Gehe zu Seite: |vorherige| Erste . 10 . 20 . 22 23 24 25 26 27 28 29 30 31 . Letzte |nächste|
H/K AVR 255/355 Bugthread
Eminenz
#1251 erstellt: 03. Okt 2009, 08:35
noggadijn schrieb:
was behebt denn die neue FW denn für probleme?
HK-Homepage schrieb:
Update Improvements
This software package includes the following updates for your AVR. Even if you have not encountered any of these issues, we recommend that you install the new software to take advantage of additional minor performance improvements:
* The elimination of audio glitches that previously occurred when the audio stream was interrupted or changed, particularly when changing sources.
* Issues with occasional loss of sound or inability to lock incoming high-resolution audio streams.
* Improved compatibility with cable set-top boxes when an HDMI™ connection is used.
In addition to the items resolved in this update, all previous improvements are also incorporated in this software, including:
* The AVR will now pass “whiter than white” and “blacker than black” video information when it is available. Note that not all video displays are compatible with these signals, and the video information cannot be displayed unless both the source and display are able to handle them.
* Occasional screen or display freezes or loss of video when the switching from analog video to HDMI™ video or between AM/FM and XM® radio have been eliminated.
* The AVR now corrects for frame jitter.
* Dolby® Pro Logic® IIx processing is now available for 7.1 systems when the input source is “DTS-ES® discrete.”
* Occasional pops and clicks with certain PCM audio sources have been eliminated.
peryair
#1252 erstellt: 03. Okt 2009, 08:42
moin
wo ist den die deutsche anleitung für den update-prozess???
Eminenz
#1253 erstellt: 03. Okt 2009, 09:18
peryair schrieb:
moin
Ist bei der Datei dabei.
markus_h.
#1254 erstellt: 03. Okt 2009, 12:13
Update Improvements
sollte man sich aufspielen, klingt gut!
Hats schon einer?
MetzTV
#1255 erstellt: 03. Okt 2009, 12:55
Hats schon einer?
Ich habs mir gestern aufgespielt, kann dazu aber nur sagen das alles genauso gut funktioniert wie vorher.
1. Ich habe meinen Receiver erst seit knapp einer Woche
2. Irgendwelche Bugs (auch die hier beschriebenen) konnte ich innerhalb dieser Zeit (mit der März-2009 Firmware) nicht nachvollziehen.
Tschö...
Eminenz
#1256 erstellt: 03. Okt 2009, 13:37
Ich packs morgen mal drauf, in der Hoffnung, dass der Zone II Bug dann weg ist.
flic*01
#1257 erstellt: 03. Okt 2009, 18:26
Habe sie vorhin aufgespielt,hatte mit der 96er kratzen in den Lautsprecher bei Bitstream zuspielung,wenn man die Lautstärke hochgeregelt hat war das Kratzen zu hören.
Mit der 95er hatte ich das Kratzen nicht mehr,dafür leichtes plopen bei auswahl des Tonformates,oder beim pause drücken.
Diese Probleme sind sind mit der neuen Software verschwunden.
Desweiteren finde ich das Bild etwas feiner aufgelöst,bei Full HD zuspielung,könnte mich da aber auch täuschen.
Bis jetzt kann ich die 97er empfehlen.
danio1978
#1258 erstellt: 03. Okt 2009, 20:00
download link?
flic*01
#1259 erstellt: 03. Okt 2009, 20:21
Bass-Statt-Höhen08
#1260 erstellt: 04. Okt 2009, 09:02
Hallo Eminenz,wie zufrieden bist du mit deinem Harman 255?
Sorry das ich dazwischen funke...
speedy7461
Gesperrt
#1261 erstellt: 04. Okt 2009, 10:23
Hab es auch drauf, und merke im Moment noch nicht viel. War vorher auch zufrieden. Hatte vorher hier und da leichtes ploppen. Jetzt absolut weg. Denke es ist auf jeden Fall zu empfehlen. Aufspielen geht recht fix. Wenn nur der Reset nicht wäre. Also schön vorher alles notieren und Zeit einplanen.
