Firmware Updates 2021
Keshava
#1 erstellt: 16. Jan 2021, 11:55
Es gibt wieder für mehrere Onkyo AV Receivers und auch für andere Geräte neue Firmware Updates:
14 January 2021
TX-NR686, TX-RZ730, TX-RZ830, TX-NR474, TX-NR575E, TX-NR676E, TX-RZ720, TX-RZ820, TX-RZ920,
TX-8270, TX-8250, CS-N575D, CR-N775D, TX-NR555, TX-NR656/HT-R695, HT-S7800/7805, TX-RZ710,
TX-RZ810, TX-RZ1100, TX-RZ3100, PR-RZ5100, TX-L50/TX-L50WL, TX-L20D/TX-L20DWL(LS5200),
LS7200, NCP-302, NS-6130, NS-6170, R-N855
https://www.intl.onkyo.com/support/firmware/index.html
Notice of Firmware Update for TX-NR686
A firmware update for the TX-NR686 network A/V receiver is available through the unit's USB input. The latest update includes the following content:
Latest Firmware Number (16 digits):1071-2000-1070-0011
As of 14 January 2021
Change login method of TIDAL for enhancing security.*
 *Please refer to the link below for more details.
 https://www.onkyo.com/manual/sup/upd/tidal_onk.pdf
Fix the issue that cannot display the logo of certain TuneIn Radio stations.
Improve reception capability in certain TuneIn Radio stations.
Minor bug fixes and improvements stability.
[Beitrag von Keshava am 16. Jan 2021, 21:07 bearbeitet]
soulparadise
Gesperrt
#2 erstellt: 17. Jan 2021, 11:30
Keshava
#3 erstellt: 10. Jun 2021, 21:05
Firmware Updates 8 June 2021:
TX-NR696
TX-NR797
TX-RZ740
TX-RZ840
TX-RZ3400
TX-8390
Notice of Firmware Update for TX-NR696
Latest Firmware Number (16 digits):R125-0910-1140-0029
As of 8 June 2021
Adds Klipsch Optimized Mode.
https://www.onkyo.com/manual/txnr595/supple_595.pdf
Add search function for SONOS device on Web Setup Menu.
Increase the upper limit of connectable SONOS device from 8 to 32.
Fix the issue which the error of when accessing Web Setup Menu via OvrC HUB.
soulparadise
Gesperrt
#4 erstellt: 12. Jun 2021, 05:56
Mich würde der Klipsch Modus sehr interessieren und frage mich gleichzeitig, warum nicht auch andere Modelle dieses bekommen....
fplgoe
#5 erstellt: 12. Jun 2021, 07:23
Weil er offensichtlich überflüssig ist, wenn andere Verstärker das ohne ihn hinbekommen.
soulparadise
Gesperrt
#6 erstellt: 12. Jun 2021, 08:18
Leider gibt es diesmal parallel keine Pioneer Updates für die baugleichen Modelle,
wie zb. für meinen VSX-LX 504...
soulparadise
Gesperrt
#7 erstellt: 29. Jun 2021, 16:23
Information über den Klipsch-Modus:
Onkyo Worldwide: "Einführung in den "Optimierten Klipsch-Modus"
Der "Klipsch Optimized Mode" ist eine Funktion, die ab dem Onkyo TX-NR696 AV-Receiver durch ein neu veröffentlichtes Firmware-Update verfügbar ist.
Wir haben eine gemeinsame Studie mit Klipsch durchgeführt, um eine Klangfeldumgebung zu schaffen, die dem Designkonzept der Lautsprecher der Klipsch-Marke Reference Series entspricht.
Der Klipsch Optimized Mode wird zukünftigen Onkyo AV-Receivern, die noch in diesem Jahr erscheinen, hinzugefügt und wird als Update verfügbar sein, wenn neue Produkte der Klipsch Reference Series auf den Markt kommen.
Wir werden unsere Beziehung zu Klipsch weiter stärken, um die "beste Unterhaltung zu Hause" zu bieten, die AV-Receiver bieten können."
fplgoe
#8 erstellt: 29. Jun 2021, 16:56
Nun sind Klipsch und Onkyo ja auch unter einem Dach vereint, da werden solche Verbindungen natürlich intensiviert.
calafat
#9 erstellt: 22. Sep 2021, 13:01
Ich bräuchte dringend eine Firmware mit Airplay 2 zu dem Onkyo ns-6130 (Airplay tauglich), damit die Problematik Audio-Buffering mit Apple tv 4k gelöst ist.
Obwohl bereits zeitgemäß 2020/21 einige Geräte bei der Auslieferung mit Airplay 2 ausgestatten worden sind, tut sich Onkyo nun doch recht schwer daran, die ns-6130/70 Modelle und beide mit Airplay Modulen bestückt, nicht aufzurüsten. Gibt`s hierzu Neuigkeiten?
