| HIFI-FORUM » Fernseher & Beamer » Plasma-Fernseher » Samsung » DER SAMSUNG 2011 PS-XX (+1) D 450 Einstiegsplasma ... | |
DER SAMSUNG 2011 PS-XX (+1) D 450 Einstiegsplasma 2D THREAD+A -A |
mentox76
erstellt: 05. Mrz 2011, 15:15
Hallo, ich verfolge begeistert die ersten Ankündigungen zu den Samsung Plasmas der Oberklasse von Samsung (8090&Co.) und frage mich ob die Einstiegsklasse auch mittlerweile gute Schwarzwerte liefert z.b. P43D450..PS51D450.. . Eventuell hat bereits jemand etwas im internet gefunden oder konnte bereits eines dieser neuen Einstiegsgeräte testen.... hoffentlich können wir diese Infos hier in diesem Thread zusammen fassen. Gruss mentox76 |
mentox76
erstellt: 05. Mrz 2011, 15:21
mentox76
erstellt: 12. Mrz 2011, 13:36
US-Infos:NEW! 43" Class (43.0" Diag.) Plasma 450 Series ![]() Plasma +1 Plasma +1 for 2011 new models means your Samsung PDP TV has a reduced bezel design that allows for a larger viewing area without having to increase the TV’s outside dimensions. Plasma +1 TVs also feature a sophisticated slim depth design. This design approach makes the TVs look lighter and less bulky. 600Hz Subfield Motion 600Hz Subfield Motion Samsung’s plasma televisions make action more life-like and natural looking. Action scenes and sporting events are crisp, clear and picture perfect. 600Hz Subfield Motion flashes a single image up to 600 times a second creating unprecedented picture quality. Contours are crisper and scrolling text sharper— no matter how fast images are moving. Fast action scenes are both clear with rich deep color detail. ConnectShare JPEG ConnectShare JPEG ConnectShare JPEG lets you play music or view photos from a USB drive. Simply plug your USB directly into your Samsung TV’s USB port and watch on the big screen with friends and family. ENERGY STAR ENERGY STAR Go green and save the planet with a Samsung TV. All Samsung TVs not only meet ENERGY STAR requirements; they exceed them. This means: • More energy savings • Lower utility bills • Leaving a smaller carbon footprint on the environment HDMI HDMI With HDMI, you can easily connect up to 2 compatible AV devices at the same time and replace AV cables with a single solution. An HDMI cable can replace anywhere from two to five cables so you can de-clutter your entertainment space with fewer wires. specifications Series * 450 Series Line of Samsung HDTV models with a common set of features and capabilities. Design * Plasma TV Video * 43.0" Screen Measured Diagonally The diagonal length of a TV screen or monitor, as measured in inches from corner to corner. * 1,280 x 720 Native Resolution Fixed number of horizontal scan lines on a TV. P (Progressive) means scan lines are drawn in sequence. * .001 ms Response Time Speed at which pixels can change color. Lower response times mean better motion image reproduction. * 600Hz Subfield Motion Refresh Rate * 16:9 Aspect Ratio Ratio of the width of an display to its height. 16:9 is the universal standard for high-definition TV. Audio * SRS TheaterSound™ Audio enhancement technology for TVs. SRS TruSurround XT provides 3D sound without extra speakers. * Built-in Bottom Speakers Mechanism in TV that outputs audio. Down firing enhances bass by directing low-end toward ground. Features * ConnectShare™JPEG * Auto Channel Search Function that seeks out available channels and automatically programs them for easy cycling. * Auto Power Off Function that automatically powers down television to save energy if no signal is present. * Auto Volume Leveler Function that caps volume on loud advertisements so that they're more consistent with programming. * Clock & On/Off Timer * Closed Captioning * HDTV