Gehe zu Seite: |vorherige| Erste . 10 . 18 19 20 21 22 23 24 25 26 27 . Letzte |nächste|
Zappiti Media Center
apachelance
#1052 erstellt: 28. Okt 2018, 10:06
Ok, Danke für die Info.
apachelance
#1053 erstellt: 29. Okt 2018, 17:27
Es gibt eine neue Version:
Improvements of version 4.19.222 (Bêta)
New features:
If a file contains the keyword “3D” in its title or path, it is automatically associated with the category 3D.
If a file contains one of the keywords “SBS, HTAB, Stereoscopy, MVC” or if its extension is “.mk3d”, it is automatically associated with the category 3D.
Improvements:
Simplifying the message to choose between “Immediate access to the movie” and “Playback with Blu-ray menu”.
Improved message design indicating the availability of the new beta (3.12) firmware that supports Blu-ray menus.
The list of terms to exclude when parsing the file name has been improved.
The 2.20: 1 and 2.39: 1 display ratios are now proposed in the synopsis edition.
A message warns users that personal music tracks can sometimes be shared.
The Zappiti Soundtrack feature now works in Offline mode.
Improvement of the advanced task “Deletion of duplicates” to take into account a new behavior.
Fixes :
Fixed an issue where the path to the music track overflowed when it was too long.
Fixed an issue that prevented users from connecting to certain shared folders configured without a password.
Fixed a scan problem that sometimes unnecessarily scanned all files already present in the collection instead of analyzing only the new contents.
On MacOS, fixed an issue that prevented access to shared folder contents on a Synology.
Fixed an issue launching the next episode that might not work in some cases.
Fixed a malfunction of the application that could occur during synopsis navigation (switching from one to another).
It is now possible to associate a music track with a personal group.
Remove duplicate episodes in some collections.
The search now correctly displays all the films of an actor or director.
GorillaBD
#1054 erstellt: 29. Okt 2018, 20:28
Die Version ist bereits ebenfalls für Synology verfügbar.
Leider hat auch diese Version dennoch auf meinem Windows-PC wieder einen Full Scan anstelle eines inkrementellen Scans der Sammlung ausgelöst.
Das kann jetzt einmalig durch den Versionswechsel bedingt sein. Beobachte und berichte.
GLG GBD
[Beitrag von GorillaBD am 29. Okt 2018, 20:32 bearbeitet]
Schnuppi81
#1055 erstellt: 29. Okt 2018, 22:45
Hallo , ich habe das Update gemacht - und jetzt Bootet er immer das Video Center Bzw lädt meine Sammlung.
Aktualisieren Sie ihre Sammlung steht immer wieder als aktuelle Aufgabe ! Könnte verzweifeln ..
Jemand eine Idee ?
BG
Edit : jetzt steht die Sammlung scheint beschädigt zu sein ?
[Beitrag von Schnuppi81 am 29. Okt 2018, 23:21 bearbeitet]
GorillaBD
#1056 erstellt: 04. Nov 2018, 08:21
Nach dem Versionswechsel auf die Beta 220 und dem direkt danach einmaligen Full-Scan läuft der inkrementelle Scan auf meinem PC und den Playern wieder einwandfrei.
GLG GBD
[Beitrag von GorillaBD am 04. Nov 2018, 08:22 bearbeitet]
sven29da
#1057 erstellt: 09. Nov 2018, 16:35
Hallo Zusammen,
da ich es aktuell nicht bewerten kann wohin meine Frage am besten passt (vermutlich hier her) erlaube ich meine Frage die ich vorhin unter "Zappiti 4K HDR" gepostet habe, auch hier zu stellen.
Info, ich habe noch keine Zappiti da Modell aktuell nicht verfügbar ist, nutzte aber jetzt schon die wenig freie zeit um mich mit zu beschäftigen.
Anliegen:
Da ich ein Synology NAS (RS815) habe, worauf auch die Filmne liegen werden, die Frage an die Erfahrenen, was für und was gegen die Installation des Zappiti Servers (Paket) auf das eigenen NAS spricht?
Alles per LAN angebunden mit einer 50Mbit DSL Leitung.
Dafür:
Vermutlich schnelles durchforsten nach Filmen beim blättern bzw wenn man nach was sucht wie bestimmten Film, Gene oder dergleichen
oder ist das bei einer 50Mbit DSL verbindung vernachlässigbar?
Dagegen:
"Dritt/Fremdanbieter" Software auf ein NAS wo man nie sicher sein kann, was mit dem NAS dadurch passiert. Heutzutage gibt es ja Schadsoftware usw.
Wie sind Eure Erfahrungen und Meinungen?
Danke & Grüße
Sven
Memphis
#1058 erstellt: 09. Nov 2018, 18:19
Ein wenig Missverständlich. Du hast eine Synology auf der die Filme liegen und da soll die Software darauf? Und das möchtest du via DSL (50MBit/s) streamen oder warum schreibst Du die DSL-Anbindung? Internetverbindung braucht beim Hinzufügen auch die Synology-App.
