| HIFI-FORUM » Stereo » Elektronik » Verstärker/Receiver » Dämpfungsfaktor bei Digitalverstärkern (Onkyo A-97... | |
Dämpfungsfaktor bei Digitalverstärkern (Onkyo A-9755)+A -A |
mark07
erstellt: 02. Feb 2006, 12:13
Hallo zusammen, Ich habe vor mir den Onkyo A-9755 zu kaufen und war deshalb vor einer Woche beim Hifi-Händler und habe diesen an 2 Dynaudios Special 25 probegehört, die ich ebenfalls zu Hause habe und an einem Yamaha AX-592 betreibe. Auf Nachfrage hin, warum der Dämpfungsfaktor beim Onkyo nur mit 25 in den Spezifikationen angegeben ist, hat er mir angeboten bei Onkyo in Japan nachzufragen. Hier die Antwort aus Japan: ================================================================== Damping Factor at Digital Amplifier Dumping Factor is obtained by static measurement and has a lot to do with Negative Feedback (NFB). As the amount of Negative Feedback increases, the values in the specifications, such as static distortion and Frequency Response, but it is not all-arounder. It could affect the sound quality because it delays transient response which affects dynamic characteristics. For example, NFB does not work in the rising edge, and in such range, circuit characteristics are directly reflected on the sound. Therefore, you could face a case where a product with excellent static characteristics does not have enough driving power in actual playback. As you know, we have an amplifier design policy “WRAT” where we seek better open-look characteristics without depending on NFB. We usually design amplifiers so as to have less negative feedback to minimize dynamic distortion. Specially, NFB in A-9755 is less than 20dB and that in our analogue amplifiers have around 30dB. On the contrary, other manufactures usually give much more NFB to get ideal values in the specifications. That is why the value of Dumping Factor of our digital amplifiers is relatively low. We believe that HICC (High Instantaneous Current Capability) has more direct impact on the sound quality. You could see the speaker driving power by this value. For your reference, here are the HICC values we got by our measurement. A-9755/977 = 100A A-1VL = 100A A927/929 = 40-50A Our AV Receivers = 40-50A PMA 2000 IV (DENON) = 40A RX-V2600 (YAMAHA) = 32A We hope this helps. Best regards, Nobuko Oshima =================================================================== Laut verschiedenen Forumsbeiträgen sollte der Dämpungsfaktor wegen der Basskontrolle doch möglichst hoch sein? Kann jemand die Aussagen von Onkyo genauer erklären (Bin Elektronik Laie)? Grüße Markus |
_axel_
erstellt: 02. Feb 2006, 12:23
Hallo. Wie war denn der Hörtest? Was interessiert Dich der DF-Wert? Gruß |
ukw
erstellt: 03. Feb 2006, 23:10
muss richtig heißen: open loop characteristics... guckst Du hier: weißt Du Bescheid. Digital Amp derzeit nur an aktiven Systemen im Bassbereich ratsam. |
frankneh
erstellt: 09. Mrz 2006, 11:34
Hallo, habe seit zwei Monaten einen Onkyo A-933, betreibt mühelos meine Canton Ergo SCL, hatte vorher einen Marantz 80 SE. Der Onkyo klingt wesentlich musikalischer, satte Bässe und saubere Höhen, höre viel Klassik aber auch mal Prince. Der Marantz klang nur im Class A Modus (20 Watt) ähnlich gut. frankneh |
cr
erstellt: 09. Mrz 2006, 11:37
Ein DF von 25 ist durchaus ausreichend. Bei Röhrenverstärkern liegt er oft weit darunter |
Onkyo A 9555 bzw. A 9755 Digitalverstärker firevsh2o am 05.01.2006 – Letzte Antwort am 18.01.2006 – 2 Beiträge |
Onkyo A-9755 Chrüter am 07.04.2006 – Letzte Antwort am 26.06.2008 – 12 Beiträge |
Onkyo A-9755 HILFEEEE collio1 am 14.04.2013 – Letzte Antwort am 14.04.2013 – 2 Beiträge |
Onkyo 9711 - 9755 - 9150 wolf-star am 20.04.2020 – Letzte Antwort am 24.04.2020 – 5 Beiträge |
Onky A 9755 - Erfahrungen? MerlinX am 15.03.2006 – Letzte Antwort am 17.03.2006 – 2 Beiträge |
Warum kein Balanceregler an Onkyo A-9755? treiberw am 18.01.2008 – Letzte Antwort am 21.01.2008 – 6 Beiträge |
Onkyo A-9755 und MC-System joerg.uhlenheuer am 30.12.2006 – Letzte Antwort am 30.12.2006 – 2 Beiträge |
Erfahrungen mit Onkyo A-1VL oder A-9755 saperion am 07.06.2007 – Letzte Antwort am 28.07.2007 – 6 Beiträge |
An die Onkyo A-9555/A-9755 Besitzer Roger66 am 22.06.2009 – Letzte Antwort am 27.12.2010 – 39 Beiträge |
Onkyo A-9555 / A-9755 Material der Knöpfe Elrond am 02.08.2009 – Letzte Antwort am 03.08.2009 – 3 Beiträge |
- Yamaha R-N1000A und R-N800A
- Loudness? ist das gut?
- PRE OUT – MAIN IN, wofür?
- Registrierte Mitglieder930.846 ( Heute: 2 )
- Neuestes MitgliedChrisH80
- Gesamtzahl an Themen1.563.928
- Gesamtzahl an Beiträgen21.839.347
