| HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » B&O VX 5000 wie öffnen | |
B&O VX 5000 wie öffnen+A -A |
Kampfwurst_Hugo
erstellt: 13. Mrz 2010, 15:11
Hallo Ich habe einen Alten B&O VX 5000 VHS Recorder geschenkt bekommen. Er ist vieleicht für 10h im Betrieb gewesen. Leider hat das Spuren hinterlassen. Nun meine Frage: Wie kann ich das Gehäuse öffnen. Ich finde irgendwie die Schrauben um den Decke abzunehmen nicht. MFG Christoph |
tri-comp
erstellt: 13. Mrz 2010, 18:55
VX-5000 ?? THAT's an old Videorecorder As far as I remember you need to remove the 2 side plastic-panels. They slide out backwards when you lift the rear-end out a little (...with a flat screwdriver) and apply some force between the front-panel and the front of the side-panel (...again with a flat screwdriver) When the panels are removed you clearly see the screws that hold the cover. This oldie needs: 1) New rubber belts 2) A new pinch-roller 3) Mostly they need to be renovated renewing the complete white plastic gear-module. It's actually quite easy to replace when you take care to insert the new one EXACTLY like the old hooking-up levers correctly. Just 3 screws (...as I remember) need to go out to replace the entire gear-unit. 4) The Capstan Motor may be worn-out. Before renovating ANYTHING just grap the capstan shaft from the top-side and see if it has any slack. Push it from side to side and feel if it fits firmly in the bearing or it goes 'clack' - 'clack' from side to side. If it 'clack's throw away the recorder. A new motor is far too expensive. I used to have a friend who is now dead. He made new teflon-bearings for me to replace the original phosphorous-bronze bearings and teflon will NEVER wear out. good luck, mfg, /tri-comp |
Lautsprecher B&O Beovox 2700: wie öffnen? Rossi68 am 28.07.2007 – Letzte Antwort am 30.07.2007 – 6 Beiträge |
Beomaster 5000 Schnino am 01.02.2016 – Letzte Antwort am 01.08.2016 – 4 Beiträge |
B&O - Bedienungsanleitung bangbuex007 am 14.09.2008 – Letzte Antwort am 19.09.2008 – 2 Beiträge |
B & O Beomaster 1400 Skalenseil Hans-Hermann am 02.12.2019 – Letzte Antwort am 08.12.2019 – 5 Beiträge |
B & O Overtuere Radiio defekt norwegen11 am 28.09.2013 – Letzte Antwort am 30.09.2013 – 4 Beiträge |
su-vx 720 technics papaja am 05.01.2008 – Letzte Antwort am 05.01.2008 – 3 Beiträge |
Reparatur B&O Beocenter 3500 am 20.03.2008 – Letzte Antwort am 23.03.2008 – 8 Beiträge |
Reparaturanleitung B&O Beogram 1000 grattler01 am 17.04.2009 – Letzte Antwort am 18.04.2009 – 2 Beiträge |
B&O Beocenter 7700 Reparaturversuch Joad am 19.08.2012 – Letzte Antwort am 13.09.2012 – 12 Beiträge |
Ältere B&O Anlage nachrüsten gigaganti am 21.09.2014 – Letzte Antwort am 21.09.2014 – 2 Beiträge |
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder930.959 ( Heute: 4 )
- Neuestes MitgliedLucias
- Gesamtzahl an Themen1.564.262
- Gesamtzahl an Beiträgen21.848.781