Tuner Built-in An internal receiver that enables a TV to utilize Digital Television technology. * Sleep Timer * V-Chip Allows parents to block inappropriate movies and programs based upon their FCC rating. Inputs & Outputs * 2 HDMI Inputs High Definition MultiMedia Interface. CEC ensures HDMI components can be controlled by one remote. * 2 Component Inputs Analog video connection that transmits information along two or three separate signals. * 1 PC Audio Input (Mini Jack) Port that allows television to receive high-quality sound directly from a computer. * 1 USB 2.0 Port Universal Serial Bus. Interface standard for connecting peripherals to a computer. USB 2.0 is high-speed. * 1 Optical Digital Audio Output Ports used to transmit digital audio streams between components without interference. Dimensions * 2.2" Depth The measurement, in inches (in.), of the television from front to back. * 39.8" (W) x 24.5" (H) x 2.2" (D) Without Stand Width, height and depth of the television, with stand, as measured in inches (in.). * 39.8" (W) x 27.5" (H) x 9.8" (D) With Stand Width, height and depth of the television, without stand, as measured in inches (in.). * Shipping Dimensions: 43.7" (W) x 29.0" (H) x 10.6" (D) Width, height and depth of the television, with shipping container, as measured in inches (in.). Weight * 35.3 lbs. Without Stand Weight of the television, without stand, as measured in pounds (lbs.). * 41.9 lbs. With Stand Weight of the television, with stand, as measured in pounds (lbs.). * Shipping Weight: 51.6 lbs. Original von der US Samsung Seite [Beitrag von mentox76 am 12. Mrz 2011, 13:41 bearbeitet] |
mentox76
erstellt: 12. Mrz 2011, 14:08
US-Infos:NEW! 51" Class (51.0" Diag.) Plasma 450 Series ![]() Plasma +1 Plasma +1 for 2011 new models means your Samsung PDP TV has a reduced bezel design that allows for a larger viewing area without having to increase the TV’s outside dimensions. Plasma +1 TVs also feature a sophisticated slim depth design. This design approach makes the TVs look lighter and less bulky. 600Hz Subfield Motion 600Hz Subfield Motion Samsung’s plasma televisions make action more life-like and natural looking. Action scenes and sporting events are crisp, clear and picture perfect. 600Hz Subfield Motion flashes a single image up to 600 times a second creating unprecedented picture quality. Contours are crisper and scrolling text sharper— no matter how fast images are moving. Fast action scenes are both clear with rich deep color detail. ConnectShare JPEG ConnectShare JPEG ConnectShare JPEG lets you play music or view photos from a USB drive. Simply plug your USB directly into your Samsung TV’s USB port and watch on the big screen with friends and family. ENERGY STAR ENERGY STAR Go green and save the planet with a Samsung TV. All Samsung TVs not only meet ENERGY STAR requirements; they exceed them. This means: • More energy savings • Lower utility bills • Leaving a smaller carbon footprint on the environment HDMI HDMI With HDMI, you can easily connect up to 2 compatible AV devices at the same time and replace AV cables with a single solution. An HDMI cable can replace anywhere from two to five cables so you can de-clutter your entertainment space with fewer wires. specifications Series * 450 Series Line of Samsung HDTV models with a common set of features and capabilities. Design * Plasma TV Video * 51.0" Screen Measured Diagonally The diagonal length of a TV screen or monitor, as measured in inches from corner to corner. * 1,280 x 720 Native Resolution Fixed number of horizontal scan lines on a TV. P (Progressive) means scan lines are drawn in sequence. * .001 ms Response Time Speed at which pixels can change color. Lower response times mean better motion image reproduction. * 600Hz Subfield Motion Refresh Rate * 16:9 Aspect Ratio Ratio of the width of an display to its height. 