Gehe zu Seite: Erste 2 3 4 5 6 . 10 . 20 . Letzte |nächste|
Neue Sharp-Displays Anfang 2007: D92U / HD1E
Braindead2k
#1 erstellt: 18. Dez 2006, 18:16
Hallo zusammen! Bin ein fauler Mitleser der nicht sooo gerne selber postet.
Möchte Euch dies jedoch nicht vorenthalten.
AQUOS D92U / HD1E (zukünftig)
"The AQUOS D92U series, in 52" and 46" screen sizes, sets a new standard for large-screen flat-panel TVs.With Full HD 1080p resolution, dramatically enhanced black level and an elegant new design, it produces a breathtaking picture quality that is second to none. The D92U Series utilizes the next generation of Sharp’s proprietary Advanced Super View/Black TFT Panel with multi-pixel technology†, providing 15,000:1 Dynamic Contrast Ratio, 4ms response time and wide viewing angles (176°H x 176°V). In addition, the D92U models include 120Hz frame rate conversion for the ultimate in fast-motion image processing. Both models are HDTVs with built-in ATSC / QAM / NTSC tuners and include 3 HDMI™, compatible with 1080p signals, and 2 HD 1080p component video inputs as well as RS-232C for control. The D92U Series features a sleek piano black cabinet, with detachable, recessed bottom-mounted speakers and the included table stand easily removes for wall mounting applications."
Features:
Full HD Spec 1080p (1920 x 1080) Resolution for the sharpest picture possible.
Next-Generation 16:9 ASV LCD Panel from Sharp’s brandnew state-of-the-art Kameyama II factory, producing 3000:1 Contrast Ratio and 4ms response time.
120 Hz Frame Rate Conversion for the ultimate in fast motion picture quality.
Multi-Pixel Technology† divides each pixel into two sections and adds an advanced driving system to provide 60% improved color reproduction at wide viewing angles.
Wide Viewing Angles (176°H x 176°W) Sharp's AQUOS viewing angles are so wide, you can view the TV clearly from anywhere in the room.
Enhanced Black Level provides the deepest, most accurate black of any flat panel TV.
Five-wavelength Backlight System enables the display of very deep greens and crimson reds, widening the available color spectrum.
High Brightness (450 cd/m2) AQUOS Liquid Crystal Televisions are very bright. You can put them virtually anywhere – even near windows, doors or other light sources – and the picture is still vivid.
Built-in ATSC / QAM / NTSC Tuners provide access to DTV and analog TV channels.*2
Six 1080p Compatible Inputs including three HDMI, two HD component, and one DVI-I.
Preis: 52" 5299 Dollar
46" 4199 Dollar
Offizielle Vorstellung: 7.Januar 2007 ( CES )
Die restlichen Daten könnt ihr unter folgender .pdf-Datei
nachlesen:
http://www.abtelectr...es/D92_SpecSheet.pdf
Wünsche Euch noch einen schönen Abend!
Euer Braindead2k
PS: Leider ist noch nicht ersichtlich, ob die neuen Displays HDMI 1.3 besitzen.
[Beitrag von Braindead2k am 18. Dez 2006, 18:28 bearbeitet]
Gladiac900
#2 erstellt: 18. Dez 2006, 20:17
ja toll, es hat ja jeder platz für 46"+...
Bei mir ist bei 42 " ende...
Mir kommts aber langsam so vor, als wie wenn die entwicklungen teils nur noch für die 46, 52 " und größer erfolgen.
Finde ich schade.
Gibt doch viele, die keine platz für ne riesenkiste haben, bzw. es soll sogar menschen geben, die ne neue entwicklung wollen, aber nicht soviel kohle haben, um 46+ zu kaufen
Und btw. ich bin mir sicher, das Fernsehprogramm wird auch mit dem besten panel nicht besser
Ex-Sunny
#3 erstellt: 18. Dez 2006, 20:31
Hi Braindead,
danke für die Info, scheint ja interessant zu werden, nachdem sie ihn auf der IFA schon mal als Prototypen vorgestellt hatten. Da war noch von einem Kontrast von 2500:1 die Rede, hat sich Sharp schon wieder "heimlich" verbessert... Allerdings war dort auch von einer eingebauten Festplatte die Rede, davon ist in den Specs nichts zu lesen...
