HIFI-FORUM » PC, Netzwerk & Multimedia » Multimediaplayer » Zappiti 4K HDR - Familie (Realtek 1295, Android 6.... | |
Gehe zu Seite: |vorherige| Erste . 10 . 20 . 30 . 40 . 46 47 48 49 50 51 52 53 54 55 . 60 . 70 Letzte |nächste|
Zappiti 4K HDR - Familie (Realtek 1295, Android 6.x, Zappiti MC V4)+A -A |
sven29da
19:20
#2459
erstellt: 12. Dez 2018, |||
k.was
19:34
#2460
Information dazu gibt es auf der Zappiti Seite hier: ![]() Restore Firmware Procedure via USB. Warning! This procedure will reset all your personal settings and account information. Thank you to carefully read all of this procedure first! Then please follow the process step by step by reading them one more time. Download the firmware file here bellow on the internal HDD of your computer. (Not directly on the flash drive). > Click here to download the firmware file for Zappiti Mini 4K HDR > Click here to download the firmware file for Zappiti One, One SE 4K HDR / Duo 4K HDR Note: As the Zappiti Mini 4K HDR have less memory than the two other models, the firmware file is different. Unzip the file on your computer. Then, place the IMG file on a 2GB USB flash drive formatted in FAT32. Note: If you do not have a USB stick with a capacity of 2 GB, you can partition the USB key into 2 partitions: the first of a size of 2 GB in Fat32 and the second unallocated. To format your USB flash drive, you can use the free AOMEI Partition Manager software. Switch off the Zappiti player by using the Power On / Off button located on the back side. Connect the USB flash drive into the USB port of the media player located next to the "RESTORE" button and disconnect the network cable. Press the "RESTORE" button by using a paper clip (small hole located on the side of the unit). While holding the reset button, turn on the player via the power button on / off at the rear of the unit. Hold the "RESTORE" button within 5 seconds, then release it. A "Z" logo will appear during 30 sec. Then, the upgrade process will start and a progress bar will be displayed on the screen. WARNING! Do not turn off the media player before the full reset. A percentage will be displayed on the screen. IMPORTANT: if you have black screen, switch off the player and try again by checking the following points: - Please use USB Flash drive up to 4GB. Some of 8 GB and over may not works. - Try again by connecting your Zappiti media player directly to your TV (without AV receiver or soundbar). - Did you try to download again the firmware? Maybe the firmware ahve been incorrectly downloaded. - Did you download the firmware file on the internal HDD of your computer or directly on your USB flash memory drive? You have to download it on the internal HDD of your computer. (Not directly on the flash drive). - Did you try to plug your USB flash drive on another USB input? If it doen't work on the USB 2.0 port, try again on another USB port. - The first initial boot after the firmware update is very long. If you switched off the player during the first initial boot, your firmware is dead. In such case, please contact us... The percentage 99% or 100% is very long. This is quite normal. Please wait until the appearance of "Z" logo. As long as the Zappiti logo is not displayed, do not turn off or disconnect the player above! Warning! The first initial start up is VERY long (1-2 min). So thank you for your patience throughout the initialization of the media player until you reach the player's home page (Zappiti / Explorer / MyApps). DO NOT RESTART the player until the main page appears. After the first initial boot, connect the Ethernet cable (if you are using it usually). Then we advise you to restart the player for better performances. The second boot should be much faster. After the second reboot, please click on "Settings", then set your language. |
