| HIFI-FORUM » English » Buy & Sell (Engl.) » XAVIAN XN 360 [Walnut] - Speaker - New for sale !! | |
XAVIAN XN 360 [Walnut] - Speaker - New for sale !!+A -A |
bhagwan69
erstellt: 22. Feb 2006, 16:09
www.xn360.comFor Sale ! Brand New. Full Import Papers. Customs Duty + Octroi paid - with documents. November, 2005 Import. Walnut Finish - sparingly used. PM me for further details. Regards, BHAGWAN69 Xavian - Manufacturer NX-360 - Model [Details are on the web site mentioned] Audition - Demo is available.
bhagwan69
erstellt: 06. Nov 2006, 08:25
The Xavian XN 360 was awarded the Danish Speaker of the Year - Editors Choice - award. Details & translation is as under :- ----------------------------------------------------------- http://www.hifi4all.dk/content/templates/anmeldelser.asp?articleid=1399&zoneid=3 This is the original site for the Xavian XN 360 review. I have copied & pasted a translated version - just for reference sake. Please do have a look if you may be interested. Thanks, ----------------------------------------------------------- I love these aha experiences, where one is sincerely surprised, because the sound is so good at so few money. to What have I then call that experience I just have had with these Xavian XN 360s? Because with a set-price at 59.900, it is well just strict enough to call ... ... them cheap or a bargain. Still it is one aha experience, because I have never heard a loudspeaker be playing like this, and I have listened to more very expensive loudspeakers. XN 360 puts rather new standard for what one can pull out of a loudspeaker. Do you believe you me? Thus go yourself out and listen, or try them at home with you. Thus not said that the fact the world's best loudspeaker, for it is a question of personal taste. But it is completely safe with at the distinguished company, among the very best ones. . The construction is 3-road's with ”top of the line” unities from Scan Speak’s Revelator series. 2 pieces 7” bass, one 4” medium-tone, and one 1” ring-treble. The price for the unities only makes up over a fourth of the loudspeaker's price! Apart from the fine unities everything as possible is loudspeakers well-consideredly, and tested to the finger-points for that safe saw optimum a result as possible. The divide-filters have filled with few, but quite good components, and the internal kabling comes from Supra. Medium-tone and treble sit at their own cabinet at the top out against the front, and the rest of the cabinet is split up up into 7 chambers, as acoustically work together in order to produce deep and stiff bass. The bass-gate is at the bottom, and the sound/the air come out between the bottom and the black pedestal. The cabinet is dimensioned to be playing all the way down to 25 Hzes, and I am near thinking that XN 360 actually does it! I tried with a test-record to hear where far they went down, and at 30 Hzes there was full level, and at 20 Hzes the level was more lower but still audible. Saw, they can play Deep bass! The cabinet on this loudspeaker is large! Enough to that that will frighten most females from letting them come into the living room (where am I however glad to have my own listen-space!). All records are collected in a groove, and not just glued in a gering. to De-stivnings there had by all accounts be plenty of. The cabinet is in any case completely dead when one knocks on it. The weight is up on just under 40 kgs.! That is probably due to also the moderate-material that among other things consists of bitumen. It hasn't been possible to look into the loudspeaker, since all unities and the record to the data terminals are sealed. The front is narrow and can precisely accommodate the two big fat men across, and slants backwards in an angle on about 15 degrees, thus the unities are playing in correct phase. The All the way round along the front, is the edge slanting, thus the front brushes itself along the unities. This is also done in order to avoid phase-mistakes and standing waves. This loudspeaker is high and deep, and that might be cause of problems placing it at a normal room on 15-20 sqm. But no, that is no problem. At a placing with 30-35 cm to the back wall, this an a little raisedly, but gave very stiff bass. If