Ich mag es nicht auf der Synology, da ich diese nur bei Gebraucht anschalte und es mich nervt, die extra dafür anzuschalten. Ab und an habe ich aber Probleme bei der Identifizierung (Cloud) gehabt, die andere mit Library auf NAS nicht hatten. Zufall, anderer Fehler oder weil es nicht Cloud ist? Kann an allem und gar nichts gelegen haben.
sven29da
#1059 erstellt: 09. Nov 2018, 19:36
Was ich bis jetzt gelernt habe ist, dass entweder die Datenbank in der Cloud liegt oder wenn man das "Zappiti Server Paket für Synology" auf dem NAS nutzt, die Datenbank auf dem eigenen NAS liegt.
Nutzt ich den Zappiti Media Player im Heimkino und durchstöbere z.B. die Filmauswahl, sucht er beim ersteren ja über das Internet per DSL Leitung in der Cloud. Da weis ich nicht wie gut das läuft sprich ohne zu Ruckeln, Nachzuladen oder dergleichen.
Starte ich dann ein Film, wird der Zappiti Media Player den Film auf der Festplatte im NAS abspielen
Oder habe ich was falsch verstanden
Habe ich die Datenbank auf meinem NAS, könnte das oben beschriebene Prozedere sofern es per DSL hackelig oder dergleichen wäre, schneller ablaufen.
Oder denke ich auch da falsch?
Nun verständlich was ich meinte/meine?
Nick_Nickel
#1060 erstellt: 09. Nov 2018, 19:49
Das ZMC kann man auch auf dem PC installieren.
Meine Filme habe ich auf einem Synology,
Installiert auf dem Syno habe ich den Zappiti Server und das Prog Mono.
Bearbeite ich meine Sammlung auf dem PC (was auch viel besser geht als auf dem Zappiti) werden beim einschalten des Player automatisch alle änderungen auf dem Zappiti angezeigt.
Die Datenbank ist auf dem Syno und der PC und der Zappiti kann darauf zugreifen
Filme abspielen geht über das Heimnetzwerk ruckelfrei auch UHD.
[Beitrag von Nick_Nickel am 09. Nov 2018, 19:50 bearbeitet]
sven29da
#1061 erstellt: 10. Nov 2018, 00:38
Wie ich schrieb, ich bezog meine Überlegung bzgl. Ruckeln/Haken oder laufendes Nachladen nicht auf die Filmwiedergabe, sondern z.B, auf das Durchsuchen der Sammlung nach einem Film oder wenn man sich dann die Details vom Film ansehen möchte.
Jetzt nachvollziehbar?
Habe vorhin hier http://zappiti-deutschland.de/zappiti-media-center/download/ bzgl. Synology Server dies gelesen:
"Die Cover werden zum Zappiti Player 4K gesendet und im internen Flashspeicher gesichert."
Habe einige YouTube Videos gesehen, einiges hier und auf anderen Seiten gelesen und versuche echt mich alleine schlau zu machen, aber ich muss Fragen, was liegt wo?
Filme liegen auf den Festplatten auf dem NAS, ok.
Wo liegen die ganzen Filminfo wie Beschreibung, Tags, Trailer, usw? im Link wird ja nur von Covers geschrieben, welche auf dem Client sprich auf dem Zappiti Media Player, liegen. Oder liegt alles auf dem Client und beim Start syncronierst er sich mit der Datenbank?
Wi liegen die ganzen Angaben welcher Film wo auf dem NAS abliegt?
@Nick
Was ist "Prog Mono"? Frage hat sich erübrigt, da ich die Install Anleitung bzgl Synology gelesen habe.
Wenn die Datenbank auf Deinem NAS liegt (da Du vermutlichauf dem NAS den Zappiti Synolgy Server installiert hast), warum noch einmal die Datenbank auf dem PC? Ich ging davon aus das es bei einer Client-Server Lösung nur EINE Datenbank gibt welche man mit einem Programm/Tool, bearbeitet sprich die Filme ediitiert, umbenennt, Gene/Gruppen erstellt und verwaltet, usw usw
Wie heist aber dieses Programm/Tool? Frage hat sich erledigt, denn das Programm heist "Zappiti Media Center V4 für Windows"
ZMC ist ja wie ich hier http://zappiti-deutschland.de/zappiti-media-center/ lese, die eigentliche Oberfläche, vergleichbar wie KODI.
Ich denke und hoffe das nun mehr Licht ins dunkle kommt.