Hier nochmal mein Link zu meinen IFA-Fotos, wo er auch zu sehen ist, einschliesslich dem Kontrastvergleich 2500:1 zu 1200:1 von damals...
IFA-Fotos 2006 mit XD1E und HD1-Geräten
Und auch nochmal der Spekulations-Thread aus dem AVS-Forum zur neuen Serie...
Sharp-Spekulations-Thread im AVS-Forum
Grüße Micha
[Beitrag von Ex-Sunny am 18. Dez 2006, 20:36 bearbeitet]
rudisilves
#4 erstellt: 18. Dez 2006, 20:37
Danke Braindead,
dann schauen wir mal, 120Hz frame; contrast 3000:1 ;3xHDMI
das hört sich gut an, aber die 120Hz ersetzen nicht 1080p24 !
mfG
[Beitrag von rudisilves am 18. Dez 2006, 20:42 bearbeitet]
aixess
#5 erstellt: 19. Dez 2006, 10:59
Aber 120Hz sind die Vorraussetzung für die Wiedergabe von 1080p24. 24 x 5 = 120
Jetzt muss der TV nur noch 1080p24 von Quellen annehmen!
aixess
#6 erstellt: 19. Dez 2006, 11:02
So sieht das Teil aus
[Beitrag von aixess am 19. Dez 2006, 11:03 bearbeitet]
The_Sidewinder
#7 erstellt: 19. Dez 2006, 12:43
Also die Serie hört sich mal wirklich klasse an. Bin echt mal darauf gespannt und sich das Warten gelohnt hat.
Haben uns extra ne neue Schrankwand geholt, wo auch Geräte mit 46-52 reinpassen. Unsere alte hatte gerade mal Platz für nen 70cm Fernseher, dann war schon schluss.
120Hz heißt ja schon, dass die 1080p24 dargestellt werden können, oder? Wie sieht es dann mit "normalen" PAL (25 Bilder) oder NTSC (24 Bilder) aus? Schließlich will ich ja auch meine bisherigen DVDs genießen können. Bin bei dem Thema noch so richtig schön Laie.
oguz
#8 erstellt: 19. Dez 2006, 12:50
120Hz heisst leider nicht, dass es auch 24p kann.
Soviel ich weiss, kann das 24p Signal auf 60Hz gewandelt werden und dann erst auf 120Hz hochgerechnet. Natürlich ruckelt das Bild dann wieder.
Mit dem normalen PAL Signal dürfte es hingegen keine Probleme geben, weil der Fernseher wahrscheinlich auch 50 bzw. 100Hz ausgeben kann.
Mit Sicherheit wird man etwas erst wohl nach dem Erscheinen der TVs sagen können.
Braindead2k
#9 erstellt: 19. Dez 2006, 13:20
Hallo zusammen.
Ich gehe nun einfach mal davon aus, dass Sharp den TrudHD-Chip verbauen wird.
Die Features sind:
Motion blur removal
Real Motion®HD
Smooth Diagonal Lines
Sharpness and Contrast Enhancement
Zu finden unter:
http://www.micronas....%2Fhome%2Findex.html
Meine Interpretation:
Dieses Real Motion HD spricht auch die "Problematik" mit den 24 Frames an. Diese sollen dann tatsächlich auf 120 Hz hochgerechnet werden und somit das Ruckeln unterdrückt werden.