I moved farther out them at the space and denser on the listening position, the level fell in the bass. In return ”niveauet” fell in the perspective also. That is a compromise, but I go away XN 360 closer on the back wall where the perspective is entirely on place. As long as the bass is so exact and stiff like it I here experience, saw peace be with the raised level! The finish is in a class apart. Leak, leak cherry-veneer that is mirrorred with the greatest precision. Other prospectses are: Walnut, maple and fugleøje-maple. If you have other wishes to the finish, it can also let itself do against a small increased price. It simply is a class this. The small distance-pieces between the bottom and the pedestal, and spikes’s are made with a piece of jewellery-similar finish. If I didn't know more any better, I'd think that that was silver. The data terminals aren't gilt - they are platinered! And that is WBT’'s best data terminals. The small ones=”plader” ones that is used if you do not want to the biwire loudspeakers, are made in silver and also are from WBT. Yuck, where is it just delicious! Down on the side you find a badge with the loudspeaker's name: TrecentoSessanta (Italian for 360), that refers to the philosophy about spreading the sound mostly possibly. The unities' finish now doesn't let anything either back to wish, everything fits perfectly, and the alu-chassis’ers are in top class. The basses are lowered into the front, the medium-tone sits on the outside of the front, a little in out the treble's chassis, which is also lowered into the front. Note the screws' placement on all unities, and peeper you correctly close to, you notice following letters round along with the screw's head How player did see a loudspeaker in absolute top class? relaxedly and U-tense, so simply it can be said. Yes, that was that test. Well, not? You want to know more about this fantastic loudspeaker? OK, you get a little more. Let us take the logical road, and start from scratch. As an earlier written then this loudspeaker delivers stiff bass. That I forgot to mention, were that that is unusually stiff bass. Present you that a large hand comes out of the bass-gate, and gets a grip on the air your listen-space, and moves this that a stamp in exactly the same time as the unities dictates. See, that is stiff bass! And it is completely unimportant whether the loudspeaker stands close to the back wall or inside a corner, and the level thus rises. On ”normale” loudspeakers would this placement completely destroy the precision, but not on XN 360 thanks to ”hånden”, which dictatorially controls the air at your listen-space. Do I need to mention the the-taljering in the bass? OK, saw rotten puddle. But, everything is there just. The bass drum gives you one stomach-puster after the other, and the basgang shakes your body like an earthquake. It is completely scary that this loudspeaker controls the bass-area. Oh, where is it good Medium-tone and treble ... I do not at all know to what I have write! That just is so perfect. The good Revelator-unities come to their full dish here, and they are exploited completely. Mate to airy, exact and detailed reproduction have you really to look long for. Voices put you at meeting in the most natural way, you stay almost in doubt that that is a loudspeaker that is playing. Crisp, dare, rough, hot, frighteningly and stretchingly, all facets are along. It is absolute top class this. Again there is the the-taljering without comparison. Everything comes through, and then there is air in between all the things in the sound picture, thus you think that that is a lie. That is the most homogeneous loudspeaker I have ever listened to. I want to go so far as to say that this isn't a ”høj taler”, but a music-mediator. Because it isn't just high talking, but arranges the music as for that was intended. apropos U-tense and relaxed, it really was the first words for that occurred to me, when I listened to this ”musikformidler” for the first time. I put a record on, and turned a little up, which actually was plenty because of this music-mediator's sensitivity and dynamic ability. I enjoyed it, and again my other self tore records out of drawers and down from shelves, because