Led blinkt 6x, wiederholt sich.
of-tv
#1 erstellt: 17. Feb 2020, 22:06
Ich habe hier ein Sony Led tv,KDL-75W855.
Nach dem Einschalten, kommt kurz Sony Logo,dann geht weg und Led blinkt 6x und wiederholt sıch.keın Ton.
S/N 6010684
P/N 18695300
Was kann defekt sein? Es ist um 3 Jahrealt.
Vielen Dank.
Of-TV
xutl
#2 erstellt: 17. Feb 2020, 22:30
Aus dem Netz
Zeitbedarf für die Suche <60sec.
hm das schaut nicht gut aus... Ich glaube da Hilft nur der techniker oder Austausch.
Red led light blinks flashes, red light error code troubleshooting Chart, TV shutsdown
Always try power reset, unplug powercord for 5 mins then factory reset tv & update with usb drive from sony site- http://esupport.sony.com/US/perl/swu-download.pl?upd_id=7151
0 no red standby light-check powercord or bad main logic board or power board, check standby volts
1 red blink not used
2 red flashes is bad power board, solution replace power board
3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
4 red blinks- can be LD board or main logic board, check inverter board wires for arcing to ground
5 red flashes- bad lcd panel connection or internal lcd short- squeeze bezel to locate bad connection
6 red flashes- ##############################
7 red flashes- main board over heating, can be short on power board or main logic board
8 red flashes- main board sp prot, try power reset, update with usb, or replace main logic board
9 blinks- check fan error, * if TV has fans
10 blinks- digital board or tuner board * some Sony TVs may not have this board
11 red flashes- bad main board, bad IC, replace main logic board
12 red light flashes is tcon error bad T-con board or bad LCD panel, replace tcon board usually
13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
14 red flashes HFR- bad TCON or Bad LCD panel, replace tcon board. unplug tcon board if tv stays on without tcon board replace tcon board.
share this post to anyone in need. get parts at Shopjimmy or Rivervalley electronics.
Ralf65
#3 erstellt: 18. Feb 2020, 07:44
wichtig für eine Beurteilung ist immer die Farbe der blinkenden LED,
eine Übersicht gibt es HIER
Rot ist immer eine Signalisierung für einen Fehler (Defekt)
[Beitrag von Ralf65 am 18. Feb 2020, 07:45 bearbeitet]
Spencer2k6
#4 erstellt: 18. Feb 2020, 10:58
@ of-tv: Ich habe dir eine private Nachricht geschickt. Bitte teste das mal.
[Beitrag von Spencer2k6 am 18. Feb 2020, 10:59 bearbeitet]
Dermoviemaker
#5 erstellt: 26. Feb 2020, 14:05
Vermutlich ein panell Schaden.
wenn du Pech hast, gibt es kein panell mehr. In den meisten Fällen, werden wir panell nur 3 Jahre gebaut, dann kommen schon die neuen Modelle.
war bei meinem auch so. Nach 3 1/2 Jahren 75 Zoll Schrott.
habe ein riesiges Fass aufgemacht bei Sony, haben sich nur entschuldigt, mehr nicht.
Daher fuer mich ganz klar, keine Sonys mehr.
Am besten bei mm oder Saturn kaufen mit 5jahres zusatzgarantie, dann hast du wenigsten fuer 5 Jahre gewissheit, bzw. Bekommst einen neuen.
Fehler sony kdl 37ex402 - LED blinkt 6x
sven503 am 19.05.2014  –  Letzte Antwort am 19.05.2014  –  2 Beiträge
Fehler 46HX925 - LED blinkt 4 mal
matty12 am 12.12.2011  –  Letzte Antwort am 21.12.2011  –  14 Beiträge
Sony LED blinkt 6 mal rot
metinakdemir am 21.08.2020  –  Letzte Antwort am 25.08.2020  –  5 Beiträge
KDL46-HX757 blinkt rot
Guido73 am 03.05.2013  –  Letzte Antwort am 19.05.2013  –  3 Beiträge
Rote LED blinkt 2x bei Sony KDL-55EX715
ac328 am 03.12.2018  –  Letzte Antwort am 27.12.2018  –  6 Beiträge
Sony KDL-32L4000 kBkT grüne LED blinkt 18mal dann rot
uelzchen am 14.07.2010  –  Letzte Antwort am 15.07.2010  –  2 Beiträge
KDL-55W805C - LED blinkt 6 mal rot - Totalschaden
le_grec am 16.10.2018  –  Letzte Antwort am 07.11.2020  –  9 Beiträge
Sony Bravia KD55XD8577 6x rotes Blinken - Bootlogo kurz sichtbar
Kokzreh am 22.11.2024  –  Letzte Antwort am 24.11.2024  –  3 Beiträge
KDL-75W855C blinkt 6 mal rot
Das_Keks am 12.01.2022  –  Letzte Antwort am 15.03.2023  –  8 Beiträge
KDL-32WD575 blinkt 4 x rot.
matthes1973 am 07.06.2020  –  Letzte Antwort am 08.06.2020  –  12 Beiträge
2020
  • Registrierte Mitglieder929.027 ( Heute: 14 )
  • Neuestes Mitgliedevian1893
  • Gesamtzahl an Themen1.559.509
  • Gesamtzahl an Beiträgen21.728.215