16:9 is the universal standard for high-definition TV. Audio * SRS TheaterSound™ Audio enhancement technology for TVs. SRS TruSurround XT provides 3D sound without extra speakers. * Built-in Bottom Speakers Mechanism in TV that outputs audio. Down firing enhances bass by directing low-end toward ground. Features * ConnectShare™ JPEG * Auto Channel Search Function that seeks out available channels and automatically programs them for easy cycling. * Auto Power Off Function that automatically powers down television to save energy if no signal is present. * Auto Volume Leveler Function that caps volume on loud advertisements so that they're more consistent with programming. * Clock & On/Off Timer * Closed Captioning * HDTV Tuner Built-in An internal receiver that enables a TV to utilize Digital Television technology. * Sleep Timer * V-Chip Allows parents to block inappropriate movies and programs based upon their FCC rating. Inputs & Outputs * 2 HDMI Inputs High Definition MultiMedia Interface. CEC ensures HDMI components can be controlled by one remote. * 2 Component Inputs Analog video connection that transmits information along two or three separate signals. * 1 PC Audio Input (Mini Jack) Port that allows television to receive high-quality sound directly from a computer. * 1 USB 2.0 Port Universal Serial Bus. Interface standard for connecting peripherals to a computer. USB 2.0 is high-speed. * 1 Optical Digital Audio Output Ports used to transmit digital audio streams between components without interference. Dimensions * 2.2" Depth The measurement, in inches (in.), of the television from front to back. * 46.8" (W) x 27.8" (H) x 2.2" (D) Without Stand Width, height and depth of the television, with stand, as measured in inches (in.). * 46.8" (W) x 30.8" (H) x 9.8" (D) With Stand Width, height and depth of the television, without stand, as measured in inches (in.). * Shipping Dimensions: 51.2" (W) x 32.8" (H) x 13.0" (D) Width, height and depth of the television, with shipping container, as measured in inches (in.). Weight * 49.6 lbs. Without Stand Weight of the television, without stand, as measured in pounds (lbs.). * 56.2 lbs. With Stand Weight of the television, with stand, as measured in pounds (lbs.). * Shipping Weight: 69.4 lbs. Infos von der US Samsung Seite [Beitrag von mentox76 am 13. Mrz 2011, 12:47 bearbeitet] |
mentox76
erstellt: 12. Mrz 2011, 14:10
Preise pendeln sich langsam ein, Geräte sind allerdings noch nicht verfügbar: Preisvergleich 43" Geizhals Preisvergleich 51" Geizhals [Beitrag von mentox76 am 12. Mrz 2011, 14:13 bearbeitet] |
mol69
erstellt: 14. Mrz 2011, 20:47
Das ist ja bitter, dass der 450er nur ConnectShare JPEG statt movie hat. Hatte mich schon auf diesen TV als meinen ersten Plasma eingestellt, aber das Abspielen von avi über usb ist Pflicht. Mal schauen, was Panasonic und LG in der Hinsicht bei ihren Einstiegsmodellen zu bieten haben. Im Notfall muss ein externer Media player her. Das Geld würde ich aber lieber direkt in den Fernseher stecken und mir nebenbei ein zusätzliches Gerät sparen. |
mentox76
erstellt: 19. Mrz 2011, 16:12
Erste Userberichte ausserhalb DE/AT/CH werden geschrieben hierUnd im avforums gibt es auch erste Berichte link@mol69 das wird auch etwas dazu geschrieben ob mkv und andere videoformate über usb funktionieren.. Und noch ein erstes Review klick mich [Beitrag von mentox76 am 19. Mrz 2011, 16:38 bearbeitet] |
mentox76
erstellt: 20. Apr 2011, 09:20