I could get enough not at all. Then the time came to where the music-mediator had be pressed. I turned up a nice drop volume, and got an answer that I didn't at all possibly. think It retorted again!: ”Er that everything you do have? Come now. Give me a little more! ” Want to you have more, I thought, while I turned up the potentiometer in a dangerous position, you have get more. What a damn, again did I get an answer in kind: ”Helt honestly, is everything you have? Because I can easily handle more, give myself now all you have! ”. But I am a chicken, and I am fond of my ears far too. Thus I gave lostly, and was sitting back with the lower jaw hanging down on the chest, and thought: That is a lie! That simply is lie. Nobody ... no loudspeaker to home use can stand abuse in that degree. But yes, now there is one that can do. Stop all the way up, where is it however relaxed and U-tense in its communication. Perspective isn't a word I want to use here, because you are looking directly into the optag-space/the concert hall. There isn't any mention of a perspective, but a wall to wall and floor to loft window-front that stands openly, and gives you view/insight to everything! I sensed at no time a limitation in it - on the recording - intended spaces. Everything is along, without exception. A thing that first occurred to me after most of the text to this test was written, were that the word neutral has never fallen me into connection with XN 360. Is it neutral? No, that is it really not! The big fat man I have already mentioned, and only that pulls it away from being neutral. Apart from it medium-tone and treble are actually also stressed. That wasn'thing I noticed from first but something that in the course of time crept up under the skin on a pleasant way pleasant way. Because it isn't hot or cold stressed. The nearest self can come, are natural or musically be-toned. highly Fidelity! Does it make sense? How does one justify a price at 59.900, for a set of loudspeakers? That is what I court do not know, but one court know I: If you want to have sounds in this class, you possibly over 100.000, have to go a completely different price range, possibly over 100.000,. Seen in that light, the price on these beautiful and fantastic music-mediators from Xavian can maybe well be justified. The only thing who torments me and that I probably get to see again. music-mediators back that I probably never to see again, are to see again. yuck, where may the hifi-life however be unfair. Specifikationer: Basenheder: 2 stk. 182 mm Scan-Speak Revelator Mellemtoneenhed: 120 mm Scan-Speak Revelator Diskantenhed: 38 mm Scan-Speak Revelator ring dome System: 3-vejs bas-refleks Frekvens område: 28 Hz – 40.000 Hz (-3 dB) Terminaler: 2 sæt platinerede WBT 0730 signature, bi-wiring Nominel impedans: 4 ohm (min. 3 ohm) Delefrekvenser: 350 & 3500 Hz, 6 dB filterorden Følsomhed (2,83 V/1m): 90 dB Anbefalet forstærker-effekt: 80 - 250 W Dimensioner: (H x B x D): 1103 x 198 x 490 mm Vægt (1 stk.): 38 kg Importør: Stoplite HiFi Søndergade 48B 8740 Brædstrup Tlf.: 70262698 Web: www.stoplite.dk Mail: info@stoplite.dk ----------------------------------------------------------- |
Shahrukh
erstellt: 06. Nov 2006, 08:58
I thought the Xavians were a Czech brand!! |
bhagwan69
erstellt: 06. Nov 2006, 09:05
The Xavian's are made on Czech Republic by Mr. Roberto Barleta. He is Italian. Married to a lady from Czech Republic. Hence he now stay's in C. R. The speakers are made in C.R. [hence they are so cheap]. The speaker won the award in Denmark. The Danish Press loved the speaker & awarded it its 'editor's choice' award. That is the special part of this product. Made by an Italian in C. R. & wins an award on Denmark - that too without giving any 'ads' in any press. Hence the product must be 'half descent' to say the least. I wish I could get the forum members to hear it. I just do not have the room to play it in - hence an audition is not possible. Sad Bhagwan |
bhagwan69
erstellt: 24. Nov 2006, 06:02
First time I am trying to upload a picture, I do hope it works; just wanted to share it with you guys. http://img299.images...labsmicroutopek5.jpg http://s2.supload.com/free/IMG_0231.JPG/view/ http://s2.supload.co..._2006_(11).JPG/view/ [Beitrag von bhagwan69 am 24. Nov 2006, 07:23 bearbeitet] |
