteil summt domitv am 03.11.2017 – Letzte Antwort am 05.01.2018 – 5 Beiträge |
Spotify Connect Onkyo TX-NR676E lodentoni am 28.09.2019 – Letzte Antwort am 29.09.2019 – 3 Beiträge |
Lautstärke Onkyo TX-NR676E Frage SethP am 25.11.2022 – Letzte Antwort am 27.11.2022 – 6 Beiträge |
Top 10 Threads in Onkyo der letzten 7 Tage
- Firmware Updates 2022
- Firmware Updates 2023
- Firmware Updates 2021
- Onkyo 2022: TX-RZ70 (11.2) und TX-RZ90 (13.2) mit Auro3D und Dirac Single/Multi BC
- Onyko TX SR606 kein Setupmenü auf TV
- Der "Onkyo TX NR 616" Stammtisch
- Information und Warnung zu HDMI-Board bei TX-NR708/808/1008
- ONKYO TX NR 636 - Katastrophe ARC und HDMI
- AVR schaltet sich über Fernbedienung nicht ab!
- Wii an Onkyo Receiver
Top 10 Threads in Onkyo der letzten 50 Tage
- Registrierte Mitglieder930.929 ( Heute: )
- Neuestes MitgliedMagic_Teddy
- Gesamtzahl an Themen1.564.183
- Gesamtzahl an Beiträgen21.845.991