sven29da
19:39
#2461
@k.was Danke ![]() Also ist ein "Firmware Restore" kurz gesagt ein Aufsoielen einer Firmware per USB ... wieder was gelernt ![]() |
espny
21:03
#2462
Gibt es einen Unterschied zw. "Restore" und "Reset" Button? Wenn ja, wo finde ich letzteren? [Beitrag von espny am 13. Dez 2018, 01:44 bearbeitet] |
sven29da
00:19
#2463
erstellt: 13. Dez 2018, |||
[quote="espny (Beitrag #2450)"][quote="sven29da (Beitrag #2448)"][ Hatte es gestern auch mit 24Hz probiert, ging nicht. Auf 23 Hz gestellt und es klappt perfekt!!! Film wird trotzdem mit 24p (23.98Hz) wiedergegeben ! :prost[/quote] Bei mir bleibt es weiterhin lange Schwarz, im Gegenteil, vorher kam für Bruchteil einer Sekunde das Bild und dann die Schwarzphase. Zwar genau so sch..aber gut, wenn Zappiti es ein extra empfiehlt, sollte es auch funktionieren. Das ist auch nicht der Fall, somit mit auf die Liste ![]() [b] PS: stellte vorhin fest, dass es bei Blurays wirklich funktionierte, sprich Bild auf einen Schlag da. Aber bei UHDs nicht. Könntest das mal bei Gelegenheit testen? Danke[/b] [Beitrag von sven29da am 13. Dez 2018, 02:57 bearbeitet] |
Komediisto
09:25
#2464
Habe die Tage was seltsames festgestellt. Bin mir aber nicht sicher, obs an der Box liegt. Hat hier zufällig jemand Panem Teil 2 "Catching Fire" in UHD? Denn bei all diesen Teilen, aber ganz besonders bei Teil 2 "Catching Fire", wird Schwarz ganz dunkelblau. In dunklen Szenen, werden schwarze Haare irgendwie dunkelblau. Das sieht aus, als wenn jemand mit nem blauen Pinsel über die Haare gemalt hätte. Aber auch andere schwarze Gegenstände, Hintergründe oder ganze Personen werden, sobald es weniger Licht gibt, dunkelblau. Da säuft alles ins dunkelblau ab. Überhaupt ist die Frabtemperatur extrem kühl. Habe zig Farbräume ausprobiert, habe HDR-Switch de- und aktiviert. Im Contextmenü während der Film läuft HDR de- und aktiviert. Nichts hilft. Falls jemand den Film hta, könnte derjenige das mal reproduzieren. Achso, das sehe ich sowohl über meinen Non-UHD-Beamer, als auch über meinen UHD-TV. |
kreni
10:54
#2465
Hallo. Wer von euch steuert den Zappiti mit einer App. Bei mir findet mein Handy im Netzwerk den Zappiti nicht. Gibs da bestimmte Einstellung beim Zappiti. Habe leider nichts gefunden. Würde gerne die Musik App nutzen da ich den Beamer nicht anmachen muss. Danke |
brevol
12:43
#2466
Die Music Control App zickt auch bei mir. Ab und zu kann die Verbindung erst durch drücken der "Back" oder "Ok" Taste aufgebaut werden. Wenn das nicht klappt, muss ich den TV kurz anschalten und Music manuell öffnen, dann findet die App den Player sofort. Zuvor muss zwingend Zappiti Service aktiviert werden
[Beitrag von brevol am 13. Dez 2018, 13:02 bearbeitet] |
k.was
14:19
#2467
Genau Zappiti Service muss immer für alle Netzwerksteuerungen einmalig eingeschaltet werden. Sowohl für die Apps als auch für IP Control über diverse Anbieter wie Control4, RTI und co. |
Komediisto
19:42
#2468
Und wo schaltet man den ein? |
k.was
19:44
#2469