Ein Update: Der PS43D450 hat uns jetzt 4 Tage lang begleitet und ist wieder zurück beim Händler. Zur geschichte: Meine Schwester sucht einen sehr günstigen aber guten 42" TV. Die bisher gesichteten LCDs in der Preisklasse 500€ (+/- 100€) waren nicht gut (Falsecontur/Bewegtbilddarstellung), daher Plasma. Da ich auch noch ein neues Gerät für unser Schlafzimmer suche, passt der Zeitpunkt perfekt. Ich habe einen Direktvergleich (Messinstrument ist mein Auge) gegen Panasonic C3e gemacht (hat der Nachbar) und als Referenz habe ich ja noch den Kuro 9G 50" (zwar unfair aber um einen weiteren Blick zubekommen sehr hilfreich) aus meinen Wohnzimmer. Pro: - Sehr gutes Bild out-of-the-box.. man muss nicht all zu viel einstellen um fürs Auge ein normales Bild zu bekommen - Sehr sehr hohe Helligkeit (Panasonic & Kuro ist viel dunkler) - Display ist beschichtet mit einer Antireflex-Folie oder ähnlich - dadurch absolut tageslichttauglich, besser als mein Pioneer Kuro und das hat mich überrascht - Schwarzwert bei Tag ist perfekt, richtig schwarz aber die Konturen saufen nicht ab (vergleich Kuro) - gute Bewegtbildwiedergabe - spielt sehr viele Formate ab über dem USB-Port - angenehmer Klang für ein Gäste/Schlafzimmer durchaus ausrechend - sehr leicht <20kg Contra: - Sehr sehr viel gesurre, das hat mich erschreckt und letzendlich dieser Exemplar als Rückgabekandidat deklariert - Schwarzwert ist nicht so prall im abgedunkelten Raum (erst recht nicht im Vergleich Kuro) - Sehr günstiger Plastikrahmen, man bemerkt sofort die "Stanz/Schnitt-Kanten" (der C3e ist nicht ganz so schlimm vom Gehäuse) - staubt heftigst schnell zu bzw. Rahmen "lädt" sich nach einer Zeit statisch auf und zieht alles an sich ran (das ist mir bei dem Pana und dem Kuro nicht aufgefallen). Da zur zeit bei uns die Pollen umherflieren ist das Gerät super wenn man alle Polen konzentriert in einem Punkt des Raumes wegputzten möchte. Kurzum, ich hatte eventuell nen schlechtes Exemplar erwischt und es gibt sicherlich Geräte die "leise" sind. Der Panasonic c3e ist aber nicht besser und jetzt wird ein Panasonic S30e getestet (kommt nächste Woche). Zur Zeit würde ich den Panasonic 42c3e (bei abgedunkelten Fernsehgenuss) nehmen weil der einfach billiger (im Angebot 375€) ist aber als TV für ein Wohnzimmer (um bei Tageslicht zu schauen) ist zur Zeit der D450 weiter vorne und die 100€ Aufpreis sind mehr als gerechtfertigt für die bessere Bewegtbilddarstellung und dem helleren Bild. Da ich aber Preisliegen gerecht noch en Panasonc 42S30e (der vom Bild her baugleich zu den Preisliegen gerechten 42u30e sein soll) testen werde, den ich mir persönlich auch für mein Schlafzimmer bestellt habe wird sich zeigen was meine Schwester dann bestellt. Meine subjektive Meinung die ich weitestgehend versuche objektiv zu halten würde ich bei beschränkten Budget nen Samsung d450 nen Panasonic c3e vorziehen, wenn den andere D450 ähnlich leise sirren wie der Panasonic. Wenn ich aber kein TV und DVD bzw. Bluray damit schauen möchte sondern nur Schwarzwerte messtechnisch im abgedunkelten Labor vergleichen will, dann würde ich den Panasonic nehmen. Ich hoffe so manch einer kann etwas damit anfangen. my 2 cents [Beitrag von mentox76 am 20. Apr 2011, 09:26 bearbeitet] |
HAL-1000
erstellt: 20. Apr 2011, 14:08
danke für den Erfahrungsbericht, man hört ja leider so gut wie gar nichts von der 450er Serie. Wäre toll wenn auch andere berichten könnten, ob denn das Surren bei allen auftritt. |
Tommytb1
erstellt: 28. Sep 2011, 10:13