Eminenz
#1262 erstellt: 04. Okt 2009, 11:26
So das 100% Gerät ist es nicht, aber das war mir vor dem Wechsel eigentlich bewusst. Der Wirkungswinkel der Fernbedienung könnte besser sein und eben der erwähnte Bug im Zusammenhang mit Logic 7 und der Zone II. Ansonsten habe ich eigentlich keine Probleme mit dem Gerät und bin zufrieden, weshalb ich den Verkauf auch abgebrochen habe. Ich warte mal, wie sich die neuen Topgeräte schlagen und spare auf den 660.
peryair
#1263 erstellt: 05. Okt 2009, 14:12
servus
mit dem neuen update des 255, knacksen meine hochtöner der lautsprecher, die über eine separate endstufe am pre-out des 255 betrieben werden
...alles wieder nur verschlimmbessert
ironkrutt
#1264 erstellt: 05. Okt 2009, 14:38
Kann das sein das die neue HK Seite wieder off ist und die alte erscheint?
Wollte grad die neue Firmware saugen.
@navier:
Hast Du vieleicht die falsche Firmware hochgeladen für die US Geräte?
Wenn ich das starte ist alles Englisch und es wird AVR254 und 354 angezeigt.
Die neue HK Seite scheint grad nicht zu gehen?!?!
flic*01
#1265 erstellt: 05. Okt 2009, 18:59
Jo ist bei meiner software auch,habe sie direkt von der H/K seite.
HARMAN KARDON® AVR 255/AVR 355 (Im Ordner zu finden)
SOFTWARE UPGRADE INSTRUCTIONS
Auch der Download ist unter 255/355 gekennzeichnet,beim starten zeigt er die receiver 354/254 an,wie gesagt habe sie drauf,und bin bis jetzt sehr zufrieden damit.
noggadijn
#1266 erstellt: 06. Okt 2009, 17:09
Update Improvements
thx , hatte das schon gelesen,aber irrtümlicherweise schon für die 0.96 interpretiert
my fault!
jacobkreutzfeld
#1267 erstellt: 07. Okt 2009, 18:35
nach dem upgrade habe ich keinen ton mehr. automatisches einlesen funktioniert auch nicht, da kein testton zu hören ist.
vorher hatte ich ton. kann mir da jmnd helfen?
danke
flic*01
#1268 erstellt: 07. Okt 2009, 19:34
was haste fürn softwareupdatet drauf gemacht,und mit welchen kabel.
Hat er zum schluss nach dem updaten erfolgreich abgeschlossen angezeigt.
Mit was für ein Betriebssystem aufn Rechner.
[Beitrag von flic*01 am 07. Okt 2009, 19:35 bearbeitet]
jacobkreutzfeld
#1269 erstellt: 07. Okt 2009, 19:39
das aktuellste, hab es mir vorgestern aus dem netz gezogen.
hatte ein usb/rs-323 kabel und unter vista. angeblich war das upgrade auch erfolgreich. ich versuch das upgrade jetzt nochmal aufzuspielen.
flic*01
#1270 erstellt: 08. Okt 2009, 13:27
würde an deiner stelle es mit xp probieren,und wenn du die möglichkeit hast,anderes kabel benutzen.
Eminenz
#1271 erstellt: 08. Okt 2009, 14:10
Bei mir lief das unter Vista mit dem Adapterkabel eigentlich gut, nur das Update der Videosektion ging bei mir nicht, das war auch schon beim 347 der Fall.
pontnewydd47
#1272 erstellt: 08. Okt 2009, 15:45
Hallo beisammen,
also nachdem die HK Seite scheinbar wieder zurückgesetzt wurde und auch die 097 Firmware nicht mehr angeboten wird, nutzte ich naviers link für die Software und das Adapterkabel welches MetzTV (beides auf der Seite 25 und vielen Dank an beide für die Tips und Infos) empfohlen hatte. Bei mir lief das updaten einwandfrei, deutsche Sprache ist auch dabei und dass sich die FW mit Receiver 354/254 meldet kann ich nicht bestätigen - zumindest fiel es mir nicht auf. Also wie gesagt, Update erfolgreich.
