| HIFI-FORUM » Reparatur & Wartung » Elektronik (Stereo&Surround) » Lautsprecher und Subwoofer » Help! Canton sub 800R. | |
Help! Canton sub 800R.+A -A |
bypioner
erstellt: 15. Dez 2022, 11:59
Hi! I had a problem with the remote control from the canton sub 800 r. The battery in the remote control is dead, and it was replaced with a new one, but the remote control only blinks red. I tried pairing, as written in the manual ("press - Phase", "+ Phase" and "Power / Auto"). Unable to connect. The warranty has long ended, the support of the canton does not want to answer letters. Tell me where can I buy a new remote or how to pair? ![]()
CarlM.
erstellt: 15. Dez 2022, 12:30
First: Check keys of the RC: use a digital camera (or the camera of a smartphone) direct it to the rc and look on the display while you are pressing the needed keys. Each time you should see the (flickering) light of the IR-diode. Second: If all keys failed the test: You are that the polarity of the battery is correct? Look for markings + and -. Polarity ist okay but no key works: RC is defective or the new battery is too old / doesn't work. If the test fails for one or two keys: perhaps you never used these keys for a long time. Try to make the work by retrying the tests several times. Third: If the RC seems to be okay (all tests passed). Turn power off and wait a minute. Retry pairing. Remember: the keys should not be pressed at the same time but sequently. Good luck! Carl |
bypioner
erstellt: 15. Dez 2022, 13:08
This is a radio remote control, it does not have an IR diode. |
CarlM.
erstellt: 15. Dez 2022, 13:37
Sorry. I read the Canton-Homepage: www.canton.de/de/archiv/sub-800-rThen you can only check the batterie (polarity, voltage). Check for other hardware like power supplies, DECT-phones ... which could cause problems. |
bypioner
erstellt: 15. Dez 2022, 13:54
Thanks for the advice. It's a shame that the support of the canton does not want to help. |
CarlM.
erstellt: 15. Dez 2022, 14:49
I see that you read other posts as well. I did the same. My impression is, that the RC loses its memory when it is not used for a longer time (with empty batteries). Maybe it has to be programmed again. There are a lot of posts concerning problem with subs using this RC (800R, 1200R, ...). [Beitrag von CarlM. am 15. Dez 2022, 14:50 bearbeitet] |
mantasel
erstellt: 27. Jan 2023, 23:52
I need that remote, can You ship it to me? I am from Lihuania. Thanks!!
Canton Gamma 800R Curd am 23.11.2008 – Letzte Antwort am 10.11.2017 – 14 Beiträge |
Canton Chrono SUB 800 R - defekt? stromlos? Bart-77 am 10.09.2017 – Letzte Antwort am 11.09.2017 – 3 Beiträge |
Please help: Zeppelin classic streikt trustableman1964 am 21.01.2019 – Letzte Antwort am 25.03.2021 – 5 Beiträge |
HECO Superior 940 - Ersatzteilfrage - Help wanted germann am 24.11.2007 – Letzte Antwort am 04.10.2011 – 9 Beiträge |
Einschaltautomatik Canton AS40 Sub Heiza am 02.12.2009 – Letzte Antwort am 02.12.2009 – 7 Beiträge |
Canton Sub defekt -=]Phoenix[=- am 11.04.2018 – Letzte Antwort am 20.11.2018 – 8 Beiträge |
Canton SUB 300 defekt Dosenbier13 am 18.11.2023 – Letzte Antwort am 21.11.2023 – 7 Beiträge |
Canton Sub AS 40 defekt ? sir_marko77 am 11.01.2011 – Letzte Antwort am 01.03.2011 – 5 Beiträge |
Canton Sub 600 Schaltnetzteil defekt MineHarry01 am 17.08.2017 – Letzte Antwort am 19.04.2024 – 71 Beiträge |
komisches Geräusch Canton Sub 10.2 Sören# am 22.02.2020 – Letzte Antwort am 01.03.2020 – 18 Beiträge |
Top 10 Threads in Lautsprecher und Subwoofer der letzten 7 Tage
- Teufel Rockster Air geht nicht mehr an
- Bose SoundTouch 300 Soundbar ohne Funktion
- Grundsatzfrage: Elkos in Frequenzweiche durch Folienkondensatoren ersetzen?
- Hilfe, Membran eingedrückt!
- Sickenkleber,welchen nehmen?
- Teufel Cinebar 52 Soundbar kein Sound Bass schon
- Logitech Z906 lässt sich nicht mehr einschalten
- Lautsprecher knackt
- Delle aus Lautsprechergitter entfernen
- Teufel Subwoofer defekt. kein Ton mehr. Was könnte defekt sein ?
Top 10 Threads in Lautsprecher und Subwoofer der letzten 50 Tage
- Registrierte Mitglieder930.682 ( Heute: 5 )
- Neuestes Mitglieda61huebscher
- Gesamtzahl an Themen1.563.516
- Gesamtzahl an Beiträgen21.827.619