Achja, die Links am Anfang des Threads ergeben nur Seitenlange ASCII Zeichen
Danke und Grüße
Sven
[Beitrag von sven29da am 10. Nov 2018, 01:30 bearbeitet]
GorillaBD
#1062 erstellt: 10. Nov 2018, 06:36
Hier hatte ich schonmal beschrieben, welche Server und Clients es für das Mediacenter gibt:
GorillaBD (Beitrag #931) schrieb:
Heisst, auf dem entsprechenden Speichergerät muss auch die Zappiti-Server-Software laufen und diese Server-Software gibt es derzeit nur für Synology- und Asustor-NAS. Das Softwarepaket für PC und Mac beinhaltet sowohl die Server-, als auch die Client-Software, daher kann man die Datenbank auf einem PC sowohl hosten, als auch wiedergeben.
Somit ergibt sich (derzeit)
Hosts (Datenspeicher und Server)
- PC
- Mac
- Synology-NAS
- Asustor-NAS
- Zappiti-Cloud
Clients (Wiedergabe)
- PC
- Mac
- Zappiti-Player
Auf allen Clients ist es möglich, eine lokale Kopie der Cloud-Datenbank zu speichern, allerdings mit den in meinem Vorbeitrag genannten Einschränkungen bezüglich der Aktualisierung der Daten.
Die Datenbank auf einem NAS zu hosten, hat imho drei Vorteile:
- Die Reaktionsgeschwindigkeit kann ggü. dem Cloud-Hosting höher sein, besonders wenn über die Internetleitung auch noch gleichzeitiger Traffic anderer Geräte stattfindet
- Bei Störungen des Internets oder Unterbrechungen/Ausfällen des Cloud-Servers ist die Datenbank davon nicht betroffen.
- Die Datenbank lässt sich mit den Backup-Tools eines NAS einfach sichern
Man benötigt also die Internetverbindung zur Datenbank nur noch zum Update, um die Bilder und Synopsen zu neuen Filmen/Serienfolgen herunterzuladen.
Sämtliche Daten der Datenbank liegen immer ausschliesslich auf dem Server. Auf dem Client werden lediglich aktuelle und Informationen der Datenbank noch zusätzlich gecached, damit einem der Zugriff noch schneller vorkommt.
Hostet man seine Datenbank in der Cloud, kann man davon eine lokale Kopie oder eine Server-Kopie anfertigen. Die lokale Kopie liegt dabei auf dem Client, die Server-Kopie auf dem NAS oder PC/Mac. Soll auch dazu dienen, dass man im Falle einer Internetunterbrechung unabhängig vom Netz ist oder den Player mit in den Outback-Urlaub ohne Internetverbindung mitnehmen kann.
Haken der lokalen Kopie: Kostet entsprechend Spiecherplatz, ist die Datenbank grösser als der freie Speicher des Players, "platzt" das Konzept. Zweiter Haken für sowohl lokale, als auch Serverkopie der Cloud: Funktioniert nicht inkrementell, man muss also nach jedem Update der Cloud-Datenbank die lokale oder Serverkopie wieder vollständig neu erzeugen, was entsprechend lange dauern kann.
Jeder Client kann auf jeden Server zugreifen: Somit ist es z.B. möglich, auch eine NAS-geführte Datenbank bequem vom PC aus zu verwalten
Hoffe, ich konnte damit etwas zusätzliches Licht ins Dunkel bringen?
Den vielleicht noch:
VORSICHT bei Versionswechseln des Mediacenters. Hostet man seine Datenbank auf einem NAS, müssen sowohl NAS als auch alle entsprechenden Clients upgedated werden. Bevor man also mutig neue Beta-Versionen installiert, kontrollieren, ob es auch die zugehörigen Versionen bereits für den NAS gibt. Im Falle des Synology-NAS erscheinen dort neue Versionen immer zeitgleich zu PC/Mac und Player. Beim Asustor-NAS ist das nicht immer der Fall.
GLG GBD
[Beitrag von GorillaBD am 10. Nov 2018, 06:48 bearbeitet]
Nick_Nickel
#1063 erstellt: 10. Nov 2018, 09:26
Das ist schnell beantwortet.
Das einrichten und das bearbeiten der Sammlung geht mit dem PC viel schneller als auf dem Zappiti selber.
Jede Änderung wird dann auch auf dem Syno gespeichert.
Memphis
#1064 erstellt: 10. Nov 2018, 10:13
Und als Ergänzung zu den Trailern, die werden aus dem Internet abgespielt. Da macht es keinen Unterschied, ob der Link zu dem Trailer in der Cloud oder auf dem NAS gespeichert ist.
sven29da
#1065 erstellt: 10. Nov 2018, 10:57
Hallo und guten Morgen,
vielen lieben Dank GorillaBD für die tolle Ausführung, denn nun ist es wirklich mir klarer geworden
Ich werde auch einen Teufel tun eine Beta zu testen. Ich gehöre zu denen die froh sind, wenn alles läuft und dann werden die Finger davon gelassen
Auch Danke an Nick udn Memphis
Habe heute Nacht auch bereits das Zappiti Packet auf denm NAS installiert und auf dem Laptop mal das ZMC, aber war dann dabei fast eingeschlafen und im Zappiti Video kann bei "einen Ordner mit Filmen hinzufügen" mein NAS finden, findet aber keinen Ordner.