Nun bitte Eure!?! (bin leider technisch nicht sooo versiert)
Viele Grüße,
Euer Brainy2k
sanandreas
#10 erstellt: 19. Dez 2006, 16:32
Weiß jemand wieviel das Teil ungefähr kosten wird ???
aixess
#11 erstellt: 19. Dez 2006, 18:09
UVP
52" 5299 Dollar
46" 4199 Dollar
lynar
#12 erstellt: 19. Dez 2006, 18:31
Hier läuft doch noch die Werbetrommel für die aktuelle Modellreihe auf Hochtouren und ich kann mir kaum vorstellen, dass jetzt eine neue Serie im Januar kommt, zumindest nicht in Deutschland. Ich schätze optimistisch geshen, eher im März und dann eben noch zu ziemlich hohen Preisen und schlechter Verfügbarkeit. Bis sich die einpendeln dauerts dann wieder ein halbes Jahr.
Ex-Sunny
#13 erstellt: 19. Dez 2006, 20:08
warum nicht eine verbesserte Premium-Variante (natürlich auch preisintensiver)? Angekündigt waren sie ja schon zur IFA für Januar'07. Interessant sicherlich auch, ob sie schon die 1.3er HDMI-Chips "beherbergen" - interessant auch, ob Sharp in die europäischen Modelle auch die 5-Farbvariante der Hintergrundbeleuchtung (mit verbessertem Grünwert) einbaut, dazu evtl. noch die Festplatte?
Und den dann noch in 57"-Zoll-Ausführung, das wäre dann meiner!
Grüße Micha
P.S. Hoffentlich ist dann auch die Ursache für das Banding und Summen gefunden, kann man eigentlich diejenigen nur bedauern, die jetzt schon zugeschlagen hatten.
[Beitrag von Ex-Sunny am 19. Dez 2006, 20:11 bearbeitet]
nick-ed
#14 erstellt: 19. Dez 2006, 21:44
Das mag ja alles schön und gut sein, Full-HD usw., jedoch wollen die meisten potentiellen LCD-Fernsehr-Käufer einen von diesen in 32".
Meiner Meinung nach wären 32" für den Verkauf zurzeit wichtiger, Philips hat das gemerkt.
Snuggel007
#15 erstellt: 20. Dez 2006, 06:39
Würde ich nicht sagen, die Tendenz geht eindeutig zu größeren Geräten. Full HD auf kleinen Geräten macht auch kein Sinn.
rolfbert
#16 erstellt: 20. Dez 2006, 07:50
das macht sehr wohl sinn, aber hängt davon ab wie weit man davon weg sitzt
[Beitrag von rolfbert am 20. Dez 2006, 07:58 bearbeitet]
aixess
#17 erstellt: 20. Dez 2006, 11:33
spielt ja auch keine Rolle, es wird vorerst ausschließlich 46" und 52" HD1E LCD-TVs geben.
Wenn welche dazu kommen, dann noch größere
rolfbert
#18 erstellt: 20. Dez 2006, 11:37
das stimmt natürlich für diese serie, allerdings bringt sharp übermorgen in japan 2 32" full hd modelle raus (ok hat nichts mit diesem thread zu tun :P)
Snuggel007
#19 erstellt: 20. Dez 2006, 17:06
Das wäre aber bei 32 Zoll nicht mal 2 mtr. Glaube kaum das du an der Scheibe klebst.
@aixess
Sind die Bilder von der Messe, oder sieht der nun auch tatsächlich so aus?
[Beitrag von Snuggel007 am 20. Dez 2006, 17:09 bearbeitet]
aixess
#20 erstellt: 20. Dez 2006, 17:57
beides. Das Bild im Datenblatt entspricht dem Design auf der IFA
AustrianPatriot
#21 erstellt: 20. Dez 2006, 18:14
hab gerade im Datenblatt die Passage gefunden, die das Ding wohl auch für Xbox360-Zocker oder Hd-DVD-SChauer zu der "ULTIMATE-MACHINE" macht:
HD COMPONENT INPUT -> 2 (1080P COMPATIBLE)
ich weiß zwar, dass man mit dem Wort "kompatibel" immer ein bissl vorsichtig sein muss, aber das klingt doch schon mal vielversprechend.