Nun, wirkliche Veränderungen zur 96 FW konnte ich nicht feststellen. Ich bin nur mal gespannt was HK mit ihrer Homepage und dem Softwarelink treibt.
pontnewydd47
[Beitrag von pontnewydd47 am 08. Okt 2009, 15:45 bearbeitet]
flic*01
#1273 erstellt: 08. Okt 2009, 18:27
Stehen wenn man das updatet startet ganz oben am Rand 254/354
Desweiteren wäre mir sonst meine kiste mit sicherheit schon abgeraucht,wenns die Falsche wäre.Aber komisch ist das schon dass das updatet nicht angeboten wird,bzw.die ganze seite platt ist,geht nur die alte Homepage.
[Beitrag von flic*01 am 08. Okt 2009, 18:43 bearbeitet]
jacobkreutzfeld
#1274 erstellt: 08. Okt 2009, 19:18
so, ich habs noch mal versuht und jetzt habe ich ton, obwohl ich nichts anders gemacht habe, als beim ersten mal.
bisher hab ich noch keinen fehler festgestellt.
flic*01
#1275 erstellt: 09. Okt 2009, 18:33
Denke es liegt an vista,hatte auch probs damit.
Running
#1276 erstellt: 09. Okt 2009, 18:45
Habe die neue Firmware erfolgreich installiert, unter Vista 64 mit einem Billig USB-Serial Adapter.
Logic 7 Musik Bug ist immer noch vorhanden, EzSet/EQ hört sich immer noch sch****e an, also auslassen.
flic*01
#1277 erstellt: 09. Okt 2009, 21:18
Naja aber die plops sind wech,für mich hats sich gelohnt,denke auch was die HDMI kompatibilität angeht,sollte man es drauf machen.
Weiss nicht also hatte es auch mit vista 64 x-mal versucht,habe es nicht gebacken bekommen zu installieren.
Eminenz
#1278 erstellt: 10. Okt 2009, 05:53
Hat bei dir das auch mit dem Videoupdate geklappt
RsRichard
#1279 erstellt: 11. Okt 2009, 02:44
bei mir hats geklappt.
es gab mal eine änderung der videoplatine an einigen neueren verstärkern. auf diese lässt sich der video part der letzten 2 firmwares nicht zu hause aufspielen, das kann nur escoor. dazu waren auch einige beiträge hier in diesem thread. escoor geht dann momentan so vor, dass das videoboard getauscht wird, so dass du auch die ganz normalen firmwares flashen kannst.
flic*01
#1280 erstellt: 11. Okt 2009, 08:27
Naja hatte es mit xp komplett aufspielen können,bei vista 64 startete nicht das programm,also nur das erste fenster.
Die Homepage ist wieder online von H/K und das updatet fürn 255/355 ist genau das gleiche was ich vor ner Woche vor dem ausklingen der Homepage dort gesaugt habe.
hanswerner1
#1281 erstellt: 11. Okt 2009, 09:59
Leider schaffe ich es nicht, die neue Firmware von Harmann downzuloaden. Nach zustimmung der Lizenzvereinbarung geht ein neues Fenster auf, das sich sofort wieder schließt.
Kann mir jemand die SW per Mail zusenden ?
Ich habe aktuell die 96.1.1 drauf. Hatte vorher sie 95.?.?.
Hat sich bei der 96... etwas an der HDMI Steuerung verändert. Ich habe am Ausgang des 355 einen HDMI Switch.