Unter MyApps findest du auch die App Zappiti Service. Logo hab ich jetzt nicht im Kopf. Irgendwas mit Z. Einmalig einschalten und schon startet die App auch immer automatisch mit sobald der Player an ist. |
kreni
01:13
#2470
erstellt: 14. Dez 2018, |||
Bei mir hat es geklappt. Danke euch. Kann mit der App Music den Zappiti steuern. Media Control App klappt das nicht. Kriege eine Fehlermeldung. Video kann nicht abgespielt werden. |
sven29da
02:54
#2471
Also wie geschrieben, bei Bluray Filme funktioniert es wirklich, bei UHD Filmen funktioniert es nicht und somit bleibt bei UHD es weiterhin viel zu lange Schwarz ![]() Heute Abend festgestellt das der Zappiti 2160/59 bzw. 2160/60Hz Filme nur in 2160/24 ausgibt und somit es entsprechend ruckelt ![]() So langsam gehen mir diese viele Dinge echt auf den S... denn für ein Premium Gerät für 350Euro erwarte ich doch das es einfach tut was es soll und nicht alles nur Baustellen sind. Bin sehr enttäuscht und genervt ![]() ![]() [Beitrag von sven29da am 14. Dez 2018, 02:56 bearbeitet] |
kreni
03:23
#2472
Ne da hast was nicht richtig eingestellt. Bei mir läuft der Film der in 60 Hz gedreht ist auch in 60 Hz . Du musst bei der Auflösung auf Auto stellen dann geht es. |
sven29da
03:38
#2473
Klick mal oben auf den Link von mir, deshalb ist kein AUTO aktiv aber ich habe umgestellt sprich "Ignore EDID" wieder ausgeschaltet, 10Bit und 4:4.4 wieder beides auf AUTO umgestellt, Film neu gestartet und weiterhin nur 24Hz und Ruckeln. Da Zappiti selber im Link angibt das bei festen EInstellen der Werte "Die Auto Framerate bleibt weiterhin aktiv." dann wäre es ja auch so ein Fehler wenn man alles auf AUTO lassen müsste damit er einfach das tut was richtig und zu erwarten ist. |
Memphis
08:45
#2474
Nur mal doof gefragt, aber ein Kabelproblem kann das nicht sein oder? Hast Du mal ein anderes probiert oder mit dem gleichen eine andere Quelle mit gleichem Film? |
kreni
10:53
#2475
Glaub auch das du ein Kabel Problem hast oder bei deiner Kette was nicht funktioniert. Habe auch ein JVC 5500 und es geht wunderbar. Es gibt ja nur diesen einen Film und paar Demo s. Die mit 60hz laufen. Ich habe den Zappiti immer auf 24 Hz stehen und die Filme die in 24 Hz laufen laufen auch rückenfrei. Mit der Umschaltung von den JVC das ist so der braucht halt immer ziemlich lange bis das Bild kommt. Die 23 Hz habe ich noch nie probiert. Wuzu auch läuft auch Wunder bar. Wenn ein 60hz Film oder Demo schauen will mache ich auf Auto die Auflösung und das geht halt gut. Wenn dich die umschaltet von JVC dich so sehr stört da hilft nur ein ander Beamer. Ich habe mich schon daran gewöhnt. Kann dir aber gerne heute Abend ein Bild als Beweis machen. |
sven29da
10:54
#2476
Nein, kein Kabel Problem ... sind alles Zappiti Probleme. Habe seit Jahren JVC, X500, X7000, X7900 und glaube mir, ich konnte damit leben, aber wenn ein Hersteller angibt dass man das umgehen kann, dann will ich das nutzen können. Ansonsten hätte ich auch bei HiMedia und Vertex bleiben können. [Beitrag von sven29da am 14. Dez 2018, 10:58 bearbeitet] |
kreni
11:05
#2477
Das stimmt auch aber das ist halt manchmal so. Kein Gerät ist perfekt. Finde der Zappiti ist ein super Ding. |
Beejay
11:53
#2478