Als User habe ich den eingetragen den ich vorher im NAS als Benutzter mit Recht "Lesen/Schreiben" eingetragen habe.
Werde später mal alles durchstarten, vielleicht hilft das ja schon, aber erst einmal ist Arbeit angesagt
Ach, es wird geschrieben Ordner "Filme" und Ordner "Serien". Müssen die Ordner genau so heißen?
Meine Struktur ist nämlich eine andere. Vielleicht liegt es schon daran
Schönen Samstag
Sven
[Beitrag von sven29da am 10. Nov 2018, 11:02 bearbeitet]
Nick_Nickel
#1066 erstellt: 10. Nov 2018, 11:20
Ich habe es so gemacht.
Im ZMC muß man eine Verknüpfung zu Filme und und eine für Serien anlegen.
Ob man die so nennen muß glaube ich nicht.
Ich habe noch einen Oppo wenn ich auf dem Syno auf die Filme zugreifen möchte geht es nur über den Ordner Video.
Synology
[Beitrag von Nick_Nickel am 10. Nov 2018, 11:22 bearbeitet]
GorillaBD
#1067 erstellt: 10. Nov 2018, 13:55
Wähle im Ordner-Auswahlfeld "Ein Gerät manuell hinzufügen"
Dann im Eigabefeld die IP-Adresse des NAS und einen Deiner dortigen Freigabeordnernamen eingeben.
Dann noch die Zugangsdaten eingeben.
Danach sollten Dir sämtliche NAS-Freigabeordner zur Auswahl angezeigt werden.
GLG GBD
[Beitrag von GorillaBD am 10. Nov 2018, 13:56 bearbeitet]
GorillaBD
#1068 erstellt: 10. Nov 2018, 14:02
Nein, für Zappiti-Video sind keine speziellen Ordnernamen notwendig, weil die spätere Identifikation über die Filenamen läuft, nicht über Ordnernamen.
Mein Oppo 203 kann ebenfalls Videodateien auch in beliebigen Ordnerpfaden finden, sofern er über SMB zugreift.
Nur bei Zugriff des Oppo über DLNA müssen die Videodaten in einem Ordnerpfad liegen, den der Mediaserver der Syno dann auch abscannt.
GLG GBD
[Beitrag von GorillaBD am 10. Nov 2018, 14:03 bearbeitet]
sven29da
#1069 erstellt: 10. Nov 2018, 15:01
Danke Euch, aber es will nicht funktionieren und das NAS kann ich aktuelll nicht neu starten, da es noch Daten von USB Platte auf eine NAS Platte schaufelt.
Habe bzw. hatte am HiMedia drei USB und eine interne Festplatte.
Aktuell schaufel ich alles auf das neue NAS, sprich alles von USB Platte auf das NAS, dann kommt die Platte als nächstes Volume (Basis) ins NAS und dann werden die nächsten Daten von nächster USB auf das NAS geschaufelt.
Ich habe folgende Struktur die ich schon immer nutze und auch diese Woche mit dem Zappiti Support geklärt habe das an meiner Struktur nichts auszusetzen ist und Zappiti alles finden wird.
Im NAS was bei mir den Namen"NAS_FilmStation" hat, werden wenn alles fertig ist, vier Platten sein.
Jede hat einen eigenen Namen zur Identifizierung sprich HDD1, HDD2, HDD3 und HDD4.
Jede Plattte hat jeweils einen "gemeinsamen Ordner" mit jeweils Namen "Filme_FilmStation_HDD1", "Filme_FilmStation_HDD2", "Filme_FilmStation_HDD3" und "Filme_FilmStation_HDD4".
In jedem Ordner gibt es einen Unterordner "Spielfilme" und darunter gibt es Ordner "2D", "3D" und "4K".
In diesen Ordner liegen dann jeweils in Unterordner die Filme.
Als Beispiel damit es nachvollziehbar ist beim Film Hobbit wäre der Pfad Filme_FilmStation_HDD1\Spielfilme\2D\Hobbit\hobbit.mkv
Dennoch klappt es nicht, nicht wenn ich in der Auswahl die IP meines NAS auswähle noch wenn ich manuell die IP Adresse des NAS und den Namen Filme_FilmStation_HDD1
Bekomme auch keine Anfrage nach User und Passwort. Sollte das nicht wie oben geschrieben erscheinen oder erst wenn er einen Ordner gefunden hat?