Ich habe den Samsung PS51D450 und bin als Laie vom Bild mit digitaler Quelle sehr angetan. Das fehlende FullHD stört mich bei 3m Sitzabstand kein Stück. Jedoch habe ich ein relativ helles Zimmer mit 2 Fenstern, wo eins genau gegenüber des TV ist und eins schräg gegenüber liegt. Und ich finde die Spiegelungen bei Tageslicht (ohne direkte Sonneneinstrahlung) leider unerträglich, sodass ich ihn zurückgeben werde und nun auf der Suche nach einer wenigerspiegelnden preiswerten Alternative bin. |
ESVTOM61
erstellt: 28. Sep 2011, 14:11
@Tommyb1 Hab den gleichen seit nun mehr 2 Monaten und bin mehr als zufrieden. Das Preis/Leistungsverhältnis ist einfach Top! Das Spiegelproblem ist eigentlich ein bekanntes Plasma Problem. Hatte vorher nen Panasonic. Der spiegelte etwas weniger. Die LG´s sollen aber in der Beziehung die Schlimmsten sein. Ich habe auch eine sehr große Fensterfront ( 6qm ! ) genau gegenüber. An hellen, sonnigen Tagen ist es schon etwas störend, aber ich kann damit leben. Zumal, zumindest bei mir, 70 oder 80% des TV Glotzen eher in den Abend/Nachtstunden ablaufen. Somit erübrigt sich das Spiegeln! Auch das Surren was hier immer wieder angesprochen wird kann ich nicht bestätigen. Er ist fast geräuschlos. Fast heißt: Wenn ich den Ton aus mache und auf unter 40 cm an den TV rangehe ist es gerade hörbar. Was mich dann schon eher etwas störte waren die etwas deplatziert angebrachten Anschlüsse. Bei mir hängt der Plasma an der Wand ( wo er hingehört ;-) ) und da ist natürlich ein Kopfhörer oder PC Anschluß an der Gehäuserückseite nun wirklich an der ungünstigsten Stelle. aber gut... Das positive überwiegt ganz klar. [Beitrag von ESVTOM61 am 28. Sep 2011, 14:19 bearbeitet] |
Roman_29
erstellt: 29. Sep 2011, 19:15
Ja hallo stimmt das ,das der PS43D450 unter 100Watt Strom verbraucht? Weil was die Firmen schreiben kann man ja nicht immer glauben. |
adiclair
erstellt: 07. Jan 2012, 07:05
Guten Morgen, hätte ein Besitzer des PS51D450 die Güte mal bitte ein Foto von der Rückansicht (wegen der Anordnung und Anschlussrichtung(en) der Anschlüsse) dieses Plasmas hier einzustellen? Online ist dahingehend leider nichts zu finden... Danke schon mal |
DER SAMSUNG PS-XX C 450 THREAD spartain am 13.03.2010 – Letzte Antwort am 18.06.2011 – 69 Beiträge |
DER SAMSUNG PS-XX C 6500 THREAD spartain am 13.03.2010 – Letzte Antwort am 06.10.2015 – 2662 Beiträge |
Der Samsung PS-XX C 530 Thread spartain am 13.03.2010 – Letzte Antwort am 14.05.2010 – 7 Beiträge |
DER SAMSUNG PS-XX C 430 THREAD ricker09 am 02.06.2010 – Letzte Antwort am 22.09.2010 – 8 Beiträge |
DER ULTIMATIVE SAMSUNG PS-XX C7790/7780/7700 THREAD Ralf2001 am 15.03.2010 – Letzte Antwort am 29.05.2017 – 10279 Beiträge |
FAQ - SAMSUNG PS-XX C7790/7780/7700 tukane am 13.10.2010 – Letzte Antwort am 02.03.2012 – 81 Beiträge |
DER ULTIMATIVE SAMSUNG PS-XX C 7790 THREAD submann am 22.03.2010 – Letzte Antwort am 22.03.2010 – 2 Beiträge |
DER Samsung XX F5000/ 5570 Plasma Thread spartain am 27.03.2013 – Letzte Antwort am 08.05.2015 – 268 Beiträge |
Samsung PS B430 / PS B450 Thread schnutinio am 21.04.2009 – Letzte Antwort am 09.12.2012 – 472 Beiträge |
Der Samsung PS-42S5H-Thread jean-paul am 10.03.2005 – Letzte Antwort am 17.06.2005 – 260 Beiträge |
- Samsung UE32C6700 Sat.system einrichten/LNB-Einstellungen für Turksat 42E
- HDMI schwarzp? auf gering oder normal?
- WLAN Verbindung verschwindet nach dem Ausschalten des TV Gerätes
- Hilfe! PS51D550 Bildeinstellung setzt sich automatisch zurück!
- flackern, flimmern bei hellen Bildern
- DER PS50A450 THRAED
- PS42A450 -grauer Bildschirm
- Der ULTIMATIVE B850 / B859 SERVICE MENÜ Thread!
- Hilfe Staub zwischen Scheibe und Panel
- PS50c687 Kanäle verschieben,wie?
- Registrierte Mitglieder930.959 ( Heute: 5 )
- Neuestes MitgliedJürgen47
- Gesamtzahl an Themen1.564.259
- Gesamtzahl an Beiträgen21.848.637
