ASRock ION 330HT MCE Remote Controller im XBMC installieren.
furzgsicht
#1 erstellt: 19. Jan 2010, 20:55
Guten Abend
Ich habe den
http://www.asrock.com/nettop/overview.asp?Model=ION%20330HT
und den XBMC 9.11 live installiert.
Die Fernbedienung funktioren leider nicht ;(
http://www.asrock.com/nettop/photo/ION%20330HT-2%28Enlarge%29.jpg
Leider kann ich kein Englisch, aber es gibt eine möglichkeit es zu bedienen.
http://xbmc.org/forum/showthread.php?t=66388
The benefit of this livecd is that the very latest karmic ubuntu packages are used. While xbmc 9.11 live from xbmc.org uses kernel 2.6.31-16, this version uses kernel-2.6.31-17 and xorg 1.7.4 for example. The livecd is created with the SDK from trunk. With many thanks for Luigi Capriotti who helped me with this release.
I changed the following items compared to livecd from xbmc.org:
- Nvidia ION only
- Removed AMD/Intel drivers (saved 100mb)
- Nvidia driver package uses 20% less space.
- Torrent transmission deamon added.
- Sabnzbd deamon added.
- Alaska, Rapier 3.06, MediaStream 1.5 added to the livecd.
- coretemp.ko built against 2.6.31-17, added to the livecd.
- Nvidia nvclock added to the livecd.
- advancedsettings.xml added with references to coretemp.ko and nvclock, added to the livecd.
- .asoundrc added to /home/xbmc with hdmi and optical sound output at the same time!
- tvheadend references removed.
- Patched runXBMC (source) , in order to load preset settings (only if .xbmc doesn't exist).
- VDPAU selected as default render method.
- Default hdmi audio, downmix to stereo on
- Timesettings Europe/Rome
- uPNP, Remote webservices on (username/password: xbmc/xbmc)
- Installed Samba
smb.conf referenced to /home/xbmc/Videos, /home/xbmc/Music, etc
- Installed Proftpd and added the ftp command
- lm-sensors added in order to show cpu temperature
- lftp, zip commands added
Download: http://xbmcfreak.smetana.nl/xbmcfreak911livev7.zip
Also available a pre-patched XBMCLive version with Boxee beta1 installed on top.
Boxee Livecd Download: http://xbmcfreak.smetana.nl/boxeelive.zip
Disclamer: Use at your own risk!
Remark: At this moment when you decide to install use the "xbmc" user when asked to create a new user. I'm working on finish-install.d script to make this more flexible!
__________________
http://www.xbmcfreak.nl/
Kann mir jemand vielleicht dabei Helfen.
Ich habe 0 Linux erfahrung 8|
[Beitrag von furzgsicht am 19. Jan 2010, 20:57 bearbeitet]
Saico
#2 erstellt: 21. Jan 2010, 13:42
ich habe den Ion 330 HT bei mir stehen, allerdings mit dem Camelot Release als Installation, nicht als Live CD. Falls du die Live version bei dir lokal installiert hast, kannst du den von ASRock nachgelieferten Treiber für den IR Receiver installieren, das hat bei mir dann sofort funktioniert.
Den Treiberbekommste hier:
http://www.asrock.co...=ION%20330HT&o=Linux
Wenn du das ganze wirklich ständig als Live CD laufen hast (kann ich nicht wirklich glauben), ist diese installation eher nutzlos
Ich hoffe das beantwortet deine Frage
Ottihag
#3 erstellt: 22. Jan 2010, 18:59
ich habe den Asrock Ion 330 HT-BD und habe auch kurz XBMC Live drauf gehabt, aber kam damit garnicht klar, Wlan wurde nicht erkannt und auch sonst wollte ich doch lieber den Komfort der Windows-Installation. Leider funktioniert da ja noch keine Hardwarebeschleunigung was über die Live-Variante gegangen wäre, aber da warte ich einfach mal ab was die folgenden Versionen bringen, oder hat jemand erfahrung zB den MPC zu integrieren?
Ich habe ein großes Problem, und zwar gehr der kleine immer mal wieder ungefragt an, ich habe nur keine ahnung ob es irgendwie an signalen liegt, die an den HDMI laufen.. oder ob er vielleicht mit irgendeiner Fernbedienung nicht funktioniert Kennt jemand das Problem?
Zu der Fernbedienung (die dem HT beiliegt) komme ich noch nicht so klar, 1. geht meine XBOX360 auch an, wenn ich auf Power drücke (lässt sich das ändern/kanal wechseln oder so?)
Ist das eigentlich funk oder wirklich infrarot?
Und wo kann ich an der Tastenbelegung der Fernbedienung was ändern? bzw geht das überhaupt?