EDIT: ist das Datenblatt auch sicher echt?! Das klingt alles irgendwie viel zu schön.... alle HD-Eingänge 1080p-kompatibel, 5 Wellenlängen-Hintergrundbeleuchtung, wahnsinns-Kontrast und dann "nur" solche Preise?!
[Beitrag von AustrianPatriot am 20. Dez 2006, 18:17 bearbeitet]
rolfbert
#22 erstellt: 20. Dez 2006, 19:51
1.5-1.8m, viel weiter sind die wände nicht auseinander :S
[Beitrag von rolfbert am 20. Dez 2006, 19:51 bearbeitet]
Snuggel007
#23 erstellt: 20. Dez 2006, 21:32
@AustrianPatriot
Das hört sich alles gut an, u. sieht nach perfektem LCD aus. Warten wir aber erstmal ab, schreiben kann man viel. Wichtig ist ob dann auch alles fehlerfrei funktioniert.
sanandreas
#24 erstellt: 21. Dez 2006, 09:22
Kann mir jemand sagen wann ich das Teil im Laden kaufen kann ?
Da steht zwar etwas von 7. Januar aber ich glaube da er in Amerika raus.
Danke schon im voraus
MfG
sanandreas
eschna
#25 erstellt: 21. Dez 2006, 10:52
In Chicago gibt es den 52D92U schon für unter 5000,- $ zu kaufen
Wäre interessant zu wissen, wann der neue auch nach Europa kommt. Hier gibt es zur Zeit nur den 52XD1E der wohl baugleich mit dem 52D62U ist, der in den USA vertrieben wird.
[Beitrag von eschna am 21. Dez 2006, 14:30 bearbeitet]
Ex-Sunny
#26 erstellt: 21. Dez 2006, 14:16
der LC-52D62U entspricht unserer Einstiegsserie LC-52XD1E.
Ab Januar soll dann die neue Premium-Serie (in Europa HD1E, in den USA D92U genannt), auf den Markt kommen.
Grüße Micha
Snuggel007
#27 erstellt: 21. Dez 2006, 19:21
Hier mal ein sehr informativer Link zum kameyama Werk 2
http://www.sharp-kameyama.com/index.html
tim002
#28 erstellt: 23. Dez 2006, 11:42
wird eigentlich es die neue serie nur in den größen 46 ud 52 geben?
aixess
#29 erstellt: 23. Dez 2006, 12:29
ja
Ballu22
#30 erstellt: 23. Dez 2006, 12:30
und beim 37" kommt nur ne überarbeitetes modell raus ...
tim002
#31 erstellt: 23. Dez 2006, 12:34
was heißt überarbeitet ist das design vom 37 überarbeitet? oder ändert sich technisch auch was?
NICKIm.
#32 erstellt: 03. Jan 2007, 22:01
Frohes Neujahr Ihr Lieben Wann wird denn nun der neue Sharp kommen d.h. als verbesserter XD1E und wann die andere Modell Reihe? Haben die dann wirklich wie in den USA ua. HDTV DVB-S Tuner integriert? Das wird eine scharfe (Sharp) Angelegenheit werden. Sicherheitshinweis: Bitte wegen Überhitzungsgefahr keine Filme für Erwachsene in HDTV gucken, das Panel könnte dann platzen SUNNY Kennst schon den neuen Termin der neuen Sharpis? Gute Nacht Ihr Lieben
rolfbert
#33 erstellt: 03. Jan 2007, 22:18
hab mal was von April gelesen
NICKIm.
#34 erstellt: 03. Jan 2007, 22:36
ROLFBERT Hallo. April? Ist das ein Aprilscherz? Jetzt aber ab auf die Couch zum Edelplasma und schauen, was es nun via Astra Digital zum schauen gibt April ist mir zu lange. Gute Nacht miteinander. Bis morgen. Servus=
AustrianPatriot
#35 erstellt: 04. Jan 2007, 00:47
Servus Leutz,
Grade folgendes im engl. AVS-Forum gelesen:
Originally Posted by Jason Bourne
Just back from my local Magnolia (Watertwon, MA).