Ohne da jetzt irgendwem zu nahe treten zu wollen: Es ist "typisch Deutsch", sich über einige wenige und im Gesamtkontext auch eher unwichtige negative Dinge aufzuregen und dabei die vielen positiven Dinge komplett aus der Betrachtung fallen zu lassen. Zusammengefasst: Jammern auf hohem Niveau. Ich habe mich seinerzeit bei der Festlegung der Komponenten bewusst dafür entschieden, zusätzlich zum Oppo (der ja auch so ziemlich alles vom NAS abspielen kann) noch einen Zappiti zu kaufen. Wobei es mir da auch um für andere Leute scheinbar unwichtige Dinge wie "die Präsentation" der Film- bzw. Serienfolgenauswahl ging (die jetzt durch die Filmmusikanspielung nochmal "schöner" geworden ist). Ja, der Zappiti findet nicht alles und man muss ein wenig Zeit ins manuelle Identifizieren stecken. Aber wenn man damit einmal durch ist, hat man ein Gerät, das alles tut, was man davon erwartet. Ich bin sehr zufrieden mit dem Gerät und habe die 250€ nie bereut. |
Nick_Nickel
12:13
#2479
Ich bin auch der Meinung der Zappiti läuft Super. |
k.was
12:52
#2480
Bei mir läuft die Kiste auch absolut rund. Inzwischen hab ich im Haus 6 Zappiti Mini + Zappiti NAS laufen an unterschiedlichen Geräten von verschiedenen Herstellern. Die 23Hz sind dafür da um die Umschaltung von 24Hz im Menü auf 23,xxx Hz zu vermeiden. Da durch entfällt der neue Bildaufbau durch den Hz wechsel der beim JVC ja wirklich Ewigkeiten braucht Ich bin aber auch mit dem Thema JVC und HDMI Board durch. Immer nur Probleme gehabt ![]() ![]() |
Cpt_Ahab
23:12
#2481
Und genau das führt eben zu Produkten mit noch höherem Niveau wo Perfektion angestrebt wird ![]() @ ALL Mein Problem, dass ich mit dem Zappiti Explorer nicht mehr aufs NAS zugreifen konnte, wurde gelöst! :-) Ich hab gerade vom Support eine neue Version als APK bekommen...bzw. eigentlich die gleiche Version der App aber leicht modifiziert und nun passts. Vielen Dank für die tolle Arbeit die die Jungs im Support und R&D machen. |
quanah
23:46
#2482
da Du ja den Oppo besitzt,hast Du mal probiert den Zappiti am HDMI Eingang anzuschliessen,würde mich deshalb interesieren weil der Oppo ja HDR Tone Mapping kann. |
Komediisto
14:16
#2483
erstellt: 15. Dez 2018, |||
Sagt mal, habt Ihr denn keine Porbleme mit UHDs inkl. HDR, was die dunklen Szenen anbelangt? Oder lag dies tatsächlich nur an "Die Tribute von Panem"? Ich habe irgendwie das Gefühl, dass durch das Update, spezifisch diese HDR-Switch-Funktion, die Farbräume o. Farbtiefe versaut wurden. Egal ob ich auf 4:2:2, 4:4:4 etc oder 8 Bit, 10 Bit ect. und was weiß ich umstelle, in ganz dunklen Szenen säuft das Schwarz in Blau ab. Ich überlege, ob ich mir das Prozedre antue und auf die Vorgängerversion zurückflashe. |
Komediisto
14:35
#2484
Okay, danke ![]() |
sven29da
21:15
#2485
Nehme doch mein ein HDR Testbild ala. Black Clipping und schau mal ob da Schwarz Schwarz ist oder nicht. |
Michael2907
22:48
#2486
Hat hier noch jemand das Problem dass sich kenne Trailer mehr abspielen lassen? Bin jetzt auf der 3.13 und bekomme immer die Meldung Filmtrailer nicht gefunden |
sven29da
21:56
#2487
erstellt: 16. Dez 2018, |||
Habe gerade Update und anschließend Factory Reset sowie Aus/Ein durchgeführt und bei 5 Filmen getestet = 5 mal "Film-Trailer nicht gefunden" |
sven29da
22:08
#2488
Nach Update, Factory Reset und AUS/Ein schalten wolte ich UHD mit SDR testen: "Display" -> "HDR->SDR Switch" -> "Turn On HDR->SDR" auf OFF was das gleiche ist wie während Filmwiedergabe "Menü" -> "Fortgeschritten" -> "HDR" auf OFF (somit hat Zappiti unter Display das On mit dem OFF vertauscht) und egal ob ich HDR->SDR auf ON oder OFF stelle oder vvon AUTO auf Ignore EDID mit 10Bit 4:4:4 einstelle, ich habe immer HDR anliegen. ![]() Wundert mich das es bei anderen scheinbar funktioniert ![]() |