Braucht man soonst was wie NFS oder dergleichen
NAS1
NAS2
NAS3
NAS4_warten
NAS5
DSP-Z9_Neuling
#1070 erstellt: 10. Nov 2018, 15:07
Eine Frage bitte zu meiner NAS DS1515
- ich habe soeben in der Übersicht der installierten Pakete gesehen, das dort der ZappitiServer mit einem BETA Zeichen versehen ist.
ZappitiServer Beta
Wie kann ich in der APP prüfen ob es auch wirklich die BETA ist?
- oder ist das nur in der Übersicht der installierten Pakete so korrekt zu erkennen?
Daran könnten ja auch meine Bildaussetzer bei UHD´s liegen.....
Vielen Dank
Werner
Memphis
#1071 erstellt: 10. Nov 2018, 18:31
@ sven29da
Wenn Du doch mit NAS zuspielst, warum dann kein Mini?
Zu Deinem Problem:
Kann es sein, dass Du keine Ordnerfreigabe erstellt hast? Mit Samba (SMB) benötigst Du eigentlich einen Benutzer, der die passenden Rechte (lesen reicht) in dem Ordner hat, damit Du ihn sehen kannst,
Wenn Du NFS nutzt, gibt es keinen Benutzer, denn Du gibst dort IP basiert frei.
Ich glaube, da fehlt einfach die Freigabe.
Nick_Nickel
#1072 erstellt: 10. Nov 2018, 18:34
Wenn ich auf meinem Syno zugreifen möchte muß Zappiti Share auswählen.
sven29da
#1073 erstellt: 10. Nov 2018, 18:53
@Memphis
es gibt nur einen einzigen Grund warum ich vom HiMedia auf den Zappiti umsteige und das ist der zweite HDMI Ausgang des Modell "One SE".
@All
So, keine Ahnung warum, aber habe gerade mal anstatt IP Adresse mal den Namen des NAS eingeben und siehe da, es kam Abfrage nach User und Passwort und danach bekam ich alle Ordner angezeigt und konnte den ersten Ordner "Spielfilme" hinzu fügen.
Also Rechte kann nicht die Ursacher sein.
Wenn jemand einen Tipp hätte, dann würde ich das umsetzen damit es auch per IP Adresse geht, wobei mir einfällt, ich habe zwei IP Adressen da zwei LAN Anschlüsse.
Versuche dann mal die andere IP Adresse.
Jetzt kann ich zumindest mal schauen was Zappiti nun mit den Filmen so anstellt.
Wäre schön wenn jetzt alles gut klappt, dann muss nur Ende des MIonats der One SE kommen. Dann sollte es ja sofort losgehen gehen, hoffe ich
Schönen Abend
Sven
sven29da
#1074 erstellt: 10. Nov 2018, 18:56
ZappitiServer Beta
Vielen Dank
Werner
Hallo Werner,
schön das wir mal wieder eine Gemeinsamkeit haben
Ich bin ja blutiger Anfänger, aber wenn ich einen Klick auf das paket mache, bekomme ich mehr Infos.
Bringt Dir das was?
zappi
Sven
GorillaBD
#1075 erstellt: 10. Nov 2018, 18:58
Dann versuchs mal mit dem "Public"-Ordner bei der manuellen Geräteeingabe.
GLG GBD
Nick_Nickel
#1076 erstellt: 10. Nov 2018, 19:02
Wenn man das ZMC als Beta nutzt muß der Zappiti Server auch Beta sein.
[Beitrag von Nick_Nickel am 10. Nov 2018, 19:03 bearbeitet]
GorillaBD
#1077 erstellt: 10. Nov 2018, 19:02
Überprüfung ist nur anhand der Versionsnummer möglich. 4.19.222 = letzte Beta, 4.18.216 = letzte offizielle Release.
Genauer gesagt: Server- und Clientversionsnummern müssen übereinstimmen
GLG GBD
[Beitrag von GorillaBD am 10. Nov 2018, 19:03 bearbeitet]
DSP-Z9_Neuling
#1078 erstellt: 10. Nov 2018, 21:05
GLG GBD
Vielen Dank,
das hat Klarheit gebracht, da ich im NAS die 4.19 habe und heute den Zappit Player auf die Beta geändert habe.
- bislang nur ein Bildfreezer bei einer UHD ....(zuvor waren es deutlich mehr...)
Danke
Memphis
#1079 erstellt: 10. Nov 2018, 22:07
Welche Software auf dem NAS ist, hat eigentlich keinen Einfluss auf Bildruckler o.ä.. Darin ist nur die Mediathek gespeichert. Wenn man einen Film schaut, wird der über die Freigabe mit dem Player geöffnet. Dabei ist das irrelevant, ob die Mediathek auf dem NAS oder in der Cloud ist.
