Kenwood KA 5002
Mägo_de_Oz
#1 erstellt: 02. Apr 2004, 22:35
Hi!
Hat jemand 'ne Ahnung, ob obiger Verstärker was taugt bzw. gar die technischen Daten parat?
Howdy
Michael-Otto
#2 erstellt: 03. Apr 2004, 06:43
Hallo Oz,
ein schönes, grundsolides Gerät, vielleicht haben an diesem die Accuphase Entwickler noch mitgearbeitet, denn nach dieser Serie haben sie Kensonic-Accuphase gegründet.
Hier die technischen Daten: Quelle Kenwood Prospekt ca.1970
SPECIFICATIONS Kenwood KA-5002
Total Power Output :
both channel 180 watts ± 1 dB at 4 ohms 140 watts = 1 dB at 8 ohms
Total Dynamic Power (IHF) :
both channel 150 watts at 4 ohms 120 watts at 8 ohms
Continuous Power Output :
each channel driven 60/60 watts at 4 ohms 50/50 watts at 8 ohms both channel driven 48/48 watts at 4 ohms
30/30 watts at 8 ohms
Harmonic Distortion :Less than 0.5% at rated output from 20 Hz to 20,000 Hz
Intermodulation Distortion : (60 Hz & 7,000 Hz, 4 :1 Less than 0.3% at rated output Less than 0.1% at -3dB rated output
Frequency Response :20 Hz to 50,000 Hz 11 dB
Sensitivity : Phono 1 2.5 mV
(for rated output Phono 2 0.06 mV, 2.5 mV (switchable)
at 8 ohms load) Mic. 2.5 mV
Aux. 1,2 200 mV
Tuner 200 mV
Tape play A200 mV
Tape play B200 mV
Main amp.input 1 V
Input Impedance :Phono 1(2.5 mV)30 k ohms,
(at 1,000 Hz) 50 k ohms (switchable)
Phono 2(0.06 mV)200 ohms
Phono 2 (2.5 mV) 50 k ohms
Mic. 50 k ohms
Aux. 1, 2 100 k ohms
Tape play A, B 100 k ohms
Main amp.input 50 k ohms
Signal to Noise Ratio :Phono 1 (2.5 mV)65 dB
(below rated output) Phono 2 (0.06 mV)45 dB
Phono 2 (2.5 mv 65 dB
Mic. 67 dB
Aux., tuner, tape play 77 dB Noise at minimum volume control 0.5 mV at 8 ohms or 0.0003 milliwatts
Damping Factor :90 at 16 ohms load
45 at 8 ohms load
Low Filter :
(for rumble)80 Hz cut-off, 12 dB per octave
High Filter :
(for scratch)7,000 Hz cut-off, 12 dB per octave
Bass Control :±10 dB at 100 Hz with 2 dB step switch
Treble Control :±10 dB at 10,000 Hz with 2 dB step switch
Input:Pair of phono 1, phono 2, Mic., Aux. 1-2, tape play A-B, 4 channel and main amp. inputs
Output :2 pairs of stereo speaker outputs (4 to 16 ohms), pre-amp. outputs, tape recording outputs A and B,
DIN standard tape rec./play connector A and B, switched and unswitched AC outlets and
4 channel output
Power Requirement :P:C 110-120 Vi220-240 V 50/60 Hz
Power Consumption :15 watts at no signal 200 watts at full power
AC outlets :3 switched, 1 unswitched
Dimension :16-15/16"(w), 5-5/32 -(H), 11-1/16-(D) 408 mm(W), 134 mm(H), 280 mm(D)
Weight :20 Ibs. (9.1 kg)
Any of the specifications given here may be changed er modified witl out notice.
Michael-Otto
Mägo_de_Oz
#3 erstellt: 03. Apr 2004, 09:11
Hi!
Vielen Dank für die Mühe!
JochenB
#4 erstellt: 03. Apr 2004, 14:33
Hi!
Stimme meinem Vorredner zu! Kann eigentlich nur ein grundsolides Gerät sein. Ich habe z. Zt. einen Kenwood KA-3750, Bj. 1977-78, in Gebrauch (und das fast täglich). Der ist nun damals nicht gerade das Flagschiff von Kenwood gewesen, aber ist klanglich nach meinem Geschmack einwandfrei und da ist noch nie was dran gewesen. Der macht echt noch richtig Power und Material ist das auch noch. Da ist noch kein einziges Computerbauteil drin, nur solide Elektronik. Allerdings die Regler muss man regelmässig reinigen, weil die sehr staubanfällig sind.
Dass die späteren Entwickler von Kensonic-Accuphase noch daran mitgebastelt haben siehst Du z.T. auch daran, dass hinten bei der Typenbezeichnung noch Trio-Kenwood steht und vor dem Schriftzug noch eine Art Blüte zu sehen ist.
Sind eigentlich zu empfehlen, die Verstärker dieser Ära.
Gruss
Jochen
Kenwood KA-5002 rauscht und knackst?!?
enies am 06.05.2004  –  Letzte Antwort am 06.05.2004  –  2 Beiträge
Kenwood KA-9150
bacherle am 29.01.2005  –  Letzte Antwort am 29.01.2005  –  2 Beiträge
Kenwood KA 1000 ?!?
hifibrötchen am 16.02.2006  –  Letzte Antwort am 11.09.2007  –  14 Beiträge
Daten von Kenwood KA 4020
Flash1 am 13.06.2006  –  Letzte Antwort am 02.12.2013  –  11 Beiträge
Kenwood KA-74 KA fragen
TrunxX am 27.02.2008  –  Letzte Antwort am 05.04.2008  –  30 Beiträge
Kenwood Ka-8150
jeremypope am 09.05.2008  –  Letzte Antwort am 13.05.2008  –  5 Beiträge
Infos zu KENWOOD KA-7150
nakidei am 15.06.2005  –  Letzte Antwort am 26.06.2005  –  12 Beiträge
Kenwood KA-50 Informationen
charlie09 am 05.05.2008  –  Letzte Antwort am 05.05.2008  –  3 Beiträge
Kenwood KA-880 D
doc_relax am 10.10.2009  –  Letzte Antwort am 13.10.2009  –  3 Beiträge
Kenwood KA-8100
tony_cross am 04.10.2004  –  Letzte Antwort am 27.11.2015  –  28 Beiträge
2004
  • Registrierte Mitglieder930.563 ( Heute: 15 )
  • Neuestes Mitgliedgoblin2k3
  • Gesamtzahl an Themen1.563.223
  • Gesamtzahl an Beiträgen21.819.505