bhagwan69
erstellt: 11. Jan 2007, 08:06
XN 360 may be sold; In New Delhi i.e. So, I would like to pull this ad out. Any idea how it can be done ? Thanks, Guys in ND could go over for a listen if interested. Please do PM me & I will give you the address & contact details. Should make for some interesting listening. |
Prithvi
erstellt: 11. Jan 2007, 16:15
Great, seems you have been sitting on this one for quite some time. Great that its finally going. |
SDhawan
erstellt: 11. Jan 2007, 17:01
Where in Delhi can I audition them? |
bhagwan69
erstellt: 12. Jan 2007, 10:04
Actually, I am rather sad to have let it go. It was a lovely speaker. The cheapest anyone could have purchased with Scanspeak Revetalor Drivers & THE CHEAPEST speaker in the world that used a Super Revalator. It went for a song. The only good part of the story is that a 'good audiophile friend' of mine purchased it. He will surely enjoy it. Maybe, I too can listen to it when I am in New Delhi. P.S. Just goes to show how difficult it is to sell a great product that does not have a 'brand' associated with it. I cannot think of any other speaker @ 200/- K that will beat it - brand new, i.e. |
bhagwan69
erstellt: 12. Jan 2007, 10:06
I will pm the contact to you. Let him set it up, once it is ready, you may call and drop by, it will be pleasure to have you over. I really liked the XN360 a lot. |
Kamal
erstellt: 12. Jan 2007, 16:22
Sanjay, Plz count me in too, if Bhagwan does'nt mind. Kamal |
bhagwan69
erstellt: 13. Jan 2007, 09:06
Why should I mind !!! I have sold the speakers. You are more than welcome to drop by for an audition. I am sure my friend in ND will love to have you over. Just coordinate and go over. I will send the details to DOC. Thanks. |
bhagwan69
erstellt: 05. Feb 2007, 06:49
Picture of the Xavian in a set up :- URL=http://img186.imageshack.us/my.php?image=xavianxn360plinuswadiamfu7.jpg] [/URL] |
bhagwan69
erstellt: 24. Jul 2007, 11:12
Hey; Did you guys actually go in for a listen ? The XN 360 i.e. Did you like it ? Hate it ? I never got a feedback from you. I was going through my postings & this crossed my mind. Just wanted to know. Thanks, |
Kamal
erstellt: 24. Jul 2007, 16:43
I guess Sanjay is content these days in enjoying his new set up. Heard it again this saturday last after we returned from the concert-it sounds really great! A truly well balanced system-CyrusCDP, Cyrus Pre/Power with ProAc Studio 140. With this, you can sit back and enjoy your music.... |
bhagwan69
erstellt: 25. Jul 2007, 04:33
Sure his set up is magnificent !!! No one is suggesting a change; I just wanted to know if you guys listened to that speaker, that is all !! |
Kamal
erstellt: 25. Jul 2007, 07:04
Over to you, Sanjay- shall we visit Mr Xavian one of these days? |
bhagwan69
erstellt: 25. Jul 2007, 07:10
Basically Guys [K & S] my suggestion is very very simple, what ever you have is always there @ your dsposal. You can hear it on a daily basis. The only way to get a different point of view is to listen to some one else's set up. The more you do the wider your horizon will become. That is all I am suggesting. It is not about the XN 360. It is for any other set up. Try and get more persons into the fold. The Hobby will get to be more fun. That is all I am suggesting. Please do take what I suggest in the right spirit. !!! |
Kamal
erstellt: 25. Jul 2007, 07:18
I like this sentiment abt the spirit! What's yours? |
Kamal
erstellt: 25. Jul 2007, 07:29
Seriously, we do try to audition whatever we can. But the prob in Delhi is that I have yet to come across a Dealer who sets up eqpt in the proper way-mostly you have a line of stuff, with punjabi bhanra remixes turned up to top volume as the most peferred way of demoing, withsome one else demoing a TV in the same space--you get the idea. As far as home setups are concerned, you need an intro, which does not come by easily. And the Expos' have become pathetic! We'll definitely try for the Xavians.... |
bhagwan69
erstellt: 25. Jul 2007, 07:39