Mit der alten FW Version konnte ich am 355 die Auflösung einstellen die wiedergegeben werden soll. Nun klappt das nicht mehr. bei 1080i Zuspielung kann ich nicht mehr 1080p einstellen und bei 1080p/24 Zuspielung kann ich nur noch 720p einstellen. Vorher war das problemlos möglich. Ohne Switch kann ich die Auflösung einstellen.
pontnewydd47
#1282 erstellt: 11. Okt 2009, 11:05
Hallo hanswerner1,
die Software hat navier hier abgelegt (direkter link S.25)
www.megaupload.com/?d=70RWQ6RH
wie ich oben auch beschrieben habe
hab sie auch dort runtergeladen, da ich Schwierigkeiten hatte sie von der HK Homepage zu saugen
pontnewydd
Running
#1283 erstellt: 11. Okt 2009, 13:32
Ja! Mein AVR ist von Sep 2008(Aufkleber Rückseite).
Eminenz
#1284 erstellt: 11. Okt 2009, 14:28
Dann würd mich mal interessieren, warum bei mir unter Vista 64 mit dem Adapterkabel weder beim 347 noch beim 255 das Videosektionsupdate funktioniert hat...
RsRichard
#1285 erstellt: 11. Okt 2009, 16:26
hab ich doch hier bereits geschrieben ;-)
Raefox
#1286 erstellt: 11. Okt 2009, 18:09
Also ich hab die neue Software nun auch drauf! konnte bisher keine Änderungen feststellen!
Wer bisher keine Probleme mit dem besagten "Ploppen" hat kann sich das Update wohl sparen.
flic*01
#1287 erstellt: 11. Okt 2009, 19:57
Muss mal was zum ploppen dazu sagen,dass das ploppen bei mir erst kam wenn die kiste richtig heiss war,also so nach ner stunde laufzeit konnte man das hören bei tonauswahl oder wenn man auf pause gedrückt hat. version 95er
Bei der 96er version war das kratzen nur zu hören bei direkter zuspielung von bitstream,also bei der ps3 hatte ich auch kein kratzen,sondern nur bei meinen panasonic bd35 und auch nur bei bitstream.
bei der 97er habe ich das absolut nicht mehr feststellen können.
Meiner ist baujahr november 2008
RsRichard
#1288 erstellt: 12. Okt 2009, 00:17
sein wir mal ehrlich, das ploppen is doch nix schlimmes? das is doch ganz leise?! wen stört das denn wirklich?
wenn ich mich an früher erinnere... da hats immer in den boxen geknackt, wenn man die quelle geändert hat, wenn man den track gewechselt hat etc. bei manch ganz altem verstärker sogar beim ändern der lautstärke. solange den boxen nix passiert^^
[Beitrag von RsRichard am 12. Okt 2009, 00:18 bearbeitet]
noggadijn
#1289 erstellt: 12. Okt 2009, 09:45
die, die das ploppen noch haben soltlen vllt mal den tipp des technikers (von mir weiter oben beschrieben!) mal ausprobieren und hier mal rückmeldung geben
greetz
Eminenz
#1290 erstellt: 12. Okt 2009, 09:46
Danke, das hilft weiter. Mein Gerät ist von Mai 09
flic*01
#1291 erstellt: 12. Okt 2009, 18:40
Stimmt schon,das ploppen war nicht so schlimm,deswegen hatte ich auch die ganze zeit die 95er drauf,aber das kratzen ging mir bei der 96er echt aufn sack.
Bin froh das beides wech ist,auch wenn das ploppen das kleinere übel war.
Triplets
#1292 erstellt: 13. Okt 2009, 08:45
Logic 7 Musik Bug ist immer noch vorhanden.
Für mich eines der Kaufargumente von Harman/Kardon-Receivern u. das haben die immer noch nicht im Griff?
Bin mal gespannt wenn die ersten Berichte zu den Nachfolgern auftauchen (160, 260, 360 u. 460).
navier
#1293 erstellt: 13. Okt 2009, 10:22
Was für ein Bug es ist?
dathunderbird
#1294 erstellt: 13. Okt 2009, 14:54
Kann einer der ein Gerät neuerer (2009) Produktion hat auch die im Thread beschriebenen Probleme feststellen?
Oder hat HK evtl. mittlerweile bei der Produktion was verändert und Bugs gefixt?