Cpt_Ahab
11:06
#2489
erstellt: 17. Dez 2018, |||
Hi, das war immer schon so. Die haben das nicht vertauscht, sondern der Switch hat einfach einen falschen Namen. Ich weiß auch nicht warum, kenne es aber schon gar nicht mehr anders. Wenn du den Switch auf "ON" hast, also die HDR-SDR Conversion aktiv, wundere ich mich sehr, dass dein TV noch immer ein HDR Signal erkennt. Kann mir da auch nicht erklären...aber vielleicht schickt er immer noch die Kennung für den HDR Mode, aber schränkt das Signal ein und der Rest des Bandes ist leer...keine Ahnung. Ich rate nur ;-) Aber Hauptsache es funktioniert jetzt. Bin echt sehr froh, dass HDR-SDR nun so gut läuft. Da hat meine Motivation auf einen neuen TV zu wechseln jetzt extrem abgenommen. Die Conversion holt anscheinend aus meinem TV mit HDR Material auch mehr raus als mit normalen BR Formaten vorher vorhanden war. Anscheined sind normal BRs ja 8bit und sogar mit Conversion kommen jetzt bei mir 10bit an, was mein TV auch kann :-) |
sven29da
11:32
#2490
Das es funktioniert sehe ich nicht so -> ![]() ![]() |
Klipsch66er
11:41
#2491
Moin Zusammen, ich habe meinen 4K TV zwar erst Morgen und noch keine 4K Files mit oder ohne HDR auf der Box. Der LGC8 kann HDR (Dolby Vision, HDR10 Pro, HLG, Advanced HDR by Technicolor) verarbeiten, Quelle: Amazon. Alles etwas verwirrend hier wegen der Kontrastgeschichte. Nun für uns Noobs wie muss der Schalter nun stehen? HDR-SDR Schalter auf On = HDR ein wenn von der Quelle das angeboten wird? HDR-SDR Schalter auf Off = HDR ausgeschaltet? Danke euch für eine Aufklärung. ![]() [Beitrag von Klipsch66er am 17. Dez 2018, 11:46 bearbeitet] |
Cpt_Ahab
11:46
#2492
Verstehe ich nicht. Was willst du mir/uns damit sagen? Schalte den Switch mal auf "ON" und mach noch einen Screenshot ;-) Ich kann das leider nicht dokumentieren weil mein TV eben kein HDR kann und ich somit im Optimalfall 10bit non HDR brauche. Zeigt mein TV auch an...mehr kann er aber auch nicht *g*
Nein, die Schalter sind nur dafür da wenn dein TV kein HDR kann. Wenn dein TV HDR kann, lässt du sie einfach auf OFF. HDR-SDR Schalter auf On = HDR Signale werden "SDR kompatibel" ausgegeben HDR-SDR Schalter auf Off = HDR bleibt so wie es ist Der HDR Schalter auf dem Screenshot von sven29da macht genau das gleich wie der in den Display Settings. [Beitrag von Cpt_Ahab am 17. Dez 2018, 11:51 bearbeitet] |
Klipsch66er
11:58
#2493
Dankeschön damit kann ich arbeiten. ![]() |
sven29da
12:06
#2494
Ich habe gestern alle Konstellationen durch probiert, unter anderem auch den "Switch" auf ON, ebenso anstatt Ignore HDMI EDID und 4:4:4 10Bit alles wieder auf AUTO aber mein Projektor bekommt weiterhin HDR zugespielt, was das Foto oben zeigt. Kann heute Abend einfach mal ein SDR Preset des Projektors nehmen, aber da UHD korrekt aussah, kann ich mir nicht vorstellen das der Zappiti ein SDR Gamma ausgibt und lediglich das HDR Flag vergisst zu entfernen. Habe aber gestern dieses Problem und ein paar weitere neue Fehler an den Support geschrieben. |
Cpt_Ahab
12:15
#2495
Dein Screenshot oben zeigt HDR "OFF"...also eigentlich HDR->SDR off...also stimmt dort alles. Das ist schon etwas verwirrend. Aber vielleicht solltest du erstmal eh alles auf Auto lassen, wie ignore EDID etc....wobei ich dann 23fps nicht einstellen kann, was wieder andere Probleme verursacht. Die Auto Einstellungen müssen definitiv noch verbessert werden, damit das Chaos reduziert wird. Aber wenn wie "source framerate and resolution" umsetzen...was wohl einer der nächsten Tasks ist, könnten sich einige dieser Probleme erledigen und man braucht die 23fps Einstellung nicht mehr. Dass sie einfach den HDR Flag vergessen oder eben weiterhin den gesamten Signalraum schicken, nur einiges leer lassen wäre natürlich beides möglich. [Beitrag von Cpt_Ahab am 17. Dez 2018, 12:16 bearbeitet] |