Das Problem muss also an anderer Stelle liegen. Und auch ein Bildfreeze ist zuviel des Guten. Er sollte komplett ohne Fehler durch laufen. Ich würde testweise einmal Kabel tauschen (LAN), da hatte ich auch schon mehrfach Probleme mit. In Zukunft baue ich meine LAN-Kabel selber, dann funktionieren die wenigstens.
katutcho
#1080 erstellt: 11. Nov 2018, 09:31
Ich bekomme den Zappiti Server auf der Syno nicht mehr zum Laufen. Im Media Center wird die Syno (getrennt) angezeigt. Nur wenn ich den Sever neu installiere läuft er kurz, indiziert, bricht dann ab.
Muss mit dem Plattentasuch zusammenhängen. Habe eine neue Platte in das NAS gebaut (single bay) und die Daten der alten Platte über das Linux Live System übers Natzwerk auf die neu bespielt. Dann habe ich den Zappiti Server nach Anleitung auf der NAS installiert, jetzt läufts es nicht mehr. Habe keine Ahnung woran liegts.
Sowohl Server und Zappiti Video haben 4.19.222
Grüsse Katutcho
[Beitrag von katutcho am 11. Nov 2018, 09:36 bearbeitet]
Nick_Nickel
#1081 erstellt: 11. Nov 2018, 11:00
Du mußt den Syno zurück setzen und alles neu machen.
Am besten nur mit einer eingebauten Festplatte und dann die Filme zurück spielen.
katutcho
#1082 erstellt: 11. Nov 2018, 11:13
Aber das habe ich eigentlich doch gemacht, indem ich eine neue HDD eingebaut habe. Diese wurde ja dann neu von der Syno initialisiert.
Im Media Center steht, der Syno-Srever ist nicht erreichbar
[Beitrag von katutcho am 11. Nov 2018, 11:33 bearbeitet]
Nick_Nickel
#1083 erstellt: 11. Nov 2018, 11:18
Ich meine auf Werkseinstellung zurücksetzen und dann die DSM neu installieren.
katutcho
#1084 erstellt: 11. Nov 2018, 11:33
Aber dann sind alle Daten weg, oder?
Vielleicht habe ich einen Dienst deaktiviert, den es braucht?
Dienste
[Beitrag von katutcho am 11. Nov 2018, 11:40 bearbeitet]
Nick_Nickel
#1085 erstellt: 11. Nov 2018, 11:38
Wenn du jede Platte einzeln eingerichtet hast nicht.
Ich habe mir ein Programm zugelegt Paragon ExtFS for Windows damit kann man z.B. Linux Daten mit Windows auslesen.
katutcho
#1086 erstellt: 11. Nov 2018, 11:43
Hallo Nick Nickel
Ich habe eine one bay. Die alte Platte hängt am Sata Port am PC. Die Daten habe ich dann per Linux Live auf die neue Platte, welche bereits in der Nas verbaut und initialisiert war, rüber geschoben.
Oben habe ich ein Screen von den Diensten der NAS angehängt. Ich deaktiviere immer alles, was ich nicht benötige, aber vielleicht brauch ich doch noch etwas, um den Server zum Laufen zu bekommen.
Nick_Nickel
#1087 erstellt: 11. Nov 2018, 12:00
Ich lasse immer alles wie es ist und aktiviere noch FTP zugriff.
katutcho
#1088 erstellt: 11. Nov 2018, 12:18
Ich habe jetzt mal alle Dienste aktiviert, aber das ZMC konnte sich immer noch nicht mit dem Server verbinden. Mache jetzt einen Werksreset und starte die Syno neu. Richte zuerst sen Server ein, und kopiere dann die Daten von der alten HDD.
Nick_Nickel
#1089 erstellt: 11. Nov 2018, 12:30
Man kann den Syno mit einer Büroklammer oder ähnliches zurück setzen.
Dann startet der Syno so als wenn du ihn gerade neu gekauft hast.
Dann den Zappiti Server und das Mono installieren..
katutcho
#1090 erstellt: 11. Nov 2018, 12:32
ich habe das jetzt über die interne Oberfläche gemacht. probier es mal so. wenn nicht dann mit Büroklammer
Nick_Nickel
#1091 erstellt: 11. Nov 2018, 12:38
So entsteht am Sonntag wehnigstens keine langeweile.
katutcho
#1092 erstellt: 11. Nov 2018, 12:45
16 h Datentransfer...aber vielleicht läuft des mit dem Paragon Tool schneller. Soll ich die neue HDD nach der Initialisierung ausbauen und auch an den PC abklemmen? Oder übers Netzwerk verschieben?
[Beitrag von katutcho am 11. Nov 2018, 12:46 bearbeitet]
Nick_Nickel
#1093 erstellt: 11. Nov 2018, 12:51
Bei Gigabit-Lan ist das egal.
Ich habe bei FTP eine Geschwindigkeit von ca 110 Mb/s.