Had the Manager look up "LC-52D92U" in his inventory system.
He found it!
Quantity On Hand was ......0.
The In Stock Date is ....... 25 February 2007
I was hoping for sooner, since I will be swapping my 3rd banding-plagued 52D62U back for a D92U. On the other hand, maybe I will benefit from letting someone else be the guinea pig this time round.
Cheers,
In den USA meint also zumindest ein Händler, dass sie die HD1Es (dort halt D92Us) am 25. Februar bekommen werden...
Wenn das stimmt, könnte der April-Termin für Europa garnicht so weit daneben sein. Zumindest der theoretische Launch-Termin. Die Sache mit der Verfügbarkeit ist dann halt wahrscheinlich wieder ein anderes Thema.
NICKIm.
#36 erstellt: 04. Jan 2007, 08:11
Guteeen Mooorgäääähn liebe Sharpis AUSTRIAN *Frohes Neues* Das ist interessant, jedoch ist es bis April noch lange hin und hier wird über einen 52" geschrieben. Der ist bestimmt klasse und somit sollte man ihn heute schon vorbestellen, gell? Mir sind 42" etwas zu gross und der Preis wird dicker sein als der geniale neue Rückpro Full HD mit 55" von Sony, der super geiles Bild hat auf dem ich Mädchen in Bikinis sah, was nicht der Grund für das geile Bild ist Bitte den Test in der aktuellen HD+TV lesen. Mal sehen ob man mich im FN bei Sharp verbinden wird, da sie ja auf Service Nummern pochen von denen ich seit vorgestern Philips die Nase voll habe
Starchild_2006
Gesperrt
#37 erstellt: 04. Jan 2007, 15:14
Mano wann kommt der 52" er denn mit 3 HDMI und 120 hz ist er doch bestens für HD-TV geeignet.
Ich hoffe das es per HDMI keine Ruckelei bei Bluray gibt??
Weiß jemand was wann er kommt?
Frohes Neues und baldige Verfügbarkeit in Deutschland.
PharaDOS
#38 erstellt: 04. Jan 2007, 15:38
frühestens mai
in wirklichkeit august
NICKIm.
#39 erstellt: 04. Jan 2007, 15:41
Hallo in die Caferunde STARCHILD Wird es ihn nur als 52" anfänglich geben? Die sind mir zu gross. Ich rief bei Sharp die normale Hamburger Nummer an. Dort in der Zentrale hat mich die Dame mit ausländischem Akzent nicht weiter verbunden, da ich kein Händler bin, sie fragte danach. So gehen die mit Endkunden um? Naja ... Kopfkratz Nun weiss ich immer noch nicht ob es dieses Modell geben wird und wenn, wann es soweit ist. Der Manager hat es ja in einer Email an mich, bestritten. Nicht alles was in den USA auf den Markt kommt, gibt es auch bei uns. Bestes Beipiel ist z.B. Hitachi die teilweise Super LCDs und PDPs bauen, nicht alle erscheinen bei uns. Zudem haben wir in Europa andere Spezifikationen als in den USA, was jedoch nicht der Hauptgrund sein sollte
rmeier
#40 erstellt: 04. Jan 2007, 20:46
Letztes Jahr an der IFA wurde die neue HD1E Serie ja bereits vorgestellt mit der Aussage, dass Sie im Februar/März auf den Markt kommen. Das Design der D92U entspricht ja auch dem was an der IFA gezeigt worden ist. Auch wurde an der IFA betont wie wichtig der Europäische Markt für Sharp ist und deswegen kann ich mir nicht vorstellen, dass die Geräte erst im August bei uns erhältlich sein werden.
NICKIm.