Es ist doch nun wirklich an der Zeit, diesem wertvollen Gerät einen neuen Schliff zu verpassen, denke ich. Mfg.
[Beitrag von calafat am 22. Sep 2021, 14:45 bearbeitet]
soulparadise
Gesperrt
#10 erstellt: 25. Sep 2021, 14:34
Auch wenn die neuen Geräte noch nicht in Europa verfügbar sind, ist es trotzdem interessant zu lesen, was es schon für neue Updates gibt:
https://www.onkyousa.com/downloads/
Firmware Update Onkyo TX-NR7100/TX-RZ50
(07-20-2021) We are pleased to offer this firmware update for the best possible performance of your Onkyo AV Receiver.
This update may be installed via USB or Network. TX-NR7100/TX-RZ50 (Current Version R107-0105-0010-0029)
The 07/20/2021 update will address the following:
1. The "Klipsch Optimized Mode" function has been added. Please refer to the link below for more details.
https://www.onkyo.com/manual/sup/upd/combo_onk.pdf
2. Virtual Remote, Limit Mode, and HDMI diagnostic functions have
been added to the Web Setup Menu.
3. Fixed the problem that the audio format of TIDAL playback
becomes AAC.
4. Fixed the problem of color corruption in Dolby Vision games on
Xbox.
5. Fixed a problem where the image would not be displayed when
VRR was turned on for Xbox.
6. Fixed the problem where High Bit Rate Audio such as Dolby
TrueHD would not be output when 4K or 8K resolution signals were
input.
7. Fixed the problem where audio would not be output from the TV
speakers when playing High Bit Rate Audio signals such as Dolby
TrueHD in TV audio output mode.
8. Fixed a problem with the HDMI diagnostic function Source Test.
https://www.onkyousa...7-20-2021_Rev1-1.pdf
Firmware Update Onkyo TX-NR5100
(07-20-2021) We are pleased to offer this firmware update for the best possible performance of your Onkyo AV Receiver. This update may be installed via USB or Network. TX-NR5100 (Current Version R109-0205-0020-0029)
1. The "Klipsch Optimized Mode" function has been added. Please refer to the link below for more details. https://www.onkyo.com/manual/sup/upd/combo_onk.pdf
becomes AAC.
Xbox.
input.
Firmware Update Instructions
Update the firmware via network or USB connection.
"Updating the firmware via network" You can update the firmware by connecting the unit to a network. "Updating the firmware via USB connection" You need a 128 MB or larger capacity USB storage for updating.
For details, see "Firmware Update" of the Instruction Manual.
https://www.onkyousa...R5100_07-20-2021.pdf
[Beitrag von soulparadise am 25. Sep 2021, 14:41 bearbeitet]
calafat
#11 erstellt: 04. Okt 2021, 09:53
Es ist mir beim näheren durchgucken der download page von Onkyo aufgefallen, dass der 18. April 2019 Support für AirPlay2 beim dem NS-6130 Geräten nicht ausgeführt oder aber bewusst ausgelassen war , wobei das nachfolgende Update vom 4. Juli (leider nur zur Stabilität von Airplay) wieder zu allen gängigen Geräten versendet wurde.
Ich bräuchte diesen Support dringend für meinen Apple tv 4k (6.Gen.), wegen der Verbesserung dieser notwendigen Audi-Bufferungskkapazität. Wäre das nicht fair und mit einer gewissen Toleranz verbunden, wenn diese NS-6170/30 Geräte nun endlich auch auf den Airplay 2 Standart gehoben werden könnten, wer kann man dazu anschreiben damit das Tatsache wird? Mfg.
[Beitrag von calafat am 04. Okt 2021, 09:55 bearbeitet]
soulparadise
Gesperrt
#12 erstellt: 08. Okt 2021, 17:57
Firmware Update Onkyo TX-NR6100/6050
(07-20-2021)
https://www.onkyousa..._6050_07-20-2021.pdf
TX-NR6100/6050
becomes AAC.
Xbox.
input.
[Beitrag von soulparadise am 08. Okt 2021, 18:07 bearbeitet]
soulparadise
Gesperrt
#13 erstellt: 15. Okt 2021, 18:49
Für einige Onkyo AV Receivers gibt es wieder neue Firmware Updates:
Firmware Updates 14 October 2021:
TX-NR696
TX-NR797
TX-RZ740
TX-RZ840
TX-RZ3400
TX-8390
A firmware update for the TX-NR696 network A/V receiver is available through the unit's USB input. The latest update includes the following content:
Latest Firmware Number (16 digits):R127-1011-1140-0030
As of 14 October 2021
Chromecast built-in version update to 1.52.
Fix the playback format issue converted as AAC format while playing TIDAL's FLAC audio format.