Ein Admin Passwort vergeben muß man glaube ich auch.
katutcho
#1094 erstellt: 11. Nov 2018, 17:20
So habe jetzt mal einen kleinen Tei übertragen und kontrolliert ob die Indizierung und der Server funktioniert. Scheint nun alles juut zu sein. In diesem Sinne, Besten Dank!!
Mit den Linux Live von paragon scheint die Übertragung auch schneller zu gehen. Anstatt 16h mit dem Ubuntu, zeigt er mir nur 9h an
sven29da
#1095 erstellt: 11. Nov 2018, 17:55
Auch ich kann Erfolg vermelden
Nachdem ich ja im Server anhand des Namens meines NAS den ersten Ordner sprich die erste Festplatte vom NAS einbinden konte, wurde auch bis auf 10 Filme alle (was ich auf den ersten Blick sehen kann) korrekt identifiziert.
Musste nur erst mal alle mkv Files die "Sample" oder "Trailer" hatte, auf dem NAS löschen, da deshalb viele Filme doppelt angezeigt wurden.
Soweit erstmal alles gut, die nächsten Platten werden somit betankt.
Eines gefällt mir nicht so.
Bei manchen steht im Cover MKV bei anderen BLURAY, wobei bei allen im mkv Dateinamen sowohl 1080 wie auch Bluray steht
Habe nun gesehen man kann diese Kennzeichnung "Medientyp auf Cover anzeigen" ausschalten, welche ich auch bei diesen normalen Filmen nicht benötige und es nur zu gerne deaktiviere, aber wo ich den Zusatz im Cover unbedingt sehen möchte ist bei UHDs.
Gibt es einen Trick, dieses "Medientyp auf Cover anzeigen" nur auf gewisse Medientypen beziehen zu können?
Brache kein 3D, kein MKV sowie kein Bluray, aber UHD ist wichtig für mich.
Gibt es eine Möglichkeit? Wenn nicht, kann man bei Zappiti als kleiner Endkunde solche Dinge einkippen mit der Hoffnung, dass beim nächsten Update dies enthalten ist?
Was ich auch gerne hätte ich wie bei KODI die Filmübersicht mit einer Reihe wo man von Film zu Film scrollen kann aber auch von Seite zu Seite und bei schnelldurchlauf direkt zu bestimmten Anfangsbuchstaben.
Was meint Ihr dazu?
Ach, udn von der Optik her gibt es nur sozusagen einen anderen SKIN in Schwarz/Weiß den man kaufen muss oder gibt es weitere Ansichten der Benutzeroberfläche?
Danke und schönen Abend
Sven
GorillaBD
#1096 erstellt: 12. Nov 2018, 09:39
sven29da (Beitrag #1095) schrieb:
1) Gibt es einen Trick, dieses "Medientyp auf Cover anzeigen" nur auf gewisse Medientypen beziehen zu können?
2) Was ich auch gerne hätte ich wie bei KODI die Filmübersicht mit einer Reihe wo man von Film zu Film scrollen kann aber auch von Seite zu Seite und bei schnelldurchlauf direkt zu bestimmten Anfangsbuchstaben.
Was meint Ihr dazu?
3) Ach, udn von der Optik her gibt es nur sozusagen einen anderen SKIN in Schwarz/Weiß den man kaufen muss oder gibt es weitere Ansichten der Benutzeroberfläche?
1)
Nein, da gibt es keinen Trick. Ja, man kann diese Option "beantragen": https://zappiti.uservoice.com/forums/310888-zappiti-english
2)
Wenn ich KODI wollte oder bräuchte, hätte ich einen KODI-Player.
Suche nach Anfangsbuchstaben ist ja ebenfalls bei Zappiti möglich und man kann sich mehr Cover pro Seite anzeigen lassen.
Ansonsten beantragen, siehe 1)
Ist ein typischer Fall von "Who moved my Cheese" Google mal...
3)
Nein, es gibt nur noch den Silver-Skin als Option, den man kaufen muss.
GLG GBD
[Beitrag von GorillaBD am 12. Nov 2018, 09:45 bearbeitet]
sven29da
#1097 erstellt: 12. Nov 2018, 10:12
Danke GBD ... ich sehe schon, ich habe noch gar keinen Zappiti Player und mache mich jetzt schon bei Zappiti unbeliebt
Heute Nacht wurden die nächste HDD vom Zappiti eingelesen und ich sehe gerade, gerade mal 5 wurden nicht identifiziert.
Funktioniert echt besser als gedacht.
Nick_Nickel
#1098 erstellt: 12. Nov 2018, 10:18
Ich nehme meine eigenen Cover.
Am PC unter Bilder ändern.
Erhalten vom Computer.
Unbenannt
GorillaBD
#1099 erstellt: 12. Nov 2018, 10:19
@Sven
Nein, im Ernst:
Das Zappiti-Mediacenter will kein KODI-"Ersatz" sein, sondern eine andersartige Alternative und ich persönlich finde das auch gut so.