Ottihag
furzgsicht
#4 erstellt: 31. Jan 2010, 12:33
Da ich kein Linux kenntnis habe, weiss ich nicht wie ich das im XBMC installieren kann.
lirc-nct677x-1.0.4-ubuntu9.10.deb
lirc-nct677x-src-1.0.4-ubuntu9.10.deb
lirc-nct677x-x64-1.0.4-ubuntu9.10.deb
noisestadt
#5 erstellt: 31. Jan 2010, 16:03
Mit ssh auf den XBMC Rechner einloggen und dann mit
sudo dpkg -i lirc-nct677x-1.0.4-ubuntu9.10.deb
installieren falls deine XBMC Version 32bit ist (sollte bei der Live Version aber so sein soweit ich weiß). Du musst den Befehl natürlich in dem Ordner ausführen, in dem sich die Datei befindet. Falls Du nicht weißt, wie das mit ssh funktioniert, starte deinen XBMC Rechner und drücke STRG+Alt+F2 (oder eine der anderen F-Tasten außer F7). Damit solltest Du zur Eingabekonsole kommen. Dann weiter wie oben beschrieben. Falls du nichts am Benutzerkonto geändert hast, sollten Login und Passwort jeweils xbmc lauten.
Falls das alles nicht hinhaut, verweise ich in solchen Fällen gerne auf die XBMC Live CD von www.xbmcfreak.nl/en
Das ist eine angepasste Live CD für Atom ION PCs, also auch den Asrock.
furzgsicht
#6 erstellt: 31. Jan 2010, 18:15
Hallo
Ich habe den
xbmcfreak911livev10.zip installiert.
Mit FlashFXP habe ich diverse Linux Ordner.
In welche Ordner muss ich das File kopieren?
http://s10b.directupload.net/file/d/2056/qup3uxnc_jpg.htm
noisestadt
#7 erstellt: 01. Feb 2010, 00:35
Am besten dorthin, wo du Schreibrechte hast und die Datei wiederfindest. Versuchs mal mit /home/xbmc/Downloads oder /home/xbmc
Dann per ssh oder lokaler Konsole:
cd /home/xbmc
tehcy
#8 erstellt: 23. Feb 2010, 18:03
Hoi,
ich hab n ähnliches Problem... Treiber sind installiert aber die Signale der FB kommen total verzögert oder gar nicht an. Hab XBMCLive 9.11 v13 druff. Manchmal klappts und dann auch wieder nicht Hab schon paar mal neuinstalliert etc. aber naja, et will net..
jemand ne idee?
edit: hat sich erledigt, ohne Maus und Tastatur gebootet und funzt perfekt! NOT
[Beitrag von tehcy am 26. Feb 2010, 16:32 bearbeitet]
furzgsicht
#9 erstellt: 12. Mrz 2010, 22:15
Install Orginal Fernbedienung
das XBMC starten, dan mit mit CTRl ALT F1 für Konsole Eingabe
XBMCLive Login: xbmc
Password: xbmc
xbmc@ubuntu://$ sudo -s
[sudo] password for xbmc: xbmc
apt-get install wget
wget http://tinyurl.com/cir-driver-ion330ht
dpkg -i ir-driver-ion330ht.deb
Remote controll configuration:
Anwählen:
1. Nuvoton Transceiver/Remotes
2. None
mit mit CTRl ALT F7 zur Menü zurück ;-)
ASROCK ION 330HT mkv 1080p am Ruckeln
Raziel85 am 07.03.2010  –  Letzte Antwort am 04.05.2010  –  7 Beiträge
Xtreamer vs ASRock ION 330
thecube am 27.09.2009  –  Letzte Antwort am 18.10.2009  –  3 Beiträge
Asrock Ion 330 Probleme. Bitte um Hilfe
GP-Sven am 26.10.2009  –  Letzte Antwort am 28.12.2009  –  25 Beiträge
ASROCK 330 verschwommene Schrift
Eichi0815 am 25.01.2010  –  Letzte Antwort am 21.02.2010  –  3 Beiträge
Asrock ION 330 + Windows 7 - HTPC-Projekt für wenig Geld
Brainbug27 am 16.07.2009  –  Letzte Antwort am 09.12.2009  –  47 Beiträge
HD-Audio bringt ASRock ION 330 ins Stocken
Deckard2019 am 08.08.2009  –  Letzte Antwort am 10.08.2009  –  7 Beiträge
HDMI / Kein Bild nach S3/S4 / ASRock ION 330
Caeso am 02.10.2009  –  Letzte Antwort am 13.12.2009  –  2 Beiträge
Asrock 330 BD
Sectomy am 02.12.2009  –  Letzte Antwort am 02.12.2009  –  3 Beiträge
Nvidia ION Meinung
couer am 12.01.2010  –  Letzte Antwort am 22.02.2010  –  12 Beiträge
Asrock Ion330-BD
DanielQQ am 21.01.2010  –  Letzte Antwort am 02.02.2010  –  3 Beiträge
  • Registrierte Mitglieder930.464 ( Heute: 7 )
  • Neuestes MitgliedP0320055an
  • Gesamtzahl an Themen1.562.918
  • Gesamtzahl an Beiträgen21.812.321