sven29da
12:32
#2496
Falles missverstanden wurde ... Sie schicken das HDR Flag da meiner Meinung ja auch weiterhin HDR ausgegeben wird, aber ich will UHDs in SDR mit BT2020 am Projektor empfangen. Dass konnte man schon vor einem jahr beim HiMedia Q10Pro indem man in den Android Einstellungen auf unter "HDR" von "AUTO" auf "SDR" umstellte. Dann gab er SDR mit BT2020 aus. |
Beejay
13:09
#2497
Nein, habe ich nicht probiert bisher. Sollte ich mal dazu kommen, sage ich Bescheid, ob das die Bildqualität anhebt.Ist aber in naher Zukunft sehr unwahrscheinlich. Bin diese Woche beruflich in Frankfurt und dann 2 Wochen im Weihnachtsurlaub. Im neuen Jahr dann wieder 5 Tage die Woche in FFM... Komme im Moment kaum dazu, Filme zu schauen. Bin schon froh, dass ich gestern OTA auf 3.13. updaten konnte. Habe allerdings den Factory Reset noch nicht gemacht. Was genau verbessert sich (angeblich) danach? Ich habe die ReleaseNotes gelesen und auch die Vergleichsbilder 3.11 => 3.13 mit den beiden Damen gesehen, aber was sie nun eigentlich woran verändert haben, ist mir irgendwie trotzdem nicht klar. Kann dazu, ob sich 3.13. NACH dem Factory Reset dann nochmal besser "anfühlt" (bzw. besser aussieht) schon jemand anhand eines eigenen "Vorher-Nachher-Vergleiches" etwas sagen? [Beitrag von Beejay am 17. Dez 2018, 13:11 bearbeitet] |
Cpt_Ahab
13:24
#2498
@ Beejay Wenn du kein Problem hast, würde ich keinen Factory Reset machen. Wüsste aktuell auch nicht warum das nötig sein sollte. Wir können nur orakeln, aber das macht keinen Sinn ![]() |
sven29da
13:26
#2499
Ich sehe null Unterschied nach dem Update und ganz ehrlich, das Magic Pixel ist für mich etwas was null greifbar ist. Ob das nur ein imaginäres Feature ist ![]() Sollten der Funktion mal eine Unterrubik im Menü gönnen, sofern es sie gibt. |
Beejay
13:27
#2500
@Cpt Ahab: Jo. Genau deswegen habe ich den bisher auch nicht gemacht. Kurz ausprobiert, ob das mit den BluRay-Menüs geht (einwandfrei) und dann wieder ausgemacht. |
2Fast4You
14:38
#2501
bei mir ist nach dem Update und Factory Reset folgende Meldung zu lesen Identifizierung neuer Dateien nicht möglich - X Zeichen - Die unterschiedlichen Kategorien haben alle Category mit einem Punkt als Unterteilung und englische Begriffe, wenn mich recht entsinne, obwohl ich Deutsch als Sprache angewählt habe. WTF - was ist hier falsch gelaufen? ![]() Dann habe ich noch das Problem das bei der Wiedergabe von unterschiedlichen Auflösungen die Bildschirme immer zwischen den Auflösungen umherschalten, egal ob beim TV oder Beamer. Erst dachte ich es liegt nur am TV, aber der Zappiti ist der Übertäter, das war auch schon vor dem Update so. Welche Einstellung ist dafür verantwortlich? [Beitrag von 2Fast4You am 17. Dez 2018, 14:41 bearbeitet] |
Komediisto
14:43
#2502
Ja ja, das Ganze HDR > SDR etc. Gekrame....seit dem Update stimmt da was nicht. Werde, wie im folgenden Text zu lesen ist, mal das Black-Level genauer unter die Lupe nehmen. Ihr könnt Euch nicht vorstellen, wie grauenhaft das Bild von Panem UHD bei dunklen Szenen aussah.