RsRichard
#1295 erstellt: 13. Okt 2009, 16:16
es hat sich nicht großartig was geändert.
manchmal ploppt es beim wechsel der quelle (welcher verstärker hat das früher nicht gemacht, da seh ich kein problem)
einige user berichten davon, dass es einen algorithmus fehler in logic7 music gibt. ich kann das bei mir allerdings leider so garnicht nachvollziehen.
ich hab momentan eigentlich garkeine probleme mit dem verstärker und alles funktioniert wie es soll.
longstag
#1296 erstellt: 13. Okt 2009, 18:58
Also das laute Knacken beim Umschalten von Fernsehsendern hat sich schon gebessert seit dem FW-Update.
Nur wenn die Sender in Dolby Digital oder Dolby PL II senden hab ich manmal ein knacken. (hört sich an wie Bitfehler).
Triplets
#1297 erstellt: 14. Okt 2009, 09:15
navier schrieb:
Was für ein Bug es ist? :?
Es handelt sich, wie weiter oben schon erwähnt, um einen Algorithmus-Fehler. Der Sound bei den Rears wandert ständig von LS zu LS bzw. schwillt kurzfristig an u. verschwindet auch in gleicher Zeit.
dathunderbird
#1298 erstellt: 14. Okt 2009, 09:16
Und dieser Bug ist trotz Firmware updates und neueren Produktionsdatum immer noch da?
Kann das jemand bestätigen der ein neues Modell hat?
RsRichard
#1299 erstellt: 14. Okt 2009, 09:50
ja also vielleicht hab ich was an den ohren, oder eine lautsprecher sind nicht hochwertig genug ^^ aber bei digitaler zuspielung über hdmi von meiner ps3 kann ich diesen bug leider seit anfang an nicht nachvollziehen.
Sebell
#1300 erstellt: 15. Okt 2009, 12:18
Kennt keiner das von mir hier geschilderte Problem?
Aktuelle Fimenware ist drauf
Link hier
RsRichard
#1301 erstellt: 15. Okt 2009, 23:51
das ist doch schon ewig so.... und das haben auch viele andere verstärker (nicht alle). was genau stört dich daran?! bei musikstücken fehlt eigentlich nix mehr und beim film schaun wird auch nix abgehackt. das ist nicht wirklich ein problem.
Quellenwechsel H/K AVR 255
rudinius am 28.03.2009  –  Letzte Antwort am 30.03.2009  –  2 Beiträge
Tonausfall bei H/K AVR 255
sven.kain am 17.02.2010  –  Letzte Antwort am 30.09.2012  –  13 Beiträge
H&K AVR 255 kein Bild mehr
yelli am 19.06.2022  –  Letzte Antwort am 22.06.2022  –  3 Beiträge
Problem: Harman-Kardon AVR 355
Tarkan.52 am 05.08.2009  –  Letzte Antwort am 06.08.2009  –  4 Beiträge
H/K AVR 355 HDMI Durchschleifen ohne funktion?
fisch99 am 24.01.2010  –  Letzte Antwort am 25.01.2010  –  2 Beiträge
H/K AVR-255 "Einstellungen" 1080p/24 bzw. 1080p/60
Sholva am 15.06.2009  –  Letzte Antwort am 15.06.2009  –  2 Beiträge
H/K AVR 255 plus Teufel Concept s
Elloco2 am 03.06.2009  –  Letzte Antwort am 08.06.2009  –  16 Beiträge
H/K AVR 255 Ton asynchron zum Bild
TschiesesKreist am 06.01.2009  –  Letzte Antwort am 11.01.2009  –  5 Beiträge
Kaufanfrage H/K
bonzo1999 am 08.08.2008  –  Letzte Antwort am 08.08.2008  –  9 Beiträge
H/K AVR 7300
vampear am 30.04.2005  –  Letzte Antwort am 12.03.2008  –  27 Beiträge
  • Registrierte Mitglieder930.678 ( Heute: 1 )
  • Gesamtzahl an Beiträgen21.826.636
