| HIFI-FORUM » Stereo » Hifi-Klassiker » Sansui Tuner TU 3900 | |
Sansui Tuner TU 3900+A -A |
tanksandrums
erstellt: 08. Jun 2004, 15:21
Aloha Musik- und Musikreproduktionsmaschinen-Verliebte! Hat jemand Infos zu obigem Tuner von Sansui? Status? Wert? Datenblätter? Bedienungsanleitung? Im Voraus vielen Dank und allersonnigste Grüße aus Wuppertal, Olaf
Michael-Otto
erstellt: 08. Jun 2004, 18:21
Hallo tanksanddrums, Hier ein paar Infos zu Deinem Tuner. Quelle Sansui Prospekt 1976/77 Original Sansui Tuner Technology To many, the ability to send music-even stereo and 4-channel music-through the air via radio beams still has the awesome and mysterious quality of magic about it. Few people aside from electronics engineers and radio specialists really understand how the phenomenon works, but we all enjoy it, nonetheless. And if the equipment used is truly first class, our enjoyment is increased a thousandfold. Sansui's widely acclaimed TU series of stereo FM/AM tuner components is engineered and built with extraordinary care to assure first-class performance in any situation. Reception and reproduction of FM stereo and AM broadcasts in even the most remote areas-or in the very heart of station-congested urban areas-is guaranteed by Sansui's original research and development of sensitive, selective and very stable tuner circuits in every TU we make The TU-3900, which matches the Sansui AU-4900/3900 amplifiers in looks, performance and price range, is by no means an exception to this tradition Designed for Functional Versatiiity One look and listen to the TU-3900 confirms that it's a first-class tuner in every way. Its easyto-read slanted tuning dial is FM linear (each 250Hz section is equidistant from the next) and its tun tuning meters are positioned for accurate use. Note the large tuning knob. smoothly counterbalanced with a flywheel Inside Note, too, the LED (Light-Emitting Diode) illuminators for pinpoint tuning and FM STEREO indication, and the pushbutton FM Muting and FM Antenna Attenuator switches. WhaYs more, the rear panel has facilities for Dolby FM and discrete 4-channel FM adaptor connections and more. IC-Paciced Circuitry with MOS FFTs The TU-3900 has an IC-packed FM frontend with a dual-gated MOS FET transistor and a newly-designed low-noise transistor amplifier for ideal FM reception. Its precision-finished 3-gang variable capacitor helps you tune in your tavonte FM station with minimum interference. And the two bi-resonator ceramic filters and monolithic IC limiter in the FM intermediate frequency (IF) stage mean clear and trouble-free FM reception for years. ICs for MPX Stereo and AM, Too Integrated circuits have also been applied to the MPX (multiplex) stereo FM demodulator section, FM IF section and AM section too. LEDs for the red-illuminated dial pointer and the FM STEREO indicator also mean longer, more reliable performance. And to assure the stable operation of all circuits, a constantvoltage power supply furnishes each with a steady and unchanging flow of power irrespective of fluctuations in AC line voltage. AM Reception Is Better Than Fver AM broadcasting has come a long way toward reducing noise and improving frequency response lately. Our AM section takes advantage of these improvements by incorporating a high-density monolithic IC, a bi-resonator Jaumann ceramic filter, a large, built-in AM bar antenna and other advanced features. Particular attention has been paid to the elimination of AM whine, whistle and boom and the reduction of adjacent-station Interference Accurate Twin Tuning Meters The problem of meters which can be fooled or over-saturated by false radio signals is one which Sansui has taken very definite steps to 'solve. And solved It wo have. The twin meters in the TU-3900 are as accurate and linear as any ever developed, while at the same time they are extremely easy to use. The one at the far left of the tuning dial is a signal-strength meter for tuning both FM and AM broadcasts lt is specially damped to indicate when you have selected the tuning position at which the incoming signal is at its maximum strength for clear reception The next is a center-of-channel meter for FM tuning. When its needle points exactly to the middle of its scale you