Die Strategie ist eine möglichst einfache Benutzung für Mann, Frau, Kind und Hund, und so stellt sich das Konzept dar.
Wer von KODI kommt, wird daher manche Einstellungsmöglichkeit vermissen, dafür kann man sich bei Zappiti aber auch nicht in solchen Untiefen der Optionen und Plug-Ins wie bei KODI geradezu verlieren.
Und viele von uns hätten gern bei einnem Wechsel mindestens alle vorherigen Optionen wie gewohnt. Was fast nie funktioniert, seien es Player, Autos oder Lebenspartner. Das ist der "Who moved my Cheese?" - Effekt...
GLG GBD
[Beitrag von GorillaBD am 12. Nov 2018, 10:24 bearbeitet]
sven29da
#1100 erstellt: 12. Nov 2018, 11:47
Es geht mir lediglich um die allabendliche Suche "was schaue ich heute" und da war das, wie ich es von KODI kenne halt schön.
Aber ich warte erst einmal ab wenn der Player da ist wie ich mit klar komme.
Nur anhand Bildern sich einen passenden Film Abends zu suchen, stelle ich mri zumindest aktuell nicht so schön vor.
Deshalb war jetzt schon mein Wunsch/Verlangen nach einer Möglichkeit einer anderern Optik, mit nur einer "Filmzeile" mit jeweiligen Namen unter dem Cover, vorhanden
Ansonsten ist es bislang recht intiutiv und komme mit zurecht, was ja schon was heißt
Mahlzeit
Sven
[Beitrag von sven29da am 12. Nov 2018, 11:51 bearbeitet]
GorillaBD
#1101 erstellt: 12. Nov 2018, 11:56
Das ist imho reine Gewöhnungssache.
Auf den allermeisten Coverbildern ist der Filmtitel ja erkennbar, daher brauche ich persönlich zum Suchen keine weiteren Informationen mehr.
Deinen Antrag, den Coverbildzusatz getrennt schalten zu können für z.B. 3D und UHD würde ich allerdings unterstützen, das gefiele mir auch.
GLG GBD
[Beitrag von GorillaBD am 12. Nov 2018, 12:01 bearbeitet]
sven29da
#1102 erstellt: 12. Nov 2018, 12:20
Schön zu lesen, denn ich hatte schon die Befürchtuing das eher kommt "man was ein Depp, braucht kein Schwein .. soll sich nicht so anstellen" oder dergleichen
Dann kommt das schon mal auf meine Liste
So leid es mir tut, muss noch mal was fragen was ich unschön finde ...
Man kann "Neue Filme einer Serie / Saga autom. gruppieren" deaktivieren.
Geht das auch bei Spielfilmen?
Ich vermute mal nicht, denn sonst würde die Option wohl zur Auswahl stehen, richtig?
Mochte keine Gruppierung (bei KODI Zusammenstellung) denn ich möchte gerne alle Filme in der Übersicht sehen.
Frage zum Zappiti Media Center
Krawallus am 21.12.2013  –  Letzte Antwort am 29.12.2013  –  2 Beiträge
Zappiti Video
johndo6 am 23.02.2022  –  Letzte Antwort am 27.02.2022  –  4 Beiträge
Zappiti 3D Media Player
qfactor am 12.01.2013  –  Letzte Antwort am 04.05.2021  –  936 Beiträge
Zappiti 303D - Alternative zu Zappiti Dynamic
K1lgoreTr0ut am 18.01.2015  –  Letzte Antwort am 18.01.2015  –  2 Beiträge
Dune HD mit Zappiti Media Center verbinden!
knubbel5 am 24.04.2016  –  Letzte Antwort am 24.04.2016  –  2 Beiträge
Zappiti 4K HDR - Familie (Realtek 1295, Android 6.x, Zappiti MC V4)
GorillaBD am 22.12.2016  –  Letzte Antwort am 31.03.2024  –  3535 Beiträge
Zappiti Server auf PC einrichten?
Aztek am 02.08.2017  –  Letzte Antwort am 02.08.2017  –  3 Beiträge
Zappiti DUO Probleme
Komediisto am 15.04.2024  –  Letzte Antwort am 16.04.2024  –  4 Beiträge
Zappiti 4K - Player (angekündigt) - Realtek RTD 1195, Android, XBMC (KODI)
GorillaBD am 14.12.2014  –  Letzte Antwort am 08.12.2018  –  71 Beiträge
synology nas ,zappiti paketquelle
mematitr am 23.10.2017  –  Letzte Antwort am 25.10.2017  –  3 Beiträge
  • Registrierte Mitglieder930.688 ( Heute: 3 )
  • Neuestes Mitgliedgebschue56
  • Gesamtzahl an Themen1.563.521
  • Gesamtzahl an Beiträgen21.827.884