Für die neuen auch:
(10-14-2021)
TX-NR5100
(Current Version R112-0306-0030-0030)
The 10/14/2021 update will address the following:
1. Chromecast built-in version update to 1.52.
2. Fix the no sound and video issue via eARC connection
from SONY TV.
https://www.onkyousa...R5100_10-14-2021.pdf
(10-14-2021)
TX-NR6100/6050
(Current Version R110-0206-0020-0030)
from SONY TV.
https://www.onkyousa..._6050_10-14-2021.pdf
(10-14-2021)
TX-NR7100/TX-RZ50
from SONY TV.
https://www.onkyousa...-RZ50_10-14-2021.pdf
[Beitrag von soulparadise am 15. Okt 2021, 18:56 bearbeitet]
soulparadise
Gesperrt
#14 erstellt: 24. Nov 2021, 20:10
Firmware Updates 24 November 2021:
SUPPORT
Firmware Updates
Update History
24 November 2021
TX-NR686
Firmware Number: 1071-3000-1070-0011
TX-RZ730
Firmware Number: 1091-3000-1070-0011
TX-RZ830
TX-NR474
Firmware Number: 1141-9010-0070-0011
TX-NR575E
Firmware Number: 1141-9020-0070-0011
TX-NR676E/HT-R997
Firmware Number: 1141-9020-3070-0011
TX-RZ720
TX-RZ820
TX-RZ920
Firmware Number: 1121-6010-3070-0011
TX-8270
Firmware Number: 1131-9000-0070-0011
TX-8250
Firmware Number: 1101-5000-0000-0011
CS-N575D
Firmware Number: 1701-6000-0000-0011
CR-N775D
Firmware Number: 1801-6000-0000-0011
TX-NR555
Firmware Number: 2170-6050-7100-0011
TX-NR656
HT-S7800/HT-S7805(HT-R695)
TX-RZ710
TX-RZ810
TX-RZ1100
Firmware Number: 2190-6000-5080-0011
TX-RZ3100
PR-RZ5100
TX-L50/TX-L50WL
Firmware Number: 2160-7030-3080-0012
TX-L20D/TX-L20DWL/(LS5200)
Firmware Number: 2150-7020-3080-0012
LS7200
Firmware Number: 2180-7040-2070-0012
NCP-302
Firmware Number: 2150-9000-0000-0011
NS-6130
Firmware Number: 2140-9000-0000-0011
NS-6170
R-N855
Firmware Number: 2160-9000-0000-0011
https://www.intl.onkyo.com/support/firmware/tx-nr686.html
Latest Firmware Number (16 digits):1071-3000-1070-0011
As of 24 Novenber 2021
soulparadise
Gesperrt
#15 erstellt: 24. Nov 2021, 22:59
Oder auch hier erhältlich:
calafat
#16 erstellt: 25. Nov 2021, 15:12
Gestern neues update von Onkyo für den ns-6130 erhalten, war überrascht wegen erneutem support.Doch, airplay 2 war nicht integriert, schade. Dafür klappt die Verbindung mit TunelnRadio und dem "SatinJazz Lady Voice" Kanal wieder. Mfg.
TX-RZ830 aktuelle Firmware
lpop am 18.12.2022  –  Letzte Antwort am 18.12.2022  –  2 Beiträge
TX-NR555 oder TX-NR656?
HellsDelight666 am 25.03.2017  –  Letzte Antwort am 27.03.2017  –  6 Beiträge
Onkyo TX-SR373, TX-NR474, TX-NR575E - Einsteigerklasse Modelle 2017
Igelfrau am 22.02.2017  –  Letzte Antwort am 14.12.2021  –  44 Beiträge
Firmware update TX-RZ710
hagilife am 01.04.2017  –  Letzte Antwort am 13.04.2017  –  3 Beiträge
TX-NR555, Firmware error
GDouglas am 08.08.2018  –  Letzte Antwort am 11.10.2018  –  7 Beiträge
Onkyo TX-NR5010 | TX-NR3010 | TX-NR1010
plotteron am 27.06.2012  –  Letzte Antwort am 13.06.2018  –  2972 Beiträge
Oberklasse 2016 Onkyo TX-RZ1100, TX-RZ3100 und PR-RZ5100
Sonophil am 28.12.2015  –  Letzte Antwort am 16.02.2024  –  1798 Beiträge
TX-NR676E vs. TX-RZ720 (enormer Preisunterschied)
rahffde am 07.12.2017  –  Letzte Antwort am 13.02.2018  –  20 Beiträge
Onkyo TX-NR1030 oder TX-RZ1100
iJoker am 25.02.2017  –  Letzte Antwort am 25.02.2017  –  2 Beiträge
Onkyo TX-NR5007, TX-NR3007, TX-NR1007 Netzwerk-AV-Receiver
Gardi am 17.08.2009  –  Letzte Antwort am 19.05.2010  –  24 Beiträge
  • Registrierte Mitglieder930.496 ( Heute: 4 )
  • Neuestes MitgliedJazzTilDeath
  • Gesamtzahl an Themen1.562.995
  • Gesamtzahl an Beiträgen21.814.195