know that your station is tuned to where noise is at a niiniinum aiiu siereu separauun is iaeai. FM Antenna Attenuator The FM Antenna Attenuator button on the TU-3900 is a feature you won't find on the average tuner in this price range. When the distance from your listening room to the transmitter is short, use this button to reduce the strength of too-strong signals to avoid overload distortion and to clarify FM sound. FM Muting As in most high-quality FM tuners the TU-3900 features a built-in FM Muting circuit to eliminate inter-station hiss noise while you tune from station to station. Unlike many tuners in this price range, however. the FM Muting circuit is switched on the front panel to allow you to disconnect it when you wish to tune in faint or distant stations which otherwise might be muted out Dolby FM and FM 4-Channe€ Features The use ot the Dolby System to reduce the noise-level in FM transmissions is gaining in popularity in parts of America and the rest of the world. Special Dolby FM adaptors are required to take advantage of this improvement, and the rear panel of the TU-3900 is especially equipped to accept them. Also on the rear panel is a DET OUT jack to which you may connect an adaptor for the reproduction of discrete 4-channel FM broadcasts when and If such broadcasts and adaptors become commercially available Additional Features The rear panel of the TU-3900 also features an extra AC convenience outlet so that you may for instance, connect and power a tape deck for tuner-to-deck recording. The built-in AM bar antenna is designed so that external AM antennas are not required in most cases. FM antenna connections are provided for the 300-ohm and 75-ohm (coaxial) type leads. TU-3900 FM SECTION TUNING RANGE 88 to 108MHz SENSITIVITY IHF 2,0 uV DIN,1.1 uV TOTAL HARMONIC DISTORTION MONO less than 0.3%, STEREOless than 0.4% SIGNAL TO NOISE RATIO better than 70dB SELECTIVITY better than 60dB CAPTURE RATIO less than 2.O dB IMAGE FREQUENCY REJECTION better than 55dB at 98MHz IF REJECTION better than 80d8 at 98M Hz SPURIOUS RESPONSE REJECTION better than 70dB at 98 MHz SPURIOUS RADIATION less than 34dB STEREO SEPARATION better than 40dB at 1.000 Hz FREQUENCYRESPONSE 30 - 15,00OHz ANTENNAINPUTIMPEDANCE 300 ohms balanced 75 ohms unbalanced FM ANTENNA ATTENUATOR -20dB AM SECTION TUNING RANGE 535 to 1.605kHz SENSITIVITY (Bar Antenna) 53dB/m at 1.OOOkHz SELECTIVITY better than 30dB at 1,OOOkHz IMAGE FREQUENCY REJECTION better than 80dB/ m at 1,OOOkHz IF REJECTIONbetterthan 80dB/m at 1,OOOkHz OUTPUT LEVEL OUTPUT775mV at FM 100% modulation, DOLBY250mV at FM 100% modulation GENERAL AC OUTLETunswitched Max. 150 watts SEMICONDUCTORS13 Transistors; 1 Zener Diode; 1 FET; 3 ICs; 2 LEDs, 6 Diodes POWER REQUIREMENTS POWER VOLTAGE 100, 120, 220, 240V 50/60Hz POWER CONSUMPTION RATED5 watts DIMENSIONS400mm (153/<")W 120mm 143,")H 240mm (9Y2")D WEIGHT5 Okg (11.0 Ibs) Not 6.3kg 113.91bs1 Packed Note: No AC outlet is provided with the models sold in Europe. Design and specifications subject to change without notice for improvements. Gruß Michael-Otto |
tanksandrums
erstellt: 09. Jun 2004, 15:49
Aloha Michael-Otto! Vielen lieben Dank! Gruß, Olaf |
Sansui Tuner TU-717 Satin am 08.08.2004 – Letzte Antwort am 13.11.2004 – 11 Beiträge |
Sansui TU 9900 baeriltis am 10.09.2008 – Letzte Antwort am 14.03.2009 – 11 Beiträge |
Sansui TU 9900 Wieschhoff Morgan am 25.10.2004 – Letzte Antwort am 12.08.2009 – 7 Beiträge |
Sansui TU-5900 vandeus am 17.04.2007 – Letzte Antwort am 20.04.2007 – 16 Beiträge |
Sansui TU 9900 Morgan am 05.09.2004 – Letzte Antwort am 06.09.2004 – 4 Beiträge |
Sansui TU-9900 b.k. am 08.11.2014 – Letzte Antwort am 09.11.2014 – 4 Beiträge |
Sansui TU 719 Herbsuser am 18.01.2008 – Letzte Antwort am 21.01.2008 – 3 Beiträge |
Sansui TU 7500 Morgan am 28.08.2004 – Letzte Antwort am 13.02.2012 – 4 Beiträge |
Bedienungsanleitung Sansui TU 9900 Morgan am 29.09.2004 – Letzte Antwort am 13.03.2009 – 13 Beiträge |
Sansui TU 5900 I.Rolfs am 23.12.2006 – Letzte Antwort am 24.12.2006 – 2 Beiträge |
2004
- JBL LX-155
- Sony WM-6DC wirklich gut?
- JBL LX-155
- Registrierte Mitglieder931.038 ( Heute: 4 )
- Neuestes Mitglied#Slowhand22#
- Gesamtzahl an Themen1.564.508
- Gesamtzahl an Beiträgen21.856.009