Super Idee. Danke Dir. Dann mach ich mich mal auf die Suche danach ![]() [Beitrag von Komediisto am 17. Dez 2018, 14:51 bearbeitet] |
sven29da
16:05
#2503
Vielleicht für Dich interessant, hier ![]() Sind auch über hier zu beziehen: ![]() [Beitrag von sven29da am 17. Dez 2018, 16:09 bearbeitet] |
Komediisto
16:16
#2504
Super, danke ![]() |
Komediisto
16:28
#2505
Also, bisher konnte ich nix feststellen. Lade aber noch ein paar Footages runter. Damit Ihr Euch mal ein Bild machen könnt, habe ich mal ein Bild genommen und es an den Stellen übermalt, wo es blau wird. So sah das ziemlich genau aus. ![]() [Beitrag von Komediisto am 17. Dez 2018, 16:28 bearbeitet] |
sven29da
17:01
#2506
Kannst gerne mal Zeitstempel und welchen Teil von Panem sagen, dann kann ich es mal bei mir testen. Du hast aber in SDR wandeln lassen, oder? Wenn Du es in SDR wandeln lässt die Frage, sieht es genaus so aus wenn Du nicht wandeln lässt? |
Komediisto
17:09
#2507
Habe alles möglich probiert. Mit HDR, ohne HDR, SDR und es ist praktisch bei allen Teilen so. Besonders aber Teil 2 Catching Fire. Aber auch bei Mockingjay Teil 1/2. Teil 1 - Hunger Games, ist es am wenigsten. Und dieses Bild sehe ich sowohl auf einem Non-HDR-Beamer Epson TW9200 als auch auf einem 4K-HDR-TV. Das ist ja das seltsame. Mit der Firm stimmt was nicht. Die haben da an HDR rumgefummelt und irgendwas falsch gemacht. Das hatte ich vorher nicht. Zeitstempel kann ich Dir nicht sagen. Habe das Bild aus'm Netz und dann mit PS blau übermalt. Einfach mal bei Catching Fire dunkle Szenen raussuchen. Gibt es ja zum Schluss reichlich von. Hatte mir heute schon bei buecher.de die 6-Discs-Version in FHD bestellt, aber dann gesehen, dass die keine Atmosspur haben. Habs dann wieder storniert. [Beitrag von Komediisto am 17. Dez 2018, 17:11 bearbeitet] |
Reijo18
17:56
#2508
Hallo, ich war sehr angetan von dem Löschen der Dateien von der internen Platte. Nach dem Update geht in dieser Richtung der Explorer nicht mehr. Hat jemand eine Idee? viele Grüsse Reijo18 |
sven29da
18:01
#2509
Siehst Du überhaupt einen Unterschied wenn Du beim Zappiti von HDR in SDR umstellst? |
Zappiti One 4K HDR yage am 03.04.2017 – Letzte Antwort am 19.12.2017 – 10 Beiträge |
Zappiti mini 4K HDR michaelessen am 14.05.2017 – Letzte Antwort am 17.05.2017 – 10 Beiträge |
Review: Zappiti Duo 4K HDR Sledgehamma am 25.01.2017 – Letzte Antwort am 27.12.2017 – 24 Beiträge |
Zappiti 4K HDR Duo - Entwickleroptionen shaky.72 am 18.08.2019 – Letzte Antwort am 19.08.2019 – 6 Beiträge |
Zappiti One 4K HDR - Ordnerbennenung Sonic666 am 14.05.2022 – Letzte Antwort am 16.05.2022 – 5 Beiträge |
Zappiti 4K - Player (angekündigt) - Realtek RTD 1195, Android, XBMC (KODI) GorillaBD am 14.12.2014 – Letzte Antwort am 08.12.2018 – 71 Beiträge |
Zappiti Mini 4K HDR probleme Ferbedienung zappiti am 14.05.2017 – Letzte Antwort am 15.05.2017 – 4 Beiträge |
Zappiti One 4k HDR - Bild ruckelt stark Elmar11 am 10.06.2017 – Letzte Antwort am 24.06.2017 – 9 Beiträge |
USB 3.0 Stick Zappiti One 4K HDR Oekomat am 02.10.2018 – Letzte Antwort am 04.10.2018 – 5 Beiträge |
Zappiti NAS RIP 4K HDR - Erfahrungen scarl am 18.02.2019 – Letzte Antwort am 24.06.2020 – 8 Beiträge |
Top 10 Threads in Multimediaplayer der letzten 7 Tage
- Amazon Fire-Tv Stick und LG OLED55CX9LA
- HI RES Streaming über QOBUZ
- INNUOS ZENmini - ZEN - ZENith -Pulse Serie - Roon Erfahrungsaustausch
- Noxon iRadio 400 keine Internetsender mehr
- Lösung der DENON WLAN Probleme
- Pioneer N-70AE / N-50AE / N-30AE
- Bluesound VAULT 2i
- Kodi v20 KEINE MKV Dateien & erkennt Bibliothek nicht mehr auf Nvidia Shild
- Anleitung für DUMMIES: Audiophiler Raspberry Selbstbau Low Budget Musikplayer/-streamer
- Audio Netzwerkplayer was bringts?
Top 10 Threads in Multimediaplayer der letzten 50 Tage
- Registrierte Mitglieder929.717 ( Heute: 1 )
- Neuestes Mitgliedjohnsonrobbins5
- Gesamtzahl an Themen1.561.047
- Gesamtzahl an Beiträgen21.766.127