#41 erstellt: 04. Jan 2007, 23:12
Guten Abend liebe Sharpis RMEIER Hallo Frau/Herr Neuling. Die zeigten dies auf der IFA? oooch menno an diesem Stand sind wir nicht gewesen da wir es zeitlich nicht schafften. Ich war zu lange bei meinem Lieblingshersteller um den Nachfolger unseres Plasmas zu betrachten der mit P beginnt P wie Pi... In welchen Diagonalen wird es die neue HighEndSerie geben d.h. mit welcher Diagonale wird sie beginnen? Komisch, dass man mir vor 2 Wochen mailte von Sharp auf Anfrage, dass keine neuen Modelle vorgesehen seien GUTE NACHT AUS DEM RAUM MG
[Beitrag von NICKIm. am 04. Jan 2007, 23:13 bearbeitet]
Ballu22
#42 erstellt: 05. Jan 2007, 12:06
habe gerade antwort von sharp erhalten mir teilten sie mit das das ein prototyp ist der in diesen ländern rausgebracht wurde und ob oder wann dies bei uns geschieht noch nicht entschieden ist
NICKIm.
#43 erstellt: 05. Jan 2007, 12:14
Mahlzeit Ihr Lieben BALLU Das deckt sich somit auch mit meiner Antwort vom Sharp Management dass diesbezüglich noch nichts feststeht. Danke für Deine Information. Nun ran an den Kochtopf
[Beitrag von NICKIm. am 05. Jan 2007, 12:15 bearbeitet]
Starchild_2006
Gesperrt
#44 erstellt: 05. Jan 2007, 16:04
Ein Prototyp der in Serie geht?????? In Amerika wo die für jeden Schei... verklagt werden???
Ich glaub die Sharpies hier in Deutschland sind total doof und wissen nicht wasa Sie sagen??
Sorry aber endlich mal ein Fernseher der alles abdeckt 3 HDMI für Settopbox, Bluray oder HD-DVD (oder neuerdings LG Kombiplayer HD-DVD und Bluray in einem Gerät), und Recorder dazu noch 120hz für das Ruckelproblem, ne unsere Modelle scheinen eher Prototypen zu sein, uns mit der aktuellen Serie wollen Sie den letzten Dreck andrehen: Banding, Streifen, Brummen und und und wie wir ja aus den Sharp thread der aktuellen Serie kennen.
Die sollen in den Sharp (äh Quark) kommen und dieses Modell hier so schnell wie möglich anbieten, Ich werde jedenfalls kein Modell mehr kaufen das nur halbe Funktionen und Ausstatung hat, deshalb können Sie die anderen verarsch... ein Fernseher ohne 24p und NUR 2 HDMI ist mir zu wenig DREI müssen es sein, wie ich eben schon beschriebgen habe, ZWITSCHER sind nicht zukunftsfähig und teuer, wer weiß wie es bei den zukünftigen Kopierschutz aussieht und man kann dann NICHTSMEHR durchschleifen ohne das das Bild runterscaliert oder schwarz bleibt, ne das ist mir zu unsicher. deswegen DREI HDMI drunter nicht und RUCKLN darf auch nichts.
UND wenn Sharp es nicht schafft dann haben SIe einen 52" weniger verkauft, dann warte ich leider auf Thoshiba oder LG oder wer als nächstes einen Fernseher mit der MINDESANFORDERUNG für die Zukunft rausbringt 24p 3 HDMI Full HD mind. 46" wenn s geht 52" für vernünftiges Geld wie halt dieser vermeintliche Sharp.
Bringt IHN endlich in Deutschland raus.
NICKIm.
#45 erstellt: 05. Jan 2007, 16:22
STARCHILD . . . Diese Worte mit dem Wort Quark lassen wir hier nun einmal unkommentiert stehen. Hierzu könnte man viel sagen. Hoffentlich hat keiner von Sharp mitgelesen. Alles was abdeckt hat ein nicht bezahlbarer Loewe und nun auch Metz, weitere werden folgen Sandte an LG eine diesbezügliche Email Anfrage unter der Rubrik Support
Starchild_2006
Gesperrt
#46 erstellt: 05. Jan 2007, 16:31
Gibt es ein Full HD mit 24 und DREI HDMI von einen anderen Hersteller??? Loewe oder Metz???