Sir, we are in the same boat ! Except for AVI - Burge Cooper - no one has a showroom or a demo area that is worth mentioning. The Dealers have the same line up in Mumbai too - La Kozy or Boomerang etc. The Dealers that know about audio, never have any gear to demo [Nova Audio]. Sushil is very much an audio guru. I have learnt a lot from him & respect him very much. Besides, the persons that buy audio - low fi or high fi do not have the chance to listen to different -serious / musical / accurate etc. set ups. Hence, their own set up is poor and below par, gong to listen to that is a waste of time ! But I still have hope, as time goes by, we meet more and more persons, maybe @ AV Shows. Not for audio demo but to find like minded persons. That makes us grow; So I am keeping the faith & the belief. |
Kamal
erstellt: 25. Jul 2007, 07:42
Amen! |
square_wave
erstellt: 25. Jul 2007, 10:12
I keep hearing a lot of good things about AVI. http://www.avihifi.co.uk/I hope you are referring to the same AVI. How would you describe their sound. |
Amp_Nut
erstellt: 25. Jul 2007, 10:56
Square Wave... The AVI being referred to in the post is the Indian AVI. http://www.audiovisionindia.com |
bhagwan69
#25
erstellt: 25. Jul 2007, 10:57
AudioVision India Pvt Ltd http://www.audiovisionindia.com/This is the D & D I was talking about. Dear Square Wave, You use this cable - Speaker Cable: Kimber Kable 4pr. It is sold in India by AVI. They have had that dealership for more than 1 decade, at least that is what I can remember. So where did you buy your cable from ? AVI has been selling Kinber for 15 + years. Ray Kimber comes to India ever year & is very close to the owners of AVI. Does AVI have any representation in Bangalore ? That I do not know. Does any forum member know ? Thanks. [Beitrag von bhagwan69 am 25. Jul 2007, 11:22 bearbeitet] |
deaf
#26
erstellt: 25. Jul 2007, 12:15
The angrezi AVI I sell in India. Regards Deaf. |
square_wave
#27
erstellt: 25. Jul 2007, 13:57
Hi Bhagwan, I picked up the 4pr long back from a friend of mine. They are VFM cables. Nothing really great. I keep trying out different cables in my system. Most are better than the 4pr. One cable that really Impressed me was the Gold reference cables by TMC cables. Very good low level detail retrieval and throws a massive soundstaging. They are quite unwieldy though. http://www.the-music-cable.com/speakercab.asp |
square_wave
#28
erstellt: 25. Jul 2007, 13:58
Oh great. They have an Indian presence now. How are the amps Deaf ? They seem to be getting very good press. |
bhagwan69
#29
erstellt: 25. Jul 2007, 14:13
Hey S.W. That cable looks interesting ? A demo / audition possible ? I would like to borrow the entire set & do an A/B in my set up; Possible ? I can give replacement Cables to you instead. Either from Germany or from Hungary. I have 2 sets in spare. Do let me know if it is possible. Thanks, http://www.the-music-cable.com/blnlab.asp |
square_wave
#30
erstellt: 25. Jul 2007, 15:00
It belonged to a friend of mine. The cables were quite long for my use. So I have returned it. It has been picked up by a friend of his. Because they are quite unwieldy, the cables need to be exact size. Let me check with him, if they can be send for an audition. Will keep you posted. |
Argento speaker cable for sale SWITCH-IT-ON am 31.08.2010 – Letzte Antwort am 31.08.2010 – 3 Beiträge |
MS-301 - New Condition for Sale sivat am 14.06.2008 – Letzte Antwort am 17.06.2008 – 2 Beiträge |
Audio Cables for sale msb1 am 28.09.2007 – Letzte Antwort am 29.09.2007 – 3 Beiträge |
For Sale: Diapason Adamantes LE Prithvi am 23.06.2007 – Letzte Antwort am 25.06.2007 – 3 Beiträge |
Many items for sale Prithvi am 16.04.2007 – Letzte Antwort am 19.11.2007 – 5 Beiträge |
Clearance Sale 3 - Hi-end Speaker sivat am 13.08.2009 – Letzte Antwort am 18.08.2009 – 2 Beiträge |
Epos M12.2 for Sale bharathana am 30.03.2010 – Letzte Antwort am 05.04.2010 – 7 Beiträge |
Legacy Audio Focus speaker for sale sacd77 am 23.11.2006 – Letzte Antwort am 29.01.2007 – 7 Beiträge |
Speaker: JMR Twin iii ..for sale Arj am 01.03.2008 – Letzte Antwort am 05.03.2008 – 12 Beiträge |
BOSE Acoustimass15 for SALE !! abhi.pani am 22.07.2005 – Letzte Antwort am 08.08.2005 – 4 Beiträge |
- Registrierte Mitglieder930.952 ( Heute: 1 )
- Neuestes MitgliedHardy6149
- Gesamtzahl an Themen1.564.253
- Gesamtzahl an Beiträgen21.848.325
[/URL]