Modell bitte!!
NICKIm.
#47 erstellt: 05. Jan 2007, 16:50
STARCHILD Ob die beiden Full HD mit integriertem HDTV Tuner auch 24p und 3 HDMI haben, das weiss ich leider nicht. Da muss ich mal auf www.metz.de und www.loewe.de direkt einmal nachsehen. Das ist eine sehr interessante Frage von Dir
fenrye
#48 erstellt: 06. Jan 2007, 13:06
na mit den anforderungen nen LCD von LOEWE zu bekommen dürfte wohl so ca. 7000-8000 euro kosten...so bei 46"!
der INDIVIDUAL bla bla oder wie der aktuelle heißt,kostet ja in 40" schon irgendwas bei 5000 euro....
Starchild_2006
Gesperrt
#49 erstellt: 06. Jan 2007, 13:46
Soll ja kein Loewe oder Metz sein, LG Samsung etc. halt mit der Vollausstattung für HD-DVD oder Bluray ohne zu Ruckeln und DREI HDMI und natürlich FULL HD
NICKIm.
#50 erstellt: 06. Jan 2007, 14:53
Grüß Gott liebe Gemeinde Das mit Loewe, Metz und Co. war ja auch als Antwort auf einen anderen Chatter gedacht. Er wollte gerne wissen ob es bereits Anbieter gibt, die Full HD DVB-S integriert haben oder werden und mindestens 3 HMDI Eingänge haben =lach=. Keiner hat bisher 3 HDMI Eingänge die man eigentlich auch nicht braucht da fast alles modular im Chassis integrier ist. Man kann natürlich auch einen Full HD vom Reis Hersteller Amoi, Benq oder Tupperware kaufen
Starchild_2006
Gesperrt
#51 erstellt: 06. Jan 2007, 19:59
3 HDMI : HDTV Settopbox per HDMI, Bluray oder HD-DVD per HDMI und Recorder per HDMI also drei sind Pflicht und der neue Sharp soll ja drei haben.
Neue Sharp-Displays Anfang 2007: nicht nur D92U aber auch D82U
Elio am 23.01.2007  –  Letzte Antwort am 26.01.2007  –  11 Beiträge
Sharp LC-46 HD1E
jp-jo am 18.11.2007  –  Letzte Antwort am 09.01.2008  –  74 Beiträge
Sharp LC-52 HD1E
Meadows9 am 07.01.2008  –  Letzte Antwort am 08.01.2008  –  3 Beiträge
Sharp XL2E/HD1E/ Philips PFL9732
mgaertner85 am 06.04.2008  –  Letzte Antwort am 08.04.2008  –  2 Beiträge
Sharp HD1E auch als 42"
pinklady63 am 19.11.2007  –  Letzte Antwort am 19.11.2007  –  5 Beiträge
Wandhalterung SHARP LC-52 HD1E
Adler_Lothar am 24.01.2008  –  Letzte Antwort am 25.01.2008  –  4 Beiträge
SHARP LC-52 HD1E Standfuß
TikTakTok am 26.01.2009  –  Letzte Antwort am 07.03.2009  –  2 Beiträge
Neue Sharp LCDs
pinklady63 am 31.03.2008  –  Letzte Antwort am 03.04.2008  –  6 Beiträge
Problem Digi Tonausgang Sharp LC52 HD1E
cazique am 26.03.2008  –  Letzte Antwort am 29.03.2008  –  7 Beiträge
Sharp LCD LC-46 HD1E Uhrzeit Daueranzeige
zokla am 08.11.2008  –  Letzte Antwort am 12.11.2008  –  5 Beiträge
  • Registrierte Mitglieder930.627 ( Heute: 10 )
  • Neuestes MitgliedCount_Vasquez
  • Gesamtzahl an Themen1.563.370
  • Gesamtzahl an Beiträgen21.823.539
